Advance Information
MPC850EC/D
Rev. 0.2, 04/2002
MPC850 (Rev. A/B/C)
Communications Controller
Hardware Specifications
This document contains detailed information on power considerations, AC/DC electrical
characteristics, and AC timing specifications for revision A,B, and C of the MPC850.
This document contains the following topics:
Topic
Part I, “Overview”
Part II, “Features”
Part III, “Electrical and Thermal Characteristics”
Part IV, “Thermal Characteristics”
Part V, “Power Considerations”
Part VI, “Bus Signal Timing”
Part VII, “IEEE 1149.1 Electrical Specifications”
Part VIII, “CPM Electrical Characteristics”
Part IX, “Mechanical Data and Ordering Information”
Part X, “Document Revision History”
Page
1
3
7
8
9
10
37
39
61
67
Part I Overview
The MPC850 is a versatile, one-chip integrated microprocessor and peripheral combination
that can be used in a variety of controller applications, excelling particularly in
communications and networking products. The MPC850, which includes support for
Ethernet, is specifically designed for cost-sensitive, remote-access, and telecommunications
applications. It is provides functions similar to the MPC860, with system enhancements such
as universal serial bus (USB) support and a larger (8-Kbyte) dual-port RAM.
In addition to a high-performance embedded MPC8xx core, the MPC850 integrates system
functions, such as a versatile memory controller and a communications processor module
(CPM) that incorporates a specialized, independent RISC communications processor
(referred to as the CP). This separate processor off-loads peripheral tasks from the embedded
MPC8xx core.
The CPM of the MPC850 supports up to seven serial channels, as follows:
One or two serial communications controllers (SCCs). The SCCs support Ethernet,
ATM (MPC850SAR), HDLC and a number of other protocols, along with a
transparent mode of operation.
One USB channel
Two serial management controllers (SMCs)
One I2C port
One serial peripheral interface (SPI).
Table 1 shows the functionality supported by the members of the MPC850 family.
Table 1. MPC850 Functionality Matrix
Number of
SCCs
Supported
Ethernet
Support
ATM Support
USB Support
MPC850
1
Yes
Yes
1
MPC850DE
2
Yes
Yes
1
MPC850SAR
2
Yes
Yes
Yes
Yes
1
Part
Number of
Multi-channel
PCMCIA Slots
HDLC Support
Supported
Additional documentation may be provided for parts listed in Table 1.
2
MPC850 (Rev. A/B/C) Hardware Specifications
MOTOROLA
Part II Features
Figure 1 is a block diagram of the MPC850, showing its major components and the relationships among
those components:
2-Kbyte
I-Cache
Embedded
MPC8xx
Core
Instruction
Bus
System Interface Unit
Memory Controller
Instruction
MMU
Unified Bus
Bus Interface Unit
1-Kbyte
D-Cache
Load/Store
Bus
Baud Rate
Generators
Parallel I/O
Ports
UTOPIA
(850SAR)
Four
Timers
System Functions
Real-Time Clock
Data
MMU
Interrupt
Controller
PCMCIA Interface
Dual-Port
RAM
20 Virtual
Serial DMA
Channels
32-Bit RISC Communications
Processor (CP) and Program ROM
Communications
Processor
Module
and
2 Virtual
IDMA
Channels
Timer
Peripheral Bus
SCC2
TDMa
SCC3
SMC1
SMC2
USB
SPI
I2C
Time Slot Assigner
Non-Multiplexed Serial Interface
Figure 1. MPC850 Microprocessor Block Diagram
The following list summarizes the main features of the MPC850:
Embedded single-issue, 32-bit MPC8xx core (implementing the PowerPC architecture) with
thirty-two 32-bit general-purpose registers (GPRs)
— Performs branch folding and branch prediction with conditional prefetch, but without
conditional execution
MOTOROLA
3
— 2-Kbyte instruction cache and 1-Kbyte data cache (Harvard architecture)
– Caches are two-way, set-associative
– Physically addressed
– Cache blocks can be updated with a 4-word line burst
– Least-recently used (LRU) replacement algorithm
– Lockable one-line granularity
— Memory management units (MMUs) with 8-entry translation lookaside buffers (TLBs) and
fully-associative instruction and data TLBs
— MMUs support multiple page sizes of 4 Kbytes, 16 Kbytes, 256 Kbytes, 512 Kbytes, and
8 Mbytes; 16 virtual address spaces and eight protection groups
Advanced on-chip emulation debug mode
Data bus dynamic bus sizing for 8, 16, and 32-bit buses
— Supports traditional 68000 big-endian, traditional x86 little-endian and modified little-endian
memory systems
— Twenty-six external address lines
Completely static design (0–80 MHz operation)
System integration unit (SIU)
— Hardware bus monitor
— Spurious interrupt monitor
— Software watchdog
— Periodic interrupt timer
— Low-power stop mode
— Clock synthesizer
— Decrementer, time base, and real-time clock (RTC) from the PowerPC architecture
— Reset controller
— IEEE 1149.1 test access port (JTAG)
Memory controller (eight banks)
— Glueless interface to DRAM single in-line memory modules (SIMMs), synchronous DRAM
(SDRAM), static random-access memory (SRAM), electrically programmable read-only
memory (EPROM), flash EPROM, etc.
— Memory controller programmable to support most size and speed memory interfaces
— Boot chip-select available at reset (options for 8, 16, or 32-bit memory)
— Variable block sizes, 32 Kbytes to 256 Mbytes
— Selectable write protection
— On-chip bus arbiter supports one external bus master
— Special features for burst mode support
General-purpose timers
— Four 16-bit timers or two 32-bit timers
— Gate mode can enable/disable counting
4
MOTOROLA
— Interrupt can be masked on reference match and event capture
Interrupts
— Eight external interrupt request (IRQ) lines
— Twelve port pins with interrupt capability
— Fifteen internal interrupt sources
— Programmable priority among SCCs and USB
— Programmable highest-priority request
Single socket PCMCIA-ATA interface
— Master (socket) interface, release 2.1 compliant
— Single PCMCIA socket
— Supports eight memory or I/O windows
Communications processor module (CPM)
— 32-bit, Harvard architecture, scalar RISC communications processor (CP)
— Protocol-specific command sets (for example, GRACEFUL STOP TRANSMIT stops transmission
after the current frame is finished or immediately if no frame is being sent and CLOSE RXBD
closes the receive buffer descriptor)
— Supports continuous mode transmission and reception on all serial channels
— Up to 8 Kbytes of dual-port RAM
— Twenty serial DMA (SDMA) channels for the serial controllers, including eight for the four
USB endpoints
— Three parallel I/O registers with open-drain capability
Four independent baud-rate generators (BRGs)
— Can be connected to any SCC, SMC, or USB
— Allow changes during operation
— Autobaud support option
Two SCCs (serial communications controllers)
— Ethernet/IEEE 802.3, supporting full 10-Mbps operation
— HDLC/SDLC™ (all channels supported at 2 Mbps)
— HDLC bus (implements an HDLC-based local area network (LAN))
— Asynchronous HDLC to support PPP (point-to-point protocol)
— AppleTalk®
— Universal asynchronous receiver transmitter (UART)
— Synchronous UART
— Serial infrared (IrDA)
— Totally transparent (bit streams)
— Totally transparent (frame based with optional cyclic redundancy check (CRC))
QUICC multichannel controller (QMC) microcode features
— Up to 64 independent communication channels on a single SCC
— Arbitrary mapping of 0–31 channels to any of 0–31 TDM time slots
MOTOROLA
5
— Supports either transparent or HDLC protocols for each channel
— Independent TxBDs/Rx and event/interrupt reporting for each channel
One universal serial bus controller (USB)
— Supports host controller and slave modes at 1.5 Mbps and 12 Mbps
— UART
— Transparent
— General circuit interface (GCI) controller
— Can be connected to the time-division-multiplexed (TDM) channel
— Supports master and slave modes
— Supports multimaster operation on the same bus
One I2C® (interprocessor-integrated circuit) port
— Supports multimaster environment
Time slot assigner
— Allows SCCs and SMCs to run in multiplexed operation
— Supports T1, CEPT, PCM highway, ISDN basic rate, ISDN primary rate, user-defined
— 1- or 8-bit resolution
— Allows independent transmit and receive routing, frame syncs, clocking
— Allows dynamic changes
— Can be internally connected to four serial channels (two SCCs and two SMCs)
Low-power support
— Full high: all units fully powered at high clock frequency
— Full low: all units fully powered at low clock frequency
— Doze: core functional units disabled except time base, decrementer, PLL, memory controller,
real-time clock, and CPM in low-power standby
— Sleep: all units disabled except real-time clock and periodic interrupt timer. PLL is active for
fast wake-up
— Deep sleep: all units disabled including PLL, except the real-time clock and periodic interrupt
timer
— Low-power stop: to provide lower power dissipation
— Separate power supply input to operate internal logic at 2.2 V when operating at or below
25 MHz
— Can be dynamically shifted between high frequency (3.3 V internal) and low frequency (2.2 V
internal) operation
Debug interface
— Eight comparators: four operate on instruction address, two operate on data address, and two
operate on data
6
MOTOROLA
— The MPC850 can compare using the =, ≠, conditions to generate watchpoints
— Each watchpoint can generate a breakpoint internally
3.3-V operation with 5-V TTL compatibility on all general purpose I/O pins.
Part III Electrical and Thermal Characteristics
This section provides the AC and DC electrical specifications and thermal characteristics for the MPC850.
Table 2 provides the maximum ratings.
Table 2. Maximum Ratings
(GND = 0V)
Rating
Supply voltage
Input
voltage 1
Junction
temperature 2
Storage temperature range
Symbol
Value
Unit
VDDH
-0.3 to 4.0
V
VDDL
-0.3 to 4.0
V
KAPWR
-0.3 to 4.0
V
VDDSYN
-0.3 to 4.0
V
Vin
GND-0.3 to VDDH + 2.5 V
V
Tj
0 to 95 (standard)
-40 to 95 (extended)
˚C
Tstg
-55 to +150
˚C
1
Functional operating conditions are provided with the DC electrical specifications in Table 5. Absolute maximum
ratings are stress ratings only; functional operation at the maxima is not guaranteed. Stress beyond those listed may
affect device reliability or cause permanent damage to the device.
CAUTION: All inputs that tolerate 5 V cannot be more than 2.5 V greater than the supply voltage. This restriction
applies to power-up and normal operation (that is, if the MPC850 is unpowered, voltage greater than 2.5 V must not
be applied to its inputs).
2 The MPC850, a high-frequency device in a BGA package, does not provide a guaranteed maximum ambient
temperature. Only maximum junction temperature is guaranteed. It is the responsibility of the user to consider
power dissipation and thermal management. Junction temperature ratings are the same regardless of frequency
rating of the device.
This device contains circuitry protecting against damage due to high-static voltage or electrical fields;
however, it is advised that normal precautions be taken to avoid application of any voltages higher than
maximum-rated voltages to this high-impedance circuit. Reliability of operation is enhanced if unused
inputs are tied to an appropriate logic voltage level (for example, either GND or VCC). Table 3 provides the
package thermal characteristics for the MPC850.
MOTOROLA
7
Part IV Thermal Characteristics
Table 3 shows the thermal characteristics for the MPC850.
Table 3. Thermal Characteristics
Characteristic
Thermal resistance for
BGA 1
Thermal Resistance for BGA (junction-to-case)
Symbol
Value
Unit
θJA
40 2
°C/W
θJA
31 3
°C/W
θJA
24 4
°C/W
θJC
8
°C/W
1
For more information on the design of thermal vias on multilayer boards and BGA layout considerations in
general, refer to AN-1231/D, Plastic Ball Grid Array Application Note available from your local Motorola sales
office.
2 Assumes natural convection and a single layer board (no thermal vias).
3 Assumes natural convection, a multilayer board with thermal vias4, 1 watt MPC850 dissipation, and a board
temperature rise of 20°C above ambient.
4 Assumes natural convection, a multilayer board with thermal vias4, 1 watt MPC850 dissipation, and a board
temperature rise of 13°C above ambient.
TJ = TA + (PD •θJA)
PD = (VDD • IDD) + PI/O
where:
PI/O is the power dissipation on pins
Table 4 provides power dissipation information.
Table 4. Power Dissipation (PD)
Characteristic
Power Dissipation
All Revisions
(1:1) Mode
1
2
Frequency (MHz)
Typical 1
Maximum 2
Unit
33
TBD
515
mW
40
TBD
590
mW
50
TBD
725
mW
Typical power dissipation is measured at 3.3V
Maximum power dissipation is measured at 3.65 V
Table 5 provides the DC electrical characteristics for the MPC850.
Table 5. DC Electrical Specifications
Characteristic
Symbol
Min
Max
Unit
Operating voltage at 40 MHz or less
VDDH, VDDL,
KAPWR, VDDSYN
3.0
3.6
V
Operating voltage at 40 MHz or higher
VDDH, VDDL,
KAPWR, VDDSYN
3.135
3.465
V
Input high voltage (address bus, data bus, EXTAL, EXTCLK,
and all bus control/status signals)
VIH
2.0
3.6
V
Input high voltage (all general purpose I/O and peripheral pins)
VIH
2.0
5.5
V
8
MOTOROLA
Table 5. DC Electrical Specifications (continued)
Characteristic
Symbol
Min
Max
Unit
VIL
GND
0.8
V
VIHC
0.7*(VCC)
VCC+0.3
V
Input leakage current, Vin = 5.5 V (Except TMS, TRST, DSCK
and DSDI pins)
Iin
100
µA
Input leakage current, Vin = 3.6V (Except TMS, TRST, DSCK
and DSDI pins)
IIn
10
µA
Input leakage current, Vin = 0V (Except TMS, TRST, DSCK and
DSDI pins)
IIn
10
µA
Input capacitance
Cin
pF
Output high voltage, IOH = -2.0 mA, VDDH = 3.0V
except XTAL, XFC, and open-drain pins
VOH
2.4
V
Output low voltage
IOL = 2.0 mA CLKOUT
IOL = 3.2 mA 1
IOL = 5.3 mA 2
IOL = 7.0 mA PA[14]/USBOE, PA[12]/TXD2
IOL = 8.9 mA TS, TA, TEA, BI, BB, HRESET, SRESET
VOL
0.5
V
Input low voltage
EXTAL, EXTCLK input high voltage
1
A[6:31], TSIZ0/REG, TSIZ1, D[0:31], DP[0:3]/IRQ[3:6], RD/WR, BURST, RSV/IRQ2, IP_B[0:1]/IWP[0:1]/VFLS[0:1],
IP_B2/IOIS16_B/AT2, IP_B3/IWP2/VF2, IP_B4/LWP0/VF0, IP_B5/LWP1/VF1, IP_B6/DSDI/AT0, IP_B7/PTR/AT3,
PA[15]/USBRXD, PA[13]/RXD2, PA[9]/L1TXDA/SMRXD2, PA[8]/L1RXDA/SMTXD2,
PA[7]/CLK1/TIN1/L1RCLKA/BRGO1, PA[6]/CLK2/TOUT1/TIN3, PA[5]/CLK3/TIN2/L1TCLKA/BRGO2,
PA[4]/CLK4/TOUT2/TIN4, PB[31]/SPISEL, PB[30]/SPICLK/TXD3, PB[29]/SPIMOSI /RXD3,
PB[28]/SPIMISO/BRGO3, PB[27]/I2CSDA/BRGO1, PB[26]/I2CSCL/BRGO2, PB[25]/SMTXD1/TXD3,
PB[24]/SMRXD1/RXD3, PB[23]/SMSYN1/SDACK1, PB[22]/SMSYN2/SDACK2, PB[19]/L1ST1,
PB[18]/RTS2/L1ST2, PB[17]/L1ST3, PB[16]/L1RQa/L1ST4, PC[15]/DREQ0/L1ST5, PC[14]/DREQ1/RTS2/L1ST6,
PC[13]/L1ST7/RTS3, PC[12]/L1RQa/L1ST8, PC[11]/USBRXP, PC[10]/TGATE1/USBRXN, PC[9]/CTS2,
PC[8]/CD2/TGATE1, PC[7]/USBTXP, PC[6]/USBTXN, PC[5]/CTS3/L1TSYNCA/SDACK1, PC[4]/CD3/L1RSYNCA,
PD[15], PD[14], PD[13], PD[12], PD[11], PD[10], PD[9], PD[8], PD[7], PD[6], PD[5], PD[4], PD[3]
2
BDIP/GPL_B5, BR, BG, FRZ/IRQ6, CS[0:5], CS6/CE1_B, CS7/CE2_B, WE0/BS_AB0/IORD, WE1/BS_AB1/IOWR,
WE2/BS_AB2/PCOE, WE3/BS_AB3/PCWE, GPL_A0/GPL_B0, OE/GPL_A1/GPL_B1,
GPL_A[2:3]/GPL_B[2:3]/CS[2:3], UPWAITA/GPL_A4/AS, UPWAITB/GPL_B4, GPL_A5, ALE_B/DSCK/AT1,
OP2/MODCK1/STS, OP3/MODCK2/DSDO
Part V Power Considerations
The average chip-junction temperature, TJ, in °C can be obtained from the equation:
TJ = TA + (PD • θJA)
(1)
where
TA
= Ambient temperature, °C
θJA = Package thermal resistance, junction to ambient, °C/W
PD
= PINT + PI/O
PINT = IDD x VDD, watts—chip internal power
PI/O = Power dissipation on input and output pins—user determined
MOTOROLA
9
Layout Practices
For most applications PI/O < 0.3 • PINT and can be neglected. If PI/O is neglected, an approximate relationship
between PD and TJ is:
PD = K ÷ (TJ + 273°C)
(2)
Solving equations (1) and (2) for K gives:
K = PD • (TA + 273°C) + θJA • PD
2
(3)
where K is a constant pertaining to the particular part. K can be determined from equation (3) by measuring
PD (at equilibrium) for a known TA. Using this value of K, the values of PD and TJ can be obtained by solving
equations (1) and (2) iteratively for any value of TA.
5.1
Layout Practices
Each VCC pin on the MPC850 should be provided with a low-impedance path to the board’s supply. Each
GND pin should likewise be provided with a low-impedance path to ground. The power supply pins drive
distinct groups of logic on chip. The VCC power supply should be bypassed to ground using at least four 0.1
µF by-pass capacitors located as close as possible to the four sides of the package. The capacitor leads and
associated printed circuit traces connecting to chip VCC and GND should be kept to less than half an inch
per capacitor lead. A four-layer board is recommended, employing two inner layers as VCC and GND planes.
All output pins on the MPC850 have fast rise and fall times. Printed circuit (PC) trace interconnection length
should be minimized in order to minimize undershoot and reflections caused by these fast output switching
times. This recommendation particularly applies to the address and data busses. Maximum PC trace lengths
of six inches are recommended. Capacitance calculations should consider all device loads as well as
parasitic capacitances due to the PC traces. Attention to proper PCB layout and bypassing becomes
especially critical in systems with higher capacitive loads because these loads create higher transient
currents in the VCC and GND circuits. Pull up all unused inputs or signals that will be inputs during reset.
Special care should be taken to minimize the noise levels on the PLL supply pins.
Part VI Bus Signal Timing
Table 6 provides the bus operation timing for the MPC850 at 50 MHz, 66 MHz, and 80 MHz. Timing
information for other bus speeds can be interpolated by equation using the MPC850 Electrical
Specifications Spreadsheet found at http://www.mot.com/netcomm.
The maximum bus speed supported by the MPC850 is 50 MHz. Higher-speed parts must be operated in
half-speed bus mode (for example, an MPC850 used at 66 MHz must be configured for a 33 MHz bus).
The timing for the MPC850 bus shown assumes a 50-pF load. This timing can be derated by 1 ns per 10 pF.
Derating calculations can also be performed using the MPC850 Electrical Specifications Spreadsheet.
10
MOTOROLA
Layout Practices
Table 6. Bus Operation Timing
50 MHz
Num
66 MHz
1
80 MHz
Characteristic
FFACT
Cap Load
(default
50 pF)
Unit
Min
Max
Min
Max
Min
Max
25
ns
B1
CLKOUT period
B1a
EXTCLK to CLKOUT phase
skew (EXTCLK > 15 MHz and
MF 10 MHz and
MF < 10)
-2.30
2.30
-2.30
2.30
-2.30
2.30
50.00
ns
B1c
CLKOUT phase jitter (EXTCLK > -0.60
15 MHz and MF
500) 2
3.00
3.00
3.00
50.00
B1h
Frequency jitter on EXTCLK 3
0.50
0.50
0.50
50.00
B2
CLKOUT pulse width low
8.00
12.12
10.00
50.00
ns
B3
CLKOUT width high
8.00
12.12
10.00
50.00
ns
B4
CLKOUT rise time
4.00
4.00
4.00
50.00
ns
B5
CLKOUT fall time
4.00
4.00
4.00
50.00
ns
B7
CLKOUT to A[6–31],
RD/WR, BURST, D[0–31],
DP[0–3] invalid
5.00
7.58
6.25
0.250
50.00
ns
B7a
CLKOUT to TSIZ[0–1], REG,
RSV, AT[0–3], BDIP, PTR invalid
5.00
7.58
6.25
0.250
50.00
ns
B7b
CLKOUT to BR, BG, FRZ,
VFLS[0–1], VF[0–2] IWP[0–2],
LWP[0–1], STS invalid 4
5.00
7.58
6.25
0.250
50.00
ns
B8
CLKOUT to A[6–31],
DP[0–3] valid
5.00
11.75
7.58
14.33
6.25
13.00
0.250
50.00
ns
B8a
RSV, AT[0–3] BDIP, PTR valid
5.00
11.75
7.58
14.33
6.25
13.00
0.250
50.00
ns
B8b
CLKOUT to BR, BG, VFLS[0–1],
VF[0–2], IWP[0–2], FRZ,
LWP[0–1], STS valid 4
5.00
11.74
7.58
14.33
6.25
13.00
0.250
50.00
ns
B9
CLKOUT to A[6–31] RD/WR,
BURST, D[0–31], DP[0–3],
TSIZ[0–1], REG, RSV, AT[0–3],
PTR high-Z
5.00
11.75
7.58
14.33
6.25
13.00
0.250
50.00
ns
MOTOROLA
11
Layout Practices
50 MHz
Num
1
66 MHz
(continued)
80 MHz
Characteristic
FFACT
Cap Load
(default
50 pF)
Unit
Min
Max
Min
Max
Min
Max
5.00
11.00
7.58
13.58
6.25
12.25
0.250
50.00
ns
B11a CLKOUT to TA, BI assertion,
(When driven by the memory
controller or PCMCIA interface)
2.50
9.25
2.50
9.25
2.50
9.25
50.00
ns
B12
5.00
11.75
7.58
14.33
6.25
13.00
0.250
50.00
ns
B12a CLKOUT to TA, BI negation
(when driven by the memory
2.50
11.00
2.50
11.00
2.50
11.00
50.00
ns
B13
5.00
19.00
7.58
21.58
6.25
20.25
0.250
50.00
ns
B13a CLKOUT to TA, BI high-Z, (when
driven by the memory controller
2.50
15.00
2.50
15.00
2.50
15.00
50.00
ns
B14
CLKOUT to TEA assertion
2.50
10.00
2.50
10.00
2.50
10.00
50.00
ns
B15
CLKOUT to TEA high-Z
2.50
15.00
2.50
15.00
2.50
15.00
50.00
ns
B16
TA, BI valid to CLKOUT(setup
time) 5
9.75
9.75
9.75
50.00
ns
B16a TEA, KR, RETRY, valid to
CLKOUT (setup time) 5
10.00
10.00
10.00
50.00
ns
B16b BB, BG, BR valid to CLKOUT
(setup time) 6
8.50
8.50
8.50
50.00
ns
B17
CLKOUT to TA, TEA, BI, BB, BG,
BR valid (Hold time).5
1.00
1.00
1.00
50.00
ns
B17a CLKOUT to KR, RETRY, except
TEA valid (hold time)
2.00
2.00
2.00
50.00
ns
B18
D[0–31], DP[0–3] valid to
CLKOUT rising edge (setup
time) 7
6.00
6.00
6.00
50.00
ns
B19
CLKOUT rising edge to D[0–31],
DP[0–3] valid (hold time) 7
1.00
1.00
1.00
50.00
ns
B20
CLKOUT falling edge (setup
time) 8
4.00
4.00
4.00
50.00
ns
B21
CLKOUT falling edge to D[0–31],
DP[0–3] valid (hold time) 8
2.00
2.00
2.00
B22
CLKOUT rising edge to CS
asserted GPCM ACS = 00
5.00
11.75
7.58
14.33
6.25
13.00
0.250
50.00
ns
B22a CLKOUT falling edge to CS
asserted GPCM ACS = 10, TRLX
= 0,1
8.00
8.00
8.00
50.00
ns
B22b CLKOUT falling edge to CS
asserted GPCM ACS = 11, TRLX
= 0, EBDF = 0
5.00
11.75
7.58
14.33
6.25
13.00
0.250
50.00
ns
B11
12
CLKOUT to TS, BB assertion
CLKOUT to TS, BB negation
CLKOUT to TS, BB high-Z
MOTOROLA
Layout Practices
50 MHz
Num
1
66 MHz
(continued)
80 MHz
Characteristic
Min
FFACT
Cap Load
(default
50 pF)
Unit
Min
Max
Max
Min
Max
B22c CLKOUT falling edge to CS
= 0, EBDF = 1
7.00
14.00 11.00 18.00
9.00
16.00
0.375
50.00
ns
B23
negated GPCM read access,
GPCM write access ACS = 00,
TRLX = 0 & CSNT = 0
2.00
8.00
2.00
8.00
2.00
8.00
50.00
ns
B24
A[6–31] to CS asserted GPCM
ACS = 10, TRLX = 0.
3.00
6.00
4.00
0.250
50.00
ns
B24a A[6–31] to CS asserted GPCM
ACS = 11, TRLX = 0
8.00
13.00
11.00
0.500
50.00
ns
B25
CLKOUT rising edge to OE,
WE[0–3] asserted
9.00
9.00
9.00
50.00
ns
B26
negated
2.00
9.00
2.00
9.00
2.00
9.00
50.00
ns
B27
ACS = 10, TRLX = 1
23.00
36.00
29.00
1.250
50.00
ns
B27a A[6–31] to CS asserted GPCM
ACS = 11, TRLX = 1
28.00
43.00
36.00
1.500
50.00
ns
9.00
9.00
9.00
50.00
ns
12.00
8.00
14.00
6.00
13.00
0.250
50.00
ns
12.00
14.00
13.00
0.250
50.00
ns
9.00
16.00
0.375
50.00
ns
B28
CLKOUT rising edge to WE[0–3]
negated GPCM write access
CSNT = 0
B28a CLKOUT falling edge to WE[0–3] 5.00
TRLX = 0,1 CSNT = 1, EBDF = 0
B28b CLKOUT falling edge to CS
TRLX = 0,1 CSNT = 1, ACS = 10
or ACS = 11, EBDF = 0
B28c CLKOUT falling edge to WE[0–3]
TRLX = 0,1 CSNT = 1 write
access TRLX = 0, CSNT = 1,
EBDF = 1
7.00
B28d CLKOUT falling edge to CS
or ACS = 11, EBDF = 1
14.00
18.00
16.00
0.375
50.00
ns
WE[0–3] negated to D[0–31],
DP[0–3] high-Z GPCM write
access, CSNT = 0
3.00
6.00
4.00
0.250
50.00
ns
B29a WE[0–3] negated to D[0–31],
access, TRLX = 0 CSNT = 1,
EBDF = 0
8.00
13.00
11.00
0.500
50.00
ns
B29
MOTOROLA
14.00 11.00 18.00
13
Layout Practices
50 MHz
Num
1
66 MHz
(continued)
80 MHz
Characteristic
FFACT
Cap Load
(default
50 pF)
Unit
Min
Max
Min
Max
Min
Max
B29b CS negated to D[0–31], DP[0–3],
high-Z GPCM write access, ACS
= 00, TRLX = 0 & CSNT = 0
3.00
6.00
4.00
0.250
50.00
ns
B29c CS negated to D[0–31], DP[0–3]
TRLX = 0, CSNT = 1, ACS = 10
8.00
13.00
11.00
0.500
50.00
ns
B29d WE[0–3] negated to D[0–31],
access, TRLX = 1, CSNT = 1,
EBDF = 0
28.00
43.00
36.00
1.500
50.00
ns
B29e CS negated to D[0–31], DP[0–3] 28.00
TRLX = 1, CSNT = 1, ACS = 10
43.00
36.00
1.500
50.00
ns
5.00
9.00
7.00
0.375
50.00
ns
B29g CS negated to D[0–31], DP[0–3]
high-Z GPCM write access TRLX
= 0, CSNT = 1, ACS = 10 or ACS
= 11, EBDF = 1
5.00
9.00
7.00
0.375
50.00
ns
B29h WE[0–3] negated to D[0–31],
EBDF = 1
25.00
39.00
31.00
1.375
50.00
ns
B29i
CS negated to D[0–31], DP[0–3] 25.00
39.00
31.00
1.375
50.00
ns
B30
CS, WE[0–3] negated to A[6–31]
invalid
GPCM write access 9
3.00
6.00
4.00
0.250
50.00
ns
8.00
B30a WE[0–3] negated to A[6–31]
invalid
GPCM write access, TRLX = 0,
CSNT = 1, CS negated to
A[6–31] invalid GPCM write
access TRLX = 0, CSNT =1,
ACS = 10 or ACS = 11, EBDF = 0
13.00
11.00
0.500
50.00
ns
B29f
14
EBDF = 1
MOTOROLA
Layout Practices
50 MHz
Num
1
66 MHz
(continued)
80 MHz
Characteristic
Min
FFACT
Cap Load
(default
50 pF)
Unit
Max
Min
Max
Min
Max
28.00
B30b WE[0–3] negated to A[6–31]
invalid
GPCM write access, TRLX = 1,
CSNT = 1. CS negated to
A[6–31] Invalid GPCM write
access TRLX = 1, CSNT = 1,
43.00
36.00
1.500
50.00
ns
B30c WE[0–3] negated to A[6–31]
invalid
access, TRLX = 0, CSNT = 1,
ACS = 10 or ACS = 11, EBDF = 1
5.00
8.00
6.00
0.375
50.00
ns
B30d WE[0–3] negated to A[6–31]
25.00
invalid GPCM write access TRLX
= 1, CSNT =1, CS negated to
39.00
31.00
1.375
50.00
ns
CLKOUT falling edge to CS valid
- as requested by control bit
CST4 in the corresponding word
in the UPM
1.50
6.00
1.50
6.00
1.50
6.00
50.00
ns
B31a CLKOUT falling edge to CS valid
CST1 in the corresponding word
in the UPM
5.00
12.00
8.00
14.00
6.00
13.00
0.250
50.00
ns
B31b CLKOUT rising edge to CS valid
CST2 in the corresponding word
in the UPM
1.50
8.00
1.50
8.00
1.50
8.00
50.00
ns
B31c CLKOUT rising edge to CS valid
CST3 in the corresponding word
in the UPM
5.00
12.00
8.00
14.00
6.00
13.00
0.250
50.00
ns
B31d CLKOUT falling edge to CS valid
in the UPM EBDF = 1
9.00
14.00 13.00 18.00 11.00 16.00
0.375
50.00
ns
B32
CLKOUT falling edge to BS valid
BST4 in the corresponding word
in the UPM
1.50
6.00
1.50
6.00
1.50
6.00
50.00
ns
B32a CLKOUT falling edge to BS valid
BST1 in the corresponding word
in the UPM, EBDF = 0
5.00
12.00
8.00
14.00
6.00
13.00
0.250
50.00
ns
B31
MOTOROLA
15
Layout Practices
50 MHz
Num
1
66 MHz
(continued)
80 MHz
Characteristic
FFACT
Cap Load
(default
50 pF)
Unit
Min
Max
Min
Max
Min
Max
B32b CLKOUT rising edge to BS valid
BST2 in the corresponding word
in the UPM
1.50
8.00
1.50
8.00
1.50
8.00
50.00
ns
B32c CLKOUT rising edge to BS valid
BST3 in the corresponding word
in the UPM
5.00
12.00
8.00
14.00
6.00
13.00
0.250
50.00
ns
B32d CLKOUT falling edge to BS valid
in the UPM, EBDF = 1
9.00
0.375
50.00
ns
B33
CLKOUT falling edge to GPL
valid - as requested by control bit
GxT4 in the corresponding word
in the UPM
1.50
6.00
1.50
6.00
1.50
6.00
50.00
ns
B33a CLKOUT rising edge to GPL
GxT3 in the corresponding word
in the UPM
5.00
12.00
8.00
14.00
6.00
13.00
0.250
50.00
ns
B34
A[6–31] and D[0–31] to CS valid
in the UPM
3.00
6.00
4.00
0.250
50.00
ns
B34a A[6–31] and D[0–31] to CS valid
in the UPM
8.00
13.00
11.00
0.500
50.00
ns
B34b A[6–31] and D[0–31] to CS valid 13.00
- as requested by CST2 in the
corresponding word in UPM
21.00
17.00
0.750
50.00
ns
B35
A[6–31] to CS valid - as
requested by control bit BST4 in
the corresponding word in UPM
3.00
6.00
4.00
0.250
50.00
ns
B35a A[6–31] and D[0–31] to BS valid
- as requested by BST1 in the
corresponding word in the UPM
8.00
13.00
11.00
0.500
50.00
ns
B35b A[6–31] and D[0–31] to BS valid 13.00
in the UPM
21.00
17.00
0.750
50.00
ns
3.00
6.00
4.00
0.250
50.00
ns
B36
16
A[6–31] and D[0–31] to GPL
in the UPM
MOTOROLA
Layout Practices
50 MHz
Num
1
66 MHz
(continued)
80 MHz
Characteristic
Min
Max
Min
Max
Min
Max
FFACT
Cap Load
(default
50 pF)
Unit
B37
UPWAIT valid to CLKOUT falling
edge 10
6.00
6.00
6.00
50.00
ns
B38
CLKOUT falling edge to UPWAIT
valid 10
1.00
1.00
1.00
50.00
ns
B39
AS valid to CLKOUT rising edge
7.00
7.00
7.00
50.00
ns
11
B40
A[6–31], TSIZ[0–1], RD/WR,
BURST, valid to CLKOUT rising
edge.
7.00
7.00
7.00
50.00
ns
B41
TS valid to CLKOUT rising edge
(setup time)
7.00
7.00
7.00
50.00
ns
B42
CLKOUT rising edge to TS valid
(hold time)
2.00
2.00
2.00
50.00
ns
B43
AS negation to memory
controller signals negation
TBD
TBD
TBD
50.00
ns
1
The minima provided assume a 0 pF load, whereas maxima assume a 50pF load. For frequencies not marked on the
part, new bus timing must be calculated for all frequency-dependent AC parameters. Frequency-dependent AC
parameters are those with an entry in the FFactor column. AC parameters without an FFactor entry do not need to be
calculated and can be taken directly from the frequency column corresponding to the frequency marked on the part.
The following equations should be used in these calculations.
For a frequency F, the following equations should be applied to each one of the above parameters:
For minima:
FFACTOR x 1000 (D50 - 20 x FFACTOR)
D=
F
For maxima:
FFACTOR x 1000 (D50 -20 x FFACTOR) 1ns(CAP LOAD - 50) / 10
D=
F
where:
D is the parameter value to the frequency required in ns
F is the operation frequency in MHz
D50 is the parameter value defined for 50 MHz
CAP LOAD is the capacitance load on the signal in question.
FFACTOR is the one defined for each of the parameters in the table.
2 Phase and frequency jitter performance results are valid only if the input jitter is less than the prescribed value.
3 If the rate of change of the frequency of EXTAL is slow (i.e. it does not jump between the minimum and maximum
values in one cycle) or the frequency of the jitter is fast (i.e., it does not stay at an extreme value for a long time) then
the maximum allowed jitter on EXTAL can be up to 2%.
4 The timing for BR output is relevant when the MPC850 is selected to work with external bus arbiter. The timing for BG
output is relevant when the MPC850 is selected to work with internal bus arbiter.
5 The setup times required for TA, TEA, and BI are relevant only when they are supplied by an external device (and not
when the memory controller or the PCMCIA interface drives them).
6 The timing required for BR input is relevant when the MPC850 is selected to work with the internal bus arbiter. The
timing for BG input is relevant when the MPC850 is selected to work with the external bus arbiter.
7 The D[0–31] and DP[0–3] input timings B20 and B21 refer to the rising edge of the CLKOUT in which the TA input
signal is asserted.
MOTOROLA
17
Layout Practices
8
The D[0:31] and DP[0:3] input timings B20 and B21 refer to the falling edge of CLKOUT. This timing is valid only for
read accesses controlled by chip-selects controlled by the UPM in the memory controller, for data beats where DLT3
= 1 in the UPM RAM words. (This is only the case where data is latched on the falling edge of CLKOUT.
9 The timing B30 refers to CS when ACS = '00' and to WE[0:3] when CSNT = '0'.
10 The signal UPWAIT is considered asynchronous to CLKOUT and synchronized internally. The timings specified in
B37 and B38 are specified to enable the freeze of the UPM output signals.
11 The AS signal is considered asynchronous to CLKOUT.
Figure 2 is the control timing diagram.
2.0 V
CLKOUT
2.0 V
0.8 V
0.8 V
A
B
2.0 V
0.8 V
Outputs
2.0 V
0.8 V
A
B
2.0 V
0.8 V
Outputs
2.0 V
0.8 V
D
C
2.0 V
0.8 V
Inputs
2.0 V
0.8 V
D
C
2.0 V
0.8 V
Inputs
A
Maximum output delay specification
B
Minimum output hold time
C
Minimum input setup time specification
D
Minimum input hold time specification
2.0 V
0.8 V
Figure 2. Control Timing
18
MOTOROLA
Layout Practices
Figure 3 provides the timing for the external clock.
CLKOUT
B1
B3
B1
B2
B4
B5
Figure 3. External Clock Timing
Figure 4 provides the timing for the synchronous output signals.
CLKOUT
B8
B7
B9
Output
Signals
B8a
B7a
B9
Output
Signals
B8b
B7b
Output
Signals
Figure 4. Synchronous Output Signals Timing
MOTOROLA
19
Layout Practices
Figure 5 provides the timing for the synchronous active pull-up and open-drain output signals.
CLKOUT
B13
B11
B12
TS, BB
B13a
B12a
B11a
TA, BI
B14
B15
TEA
Figure 5. Synchronous Active Pullup and Open-Drain Outputs Signals Timing
Figure 6 provides the timing for the synchronous input signals.
CLKOUT
B16
B17
TA, BI
B16a
B17a
TEA, KR,
RETRY
B16b
B17
BB, BG, BR
Figure 6. Synchronous Input Signals Timing
MOTOROLA
Layout Practices
Figure 7 provides normal case timing for input data.
CLKOUT
B16
B17
TA
B18
B19
D[0:31],
DP[0:3]
Figure 7. Input Data Timing in Normal Case
Figure 8 provides the timing for the input data controlled by the UPM in the memory controller.
CLKOUT
TA
B20
B21
D[0:31],
DP[0:3]
Figure 8. Input Data Timing when Controlled by UPM in the Memory Controller
MOTOROLA
21
Layout Practices
Figure 9 through Figure 12 provide the timing for the external bus read controlled by various GPCM factors.
CLKOUT
B11
B12
TS
B8
A[6:31]
B22
B23
CSx
B25
B26
OE
B28
WE[0:3]
B19
B18
D[0:31],
DP[0:3]
Figure 9. External Bus Read Timing (GPCM Controlled—ACS = 00)
22
MOTOROLA
Layout Practices
CLKOUT
B11
B12
TS
B8
A[6:31]
B23
B22a
CSx
B24
B25
B26
OE
B18
B19
D[0:31],
DP[0:3]
Figure 10. External Bus Read Timing (GPCM Controlled—TRLX = 0, ACS = 10)
CLKOUT
B11
B12
TS
B8
B22b
A[6:31]
B23
B22c
CSx
B24a
B25
B26
OE
B18
B19
D[0:31],
DP[0:3]
Figure 11. External Bus Read Timing (GPCM Controlled—TRLX = 0, ACS = 11)
MOTOROLA
23
Layout Practices
CLKOUT
B11
B12
TS
B8
A[6:31]
B23
B22a
CSx
B27
OE
B26
B27a
B22bB22c
B18
B19
D[0:31],
DP[0:3]
Figure 12. External Bus Read Timing (GPCM Controlled—TRLX = 1, ACS = 10, ACS = 11)
24
MOTOROLA
Layout Practices
Figure 13 through Figure 15 provide the timing for the external bus write controlled by various GPCM
factors.
CLKOUT
B11
B12
TS
B8
B30
A[6:31]
B22
B23
CSx
B25
B28
WE[0:3]
B26
B29
OE
B29a
B8
B9
D[0:31],
DP[0:3]
Figure 13. External Bus Write Timing (GPCM Controlled—TRLX = 0, CSNT = 0)
MOTOROLA
25
Layout Practices
CLKOUT
B11
B12
TS
B8
B30aB30c
A[6:31]
B22
B23
B28bB28d
CSx
B25
B29cB29g
WE[0:3]
B26
B29aB29f
OE
B28a B28c
B8
B9
D[0:31],
DP[0:3]
Figure 14. External Bus Write Timing (GPCM Controlled—TRLX = 0, CSNT = 1)
26
MOTOROLA
Layout Practices
CLKOUT
B11
B12
TS
B8
B30bB30d
A[6:31]
B22
B23
B28bB28d
CSx
B25
B29eB29i
WE[0:3]
B26
B29d
OE
B29
B8
B28aB28c
B9
D[0:31],
DP[0:3]
Figure 15. External Bus Write Timing (GPCM Controlled—TRLX = 1, CSNT = 1)
Figure 16 provides the timing for the external bus controlled by the UPM.
MOTOROLA
27
Layout Practices
CLKOUT
B8
A[6:31]
B31a
B31c
B31d
B31
B31b
CSx
B34
B34a
B34b
B32c
B32aB32d
B32
B32b
BS_A[0:3],
BS_B[0:3]
B35 B36
B35a
B33a
B35b
B33
GPL_A[0–5],
GPL_B[0–5]
Figure 16. External Bus Timing (UPM Controlled Signals)
Figure 17 provides the timing for the asynchronous asserted UPWAIT signal controlled by the UPM.
CLKOUT
B37
UPWAIT
B38
CSx
BS_A[0:3],
BS_B[0:3]
GPL_A[0–5],
GPL_B[0–5]
Figure 17. Asynchronous UPWAIT Asserted Detection in UPM Handled Cycles Timing
28
MOTOROLA
Layout Practices
Figure 18 provides the timing for the asynchronous negated UPWAIT signal controlled by the UPM.
CLKOUT
B37
UPWAIT
B38
CSx
BS_A[0:3],
BS_B[0:3]
GPL_A[0–5],
GPL_B[0–5]
Figure 18. Asynchronous UPWAIT Negated Detection in UPM Handled Cycles Timing
Figure 19 provides the timing for the synchronous external master access controlled by the GPCM.
CLKOUT
B41
B42
TS
B40
A[6:31],
TSIZ[0:1],
R/W, BURST
B22
CSx
Figure 19. Synchronous External Master Access Timing (GPCM Handled ACS = 00)
MOTOROLA
29
Layout Practices
Figure 20 provides the timing for the asynchronous external master memory access controlled by the
GPCM.
CLKOUT
B39
AS
B40
A[6:31],
TSIZ[0:1],
R/W
B22
CSx
Figure 20. Asynchronous External Master Memory Access Timing (GPCM Controlled—ACS = 00)
Figure 21 provides the timing for the asynchronous external master control signals negation.
AS
B43
CSx, WE[0:3],
OE, GPLx,
BS[0:3]
Figure 21. Asynchronous External Master—Control Signals Negation Timing
Table 7 provides interrupt timing for the MPC850.
Table 7. Interrupt Timing
Num
Characteristic 1
50 MHz
66MHz
80 MHz
Unit
Min
Max
Min
Max
Min
Max
I39
IRQx valid to CLKOUT rising edge (set up time)
6.00
6.00
6.00
ns
I40
IRQx hold time after CLKOUT.
2.00
2.00
2.00
ns
I41
IRQx pulse width low
3.00
3.00
3.00
ns
I42
IRQx pulse width high
3.00
3.00
3.00
ns
I43
IRQx edge-to-edge time
80.00
121.0
100.0
ns
1
The timings I39 and I40 describe the testing conditions under which the IRQ lines are tested when being defined as
level sensitive. The IRQ lines are synchronized internally and do not have to be asserted or negated with reference
to the CLKOUT.
The timings I41, I42, and I43 are specified to allow the correct function of the IRQ lines detection circuitry, and has no
direct relation with the total system interrupt latency that the MPC850 is able to support
30
MOTOROLA
Layout Practices
Figure 22 provides the interrupt detection timing for the external level-sensitive lines.
CLKOUT
I39
I40
IRQx
Figure 22. Interrupt Detection Timing for External Level Sensitive Lines
Figure 23 provides the interrupt detection timing for the external edge-sensitive lines.
CLKOUT
I39
I41
I42
IRQx
I43
I43
Figure 23. Interrupt Detection Timing for External Edge Sensitive Lines
Table 8 shows the PCMCIA timing for the MPC850.
Table 8. PCMCIA Timing
50MHz
Num
66MHz
80 MHz
Characteristic
FFACTOR Unit
Min
Max
Min
Max
Min
Max
P44
A[6–31], REG valid to PCMCIA strobe
asserted. 1
13.00
21.00
17.00
0.750
ns
P45
A[6–31], REG valid to ALE negation.1
18.00
28.00
23.00
1.000
ns
P46
CLKOUT to REG valid
5.00
13.00
8.00
16.00
6.00
14.00
0.250
ns
P47
CLKOUT to REG Invalid.
6.00
9.00
7.00
0.250
ns
P48
CLKOUT to CE1, CE2 asserted.
5.00
13.00
8.00
16.00
6.00
14.00
0.250
P49
CLKOUT to CE1, CE2 negated.
5.00
13.00
8.00
16.00
6.00
14.00
0.250
ns
P50
CLKOUT to PCOE, IORD, PCWE, IOWR
assert time.
11.00
11.00
11.00
ns
P51
negate time.
2.00
11.00
2.00
11.00
2.00
11.00
ns
P52
CLKOUT to ALE assert time
5.00
13.00
8.00
16.00
6.00
14.00
0.250
ns
MOTOROLA
31
Layout Practices
Table 8. PCMCIA Timing (continued)
50MHz
Num
66MHz
80 MHz
Characteristic
FFACTOR Unit
Min
Max
Min
Max
Min
Max
13.00
16.00
14.00
0.250
ns
P53
CLKOUT to ALE negate time
P54
PCWE, IOWR negated to D[0–31]
invalid.1
3.00
6.00
4.00
0.250
ns
P55
WAIT_B valid to CLKOUT rising edge.1
8.00
8.00
8.00
ns
P56
CLKOUT rising edge to WAIT_B invalid.1
2.00
2.00
2.00
ns
1
PSST = 1. Otherwise add PSST times cycle time.
PSHT = 0. Otherwise add PSHT times cycle time.
These synchronous timings define when the WAIT_B signal is detected in order to freeze (or relieve) the PCMCIA
current cycle. The WAIT_B assertion will be effective only if it is detected 2 cycles before the PSL timer expiration.
See PCMCIA Interface in the MPC850 PowerQUICC User’s Manual.
Figure 24 provides the PCMCIA access cycle timing for the external bus read.
CLKOUT
TS
P44
A[6:31]
P46
P45
P47
REG
P48
P49
CE1/CE2
P50
P51
P53
P52
PCOE, IORD
P52
ALE
B18
B19
D[0:31]
Figure 24. PCMCIA Access Cycles Timing External Bus Read
32
MOTOROLA
Layout Practices
Figure 25 provides the PCMCIA access cycle timing for the external bus write.
CLKOUT
TS
P44
A[6:31]
P46
P45
P47
REG
P48
P49
CE1/CE2
P50
P51
P53
P52
B8
B9
P54
PCOE, IOWR
P52
ALE
D[0:31]
Figure 25. PCMCIA Access Cycles Timing External Bus Write
Figure 26 provides the PCMCIA WAIT signals detection timing.
CLKOUT
P55
P56
WAIT_B
Figure 26. PCMCIA WAIT Signal Detection Timing
MOTOROLA
33
Layout Practices
Table 9 shows the PCMCIA port timing for the MPC850.
Table 9. PCMCIA Port Timing
50 MHz
Num
P57
66 MHz
80 MHz
Characteristic
Unit
Min
Max
Min
Max
Min
Max
19.00
19.00
19.00
ns
18.00
26.00
22.00
ns
CLKOUT to OPx valid
drive 1
P58
HRESET negated to OPx
P59
IP_Xx valid to CLKOUT rising edge
5.00
5.00
5.00
ns
P60
CLKOUT rising edge to IP_Xx invalid
1.00
1.00
1.00
ns
1
OP2 and OP3 only.
Figure 27 provides the PCMCIA output port timing for the MPC850.
CLKOUT
P57
Output
Signals
HRESET
P58
OP2, OP3
Figure 27. PCMCIA Output Port Timing
Figure 28 provides the PCMCIA output port timing for the MPC850.
CLKOUT
P59
P60
Input
Signals
Figure 28. PCMCIA Input Port Timing
34
MOTOROLA
Layout Practices
Table 10 shows the debug port timing for the MPC850.
Table 10. Debug Port Timing
50 MHz
Num
66 MHz
80 MHz
Characteristic
Unit
Min
Max
Min
Max
Min
Max
D61
DSCK cycle time
60.00
91.00
75.00
ns
D62
DSCK clock pulse width
25.00
38.00
31.00
ns
D63
DSCK rise and fall times
0.00
3.00
0.00
3.00
0.00
3.00
ns
D64
DSDI input data setup time
8.00
8.00
8.00
ns
D65
DSDI data hold time
5.00
5.00
5.00
ns
D66
DSCK low to DSDO data valid
0.00
15.00
0.00
15.00
0.00
15.00
ns
D67
DSCK low to DSDO invalid
0.00
2.00
0.00
2.00
0.00
2.00
ns
Figure 29 provides the input timing for the debug port clock.
DSCK
D61
D62
D62
D63
D63
Figure 29. Debug Port Clock Input Timing
Figure 30 provides the timing for the debug port.
DSCK
D64
D65
DSDI
D66
D67
DSDO
Figure 30. Debug Port Timings
MOTOROLA
35
Layout Practices
Table 11 shows the reset timing for the MPC850.
Table 11. Reset Timing
50 MHz
Num
66MHz
80 MHz
Characteristic
FFACTOR Unit
Min
Max
Min
Max
Min
Max
R69
CLKOUT to HRESET high impedance
20.00
20.00
20.00
ns
R70
CLKOUT to SRESET high impedance
20.00
20.00
20.00
ns
R71
RSTCONF pulse width
340.00
515.00
425.00
17.000
ns
R72
R73
Configuration data to HRESET rising
edge set up time
350.00
505.00
425.00
15.000
ns
R74
Configuration data to RSTCONF rising
edge set up time
350.00
350.00
350.00
ns
R75
Configuration data hold time after
RSTCONF negation
0.00
0.00
0.00
ns
R76
HRESET negation
0.00
0.00
0.00
ns
R77
HRESET and RSTCONF asserted to
data out drive
25.00
25.00
25.00
ns
R78
RSTCONF negated to data out high
impedance.
25.00
25.00
25.00
ns
CLKOUT of last rising edge before chip
tristates HRESET to data out high
impedance.
25.00
25.00
25.00
ns
R79
R80
DSDI, DSCK set up
60.00
90.00
75.00
3.000
ns
R81
DSDI, DSCK hold time
0.00
0.00
0.00
ns
R82
SRESET negated to CLKOUT rising
edge for DSDI and DSCK sample
160.00
242.00
200.00
8.000
ns
Figure 31 shows the reset timing for the data bus configuration.
HRESET
R71
R76
RSTCONF
R73
R74
R75
D[0:31] (IN)
Figure 31. Reset Timing—Configuration from Data Bus
36
MOTOROLA
Layout Practices
Figure 32 provides the reset timing for the data bus weak drive during configuration.
CLKOUT
R69
HRESET
R79
RSTCONF
R77
R78
D[0:31] (OUT)
(Weak)
Figure 32. Reset Timing—Data Bus Weak Drive during Configuration
Figure 33 provides the reset timing for the debug port configuration.
CLKOUT
R70
R82
SRESET
R80
R80
R81
R81
DSCK, DSDI
Figure 33. Reset Timing—Debug Port Configuration
Part VII IEEE 1149.1 Electrical Specifications
Table 12 provides the JTAG timings for the MPC850 as shown in Figure 34 to Figure 37.
Table 12. JTAG Timing
50 MHz
Num
66MHz
80 MHz
Characteristic
Unit
Min
Max
Min
Max
Min
Max
J82
TCK cycle time
100.00
100.00
100.00
ns
J83
TCK clock pulse width measured at 1.5 V
40.00
40.00
40.00
ns
J84
TCK rise and fall times
0.00
10.00
0.00
10.00
0.00
10.00
ns
J85
TMS, TDI data setup time
5.00
5.00
5.00
ns
MOTOROLA
37
Layout Practices
Table 12. JTAG Timing (continued)
50 MHz
Num
66MHz
80 MHz
Characteristic
Unit
Min
Max
Min
Max
Min
Max
25.00
25.00
25.00
ns
27.00
27.00
27.00
ns
0.00
0.00
0.00
ns
20.00
20.00
20.00
ns
J86
TMS, TDI data hold time
J87
TCK low to TDO data valid
J88
TCK low to TDO data invalid
J89
TCK low to TDO high impedance
J90
TRST assert time
100.00
100.00
100.00
ns
J91
TRST setup time to TCK low
40.00
40.00
40.00
ns
J92
TCK falling edge to output valid
50.00
50.00
50.00
ns
J93
TCK falling edge to output valid out of high
impedance
50.00
50.00
50.00
ns
J94
TCK falling edge to output high impedance
50.00
50.00
50.00
ns
J95
Boundary scan input valid to TCK rising edge
50.00
50.00
50.00
ns
J96
TCK rising edge to boundary scan input invalid
50.00
50.00
50.00
ns
TCK
J82
J83
J82
J83
J84
J84
Figure 34. JTAG Test Clock Input Timing
TCK
J85
J86
TMS, TDI
J87
J88
J89
TDO
Figure 35. JTAG Test Access Port Timing Diagram
38
MOTOROLA
PIO AC Electrical Specifications
TCK
J91
J90
TRST
Figure 36. JTAG TRST Timing Diagram
TCK
J92
J94
Output
Signals
J93
Output
Signals
J95
J96
Input
Signals
Figure 37. Boundary Scan (JTAG) Timing Diagram
Part VIII CPM Electrical Characteristics
This section provides the AC and DC electrical specifications for the communications processor module
(CPM) of the MPC850.
8.1
Table 13 provides the parallel I/O timings for the MPC850 as shown in Figure 38.
Table 13. Parallel I/O Timing
All Frequencies
Num
Characteristic
Unit
Min
Max
29
Data-in setup time to clock high
15
ns
30
Data-in hold time from clock high
7.5
ns
31
Clock low to data-out valid (CPU writes data, control, or direction)
25
ns
MOTOROLA
39
IDMA Controller AC Electrical Specifications
CLKOUT
29
30
DATA-IN
31
DATA-OUT
Figure 38. Parallel I/O Data-In/Data-Out Timing Diagram
8.2
Table 14 provides the IDMA controller timings as shown in Figure 39 to Figure 42.
Table 14. IDMA Controller Timing
All Frequencies
Num
Characteristic
Unit
Min
Max
40
DREQ setup time to clock high
7.00
ns
41
DREQ hold time from clock high
3.00
ns
42
SDACK assertion delay from clock high
12.00
ns
43
SDACK negation delay from clock low
12.00
ns
44
SDACK negation delay from TA low
20.00
ns
45
SDACK negation delay from clock high
15.00
ns
46
TA assertion to falling edge of the clock setup time (applies to external TA)
7.00
ns
CLKOUT
(Output)
41
40
DREQ
(Input)
Figure 39. IDMA External Requests Timing Diagram
40
MOTOROLA
CLKOUT
(Output)
TS
(Output)
R/W
(Output)
42
43
DATA
46
TA
(Output)
SDACK
Figure 40. SDACK Timing Diagram—Peripheral Write, TA Sampled Low at the Falling Edge
of the Clock
CLKOUT
(Output)
TS
(Output)
R/W
(Output)
42
44
DATA
TA
(Output)
SDACK
Figure 41. SDACK Timing Diagram—Peripheral Write, TA Sampled High at the Falling Edge
of the Clock
MOTOROLA
41
Baud Rate Generator AC Electrical Specifications
CLKOUT
(Output)
TS
(Output)
R/W
(Output)
42
45
DATA
TA
(Output)
SDACK
Figure 42. SDACK Timing Diagram—Peripheral Read
8.3
Table 15 provides the baud rate generator timings as shown in Figure 43.
Table 15. Baud Rate Generator Timing
All Frequencies
Num
Characteristic
Unit
Min
Max
10.00
ns
50
BRGO rise and fall time
51
BRGO duty cycle
40.00
60.00
52
BRGO cycle
40.00
ns
50
50
BRGOn
51
51
52
Figure 43. Baud Rate Generator Timing Diagram
42
MOTOROLA
Timer AC Electrical Specifications
8.4
Table 16 provides the baud rate generator timings as shown in Figure 44.
Table 16. Timer Timing
All Frequencies
Num
Characteristic
Unit
Min
Max
61
TIN/TGATE rise and fall time
10.00
ns
62
TIN/TGATE low time
1.00
clk
63
TIN/TGATE high time
2.00
clk
64
TIN/TGATE cycle time
3.00
clk
65
CLKO high to TOUT valid
3.00
25.00
ns
CLKOUT
61
63
62
TIN/TGATE
(Input)
61
64
65
TOUT
(Output)
Figure 44. CPM General-Purpose Timers Timing Diagram
8.5
Serial Interface AC Electrical Specifications
Table 17 provides the serial interface timings as shown in Figure 45 to Figure 49.
Table 17. SI Timing
All Frequencies
Num
Characteristic
Unit
70
L1RCLK, L1TCLK frequency (DSC = 0) 1, 2
71
L1RCLK, L1TCLK width low (DSC = 0) 2
3
71a
L1RCLK, L1TCLK width high (DSC = 0)
72
L1TXD, L1STn, L1RQ, L1xCLKO rise/fall time
73
L1RSYNC, L1TSYNC valid to L1xCLK edge Edge
(SYNC setup time)
MOTOROLA
Min
Max
SYNCCLK/2.
5
MHz
P + 10
ns
P + 10
ns
15.00
ns
20.00
ns
43
Table 17. SI Timing (continued)
All Frequencies
Num
Characteristic
Unit
Min
Max
35.00
ns
15.00
ns
74
L1xCLK edge to L1RSYNC, L1TSYNC, invalid
(SYNC hold time)
75
L1RSYNC, L1TSYNC rise/fall time
76
L1RXD valid to L1xCLK edge (L1RXD setup time)
17.00
ns
77
L1xCLK edge to L1RXD invalid (L1RXD hold time)
13.00
ns
10.00
45.00
ns
4
78
L1xCLK edge to L1STn valid
78A
L1SYNC valid to L1STn valid
10.00
45.00
ns
79
L1xCLK edge to L1STn invalid
10.00
45.00
ns
80
L1xCLK edge to L1TXD valid
10.00
55.00
ns
10.00
55.00
ns
0.00
42.00
ns
80A
L1TSYNC valid to L1TXD valid
4
81
L1xCLK edge to L1TXD high impedance
82
L1RCLK, L1TCLK frequency (DSC =1)
16.00 or
SYNCCLK/2
MHz
83
L1RCLK, L1TCLK width low (DSC =1)
P + 10
ns
P + 10
ns
30.00
ns
1.00
L1TCLK
83A
84
1)3
L1CLK edge to L1CLKO valid (DSC = 1)
L1TSYNC4
85
L1RQ valid before falling edge of
86
L1GR setup time2
42.00
ns
87
L1GR hold time
42.00
ns
88
L1xCLK edge to L1SYNC valid (FSD = 00) CNT =
0000, BYT = 0, DSC = 0)
0.00
ns
1
The ratio SyncCLK/L1RCLK must be greater than 2.5/1.
These specs are valid for IDL mode only.
3 Where P = 1/CLKOUT. Thus for a 25-MHz CLKO1 rate, P = 40 ns.
4 These strobes and TxD on the first bit of the frame become valid after L1CLK edge or L1SYNC,
whichever is later.
2
44
MOTOROLA
L1RCLK
(FE=0, CE=0)
(Input)
71
70
71a
72
L1RCLK
(FE=1, CE=1)
(Input)
RFSD=1
75
L1RSYNC
(Input)
73
74
L1RxD
(Input)
77
BIT0
76
78
79
L1STn
(Output)
Figure 45. SI Receive Timing Diagram with Normal Clocking (DSC = 0)
MOTOROLA
45
L1RCLK
(FE=1, CE=1)
(Input)
72
83a
82
L1RCLK
(FE=0, CE=0)
(Input)
RFSD=1
75
L1RSYNC
(Input)
73
74
L1RXD
(Input)
77
BIT0
76
78
79
L1ST(4-1)
(Output)
84
L1CLKO
(Output)
Figure 46. SI Receive Timing with Double-Speed Clocking (DSC = 1)
46
MOTOROLA
L1TCLK
(FE=0, CE=0)
(Input)
71
70
72
L1TCLK
(FE=1, CE=1)
(Input)
73
TFSD=0
75
L1TSYNC
(Input)
74
80a
L1TxD
(Output)
81
BIT0
80
79
78
L1STn
(Output)
Figure 47. SI Transmit Timing Diagram
MOTOROLA
47
L1RCLK
(FE=0, CE=0)
(Input)
72
83a
82
L1RCLK
(FE=1, CE=1)
(Input)
TFSD=0
75
L1RSYNC
(Input)
73
74
L1TXD
(Output)
81
BIT0
80
78a
79
L1ST(4-1)
(Output)
78
84
L1CLKO
(Output)
Figure 48. SI Transmit Timing with Double Speed Clocking (DSC = 1)
48
MOTOROLA
MOTOROLA
L1GR
(Input)
L1RQ
(Output)
L1ST(4-1)
(Output)
L1RXD
(Input)
L1TXD
(Output)
L1RSYNC
(Input)
L1RCLK
(Input)
80
77
74
2
3
5
72
B15 B14 B13
71
71
4
86
85
76
6
87
B17 B16 B15 B14 B13
B17 B16
73
1
8
78
B12 B11 B10
B12 B11 B10
7
9
D1
D1
10
A
A
12
14
15
16
17
18
B25 B24 B23 B22 B21 B20
13
B27 B26 B25 B24 B23 B22 B21 B20
81
B27 B26
11
19
D2
D2
M
M
Figure 49. IDL Timing
49
SCC in NMSI Mode Electrical Specifications
8.6
Table 18 provides the NMSI external clock timing.
Table 18. NMSI External Clock Timing
All Frequencies
Num
1
Characteristic
100
RCLKx and TCLKx frequency 1 (x = 2, 3 for all specs in this
table)
101
RCLKx and TCLKx width low
102
RCLKx and TCLKx rise/fall time
103
Unit
Min
Max
1/SYNCCLK
ns
1/SYNCCLK +5
ns
15.00 ns
TXDx active delay (from TCLKx falling edge)
0.00
50.00 ns
104
RTSx active/inactive delay (from TCLKx falling edge)
0.00
50.00 ns
105
CTSx setup time to TCLKx rising edge
5.00
ns
106
RXDx setup time to RCLKx rising edge
5.00
ns
107
RXDx hold time from RCLKx rising edge 2
5.00
ns
108
CDx setup time to RCLKx rising edge
5.00
ns
The ratios SyncCLK/RCLKx and SyncCLK/TCLKx must be greater than or equal to 2.25/1.
Also applies to CD and CTS hold time when they are used as an external sync signal.
2
Table 19 provides the NMSI internal clock timing.
Table 19. NMSI Internal Clock Timing
All Frequencies
Num
1
2
50
Characteristic
Unit
Min
Max
0.00
SYNCCLK/3
MHz
ns
100
RCLKx and TCLKx frequency 1 (x = 2, 3 for all specs in this table)
102
103
0.00
30.00
ns
104
0.00
30.00
ns
105
40.00
ns
106
40.00
ns
0.00
ns
40.00
ns
edge 2
107
108
The ratios SyncCLK/RCLKx and SyncCLK/TCLK1x must be greater or equal to 3/1.
Also applies to CD and CTS hold time when they are used as an external sync signals.
MOTOROLA
Figure 50 through Figure 52 show the NMSI timings.
RCLKx
102
102
101
106
100
RXDx
(Input)
107
108
CDx
(Input)
107
CDx
(SYNC Input)
Figure 50. SCC NMSI Receive Timing Diagram
TCLKx
102
102
101
100
TXDx
(Output)
103
105
RTSx
(Output)
104
104
CTSx
(Input)
107
CTSx
(SYNC Input)
Figure 51. SCC NMSI Transmit Timing Diagram
MOTOROLA
51
Ethernet Electrical Specifications
TCLKx
102
102
101
100
TXDx
(Output)
103
RTSx
(Output)
104
107
104
105
CTSx
(Echo Input)
Figure 52. HDLC Bus Timing Diagram
8.7
Table 20 provides the Ethernet timings as shown in Figure 53 to Figure 55.
Table 20. Ethernet Timing
All Frequencies
Num
52
Characteristic
120
CLSN width high
121
RCLKx rise/fall time (x = 2, 3 for all specs in this table)
122
RCLKx width low
period 1
Unit
Min
Max
40.00
ns
15.00
ns
40.00
ns
80.00
120.00
ns
123
RCLKx clock
124
RXDx setup time
20.00
ns
125
RXDx hold time
5.00
ns
126
RENA active delay (from RCLKx rising edge of the last data bit)
10.00
ns
127
RENA width low
100.00
ns
128
15.00
ns
129
TCLKx width low
40.00
ns
99.00
101.00
ns
period1
130
TCLKx clock
131
TXDx active delay (from TCLKx rising edge)
10.00
50.00
ns
132
TXDx inactive delay (from TCLKx rising edge)
10.00
50.00
ns
MOTOROLA
Table 20. Ethernet Timing (continued)
All Frequencies
Num
Max
TENA active delay (from TCLKx rising edge)
10.00
50.00
ns
134
TENA inactive delay (from TCLKx rising edge)
139
2
Unit
Min
133
138
1
Characteristic
CLKOUT low to SDACK
10.00
50.00
ns
asserted 2
20.00
ns
2
20.00
ns
CLKOUT low to SDACK negated
The ratios SyncCLK/RCLKx and SyncCLK/TCLKx must be greater or equal to 2/1.
SDACK is asserted whenever the SDMA writes the incoming frame destination address into memory.
CLSN(CTSx)
(Input)
120
Figure 53. Ethernet Collision Timing Diagram
RCLKx
121
121
122
124
123
RXDx
(Input)
Last Bit
125
126
127
RENA(CDx)
(Input)
Figure 54. Ethernet Receive Timing Diagram
MOTOROLA
53
SMC Transparent AC Electrical Specifications
TCLKx
128
128
131
129
130
TxDx
(Output)
132
133
134
TENA(RTSx)
(Input)
RENA(CDx)
(Input)
(NOTE 2)
NOTES:
1. Transmit clock invert (TCI) bit in GSMR is set.
2. If RENA is deasserted before TENA, or RENA is not asserted at all during transmit, then the
CSL bit is set in the buffer descriptor at the end of the frame transmission.
Figure 55. Ethernet Transmit Timing Diagram
8.8
Figure 21 provides the SMC transparent timings as shown in Figure 56.
Table 21. Serial Management Controller Timing
All Frequencies
Num
1
54
Characteristic
Unit
Min
Max
150
SMCLKx clock period 1
100.00
ns
151
SMCLKx width low
50.00
ns
151a
SMCLKx width high
50.00
ns
152
SMCLKx rise/fall time
15.00
ns
153
SMTXDx active delay (from SMCLKx falling edge)
10.00
50.00
ns
154
SMRXDx/SMSYNx setup time
20.00
ns
155
SMRXDx/SMSYNx hold time
5.00
ns
The ratio SyncCLK/SMCLKx must be greater or equal to 2/1.
MOTOROLA
SPI Master AC Electrical Specifications
SMCLKx
152
152
151
151a
150
SMTXDx
(Output)
NOTE
154
153
155
SMSYNx
154
155
SMRXDx
(Input)
NOTE:
1. This delay is equal to an integer number of character-length clocks.
Figure 56. SMC Transparent Timing Diagram
8.9
Table 22 provides the SPI master timings as shown in Figure 57 and Figure 58.
Table 22. SPI Master Timing
All Frequencies
Num
MOTOROLA
Characteristic
Unit
Min
Max
160
MASTER cycle time
4
1024
tcyc
161
MASTER clock (SCK) high or low time
2
512
tcyc
162
MASTER data setup time (inputs)
50.00
ns
163
Master data hold time (inputs)
0.00
ns
164
Master data valid (after SCK edge)
20.00
ns
165
Master data hold time (outputs)
0.00
ns
166
Rise time output
15.00
ns
167
Fall time output
15.00
ns
55
SPICLK
(CI=0)
(Output)
161
167
166
161
160
SPICLK
(CI=1)
(Output)
163
167
162
SPIMISO
(Input)
msb
166
Data
lsb
165
msb
164
167
SPIMOSI
(Output)
166
msb
Data
lsb
msb
Figure 57. SPI Master (CP = 0) Timing Diagram
SPICLK
(CI=0)
(Output)
161
167
166
161
160
SPICLK
(CI=1)
(Output)
163
167
162
SPIMISO
(Input)
166
msb
Data
165
lsb
msb
164
167
SPIMOSI
(Output)
msb
166
Data
lsb
msb
Figure 58. SPI Master (CP = 1) Timing Diagram
56
MOTOROLA
SPI Slave AC Electrical Specifications
8.10 SPI Slave AC Electrical Specifications
Table 23 provides the SPI slave timings as shown in Figure 59 and Figure 60.
Table 23. SPI Slave Timing
All Frequencies
Num
Characteristic
Unit
Min
Max
2
tcyc
170
Slave cycle time
171
Slave enable lead time
15.00
ns
172
Slave enable lag time
15.00
ns
173
Slave clock (SPICLK) high or low time
1
tcyc
174
Slave sequential transfer delay (does not require deselect)
1
tcyc
175
Slave data setup time (inputs)
20.00
ns
176
Slave data hold time (inputs)
20.00
ns
177
Slave access time
50.00
ns
178
Slave SPI MISO disable time
50.00
ns
179
Slave data valid (after SPICLK edge)
50.00
ns
180
Slave data hold time (outputs)
0.00
ns
181
Rise time (input)
15.00
ns
182
Fall time (input)
15.00
ns
MOTOROLA
57
SPISEL
(Input)
172
171
174
SPICLK
(CI=0)
(Input)
173
182
173
181
170
SPICLK
(CI=1)
(Input)
177
181
182
180
SPIMISO
(Output)
msb
178
Data
175
msb
Undef
msb
179
176
SPIMOSI
(Input)
lsb
181 182
Data
lsb
msb
Figure 59. SPI Slave (CP = 0) Timing Diagram
58
MOTOROLA
I2C AC Electrical Specifications
SPISEL
(Input)
172
171
174
170
SPICLK
(CI=0)
(Input)
173
182
181
173
181
SPICLK
(CI=1)
(Input)
177
182
180
SPIMISO
(Output)
msb
Undef
175
Data
msb
lsb
179
176
SPIMOSI
(Input)
178
msb
181 182
Data
msb
lsb
Figure 60. SPI Slave (CP = 1) Timing Diagram
8.11 I2C AC Electrical Specifications
Table 24 provides the I2C (SCL < 100 KHz) timings.
Table 24. I2C Timing (SCL < 100 KHZ)
All Frequencies
Num
Characteristic
Unit
Min
Max
200
SCL clock frequency (slave)
0.00
100.00
KHz
200
SCL clock frequency (master) 1
1.50
100.00
KHz
202
Bus free time between transmissions
4.70
µs
203
Low period of SCL
4.70
µs
204
High period of SCL
4.00
µs
205
Start condition setup time
4.70
µs
206
Start condition hold time
4.00
µs
207
Data hold time
0.00
µs
MOTOROLA
59
Table 24. I2C Timing (SCL < 100 KHZ) (CONTINUED)
All Frequencies
Num
1
Characteristic
Unit
Min
Max
250.00
ns
208
Data setup time
209
SDL/SCL rise time
1.00
µs
210
SDL/SCL fall time
300.00
ns
211
Stop condition setup time
4.70
µs
SCL frequency is given by SCL = BRGCLK_frequency / ((BRG register + 3) * pre_scaler * 2).
The ratio SyncClk/(BRGCLK/pre_scaler) must be greater or equal to 4/1.
Table 25 provides the I2C (SCL > 100 KHz) timings.
Table 25. I2C Timing (SCL > 100 KHZ)
All Frequencies
Num
200
1
60
Characteristic
(master) 1
Expression
Unit
Min
Max
fSCL
BRGCLK/48
Hz
fSCL
BRGCLK/16512
BRGCLK/48
Hz
200
SCL clock frequency
202
1/(2.2 * fSCL)
s
203
Low period of SCL
1/(2.2 * fSCL)
s
204
High period of SCL
1/(2.2 * fSCL)
s
205
1/(2.2 * fSCL)
s
206
1/(2.2 * fSCL)
s
207
Data hold time
s
208
Data setup time
1/(40 * fSCL)
s
209
SDL/SCL rise time
1/(10 * fSCL)
s
210
SDL/SCL fall time
1/(33 * fSCL)
s
211
1/2(2.2 * fSCL)
s
SCL frequency is given by SCL = BrgClk_frequency / ((BRG register + 3) * pre_scaler * 2).
The ratio SyncClk/(Brg_Clk/pre_scaler) must be greater or equal to 4/1.
MOTOROLA
Figure 61 shows the I2C bus timing.
SDA
202
203
204
205
208
207
SCL
206
209
210
211
Figure 61. I2C Bus Timing Diagram
Part IX Mechanical Data and Ordering
Information
Table 26 provides information on the MPC850 derivative devices.
Table 26. MPC850 Derivatives
Ethernet Support
Number of SCCs 1
32-Channel HDLC
Support
64-Channel HDLC
Support 2
MPC850
N/A
One
N/A
N/A
MPC850DE
Yes
Two
N/A
N/A
MPC850SAR
Yes
Two
N/A
Yes
Device
1
2
Serial Communication Controller (SCC)
50 MHz version supports 64 time slots on a time division multiplexed line using one SCC
MOTOROLA
61
Pin Assignments and Mechanical Dimensions of the PBGA
Table 27 identifies the packages and operating frequencies available for the MPC850.
Table 27. MPC850 Package/Frequency/Availability
Package Type
256-Lead Plastic Ball Grid Array
(ZT suffix)
(CZT suffix)
9.1
Frequency (MHz)
Temperature (Tj)
Order Number
50
0°C to 95°C
XPC850ZT50B
XPC850DEZT50B
XPC850SRZT50B
66
0°C to 95°C
XPC850ZT66B
XPC850DEZT66B
XPC850SRZT66B
80
0°C to 95°C
XPC850ZT80B
XPC850DEZT80B
XPC850SRZT80B
50
-40°C to 95°C
XPC850CZT50B
XPC850DECZT50B
XPC850SRCZT50B
66
XPC850CZT66B
XPC850DECZT66B
XPC850SRCZT66B
80
XPC850CZT80B
XPC850DECZT80B
XPC850SRCZT80B
the PBGA
The original pin numbering of the MPC850 conformed to a Motorola proprietary pin numbering scheme
that has since been replaced by the JEDEC pin numbering standard for this package type. To support
customers that are currently using the non-JEDEC pin numbering scheme, two sets of pinouts, JEDEC and
non-JEDEC, are presented in this document.
62
MOTOROLA
Figure 62 shows the non-JEDEC pinout of the PBGA package as viewed from the top surface.
T
PC14
PB28
PB27
PC12
TCK
PB24
PB23
PA8
PC15
PA14
PA13
PA12
TMS
TDI
PC11
PB22
PC9
PB19
PA4
PB16
PD15
PA15 PB30
PB29
PC13
PB26
TRST
N/C
PC10
PA6
PB18
PC5
PD13
PD9
PD4
TDO
PB25
PA9
N/C
PC8
PB17
PC6
PD11
PD3
IR Q7
IRQ1
PA7
VDDL
PA5
PC7
PC4
PD14
PD10
PD8
R
PD12
PD7
PD6
P
PD5
N/C
N
A8
A7
PB31
N/C
A11
A9
A12
A6
D12
D13
D8
D0
A15
A14
A13
A10
D23
D27
D4
D1
A27
A19
A16
A17
D17
D10
D9
D11
D15
D14
D2
D3
IRQ0
M
L
K
J
VDDL
A20
A21
N/C
GND
H
A29
A23
A25
A24
D22
D18
D16
D5
A28
A30
A22
A18
D25
D20
D19
VDDL
A31
TSIZ0
A26
WE3
D28
D24
D21
D6
WE1
TSIZ1
N/C
GPLA0
D26
D31
D29
D7
WE0
WE2
GPLA3
CS5
CS0
GPLA4
TS
IRQ2
IPB7
IPB2 MODCK1
DP2
D30
CLKOUT
CS6
WR
GPLA5
TEA
BG
IPB5
IPB1
IPB6
N/C RSTCONF W AITB DP0
DP3
N/C
G
F
VDDH
E
D
TEXP
DP1
C
GPLA1 GPLA2
B
CS4
CS7
CS2
GPLB4
BI
BR
N/C
CS3
CS1
BDIP
TA
BB
16
15
14
13
BU RST IPB4
ALEB
IR Q4 MODCK2 HRESETSRESETPORESET XFC VDDSYN
A
12
11
IRQ6
10
IPB3
9
IPB0
8
VDDL EXTCLKEXTAL
7
6
5
VSSSYN
XTAL KAPWR VSSSYN1
4
3
2
1
Figure 62. Pin Assignments for the PBGA (Top View)—non-JEDEC Standard
MOTOROLA
63
Figure 63 shows the JEDEC pinout of the PBGA package as viewed from the top surface.
U
PC14
PB28
PB27
PC12
TCK
PB24
PB23
PA8
PC15
PA14
PA13
PA12
TMS
TDI
PC11
PB22
PC9
PB19
PA4
PB16
PD15
PA15 PB30
PB29
PC13
PB26
TRST
N/C
PC10
PA6
PB18
PC5
PD13
PD9
PD4
TDO
PB25
PA9
N/C
PC8
PB17
PC6
PD11
PD3
IR Q7
IRQ1
PA7
VDDL
PA5
PC7
PC4
PD14
PD10
PD8
T
PD12
PD7
PD6
R
PD5
N/C
P
A8
A7
PB31
N/C
A11
A9
A12
A6
D12
D13
D8
D0
A15
A14
A13
A10
D23
D27
D4
D1
A27
A19
A16
A17
D17
D10
D9
D11
D15
D14
D2
D3
IRQ0
N
M
L
K
VDDL
A20
A21
N/C
GND
J
A29
A23
A25
A24
D22
D18
D16
D5
A28
A30
A22
A18
D25
D20
D19
VDDL
A31
TSIZ0
A26
WE3
D28
D24
D21
D6
WE1
TSIZ1
N/C
GPLA0
D26
D31
D29
D7
WE0
WE2
GPLA3
CS5
CS0
GPLA4
TS
IRQ2
IPB7
IPB2 MODCK1
DP2
D30
CLKOUT
CS6
WR
GPLA5
TEA
BG
IPB5
IPB1
IPB6
DP3
N/C
H
G
VDDH
F
E
TEXP
DP1
D
GPLA1 GPLA2
C
CS4
CS7
CS2
GPLB4
BI
BR
N/C
CS3
CS1
BDIP
TA
BB
17
16
15
14
BU RST IPB4
ALEB
VDDSYN
B
13
12
IRQ6
IPB3
11
10
IPB0
9
VDDL EXTCLKEXTAL
8
7
6
VSSSYN
XTAL KAPWR VSSSYN1
5
4
3
2
Figure 63. Pin Assignments for the PBGA (Top View)—JEDEC Standard
For more information on the printed circuit board layout of the PBGA package, including thermal via design
and suggested pad layout, please refer to AN-1231/D, Plastic Ball Grid Array Application Note available
from your local Motorola sales office.
64
MOTOROLA
Figure 64 shows the non-JEDEC package dimensions of the PBGA.
NOTES:
1. DIMENSIONING AND TOLERANCING PER ASME
Y14.5M, 1994.
2. DIMENSIONS IN MILLIMETERS.
3. DIMENSION b IS MEASURED AT THE MAXIMUM
SOLDER BALL DIAMETER, PARALLEL TO PRIMARY
DATUM C.
4. PRIMARY DATUM C AND THE SEATING PLANE ARE
DEFINED BY THE SPHERICAL CROWNS OF THE
SOLDER BALLS.
D
A
0.20 C
256X
D2
0.35 C
E
DIM
A
A1
A2
A3
b
D
D1
D2
E
E1
E2
e
E2
4X
0.20
A2
A3
TOP VIEW
MILLIMETERS
MIN
MAX
1.91
2.35
0.50
0.70
1.12
1.22
0.29
0.43
0.60
0.90
23.00 BSC
19.05 REF
19.00
20.00
23.00 BSC
19.05 REF
19.00
20.00
1.27 BSC
B
A1
A
(D1)
15X
C
e
SEATING
PLANE
T
R
P
N
M
L
K
J
H
G
F
E
D
C
B
A
SIDE VIEW
15X
e
(E1)
4X
e /2
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
256X
BOTTOM VIEW
b
0.30
M
C A B
0.15
M
C
Figure 64. Package Dimensions for the Plastic Ball Grid Array (PBGA)—non-JEDEC Standard
MOTOROLA
65
Figure 65 shows the JEDEC package dimensions of the PBGA.
NOTES:
Y14.5M, 1994.
DATUM C.
SOLDER BALLS.
D
A
0.20 C
256X
D2
0.35 C
E
DIM
A
A1
A2
A3
b
D
D1
D2
E
E1
E2
e
E2
4X
0.20
A2
A3
TOP VIEW
MILLIMETERS
MIN
MAX
1.91
2.35
0.50
0.70
1.12
1.22
0.29
0.43
0.60
0.90
23.00 BSC
19.05 REF
19.00
20.00
23.00 BSC
19.05 REF
19.00
20.00
1.27 BSC
B
A1
A
(D1)
15X
C
e
SEATING
PLANE
U
T
R
P
N
M
L
K
J
H
G
F
E
D
C
B
SIDE VIEW
15X
e
(E1)
4X
e /2
2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
256X
BOTTOM VIEW
b
0.30
M
C A B
0.15
M
C
CASE 1130-01
ISSUE B
Figure 65. Package Dimensions for the Plastic Ball Grid Array (PBGA)—JEDEC Standard
66
MPC850 (Rev. A/B/C) Hardware Specifications
MOTOROLA
Part X Document Revision History
Table 28 lists significant changes between revisions of this document.
Table 28. Document Revision History
67
Revision
Date
Change
0.1
11/2001
Removed reference to 5 Volt tolerance capability on peripheral interface pins.
Replaced SI and IDL timing diagrams with better images. Put into new
template, added this revision table.
0.2
04/2002
Put in the new power numbers and added Rev. C
MOTOROLA
HOW TO REACH US:
USA/EUROPE/LOCATIONS NOT LISTED:
Motorola Literature Distribution;
P.O. Box 5405, Denver, Colorado 80217
1-303-675-2140 or 1-800-441-2447
JAPAN:
Motorola Japan Ltd.;
SPS, Technical Information Center,
3-20-1, Minami-Azabu Minato-ku,
Tokyo 106-8573 Japan
81-3-3440-3569
Information in this document is provided solely to enable system and software implementers to use
ASIA/PACIFIC:
Motorola products. There are no express or implied copyright licenses granted hereunder to design
Motorola Semiconductors H.K. Ltd.;
Silicon Harbour Centre, 2 Dai King Street,
Tai Po Industrial Estate, Tai Po, N.T., Hong Kong
852-26668334
or fabricate any integrated circuits or integrated circuits based on the information in this document.
TECHNICAL INFORMATION CENTER:
use of any product or circuit, and specifically disclaims any and all liability, including without
1-800-521-6274
limitation consequential or incidental damages. “Typical” parameters which may be provided in
HOME PAGE:
Motorola reserves the right to make changes without further notice to any products herein.
Motorola makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, nor does Motorola assume any liability arising out of the application or
Motorola data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be validated
http://www.motorola.com/semiconductors
for each customer application by customer’s technical experts. Motorola does not convey any
DOCUMENT COMMENTS:
license under its patent rights nor the rights of others. Motorola products are not designed,
FAX (512) 933-2625,
Attn: RISC Applications Engineering
intended, or authorized for use as components in systems intended for surgical implant into the
body, or other applications intended to support or sustain life, or for any other application in which
the failure of the Motorola product could create a situation where personal injury or death may
occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized
application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries,
affiliates, and distributors harmless against all claims, costs, damages, and expenses, and
reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that Motorola was
negligent regarding the design or manufacture of the part.
Motorola and the Stylized M Logo are registered in the U.S. Patent and Trademark Office.
digital dna is a trademark of Motorola, Inc. All other product or service names are the property of
their respective owners. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer.
© Motorola, Inc. 2002
MPC850EC/D
