MUSES03
MUSES03
    NJR(新日本无线)
    DIP8
    IC OPAMP JFET 1 CIRCUIT 8DIP
MUSES03 数据手册
MUSES03 High-Quality Sound, J-FET Input, Single Operational Amplifier for Premium Audio ■FEATURES ■GENERAL DESCRIPTION ● High-quality sound ● Operating Voltage ● Operating Current ● Low Input Bias Current ● Low Noise ● Ultralow Distortion ● High Slew Rate ● Gain Bandwidth Product ● J-FET Input ● Package Outline The MUSES03 is a high-quality sound J-FET input single operational amplifier for premium audio equipment. The MUSES03 uses advanced circuit design and special material and assembly technology to high-quality sound. The MUSES03 features high-quality sound, low input bias current, low noise, ultralow distortion and high slew rate, and it is suitable for I/V converters, preamplifiers, active filters, headphone amplifiers, and line amplifiers. ±3.5V to ±18V 5.8mA typ. 5pA typ. 7.5nV/√Hz typ. at f=1kHz 0.00003% typ. at f=1kHz 35V/µs typ. 12MHz typ. DIP8 (OFC lead-frame) OFC: Oxygen-Free Copper ■APPLICATION ● Hi-Fi Audio Application ● Professional Audio Application ■PIN CONFIGURATION PIN NO. 1 2 3 4 5 6 7 8 SYMBOL NC –INPUT +INPUT VNC OUTPUT 1 8 2 7 3 6 4 5 V+ NC MUSES and this logo are trademarks of New Japan Radio Co., Ltd. Ver.4.2 http://www.njr.com/ -1- MUSES03 ■ORDERING INFORMATION PACKAGE PART NUMBER OUTLINE MUSES03 DIP8 RoHS yes HALOGEN- TERMINAL FREE FINISH yes Sn-2Bi MARKING 03 WEIGHT (mg) 470 MOQ(pcs) 200 Note: "-" is non-evaluation. Please contact your sales representative for more information. ■ABSOLUTE MAXIMUM RATINGS PARAMETER Supply Voltage Differential Input Voltage Input Voltage Output Peak Current SYMBOL + V -V VID VIN IOP RATINGS ±19 ±6 (1) ±18 250 Power Dissipation (Ta=25°C) Operating Temperature Range Storage Temperature Range PD Topr Tstg 870 -40 to +85 -50 to+150 (2) UNIT V V V mA mW °C °C (1): If the supply voltage is less than ±18V, the input voltage must not over the supply voltage. (2): Mounted on glass epoxy board. (76.2×114.3×1.6mm: based on EIA/JDEC standard, 2Layers) ■RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Ver.4.2 SYMBOL + V -V RATINGS ±3.5 to ±18 http://www.njr.com/ UNIT V -2- MUSES03 ■POWER DISSIPATION vs. AMBIENT TEMPERATURE IC is heated by own operation and possibly gets damage when the junction power exceeds the acceptable value called Power Dissipation PD. The dependence of the MUSES03 PD on ambient temperature is shown in Fig 1. The plots are depended on following two points. The first is PD on ambient temperature 25ºC, which is the maximum power dissipation. The second is 0W, which means that the IC cannot radiate any more. Conforming the maximum junction temperature Tjmax to the storage temperature Tstg derives this point. Fig.1 is drawn by connecting those points and conforming the PD lower than 25ºC to it on 25ºC. The PD is shown following formula as a function of the ambient temperature between those points. Dissipation Power PD = Tjmax - Ta ja [W] (Ta ≥ 25ºC ) Where, ja is heat thermal resistance which depends on parameters such as package material, frame material and so on. Therefore, PD is different in each package. While, the actual measurement of dissipation power on MUSES03 is obtained using following equation. + (Actual Dissipation Power) = (Supply Current Icc) X (Supply Voltage V – V-) – (Output Power Po) The MUSES03 should be operated in lower than PD of the actual dissipation power. To sustain the steady state operation, take account of the Dissipation Power and thermal design. Ver.4.2 http://www.njr.com/ -3- MUSES03 ■ELECTRICAL CHARACTERISTICS (Ta=25 °C) + DC CHARACTERISTICS (V /V =15V, RL to GND, Ta=25°C, unless otherwise specified) PARAMETER SYMBOL TEST CONDITION MIN. Operating Current Icc No Signal, RL=∞ Input Offset Voltage Input Bias Current Input Offset Current Voltage Gain 1 Voltage Gain 2 Voltage Gain 3 VIO IB IIO AV1 AV2 AV3 Common Mode Rejection Ratio Supply Voltage Rejection Ratio Max Output Voltage 1 Max Output Voltage 2 Max Output Voltage 3 Input Common Mode Voltage Range + RS=50Ω RL=10kΩ, Vo=±13V RL=2kΩ, Vo=±12.8V RL=600Ω, Vo=±12.5V TYP. 5.8 MAX. 10 UNIT mA 90 90 90 1.0 5.0 2.0 115 115 115 250 220 - mV pA pA dB dB dB CMR SVR VOM1 VOM2 VOM2 VICM=±12.5V + V /V =±3.5 to ±18V RL=10kΩ RL=2kΩ RL=600Ω 70 80 ±13.0 ±12.8 ±12.5 90 100 ±14.0 ±13.8 ±13.5 - dB dB V V V VICM CMR≥70dB ±12.0 ±13.0 - V TYP. 12 MAX. - UNIT MHz 13 - MHz 70 - Deg 7.5 1.0 - nV/√Hz μVrms 0.00003 - % 35 - V/us - AC CHARACTERISTICS (V /V =15V, VCM=0V, Ta=25°C, unless otherwise specified) PARAMETER SYMBOL TEST CONDITION MIN. Gain Bandwidth Product GB f=10kHz AV=+100, RS=100Ω, Unity Gain Frequency fT RL=2kΩ, CL=10pF AV=+100, RS=100Ω, Phase Margin ΦM RL=2kΩ, CL=10pF Input Noise Voltage1 VNI1 f=1kHz Input Noise Voltage2 VNI2 f=20-20kHz f=1kHz , AV=+10, Total Harmonic Distortion THD Vo=5Vrms, RL=2kΩ AV=1, VIN=2Vp-p, Slew Rate SR RL=2kΩ, CL=10pF ■ NOTE The output current should not exceed the maximum output peak current (250mA) of absolute maximum ratings. If the maximum output peak current exceeds 250mA, connect a current-limiting resistor to the output. Calculating formula:R= V/ I Current-limiting resistor R(Ω):Current-limiting resistor V(V):Supply voltage I (A):Output peak current Example 18V/ 0.2A=90Ω or more (91Ω, 100Ω) 9V/ 0.2A=45Ω or more (47Ω, 51Ω) Resistance value is a reference value. It does not guarantee the characteristics of the product. Ver.4.2 http://www.njr.com/ -4- MUSES03 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Common-Mode Input Voltage V+/V-=±15V, Null Amp 10 Input Offset Voltage [mV] 8 6 4 2 0 -2 -4 -6 -8 -10 -16-14-12-10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 16 Common-Mode Input Voltage [V] Ver.4.2 http://www.njr.com/ -5- MUSES03 ■ TYPICAL CHARACTERISTICS CMR vs. Temperature V+/V-=±15V, VIN=-12 to 0V, Common-Mode Rejection Ratio [dB] 120 100 80 60 40 20 0 -60 -40 -20 0 20 40 60 80 100 120 140 160 Ambient Temperature [ºC] SVR vs. Temperature V+/V-=±3.5V - ±18V Supply Voltage Rejection Ratio [dB] 140 120 100 80 60 40 20 0 -60 -40 -20 0 20 40 60 80 100 120 140 160 Ambient Temperature [ºC] GBW vs. Temperature V+/V-=±15V, f=10kHz, AV=80dB, RF=200k, RS=20 Gain Bandwidth Product [MHz] 18 16 14 12 10 8 6 4 2 0 -60 -40 -20 0 20 40 60 80 100 120 140 160 Ambient Temperature [ºC] Ver.4.2 http://www.njr.com/ -6- MUSES03 ■ TYPICAL CHARACTERISTICS Voltage Gain vs. Frequency V+/V-=±15V, RF=200k, RS=20, Ta=27ºC 100 Voltage Gain [dB] 80 60 40 20 0 -20 -40 100 1k 10k 100k 1M Frequency [Hz] 10M 100M Equivalent Input Noise Voltage [nV/√Hz] Voltage Noise Densityvs. Frequency V+/V-=±15V, RF=2k, RS=20, Ta=25ºC 50 45 40 35 30 25 20 15 10 5 0 1 10 100 1k Frequency [Hz] 10k 100k THD+N vs. Output Voltage V+/V-=±15V, R1=550, R2=5k, R3=50, BPF:400-20kHz 1 THD + N 0.1 0.01 0.001 0.0001 0.00001 0.001 Ver.4.2 0.01 0.1 1 10 Output Voltage [Vrms] 100 http://www.njr.com/ -7- MUSES03 ■PACKAGE OUTLINE DIP8(MUSES) Ver.4.2 http://www.njr.com/ -8- MUSES03 ■PACKING SPECIFICATION Plastic Tube Container Dimensions DIP8(MUSES) packages are packed in the plastic tube container. The dimensions are mentioned as follows. Plastic Tube Container dimensions for DIP8(MUSES) Symbol DIP8 H L W Material 10.6mm 110mm 13.2mm PS Carbon Stopper Rubber Knob Contents L (Carbon tube) W H 10pcs Put in the outer box Air packing New Japan Radio Co.,Ltd New Japan Radio Co.,Ltd Label Side cover Insert into the outer box Ver.4.2 http://www.njr.com/ -9- MUSES03 ■RECOMMENDED MOUNTING METHOD FLOW SOLDERING METHOD *flow soldering procedure 260°C 120°C 80°C Room Temp. a b a:Temperature ramping rate b:Pre-heating temperature b:Pre-heating time c:Peak temperature d:Peak time d:Temperature ramping rate c d : 1 to 7°C /s : 80 to 120°C : 60 to 120s : not exceeding 260°C : within 10s : 1 to 7°C /s The temperature indicates at the surface of mold package. IRON SOLDERING METHOD *Iron Soldering conditions Temperature of Iron: not exceeding 350°C Soldering time: within 3s ( At 1 lead) ■PRECAUTION FOR COUNTERFEIT SEMICONDUCTOR PRODUCTS We have recently detected many counterfeit semiconductor products that have very similar appearances to our operational amplifier “MUSES” in the world-wide market.In most cases, it is hard to distinguish them from our regular products by their appearance, and some of them have very poor quality and performance. They can not provide equivalent quality of our regular product, and they may cause breakdowns or malfunctions if used in yoursystems or applications. We would like our customers to purchase “MUSES” through our official sales channels : our sales branches, sales subsidiaries and distributors. Please note that we hold no responsibilities for any malfunctions or damages caused by using counterfeit products. We would appreciate your understanding. Ver.4.2 http://www.njr.com/ - 10 - MUSES03 [ CAUTION ] 1. New JRC strives to produce reliable and high quality semiconductors. New JRC's semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of New JRC's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. All other trademarks mentioned herein are property of their respective companies. 3. To ensure the highest levels of reliability, New JRC products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. New JRC offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact New JRC's Sale's Office if you are uncertain about the products listed in this catalog. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in the catalog may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment. Aerospace Equipment Equipment Used in the Deep sea Power Generator Control Equipment (Nuclear, Steam, Hydraulic) Life Maintenance Medical Equipment Fire Alarm/Intruder Detector Vehicle Control Equipment (airplane, railroad, ship, etc.) Various Safety devices 7. New JRC's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this catalog. Failure to employ New JRC products in the proper applications can lead to deterioration, destruction or failure of the products. New JRC shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of its products. Products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. 8. Warning for handling Gallium and Arsenic(GaAs) Products (Applying to GaAs MMIC, Photo Reflector). This Products uses Gallium(Ga) and Arsenic(As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed, please follow the related regulation and do not mix this with general industrial waste or household waste. 9. The product specifications and descriptions listed in this catalog are subject to change at any time, without notice. Ver.4.2 http://www.njr.com/ - 11 -
MUSES03 价格&库存
很抱歉,暂时无法提供与“MUSES03”相匹配的价格&库存,您可以联系我们找货
