P1J-12.5MB-AX16PA
P1J-12.5MB-AX16PA
    SENSATA(森萨塔)
    DIP8
    SENSOR PRESS 0-12.5 MBAR I2C
P1J-12.5MB-AX16PA 数据手册
| P1J Pressure Sensor Description The P1J series of pressure sensors incorporates a piezo-resistive sensing element in a compact package. Using a 2.7 to 5.5 VDC supply voltage, the P1J provides a SPI or I2C digital output as required by your application. Internal temperature compensation provides and accurate, easy to use sensor. The industry standard terminal pins provides ease of use for your printed circuit board designs. Features • Compact Package • Amplified Temperature Compensated Digital Output • No Position Sensitivity above 0-2”H2O • EMI/RFI and ESD Protected • Superior Output Signal Stability • Printed Circuit Board through Hole Mounting Applications • Variable Air Volume Systems • Filter Pressure Monitoring • Duct Air Flow • Modulated Furnace Controls • Combustion Airflow • Gaseous Leak Detection • Medical Applications: Oxygen Concentrators, Ventilators, Anesthesia Equipment, CPAP, Wound Therapy. MAIN FEATURES Pressure Ranges 2, 5, 10, +/-2, +/- 5, +/- 10 inches of water; 5, 12.5, 25, +/- 5, +/- 6, +/- 12.5, +/- 25 mbar Electrical Connection PCB thru hole terminal pins, 2.54 mm [.100 inch] pitch Pressure Connection Barbed port, 1.9[.08] diameter Housing Material PPS, 40% glass filled, black Terminal Pin Material Phosphor bronze, tin plated Supply Voltage 2.7 to 5.5 VDC Output Signal 14 Bit Digital Output Count – Digital count at null (0% FS): 1638 Digital count at full scale (100% FS) 14745 Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com TECHNICAL SPECIFICATIONS Pressure Ranges from 0 to... 2” H2O 5” H2O 10” H2O +/- 2” mBar +/- 5” mBar from 0 to... 5mbar 12.5mbar 20mbar +/- 5mbar +/- 12.5 mbar Proof Pressure Factor 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) 1.0 PSI/ (70mbar) Burst Pressure Factor 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) 1.8 PSI/ (125mbar) Physical Expected Operating Life 10 million full pressure life cycles Shelf Life 10 years minimum Stability +/- 0.5% of full scale span for 1 year Vibration 10 G’s peak to peak sinusoidal (20 to 1600Hz) Shock Resistance Weight 50 G’s ½ Sinewave, 11 mSec pulse, 18 pulses (6 per axis) 3.5g max. Operating Temperature -20°C to 85°C Storage Temperature -40°C to 85°C Humidity Media Up to 92% RH in a non-condensing environment Dry air Performance Accuracy 0.25% Max (% of full scale span) (RSS of linearity, hysteresis and repeatability) Temp. Error 0.05%/ C [% of full scale span] Temp. Error 5% full scale span within temperature range -20° to 0°C and 60° to 85°C 0 to 60°C Electrical Input Voltage Protection Excitation Current -0.3 to 6 VDC on Vin PIN, -0.3 to Vs+0.3 on all other pins < 2.5mA Minimum Load 25k Ohms between output and ground Response Time 0.5 ms Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com DIMENSIONS Dimensions in mm [Inch] Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com I2C COMMUNICATION Acknowledge (ACK) Output Signal Resolution 12 Bits (11 bits minimum for 0-2” H2O and 0-5 mBar range) Update Rate 0.5 ms Digital Count at 0% Pressure Digital Count at 100% Pressure Sensor Slave Addresses 1638 (10% of 2^14 counts or 0x666) 14745 (90% of 2^14 counts or 0x3999) 40 (0x28), 56 (0x38), 72 (0x48), 88 (0x58), 104 (0x68), 120 (0x78) SYMBOL MIN MAX UNITS Analog Supply Voltage to Gnd VDD 2.7 5.5 V High-level input voltage VIH 0.8 × VDD VDD V Low-level input voltage VIL 0 0.2 × VDD V High-level output voltage VOH VDD - 0.2 - V Low-level output voltage VOL - 0.2 V Output Sourcing Current IOH_SDA -1.9 -4.8 mA Output Sink Current IOL_SDA 2.3 6.2 mA 200 pF PARAMETER Load Capacitance at SDA (@ 400 kHz) CSDA Pull-up Resistor RI2C_PU Input Capacitance (each pin) CI2C_IN Ω 500 10 pF fSCL 100 400 kHz tHDSTA 0.1 - µs Minimum SCL clock low width 1) tLOW 0.6 µs Minimum SCL clock high width 1) tHIGH 0.6 µs Start condition setup time relative to SCL edge tSUSTA 0.1 µs Data hold time on SDA relative to SCL edge tHDDAT 0 µs Data setup time on SDA relative to SCL edge tSUDAT 0.1 µs Stop condition setup time on SCL tSUSTO 0.1 µs tBUS 2 µs SCL clock frequency START condition hold time relative to SCL range Bus free time between stop condition and start condition 1) Combined low and high widths must equal or exceed minimum SCLK period. Page 4 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com I2C TIMING DIAGRAM Note There are three adjustments to the I2C implementation compared with the original I2C™ protocol: • Sending a start-stop condition without any transitions on the CLK line (no clock pulses in between) creates a communication error for the next communication, even if the next start condition is correct and the clock pulse is applied. An additional start condition must be sent, which results in restoration of proper communication. • The restart condition—a falling SDA edge during data transmission when the CLK clock line is still high—creates the same situation. The next communication fails, and an additional start condition must be sent for correct communication. • A falling SDA edge is not allowed between the start condition and the first rising SCL edge. If using an I2C™ address with the first bit 0, SDA must be held low from the start condition through the first bit. Page 5 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com SPI COMMUNICATION Output Packet with Positive Edge Sampling Packet = [ {S(1:0), B(13:8)}, {B(7:0)}, {T(10:3)}, {T(2:0),xxxxx}] Where S(1:0) = Status bits of packet (normal, command, busy, diagnostic) B(13:8) = Upper 6 bits of 14-bit bridge data B(7:0) = Lower 8 bits of 14-bit bridge data T(10:0) = NOT corrected temperature data (mask out or terminate read early) Output Signal Resolution 12 Bits (11 bits minimum for 0-2” H2O and 0-5 mBar range) Update Rate 0.5 ms Digital Count at 0% Pressure Digital Count at 100% Pressure 1638 (10% of 214 counts or 0x666) 14746 (90% of 214 counts or 0x3999) SYMBOL MIN MAX UNITS Analog Supply Voltage to Gnd VDD 2.7 5.5 V High-Level Input Voltage VIH 0.8 × VDD VDD V Low-Level Input Voltage VIL 0 0.2 × VDD V High-Level Output Voltage VOH VDD - 0.2 - V Low-Level Output Voltage VOL - 0.2 V IOH_MISO 1.9 -4.8 mA IOH_SS -0.63 -1.9 mA IOL_MISO 2.3 6.2 mA IOL_SS 0.85 3.0 mA 10 pF PARAMETER Output Sourcing Current @ VOH Output Sink Current @ VOL Input Capacitance (Each Pin) CI2C_IN SCLK Clock Frequency (4 MHz clock) fSCL 50 800 kHz SCLK Clock Frequency (1 MHz clock) tSCL 50 200 kHz SS Drop to First Clock Edge tHDSS 2.5 µs Minimum SCL Clock Low Width 1) tLOW 0.6 µs Minimum SCL Clock High Width 1) tHIGH 0.6 µs Clock Edge to Data Transition tCLKD 0 Rise of SS Relative to Last Clock Edge tSUSS 0.1 µs Bus Free Time Between Rise and Fall of SS tBUS 2 µs 0.1 µs 1) Combined low and high widths must equal or exceed minimum SCLK period. Page 6 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com SPI TIMING DIAGRAM Note The MISO line is setup to change state on the falling edge of the SCLK clock. Accordingly, the master should sample the data on the rising edge of the SCLK signal. I2C/SPI DIAGNOSTIC FEATURES The P1J offers a full suite of diagnostic features to ensure robust system operation. The diagnostic states are indicated by a transmission of the status of the 2 MSBs of the bridge high byte data or by a saturated output at 3FFFH. STATUS BITS (2 MSB’S OF OUTPUT PACKAGE) Signal resolution Update rate Digital count at 0% pressure Digital count at 100% pressure DEFINITION 12 Bits (11 bits minimum for 0-2” H2O and 0-5 mBar range) 0.5 ms 1638 (10% of 214 counts or 0x666) 14746 (90% of 214 counts or 0x3999) When the two MSBs are 11, one of the following faults listed below is indicated. • Invalid EEPROM signature • Loss of bridge positive or negative • Bridge input short • Loss of bridge source • Loss of bridge sink All diagnostics are detected in the next measurement cycle and reported in the subsequent data fetch. Once a diagnostic is reported, the diagnostic status bits will not change unless both the cause of the diagnostic is fixed and a power-on-reset is performed. Page 7 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com Example : P1J-2-AX16PA ORDERING OPTIONS P1J Pressure sensor 0 -1” H20, I2C 28 Hex digital output, no internal material seal, barbed tube fitting port with PCB Terminal Pin connection, no external material seal. P1J Family 2 A X 16 P A P1J Pressure Ranges 2: 2B: 5: 5B: 10: 10B: 5MB: 5MBB: 6MBB: 12.5MB: 12.5MBB: 25MB: 25MBB 0-2” H2O +/- 2” H2O 0-5” H2O +/- 5” H2O 0-10” H2O +/- 10” H2O 0-5 mbar +/- 5 mbar +/- 6 mbar 0-12.5 mbar +/-12.5 mbar 0-25 mbar +/- 25 mbar Output Type 8: SPI A: l2C, 28 HEX B: l2C, 38 HEX C: l2C, 48 HEX D: l2C, 58 HEX E: l2C, 68 HEX F: l2C, 78 HEX Seal Material X: None Pressure Connection 16: Barb or Tube Fitting Built-in Connector P: PCB Terminal Pins Seal Material A: None Page 8 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com AGENCY APPROVALS & CERTIFICATIONS Page 9 Revised 2/16/18 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. CONTACT US Americas +1 (800) 350 2727 sensors@sensata.com switches@sensata.com Europe, Middle East & Africa +359 (2) 809 1826 pressure-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
P1J-12.5MB-AX16PA 价格&库存
很抱歉,暂时无法提供与“P1J-12.5MB-AX16PA”相匹配的价格&库存,您可以联系我们找货
