UM3243EEUS
UM3243EEUS
    UNION(英联)
    TSSOP-28
    UM3243系列是3驱动器/5接收器的3V - 5.5V供电RS - 232收发器,具有自动断电和低电源电流特性。当任何接收器输入未检测到有效的RS - 232电平信号时,电荷泵电路和驱动器将断电。断...
UM3243EEUS 数据手册
UM3243 Low Supply Current, 3V to 5.5V, 250kbps, 3-Driver/5-Receiver, Enhanced ESD Protection Smart RS-232 Transceivers UM3243EEAS/UM3243EEASR/ UM3243EEUS/UM3243EESS/UM3243EEQA General Description The UM3243 series are 3-driver/5-receiver 3V-5.5V powered RS-232 transceivers featuring Auto Power-Off and low supply current, when no valid RS-232 level signal is sensed on any receiver inputs, the charge pump circuit and drivers will be powered off. Disconnection of the RS-232 cable or poweroff of the transmitters of the attaching peripherals will lead to Power-Off mode. When a valid level is applied to any RS-232 receiver inputs, the chip will turn on again. The Auto Power-Off mode helps to save power without changing the existing system. The UM3243 transceivers have a regulated discontinuous mode dual charge pump power supply and low-dropout transmitters, which combine to deliver true RS-232 performance from a single +3V to +5.5V supply. Data rate of 250kbps is guaranteed. The UM3243 needs only four 0.1μF capacitors in 3.3V operation, and can operate from input voltages ranging from +2.7V to +5.5V. They are ideal for 3.3V-only systems, mixed 3.3V and 5.0V systems, or 5.0V-only systems that require true RS-232 performance or EIA/TIA-562 levels of ±3.7V with supply voltages as low as 2.7V. The UM3243 includes one complementary always-active receiver. This receiver can monitor an external device (such as a modem) in Power-Off. The UM3243 also includes an always-active _________________ INVALID output which indicates valid RS-232 signal levels on any receiver inputs. It is usually used in UART wakeup. The UM3243 also features enhanced ESD protection with ±15kV for human body mode and ±8kV for IEC61000-4-2 contact discharge mode. Applications z z z z z Industrial Controllers and Instruments Notebooks, Palmtop PCs and Laptops Networking Routers and Switches Peripherals Printers, PDAs and POS Features z z z z z z z z z Meets True EIA/TIA-232-F Standards from a +3.0V to +5.5V Power Supply Meets EIA/TIA-562 Levels of ±3.7V with Supply Voltages as Low as 2.7V Auto Power-Off Feature to Disable Driver Outputs when No Valid RS-232 Signal is Sensed 250kbps Minimum Transmission Rate 0.1μA (Typ) Low Power-Off Current Accepts 5V Logic Input with 3.3V Supply Latch-Up Performance Exceeds 200mA Enhanced ESD Specifications for RS-232 Pins: ±15kV Human Body Mode ±8kV IEC61000-4-2 Contact Discharge Mode Available in SSOP28, TSSOP28, SOP28 and QFN32 Packages http://www.union-ic.com Rev.03 Jan.2018 1/24 UM3243 Pin Configurations Top View XX: Week Code UM3243EEAS/UM3243EEASR SSOP28 XX: Week Code UM3243EEUS TSSOP28 SSOP28/TSSOP28/SOP28 XX: Week Code UM3243EESS SOP28 http://www.union-ic.com Rev.03 Jan.2018 2/24 VCC V+ C1+ NC XX: Week Code UM3243EEQA QFN32 5.0×5.0 NC ROUT3 ROUT4 C2+ TIN1 ROUT5 V- C2TIN2 NC TIN3 NC UM3243 QFN32 5.0×5.0 Pin Description Pin No. UM3243EEAS/EEASR/ EEUS/EESS UM3243EEQA Pin Name 1 29 C2+ 2 30 C2- 3 4-8 9, 10, 11 12, 13, 14 15-19 31 1-5 6, 7, 8 10, 11, 12 13, 14, 15, 17, 18 VRIN_ TOUT_ TIN_ ROUT_ 20 19 ROUT2B 21 20 22 21 FORCEOFF 23 22 FORCEON 24 23 C1- 25 26 27 24 26 27 GND VCC V+ 28 28 C1+ - 9, 16, 25, 32 NC _______________ INVALID __________________ http://www.union-ic.com Rev.03 Jan.2018 Function Positive Terminal of Inverting Charge-Pump Capacitor Negative Terminal of Inverting Charge-Pump Capacitor Negative Voltage Generated by the Charge Pump RS-232 Receiver Inputs RS-232 Transmitter Outputs TTL/CMOS Transmitter Inputs TTL/CMOS Receiver Outputs Non-Inverting Receiver Output—active in Power-Off _______________ Output of the Valid Signal Detector. INVALID is enabled high if a valid RS-232 level is present on any receiver inputs. Drive low to shut down transmitters and on-board power supply. This overrides all Automatic circuitry and FORCEON (See Function Tables). Drive high to override automatic circuitry keeping __________________ transmitters on (FORCEOFF must be high) (See Function Tables). Negative Terminal of the Voltage Doubler Charge-Pump Capacitor Ground +3.0V to +5.5V Supply Voltage Positive Voltage Generated by the Charge Pump Positive Terminal of the Voltage Doubler Charge-Pump Capacitor Not connected. 3/24 UM3243 Ordering Information Part Number Temp. Range Package Type Shipping Qty UM3243EEAS -40°C to +85°C SSOP28 UM3243EEASR -40°C to +85°C SSOP28 UM3243EEUS -40°C to +85°C TSSOP28 48pcs/Tube 2000pcs/13Inch Tape & Reel 3000pcs/13Inch Tape & Reel UM3243EESS -40°C to +85°C SOP28 UM3243EEQA -40°C to +85°C QFN32 5.0×5.0 25pcs/Tube 3000pcs/13Inch Tape & Reel Absolute Maximum Ratings (Note 1) Symbol Parameter Value Unit VCC Supply Voltage on VCC -0.3 to +6 V V+ Voltage on V+ (VCC-0.3) to +7.5 V V- Voltage on V- -7.5 to +0.3 V -0.3 to +6V V Voltage on ROUT_, INVALID, ROUT2B -0.3 to (VCC+0.3) V Voltage on RIN_ ±30 V Voltage on TOUT_ (V--0.3) to (V++0.3) V Short-Circuit Duration, TOUT_ to GND Continuous _____________________ Voltage on TIN_, FORCEOFF, FORCEON _________________ PD Continuous Power Dissipation at TA=70°C SSOP28 762 TSSOP28 696 SOP28 1000 QFN32 1500 mW TA Operating Temperature Range -40 to +85 °C TSTG Storage Temperature Range Maximum Lead Temperature for Soldering 10 Seconds -65 to +165 °C +300 °C TL Note 1: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. http://www.union-ic.com Rev.03 Jan.2018 4/24 UM3243 Electrical Characteristics (VCC=+3.0V to +5.5V, C1- C4=0.1μF, TA=TMIN to TMAX, unless otherwise noted. Typical values are at TA=25°C) Parameter Symbol Conditions Min Typ Max Unit VCC=3.3V 3.0 3.3 3.6 VCC=5.0V All RIN_ Open, FORCEON=GND, _____________________ FORCEOFF=VCC 4.5 5.0 5.5 0.1 10 μA 0.1 10 μA 0.6 1.0 mA 0.8 V DC CHARACTERISTICS (VCC=+3.3V or +5V, TA=25°C) Supply Voltage Supply Current, Auto Power-Off Supply Current, Forced Power-Off ICC FORCEOFF=GND _____________________ FORCEON=FORCEOFF=VCC, Other Input NC, All Outputs with No Load Supply Current, Normal LOGIC INPUTS Input Logic Threshold Low _____________________ TIN_, FORCEON, FORCEOFF TIN_, FORCEON, FORCEOFF Input Logic Threshold High Input Hysteresis _____________________ _____________________ VCC=3.3V 2.0 VCC=5.0V 2.4 Vhys IIL V 0.2 _____________________ Input Leakage Current V V FORCEON, FORCEOFF ±0.01 ±1.0 μA Transmitter Disabled ±0.01 ±1.0 μA Transmitter Enabled ±1 ±5 μA 0.4 V TIN_ LOGIC OUTPUTS Output Voltage Low VOL Output Voltage High VOH Output Leakage Current IOL _________________ INVALID, ROUT2B, ROUT_ ROUT_ http://www.union-ic.com Rev.03 Jan.2018 IOL=1.6mA IOH=-1.0mA Receivers Disabled, Connected to VCC or GND VCC-0.6 VCC-0.1 ±0.05 V ±10 μA 5/24 UM3243 Electrical Characteristics (Continued) (VCC=+3.0V to +5.5V, C1- C4=0.1μF, TA=TMIN to TMAX, unless otherwise noted. Typical values are at TA=25°C) Parameter Symbol Conditions Min Typ Max Unit 30 V RECEIVER INPUTS Input Voltage Range -30 Input Threshold Low RIN_ Input Threshold High Input Hysteresis Vhys Input Resistance Ri VCC=3.3V 0.8 1.15 VCC=5.0V 0.8 1.55 V VCC=3.3V 1.35 2 VCC=5.0V 1.75 2 0.2 TA=+25°C 3 5 ±5.0 ±5.4 V V 7 kΩ TRANSMITTER OUTPUTS Output Voltage Swing VOUT Output Short-Circuit Current IOS Output Leakage Current IOL All Transmitter Outputs Loaded with 3kΩ to Ground Short to VCC , VCC=3.3V GND or Other VCC=5.0V TXD Pin Transmitter Disabled, Connected to V+ or V- http://www.union-ic.com Rev.03 Jan.2018 V ±20 ±40 mA ±30 ±50 mA ±1 ±10 μA 6/24 UM3243 Electrical Characteristics (Continued) (VCC=+3.0V to +5.5V, C1- C4=0.1μF, TA=TMIN to TMAX, unless otherwise noted. Typical values are at TA=25°C) Parameter Symbol Conditions Min Typ Max Unit TIMING CHARACTERISTICS Maximum Data Rate Receiver Propagation Delay Receiver Skew Receiver Output Enable Time Receiver Output Disable Time tPLH, tPHL RL=3kΩ to 7kΩ, CL=50pF to 1000pF, One Transmitter Switching All Parts, CL=150pF Normal Figure 4 Operation kbps 0.15 μs |tPHL-tPLH| tEN tDIS Transmitter Propagation Delay tPLH, tPHL Transmitter Skew |tPHL-tPLH| CL=150pF, RL=3kΩ Figure 5 RL=3kΩ, CL=2500pF, All Transmitters Loaded Figure 3 TA=+25°C, VCC=3.3V, RL=3kΩ to 7kΩ, Transition-Region CL=50pF to 1000pF, SR(tr) Slew Rate Measured from -3V to +3V or +3V to -3V, Figure 2 ESD AND LATCH UP PERFORMANCE RIN_, TOUT_ ESD-Protection Voltage Other Pins ESD-Protection Voltage Latch Up Performance 250 0.1 μs 0.2 μs 0.2 μs 1.3 5 15 μs 0.25 μs 30 V/μs Human Body Model IEC61000-4-2, Contact Discharge ±15 Human Body Model ±2 kV JEDEC Standard No.78D ±200 mA http://www.union-ic.com Rev.03 Jan.2018 ±8 kV 7/24 UM3243 Auto Power-Off Electrical Characteristics Over recommended ranges noted) (Figure 6) Parameter Receiver Input_______________ Positive Threshold to INVALID Output High Receiver Input _______________ Negative Threshold to INVALID Output High Receiver Input Threshold _________________ to INVALID Output Low Receiver Positive or Negative Threshold to _________________ INVALID High Receiver Positive or Negative Threshold to _________________ INVALID Low Receiver Edge to Charge Pump Setup of supply voltage and operating free-air temperature (unless otherwise Symbol Test Conditions VIT+(valid) FORCEON=GND, ___________________ FORCEOFF=VCC VIT-(valid) FORCEON=GND, ___________________ FORCEOFF=VCC -2.7 VT(invalid) FORCEON=GND, ___________________ FORCEOFF=VCC -0.3 tvalid tinvalid ten http://www.union-ic.com Rev.03 Jan.2018 FORCEON=GND, ___________________ FORCEOFF=VCC, VCC=5V, Figure 6 FORCEON=GND, ___________________ FORCEOFF=VCC, VCC=5V, Figure 6 FORCEON=GND, ___________________ FORCEOFF=VCC, VCC=5V, Figure 6 Min Typ Max Unit 2.7 V V 0.3 V 1 μs 30 μs 150 μs 8/24 UM3243 Typical Operating Characteristics (VCC=+3.3V, 0.47μF capacitors, all transmitters loaded with 3kΩ and CL, TA=25°C, unless otherwise noted.) V+, V- vs. Supply Voltage 8 6 6 4 4 2 VOUT+ Transmitting at 250kbps CL=1000pF 0 V+, V- (V) Transmitter Output Voltage (V) Transmitter Output Voltage vs. Supply Voltage 8 VOUT- 2 -2 -2 -4 -4 -6 -6 -8 Transmitting at 250kbps CL=1000pF 0 V+ V- -8 2.4 2.9 3.4 3.9 Supply Voltage (V) 4.4 4.9 2.4 5.4 2.9 3.4 3.9 4.4 4.9 5.4 Supply Voltage (V) Supply Current vs. Supply Voltage Transmitter Output Voltage vs. Load Capacitance 35 8 Transmitter Output Voltage (V) 6 Supply Current (mA) 30 25 Transmitting at 250kbps CL=1000pF 20 4 2 VOUT+ 0 VOUT- Transmitting at 20kbps -2 -4 -6 -8 15 2.4 2.9 3.4 3.9 Supply Voltage (V) 4.4 4.9 0 5.4 500 1000 1500 2000 Load Capacitance (pF) 2500 3000 Supply Current vs. Load Capacitance Slew Rate vs. Load Capacitance 50 26 45 24 22 Transmitting at 20kbps 35 Supply Current (mA) Slew Rate (V/μs) 40 30 +Slew 25 -Slew 20 15 10 20K 20 120K 18 250K 16 14 12 5 10 0 0 500 1000 1500 2000 Load Capacitance (pF) 2500 http://www.union-ic.com Rev.03 Jan.2018 3000 0 500 1000 1500 2000 Load Capacitance (pF) 2500 3000 9/24 UM3243 Typical Operating Characteristics (Continued) (VCC=+3.3V, 250kbps data rate, 0.47μF capacitors, all transmitters loaded with 5kΩ and CL, TA=25°C, unless otherwise noted.) V+, V- vs. Supply Voltage 8 6 6 4 4 2 Transmitting at 250kbps CL=1000pF 0 V+, V- (V) Transmitter Output Voltage (V) Transmitter Output Voltage vs. Supply Voltage 8 VOUT+ VOUT- 2 Transmitting at 250kbps CL=1000pF 0 -2 -2 -4 -4 -6 -6 V+ V- -8 -8 2.4 2.9 3.4 3.9 Supply Voltage (V) 4.4 4.9 http://www.union-ic.com Rev.03 Jan.2018 5.4 2.4 2.9 3.4 3.9 4.4 Supply Voltage (V) 4.9 5.4 10/24 UM3243 Function Tables Table 1. Each Transmitter (Note 2) INPUTS OUTPUT VALID RIN RS-232 TOUT LEVEL X X L X Z L H H X H H H H X L L L H Yes H H L H Yes L X L H No Z Note 2: H=high level, L=low level, X=irrelevant, Z=high impedance _________________________ TIN FORCEON FORCEOFF TRANSMITTER STATUS Forced Power-Off Normal Operation with Forced Power-On Normal Operation with Auto Power-On Auto Power-Off Table 2. Each Receiver (Note 3) RIN X L H Open INPUTS FORCEON X X X X _________________________ FORCEOFF L H H H OUTPUT ROUT Z H L H RECEIVER STATUS Forced Power-Off Normal Operation ________________ Table 3. ROUT2B and Outputs INVALID (Note 3) INPUTS OUTPUTS OUTPUT VALID RIN _________________________ ___________________ STATUS RS-232 RIN2 FORCEON FORCEOFF INVALID ROUT2B LEVEL Yes L X X H L Yes H X X H H Always Active Yes Open X X H L No Open X X L L Note 3: H=high level, L=low level, X=irrelevant, Z=high impedance (off), Open=input disconnected or connected driver off http://www.union-ic.com Rev.03 Jan.2018 11/24 UM3243 Logic Diagram Figure 1 http://www.union-ic.com Rev.03 Jan.2018 12/24 UM3243 Parameter Measurement Information SR(tr ) = 6V tTHL or tTLH Figure 2. Transmitter Slew Rate Figure 3. Transmitter Pulse Skew Figure 4. Receiver Propagation Delay Times Figure 5. Receiver Enable and Disable Times http://www.union-ic.com Rev.03 Jan.2018 13/24 UM3243 __________________ Figure 6. INVALID Propagation Delay Times and Supply Enabling Time http://www.union-ic.com Rev.03 Jan.2018 14/24 UM3243 Typical Operating Circuits Figure 7 Application Information RS-232 Receivers The UM3243’s receivers convert RS-232 signals to CMOS-logic output levels. All receivers have inverting three-state outputs and can be active or inactive. The UM3243’s receivers are _____________________ high-impedance when the part is in Forced Power-Off mode (FORCEOFF=low). The UM3243 features an always-active complementary output (ROUT2B). ROUT2B monitors receiver activity while the other receivers are high-impedance. This allows Ring Indicator to be monitored without forward biasing other devices connected to the receiver outputs. This is ideal for systems where VCC drops to_________________ 0 in Power-Off to accommodate peripherals such as UARTs (Figure 8). The UM3243 features an INVALID output that is enabled low when no valid RS-232 signal levels _________________ have been detected on all receiver inputs. INVALID is functional in any mode (Figure 6). http://www.union-ic.com Rev.03 Jan.2018 15/24 UM3243 Figure 8. The UM3243 detects RS-232 activity when the UART and interface are powered off. Auto Power-Off and Wakeup The UM3243 achieves _____________________ a 0.1μA supply current Auto Power-Off feature, which operates when FORCEON is low and FORCEOFF is high. When the device senses no valid signal levels on all receiver inputs for tinvalid time (typically 30μs), the onboard charge pump and drivers are powered off, reducing supply current to 0.1μA. This occurs if the RS-232 cable is disconnected or the connected peripheral transmitters are turned off. The device turns on again when a valid level is applied to any RS-232 receiver input for tvalid time (typically 1μs). The charge pump will set up after ten time (typically 150μs). As a result, the system saves power without changes to the existing system. _____________________ Table 3 and Figure 9 summarize the UM3243 operating modes. FORCEON and FORCEOFF override Auto Power-Off. When neither control is asserted, the IC will select between these states automatically, based on receiver input levels. Figure 6 depicts valid and invalid RS-232 receiver levels and timing diagram for Auto Power-Off operation. Figure 9. UM3243 Auto Power-Off Logic http://www.union-ic.com Rev.03 Jan.2018 16/24 UM3243 RS-232 Transmitters The transmitters are inverting level translators that convert CMOS-logic levels to EIA/TIA-232 levels. They guarantee a 250kbps data rate with worst-case loads of 3kΩ in parallel with 1000pF, providing compatibility with PC-to-PC communication software. Transmitters can be paralleled to drive multiple receivers. In Power-Off mode (See Table 1), the transmitters are disabled and the outputs are forced into a high-impedance state. Dual Charge Pump Voltage Converter and Capacitor Selection The UM3243’s internal power supply consists of a regulated dual charge pump that provides output voltages of +6V (doubling charge pump) and -6V (inverting charge pump), over the +3.0V to +5.5V VCC range. The charge pump operates in discontinuous mode: if the output voltage is less than 6V, the charge pump is enabled; if the output voltage exceeds 6V, the charge pump is disabled. The charge pump requires a flying capacitor (C1, C2) and a reservoir capacitor (C3, C4) to generate the V+ and V- supplies. The capacitor type used for C1–C4 is not critical for proper operation; either polarized or non-polarized capacitors may be used. The charge pump requires 0.1μF capacitors for 3.3V operation. For other supply voltages, refer to Table 4 for required capacitor values. Do not use values smaller than those listed in Table 4. Increasing the capacitor values (e.g., by a factor of 2) reduces ripple on the transmitter outputs and slightly reduces power consumption. When using the minimum required capacitor values, make sure the capacitor value does not degrade excessively with temperature. If in doubt, use capacitors with a larger nominal value. The capacitor’s equivalent series resistance (ESR) usually rises at low temperatures and influences the amount of ripple on V+ and V-. Table 4. Required Capacitor Values VCC (V) 3.15 to 3.6 4.5 to 5.5 3.0 to 5.5 2.4 to 3.0 C1, C2, C3, C4 (μF) 0.1 0.1 0.47 0.47 High Data Rates The UM3243 maintains the RS-232 ±5.0V minimum transmitter output voltage even at high data rates. Figure 10 shows a transmitter loopback test circuit. Figure 11 shows a loopback test result at 120kbps, and Figure 12 shows the same test at 250kbps. For Figure 11, all three transmitters were driven simultaneously at 120kbps into RS-232 loads in parallel with 1000pF. For Figure 12, a single transmitter was driven at 250kbps, and all three transmitters were loaded with an RS-232 receiver in parallel with 1000pF. http://www.union-ic.com Rev.03 Jan.2018 17/24 UM3243 Figure 10. Loopback Test Circuit 5V/div TIN1 5V/div TOUT1 ROUT1 5V/div 2µs/div Figure 11. Loopback Test Result at 120kbps Figure 12. Loopback Test Result at 250kbps http://www.union-ic.com Rev.03 Jan.2018 18/24 UM3243 Package Information UM3243EEAS: SSOP28 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.65 1.75 1.85 0.065 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 9.90 10.20 10.50 0.390 0.402 0.413 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 0.75 0.95 0.022 0.030 0.037 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 10.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.03 Jan.2018 19/24 UM3243 UM3243EEASR: SSOP28 Outline Drawing Symbol A A1 A2 b c D E E1 e L θ DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 2.00 0.079 0.05 0.002 1.65 1.75 1.85 0.065 0.069 0.073 0.22 0.30 0.38 0.009 0.012 0.015 0.09 0.17 0.25 0.004 0.007 0.010 9.90 10.20 10.50 0.390 0.402 0.413 5.00 5.30 5.60 0.197 0.209 0.220 7.40 7.80 8.20 0.291 0.307 0.323 0.65BSC 0.026BSC 0.55 0.75 0.95 0.022 0.030 0.037 0° 8° 0° 8° Land Pattern NOTES: 1. Compound dimension: 10.20×5.30; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.03 Jan.2018 20/24 UM3243 UM3243EEUS: TSSOP28 Outline Drawing Symbo l A A1 A2 A3 b c D E E1 e L L1 L2 θ1 θ2 θ3 DIMENSIONS MILLIMETERS INCHES Min Typ Max Min Typ Max 1.20 0.047 0.05 0.15 0.002 0.006 0.80 1.05 0.031 0.041 0.34 0.44 0.54 0.013 0.017 0.021 0.19 0.30 0.007 0.012 0.09 0.20 0.004 0.008 9.60 9.70 9.80 0.378 0.382 0.386 4.30 4.40 4.50 0.169 0.173 0.177 6.20 6.40 6.60 0.244 0.252 0.260 0.65BSC 0.026BSC 0.45 0.60 0.75 0.018 0.024 0.030 1.00REF 0.039REF 0.25BSC 0.010BSC 0° 8° 0° 8° 10° 12° 14° 10° 12° 14° 10° 12° 14° 10° 12° 14° Land Pattern NOTES: 1. Compound dimension: 9.70×4.40; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.03 Jan.2018 21/24 UM3243 UM3243EESS: SOP28 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 2.35 2.55 2.80 0.093 0.100 0.110 A1 0.10 0.20 0.30 0.004 0.008 0.012 A2 2.25 - 2.65 0.089 - 0.104 b 0.33 - 0.54 0.013 - 0.021 c 0.15 - 0.33 0.006 - 0.013 D 17.40 - 18.10 0.685 - 0.713 E 7.40 7.55 7.70 0.291 0.297 0.303 E1 10.20 10.40 10.61 0.402 0.409 0.418 e 1.27BSC 0.050BSC L 0.40 - 1.27 0.016 - 0.050 θ 0° - 8° 0° - 8° Land Pattern NOTES: 1. Compound dimension: 17.75×7.55; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. http://www.union-ic.com Rev.03 Jan.2018 22/24 UM3243 UM3243EEQA: QFN32 5.0×5.0 Outline Drawing DIMENSIONS Symbol MILLIMETERS INCHES Min Typ Max Min Typ Max A 0.70 0.75 0.80 0.028 0.030 0.031 A1 0.00 0.02 0.05 0.000 0.0008 0.002 A3 0.20REF 0.008REF b 0.20 0.25 0.30 0.008 0.010 0.012 D 4.90 5.00 5.10 0.193 0.197 0.201 D2 3.30 - 3.60 0.130 - 0.142 E 4.90 5.00 5.10 0.193 0.197 0.201 E2 3.30 - 3.60 0.130 - 0.142 e 0.50TYP 0.020TYP k 0.20 - - 0.008 - - L 0.324 0.40 0.476 0.013 0.016 0.019 Land Pattern NOTES: 1. Compound dimension: 5.00×5.00; 2. Unit: mm; 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation http://www.union-ic.com Rev.03 Jan.2018 23/24 UM3243 GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No.570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com http://www.union-ic.com Rev.03 Jan.2018 24/24
