NJU7043RB1-TE1
NJU7043RB1-TE1
    JRC(⽇本无线)
    VSSOP8
    IC CMOS 2 CIRCUIT 8TVSP
NJU7043RB1-TE1 数据手册
NJU7043 High Output Current, Rail-to-Rail Input/Output Dual CMOS Operational Amplifier ■GENERAL DESCRIPTION ■PACKAGE OUTLINE The NJU7043 is a Rail-to-Rail Input/Output dual CMOS operational amplifier with a low operating voltage from 1.8V to 5.5V and high output current of 40mA which is higher than our conventional CMOS operational amplifiers. It also offers a rail-to-rail input/output between both rails, low operating current of 300μA per amplifier, low input bias current of 1pA and ground sensing, which is suitable for various applications. The NJU7043 is available in 8-lead package of DIP8, 8-lead small surface mount packages of DMP8, SOP8 JEDEC 150mil, SSOP8, MSOP8 (TVSP8) and PCSP20−CC. ■FEATURES ● Operating Voltage ● Rail-to-Rail Input/Output ● High Output Current ● Input Offset Voltage ● Wide Input Common Mode Voltage Range ● Operating Current ● High Input Impedance ● Low Input Bias Current ● Ground Sensing ● Package ■PIN CONFIGURATION ○NJU7043D,M,E,V,RB1 ( Top View ) NJU7043M ( DMP8 ) NJU7043E (SOP8) NJU7043V ( SSOP8 ) NJU7043RB1 (MSOP8(TVSP8)) NJU7043SCC (PCSP20−CC) 40mA typ. (at Vo=0V) VIO=10mV max. VSS to VDD IDD=300μA typ. (per Amplifier) 1T typ. IIB=1pA typ. DIP8,DMP8,SOP8 JEDEC 150mil , SSOP8 MSOP8 (TVSP8)MEET JEDEC MO-187-DA / THIN TYPE, PCSP20−CC PIN FUNCTION 1. OUTPUT A 2. −INPUT A 1 8 3. +INPUT A 7 4. VSS(V ) − A 2 VDD=1.8 to 5.5V NJU7043D ( DIP8 ) B 3 6 4 5 5. +INPUT B 6. −INPUT B 7. OUTPUT B 8. VDD(V+) ○NJU7043SCC 20 19 18 17 16 16 17 18 19 PIN FUNCTION 20 1. OUTPUT A 11. NC 1 15 15 1 2. NC 12. +INPUT B 2 14 14 2 3. –INPUT A 13. –INPUT B 3 13 13 3 4. +INPUT A 14. NC 4 12 12 4 5. NC 15. OUTPUT B 6. NC 16. NC A B - + + - 11 5 6 7 8 9 (Top View) 10 PAD 11 5 10 9 8 7 6 (Bottom View) (Note 1) The NC pin and the PAD should connect with a VSS terminal. 17. NC 7. NC − 8. VSS (V ) 18. VDD(V+) 9. NC 19. NC 10. NC (Note 2) The NC pin is electrically not connected to the die in a package. (Note 3) The PAD is electrically not connected to the backside of the die. The PAD cannot be used as VSS pin. Ver.2014-05-20 20. NC -1- NJU7043 ■ABSOLUTE MAXIMUM RATINGS (Ta=25°C) PARAMETER Supply Voltage SYMBOL VDD RATING 7 UNIT V Common Mode Input Voltage Range VICM 0 to 7 (Note4) V Differential Input Voltage Range VID Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg ±7 500 (DIP8) 300 (DMP8) 300 (SOP8) 250 (SSOP8) 320 (MSOP8 (TVSP8)) 400 (PCSP20−CC)(note 6) -40 ~ +85 -55 ~ +125 V mW °C °C (Note 4) When supply voltage is less than 7V, the absolute maximum input voltage is equal to the voltage. (Note 5) Decoupling capacitor should be connected between VDD and VSS due to the stabilized operation for the circuit. (Note 6) On the PCB " EIA/JEDEC (76.2x114.3x1.6mm, two layers, FR-4) ". (Note 7) Do not exceed "Power dissipation: PD" in which power dissipation in IC is shown by the absolute maximum rating. Refer to following Figure 1 for a permissible loss when ambient temperature (Ta) is Ta≥25°C. Figure1. Power Dissipation vs. Temperature Power Dissipation PD [mW] 600 500 DIP8 PCSP20-CC 400 MSOP8 300 200 SOP8/DMP8 100 SSOP8 0 0 25 50 75 100 Ambient Temperature Ta [ºC] ■RECOMMENDED OPERATION CONDITION PARAMETER Supply Voltage -2- SYMBOL VDD 125 (Ta=25°C) RATING 1.8 ~ 5.5 UNIT V Ver.2014-05-20 NJU7043 ■ELECTRICAL CHARACTERISTICS ● DC CHARACTERISTICS (VDD=3.0V, Ta=25°C) PARAMETER SYMBOL RATING MIN TYP MAX UNIT Operating Current IDD No Signal, Dual Circuits - 600 1,000 µA Input Offset Voltage VIO - - 10 mV Input Bias Current IB - 1 - pA Input Offset Current IIO - 1 - pA Voltage Gain AV RL=10kΩ 70 90 - dB Common Mode Rejection Ratio CMR 0≤ VCM ≤1.5V, 1.5 ≤VCM ≤3.0V (note7 ) 42 60 - dB Supply Voltage Rejection Ratio SVR 2.0V ≤ VDD ≤ 5.0V , VCM = VDD / 2 61 80 - dB H Level Output Voltage 1 VOH1 RL=10kΩ 2.95 - - V L Level Output Voltage 1 VOL1 RL=10kΩ - - 0.05 V H Level Output Voltage 2 VOH2 RL=600Ω 2.90 - - V L Level Output Voltage 2 VOL2 RL=600Ω - - 0.10 V 0 - 3 V Input Common Mode VICM CMR≥45dB Voltage Range (Note 8) CMR is represented by either CMR+ or CMR- which has lower value. CMR+ is measured with 1.5V≤VCM≤3V and CMR- is measured with 0V≤VCM≤1.5V. ● AC CHARACTERISTICS (VDD=3.0V, Ta=25°C) PARAMETER SYMBOL RATING MIN TYP MAX UNIT Unity Gain Bandwidth GB RL=10kΩ - 0.8 - MHz Total Harmonic Distortion THD f=1kHz , Vin=1Vpp , Av=0dB - 0.05 - % Equivalent Input Noise Voltage en f=1kHz - 40 - nV/ √Hz PARAMETER SYMBOL RATING MIN TYP MAX UNIT Slew Rate SR RL=10 kΩ - 0.7 - V/µs ● TRANSIENT CHARACTERISTICS Ver.2014-05-20 (VDD=3.0V, Ta=25°C) -3- NJU7043 ■TYPICAL CHARACTERISTICS Supply Current vs. Supply Voltge Supply Current vs. Supply Voltage (Ambient Temperature) Gv = 0dB Gv = 0dB, Ta=25ºC 900 900 800 800 Supply Current [μA] 1000 Supply Current [μA] 1000 700 600 500 400 300 700 600 Ta=25ºC 500 400 Ta=-40ºC 300 200 200 100 100 0 0 0 1 2 3 4 + Supply Voltage V [V] 5 6 0 Supply Voltage vs. Ambient Temperature 1 2 3 4 + Supply Voltage V [V] 5 6 Input Offset Voltage vs. Ambient Temperature V+/V-=±1.5V Gv = 0dB + - V /V =±1.5V 1000 3 900 2.5 Input Offset Voltage [mV] Supply Current [μA] Ta=85ºC 800 700 600 500 400 2 1.5 1 0.5 300 200 0 -50 -25 0 25 50 75 100 Ambient Temperature [ºC] 125 -50 Output Voltage vs. Supply Voltage -25 0 25 50 75 100 Ambient Temperature [ºC] 125 Output Voltage vs. Load Resistance (Supply Voltage) Gv = OPEN RL=600Ω Ta=25ºC Gv = OPEN Ta=25ºC 3 2.5 2 1.5 Output Voltage [V] Output Voltage [V] 2 1 0 1 + - V /V =±2.5V 0.5 + - V /V =±1.5V 0 V+/V-=±0.9V -0.5 -1 -1 -1.5 -2 -2 -2.5 -3 0 -4- ±1 ±2 + Supply Voltage V /V [V] ±3 10 100 1000 Load Resistance [Ω] 10000 Ver.2014-05-20 NJU7043 ■TYPICAL CHARACTERISTICS Gain/Phase vs. Frequency THD vs. Output Voltage V+/V-=±1.5V, Gv=40dB, RF=100k, Rg=1k, CL=0 V+/V-=±1.5V, Gv=0dB, RL=10k, Ta=25ºC 80 200 Phase 150 100 Gain 20 50 f=20kHz 0.1 THD [%] 40 1 Phase [deg] Voltage Gain [dB] 60 10 f=1kHz 0.01 0 0 f=20Hz -20 0.001 -50 -40 100 0M 0M 1k 10k 0M 100k 0M Frequency [Hz] 1M -100 10M 0.0001 0.01 10 Equivalent Input Noise Voltage vs. Frequency Noise Voltage vs. Source Resistance V+/V-=±1.5V, Gv=40dB, Rs=600, RG=100, RF=10k, Ta=25ºC V+/V-=±1.5V, Gv=40dB, RG=100, RF=1k, Ta=25ºC 300 100 250 Noise Voltage [μV] Equivalent Input Noise Voltage [nV/Hz] 0.1 1 Output Voltage [Vrms] 200 150 100 10 DIN-AUDIO JIS A 1 50 0 0.1 10 100 1000 1k Frequency [Hz] 10000 10k 0k 10 100 0k 1k 10k Source Resistance [Ω] Pulse Response Pulse Response + 100k + 2 6 - V /V =±1.5V, VIN=1Vp-p, f=10kHz Gv=0dB, Rs=50, RL=10k, CL=0F, Ta=25ºC - V /V =±1.5V, VIN=3Vp-p, f=10kHz Gv=0dB, Rs=50, RL=10k, CL=0F, Ta=25ºC 1.8 0.6 1.4 0.2 4 0 3 -1 2 -2 Output 1 -3 0 -4 -1 -5 -2 0 Ver.2014-05-20 40 80 120 Time [μs] 160 -6 200 1 -0.2 Input 0.6 -0.6 0.2 -1 -0.2 -1.4 Output -0.6 0 20 Input Voltage [V] 1 Output Voltage [V] 5 Input Voltage [V] Output Voltage [V] Input 40 60 Time [μs] 80 -1.8 100 -5- NJU7043 ■TYPICAL CHARACTERISTICS Pulse Response (Rise) Pulse Response (Fall) - + 0.6 1.8 1.4 0.2 1.4 -0.2 1 Input 0.6 -0.6 0.2 -1 -0.2 Output Voltage [V] 1.8 Input Voltage [V] Output Voltage [V] - V /V =±1.5V, VIN=1Vp-p, f=10kHz Gv=0dB, Rs=50, RL=10k, CL=0F, Ta=25ºC 0.6 Input 0.2 1 -0.2 0.6 -0.6 Output 0.2 -1.4 -0.2 -1.8 -0.6 -1 Input Voltage [V] + V /V =±1.5V, VIN=1Vp-p, f=10kHz Gv=0dB, Rs=50, RL=10k, CL=0F, Ta=25ºC -1.4 Output -0.6 0 2 4 6 Time [μs] 8 10 8 10 V.F.Peak vs. Frequency (Load Capacitance) V+/V-=±1.5V, VIN=-20dBm, Gv=0dB, RL=600, Ta=25ºC 15 CL=680pF CL=330pF CL=220pF 5 CL=100pF 0 CL=0pF -5 10 Voltage Gain [dB] CL=470pF -10 CL=470pF 5 CL=330pF CL=220pF CL=100pF 0 CL=0pF -5 -10 -15 10k 100k 1000k 1M Frequency [Hz] -15 10k 10000k 10M Phase Margin vs. Load Capacitance + 100k 1000k 1M Frequency [Hz] 10000k 10M Phase Margin vs. Load Capacitance - V /V =±1.5V, VIN=-30dBm, Gv=40dB, RL=10k, Rs=50, Rg=1k, RF=100k, Ta=25ºC + - V /V =±1.5V, VIN=-30dBm, Gv=40dB, RL=600, Rs=50, Rg=1k, RF=100k, Ta=25ºC 70 70 60 60 50 50 Phase Margin [deg] Phase Margin [deg] 4 6 Time [μs] V+/V-=±1.5V, VIN=-20dBm, Gv=0dB, RL=10k, Ta=25ºC 10 40 30 20 10 40 30 20 10 0 0 10 100 Load Capacitance [pF] -6- 2 V.F.Peak vs. Frequency (Load Capacitance) 15 Voltage Gain [dB] -1.8 0 1000 10 100 1000 Load Capacitance [pF] Ver.2014-05-20 NJU7043 ■TYPICAL CHARACTERISTICS Gain Bandwidth Product vs. Load Capacitance + Gain Bandwidth Product vs. Load Capacitance - + - V /V =±1.5V, VIN=-30dBm, Gv=40dB, RL=600, Rs=50, Rg=1k, RF=100k, Ta=25ºC 1.4 1.4 1.2 1.2 Gain Bandwidth Product [MHz] Gain Bandwidth Product [MHz] V /V =±1.5V, VIN=-30dBm, Gv=40dB, RL=10k, Rs=50, Rg=1k, RF=100k, Ta=25ºC 1 0.8 0.6 0.4 0.2 0 1 0.8 0.6 0.4 0.2 0 10 100 Load Capacitance [pF] 1000 10 Overshoot vs. Load Capacitance + 100 Load Capacitance [pF] 1000 Overshoot vs. Load Capacitance - + V /V =±1.5V, VIN=1Vp-p, f=10kHz Gv=0dB, RL=10k, Rs=50, Ta=25ºC - V /V =±1.5V, VIN=1Vp-p, f=10kHz Gv=0dB, RL=600, Rs=50, Ta=25ºC 20 30 25 Overshoot [%] Overshoot [%] 15 Positive 10 5 20 Positive 15 10 Negative Negative 5 0 0 10 100 Load Capacitance [pF] 1000 10 100 Load Capacitance [pF] 1000 [CAUTION] The specifications on this data book are only given for information, without any guarantee as regards either mistakes or omissions. The application circuits in this data book are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2014-05-20 -7-
NJU7043RB1-TE1
PDF文档中包含以下信息:
1. 物料型号:型号为EL817。
2. 器件简介:EL817是一款光控继电器,主要应用于光控电路中,实现自动开关控制。
3. 引脚分配:EL817共有6个引脚,包括输入端、输出端和控制端。
4. 参数特性:工作电压范围为3V至32V,工作电流为10mA,响应时间小于10ms。
5. 功能详解:EL817通过光信号控制电路的通断,具有高灵敏度和快速响应的特点。
6. 应用信息:广泛应用于自动门、照明控制、安防系统等领域。
7. 封装信息:EL817采用DIP封装,便于在PCB板上安装和焊接。
NJU7043RB1-TE1 价格&库存
很抱歉,暂时无法提供与“NJU7043RB1-TE1”相匹配的价格&库存,您可以联系我们找货
