NJM8068RB1-TE1
NJM8068RB1-TE1
    JRC(⽇本无线)
    VSSOP8
    IC AUDIO 2 CIRCUIT 8TVSP
NJM8068RB1-TE1 数据手册
NJM8068 LOW NOISE, BIPOLAR INPUT DUAL AUDIO OPERATIONAL AMPLIFIER FEATURES DESCRIPTION ● Designed for High-Quality Sound ● Low Noise 3.5 nV/√Hz at 1kHz ● Low Distortion 0.001% ● Slew Rate 6.8V/µs ● Gain Bandwidth Product 19 MHz ● Open-Loop Voltage Gain 120dB ● Unity-Gain Stable . ● Bipolar Input ● Supply Voltage ±4V to ±18V ● Operating Temperature -40°C to 125°C ● Supply Current (All Amplifiers) 5 mA typ. ● Package SOP8 MSOP8 (TVSP8)* NJM8068 is a low noise bipolar input dual audio operational amplifier has 3.5 nV/√Hz at 1kHz. The NJM8068 features Low distortion, high slew rate, wide bandwidth and high open-loop gain. In addition, unity-gain stable allows voltage-follower operation. These features make NJM8068 ideal for audio pre amplifier, microphone amplifier, line amplifier and other audio applications. NJM8068 operate over a wide temperature range of -40°C to 125°C, making this IC ideal for use in industrial measurement instruments The NJM8068 is available in 8-pin SOP and MSOP (TVSP) packages. * meet JEDEC MO-187-DA / thin type ■ RELATED PRODUCT APPLICATIONS ● Professional Audio Sets ● Audio Pre / Microphone Amplifiers ● Analog / Digital Mixers ● AV Receivers ● Car Audio ● Industrial Measurement Instruments PRODUCT NAME NJM8080 FEATURES 5nV/√Hz, 0.0005%, 5V/μs, 15MHz (Low noise, low distortion audio Op-Amp) ■ EQUIVALENT CIRCUIT Ver.3.1 http://www.njr.com/ -1- NJM8068 ■ PIN CONFIGURATIONS PRODUCT NAME NJM8068G NJM8068B1 Package SOP8 MSOP8 (TVSP8) (Top View) Pin Functions A OUTPUT 1 8 V+ A -INPUT 2 7 B OUTPUT A +INPUT 3 6 B -INPUT V- 4 5 B +INPUT ■ PRODUCT NAME INFORMATION NJM8068 RB1 Part Number (TE1) Package Taping Form ■ ORDER INFORMATION PRODUCT NAME PACKAGE RoHS HALOGENFREE TERMINAL FINISH MARKING WEIGHT (mg) MOQ (pcs) SOP8 Yes Yes Pure Sn 8068 88 2500 MSOP8 (TVSP8) Yes Yes Sn2Bi 8068 18 2000 NJM8068G NJM8068RB1 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL RATING UNIT V /V ±18 V VID ±36 V + Supply Voltage (1) Differential Input Voltage (2) Input Voltage - VIN Output Terminal Input Voltage VO (3) - V -0.3 to V⁻+36 - + V -0.3 to V +0.3 V V (4) Power Dissipation 2-Layer / 4-Layer PD 690 / 1000 510 / 680 mW Storage Temperature Range Tstg -65 to 150 °C Maximum Junction Temperature Tjmax 150 °C SYMBOL VALUE SOP8 MSOP8 (TVSP8) ■ THERMAL CHARACTERISTICS PACKAGE UNIT (4) Junction-to-Ambient Thermal Resistance 2-Layer / 4-Layer Θja SOP8 MSOP8 (TVSP8) Junction-to-Top of Package Characterization Parameter °C/W 181 / 125 245 / 184 (4) 2-Layer / 4-Layer Ψjt °C/W SOP8 49 / 43 MSOP8 (TVSP8) 51 / 45 (1) Differential voltage is the voltage difference between +INPUT and -INPUT. + (2) Input voltage is the voltage should be allowed to apply to the input terminal independent of the magnitude of V . The normal operation will establish when any input is within the “Common-Mode Input Voltage Range” of electrical characteristics. (3) Power dissipation is the power that can be consumed by the IC at Ta=25°C, and is the typical measured value based on JEDEC condition. (4) 2-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6 mm: based on EIA/JDEC standard, 2-layer FR-4) 4-Layer: Mounted on glass epoxy board. (76.2×114.3×1.6 mm: based on EIA/JDEC standard, 4-layer FR-4), internal Cu area: 74.2 x 74.2 mm Ver.3.1 http://www.njr.com/ -2- NJM8068 ■ POWER DISSIPATION vs. AMBIENT TEMPERATURE Power Dissipation vs. Temperature Power Dissipation vs. Temperature 4-Layer 1200 1200 1100 1100 1000 1000 Power Dissipation PD [mW] Power Dissipation PD [mW] 2-Layer 900 800 700 600 SOP8 500 400 300 MSOP8(TVSP8) 200 900 800 700 SOP8 600 500 400 MSOP8(TVSP8) 300 200 100 100 0 0 0 25 50 75 100 125 0 150 25 50 75 100 125 150 Ambient Temperature [°C] Ambient Temperature [°C] ■ RECOMMENDED OPERATING CONDITIONS PARAMETER Supply Voltage Operating Temperature Range SYMBOL + - CONDITIONS Ta=25°C V /V Topr VALUE UNIT ±4 to ±18 V -40 to 125 °C ■ ELECTRICAL CHARACTERISTICS (V+/V-=±15V, Ta=25°C, unless otherwise noted.) PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT - 0.3 3 mV - 260 1000 nA INPUT/OUTPUT CHARACTERISTICS Input Offset Voltage Input Bias Current VIO RS 10kΩ IB Input Offset Current IIO Open-Loop Voltage Gain AV - 5 200 nA 90 120 - dB CMR 80 110 - dB Input Resistance RIN 50 300 - kΩ Common-Mode Input Voltage Range VICM ±12 ±13.5 - V Maximum Output Voltage VOM ±12 ±13.5 - V Common-Mode Rejection Ratio RL=2kΩ, VO=±10V RL 2kΩ POWER SUPPLY Supply Current (All Amplifiers) ISUPPLY - 5 8 mA Supply Voltage Rejection Ratio SVR 80 120 - dB f=100kHz - 19 - MHz fT GV=0dB - 7.5 - MHz SR RL 2kΩ - 6.8 - V/μs f=1kHz - 3.5 - nV/√Hz FLAT, f=20Hz to 20kHz - 0.5 0.7 µVrms THD+N - 0.001 - % CS - 120 - dB AC CHARACTERISTICS Gain Bandwidth Product Unity Gain Frequency Slew Rate GBW Noise, Distortion Equivalent Input Noise Voltage Total Harmonic Distortion + Noise Channel Separation Ver.3.1 en http://www.njr.com/ -3- NJM8068 ■ TYPICAL CHARACTERISTICS 80dB Gain/Phase vs. Frequency V+/V-=±15V, Ta=25ºC Ta=125ºC 0 Ta=25ºC 40 -30 Ta=-40ºC Phase 20 -60 0 -90 Ta=125ºC -20 -120 Ta=25ºC Ta=-40ºC 100 1k 10k 100k 1M Frequency [Hz] -150 10M -180 100M Phase [deg] 60 Equivalent Input Noise Voltage [nV/Hz] Gain 80 Voltage Gain [dB] Voltage Noise vs. Frequency V+/V- = ±15V, Gv=80dB, RL=2kΩ, CL=100pF 100 16 14 12 10 8 6 4 2 0 1 Maximum Output Voltage vs. Load Resistance 10 100 1k Frequency [Hz] 10k 100k Maximum Output Voltage vs. Output Current V+/V-=±15V, Gv=open V+/V-=±15V 15 15 Maximum Output Voltage [V] Maximum Output Voltage [V] Ta=-40ºC 10 Ta=25ºC 5 Ta=125ºC 0 Ta=125ºC -5 Ta=25ºC -10 Ta=25ºC 10 Ta=-40ºC 5 Ta=125ºC 0 Ta=125ºC -5 -10 Ta=-40ºC Ta=25ºC Ta=-40ºC -15 -15 10 100 1k 10k Load Resistance [Ω] 100k 0 Supply Current vs. Supply Voltage 100 Supply Current vs. Temperature RL= 6 50 Output Current [mA] RL= 7.0 Ta=25ºC 6.5 4 Ta=-40ºC Supply Current [mA] Supply Current [mA] 5 Ta=125ºC 3 2 1 V+/V-=±15V 5.5 5.0 4.5 V+/V-=±4V 4.0 3.5 0 3.0 0 Ver.3.1 6.0 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 Supply Voltage V+/V- [V] -50 http://www.njr.com/ -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -4- NJM8068 ■ TYPICAL CHARACTERISTICS Input Offset Voltage vs. Temperature 3 2 2 1 Input Offset Voltage [mV] Input Offset Voltage [mV] Input Offset Voltage vs. Supply Voltage 3 Ta=105ºC Ta=25ºC 0 -1 Ta=125ºC Ta=-40ºC -2 V+/V-=±4V 1 0 -1 V+/V-=±15V -2 -3 -3 0 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 Supply VoltageV+/V- [V] -50 Input Offset Voltage vs. Common-Mode Input Voltage -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Input Offset Voltage vs. Common-Mode Input Voltage V+/V-=±4V 3 3 2 2 Ta=-40ºC 1 Ta=25ºC Input Offset Voltage [mV] Input Offset Voltage [mV] V+/V-=±15V Ta=105ºC 0 -1 Ta=125ºC -2 Ta=25ºC 1 0 Ta=125ºC -1 -3 -15 -10 -5 0 5 10 Common-Mode Input Voltage [V] 15 -4 -3 -2 -1 0 1 2 3 Common-Mode Input Voltage [V] 4 Common Mode and Supply Voltage Rejection Ratio vs. Temperature Input Bias Current vs. Temperature V+/V-=±15V 140 Common Mode and Supply Voltage Rejection Ratio [dB] 600 500 Input Bias Current [nA] Ta=105ºC -2 -3 400 300 200 100 0 130 SVR 120 110 100 90 CMR @V+/V-=±15V 80 70 60 50 40 -50 Ver.3.1 Ta=-40ºC -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -50 http://www.njr.com/ -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] -5- NJM8068 ■ TYPICAL CHARACTERISTICS Open-Loop Voltage Gain vs. Temperature Maximum Output Voltage vs. Temperature V+/V-=±15V, VO=±10V 140 15 Maximum Output Voltage [V] Open-Loop Voltage Gain [dB] 130 120 110 100 90 80 70 60 10 V+/V-=±15V V+/V-=±4V 5 0 -5 V+/V-=±4V V+/V-=±15V -10 50 40 -15 -50 -25 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Maximum Output Voltage vs. Supply Voltage THD+N vs. Output Voltage RL=2kΩ V+/V-=±15V, RS=20, RF=2k, RG=10k, Ta=25°C 18 1 Ta=125ºC 12 0.1 Ta=-40ºC 6 THD+N [%] Maximum Output Voltage [V] 0 25 50 75 100 125 150 Ambient Temperature [°C] Ta=25ºC 0 Ta=25ºC -6 f=20kHz 0.01 V+ 0.1uF 0.001 -12 + 200uF RF Ta=-40ºC RS f=1kHz 20Hz Ta=125ºC 1kHz RG 0.1uF 20kHz + 200uF f=20Hz V- -18 0 Ver.3.1 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 Supply Voltage V+/V- [V] 0.0001 0.01 http://www.njr.com/ 0.1 1 10 Output Voltage [Vrms] 100 -6- NJM8068 ■ TEST CIRCUITS ● ISUPPLY ● VIO, CMR, SVR RG=50Ω, RF=50kΩ V+ RF A V+ RG VO RG V- RF V- VS=V+-V- ● VOH, VOL VOH; Vin+ = 1V, Vin- = -1V VOL; Vin+ = -1V, Vin- = 1V V+ VO RL V- Vin+ Vin- ● SR RL=2kΩ 90% V+ Vo VO 50Ω Ver.3.1 V- 90% ΔV ΔV 10% Δt Δt 10% RL http://www.njr.com/ -7- NJM8068 SOP8 Unit: mm ■ PACKAGE DIMENSIONS DE TAI L F D T e/2 5 8 E E1 1 4 U h × 45 ° 6 ×e ∞0 M U M θ A2 CC C Z A A1 Z S EA TIN G PL ANE 8 ×b b bb M D ESCRIP TION TO TA L THI CKN ESS SYMBOL A MIN .053 INCH NCM MAX .069 STAND OFF A1 .004 .010 0.10 0. 25 MOL D T HICK NES S LE AD WID TH A2 b .04 9 .014 .019 1.25 0.35 0.4 9 L/F T HICKN ESS C . 007 .010 0.19 0.25 D .189 .197 4.80 5.00 E1 .150 .1 57 3 .80 4.00 E .228 .2 44 5.80 BO DY SIZ E LEAD PITCH e .05 0 BSC 6.20 .015 .049 0.4 0 1.2 5 h .010 .020 0.2 5 0.5 0 0° 5° θ2 2° 7° 7° 15 ° 0° 5° 12 ° 2° 7° 15 ° 7° LEAD EDGE OFF SET LEA D O F FSET ∞O b bb .010 .010 0 . 25 0.2 5 COPLA NA R ITY CCC .0 04 0. 10 Ver.3.1 θ1 1 .27 B SC L θ θ1 Z U S T S M IL LIM ET ER MIN NCM MA X 1.35 1. 75 θ2 C 12 ° http://www.njr.com/ [ 0.2 5] L DE TAI L F -8- NJM8068 SOP8 Unit: mm ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0 . 72 5.72 1.27 1 . 27 3. 8 1 Ver.3.1 http://www.njr.com/ -9- NJM8068 MSOP8 (TVSP8) JEDEC MO-187-DA/THIN TYPE Unit: mm ■ PACKAGE DIMENSIONS 2. 9 ± 0 .1 0 ∼ 10 ゚ 1 0 .55 ± 0 .1 4.0 ±0 .2 5 2.8 ±0 .1 8 4 0. 127 0. 65 +0.05 -0.03 0 .08 0. 2 ± 0 .05 0. 05 M 0 .1 ±0 .05 1.0m ax 0 .4 75 ± 0 .1 ■ EXAMPLE OF SOLDER PADS DIMENSIONS 0.65 3. 5 1 .0 0.23 1.95 Ver.3.1 http://www.njr.com/ - 10 - NJM8068 SOP8 Unit: mm ■ PACKING SPEC REEL DIMENSIONS / TAPING DIMENSIONS 8 12 3 30 Fee d di rec ti on 8 12.4 TAPING STATE Insert direction Sealing with covering tape (TE2) Feed direction Empty tape Devices Empty tape Trailer 60pcs 2500pcs/reel Leader 60pcs PACKING STATE Label Label ESD Label Ver.3.1 http://www.njr.com/ - 11 - NJM8068 MSOP8 (TVSP8) MEET JEDEC MO-187-DA/THIN TYPE Unit: mm ■ PACKING SPEC TAPING DIMENSIONS Feed d ir ec ti on P2 P0 φD 0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 W W1 B W1 W F E T A P1 T2 φD 1 DIMENSION 4.4 3.2 1.5 +0.1 0 1.5 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.30±0.05 1.75 (MAX.) 12.0±0.3 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 C SYMBOL A B C D E W W1 B A D E DIMENSION φ254±2 φ100±1 φ 13±0.2 φ 21±0.8 2±0.5 13.5±0.5 2.0±0.2 W TAPING STATE Insert direction Sealing with covering tape (TE1) Devices Empty tape Feed direction more than 20pitch 2000pcs/reel Empty tape Covering tape more than 20pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.3.1 http://www.njr.com/ - 12 - NJM8068 ■ RECOMMENDED MOUNTING METHOD INFRARED REFLOW SOLDERING PROFILE f 260°C e 230°C 220°C a d b 180°C c d e f g 150°C Temperature ramping rate Pre-heating temperature Pre-heating time Temperature ramp rate 220°C or higher time 230°C or higher time Peak temperature Temperature ramping rate 1 to 4°C/s 150 to 180°C 60 to 120s 1 to 4°C/s shorter than 60s shorter than 40s lower than 260°C 1 to 6°C/s The temperature indicates at the surface of mold package. Room Temp. a Ver.3.1 b c g http://www.njr.com/ - 13 - NJM8068 [ CAUTION ] 1. NJR strives to produce reliable and high quality semiconductors. NJR’s semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of NJR's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial property rights. All other trademarks mentioned herein are the property of their respective companies. 3. To ensure the highest levels of reliability, NJR products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. NJR offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact NJR's Sale's Office if you are uncertain about the products listed in this datasheet. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in this datasheet may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment.        7. 8. 9. Ver.3.1 Aerospace Equipment Equipment Used in the Deep Sea Power Generator Control Equipment (Nuclear, steam, hydraulic, etc.) Life Maintenance Medical Equipment Fire Alarms / Intruder Detectors Vehicle Control Equipment (Airplane, railroad, ship, etc.) Various Safety Devices NJR's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. NJR shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. The products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. Warning for handling Gallium and Arsenic (GaAs) Products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. The product specifications and descriptions listed in this datasheet are subject to change at any time, without notice. http://www.njr.com/ - 14 -
NJM8068RB1-TE1 价格&库存
很抱歉,暂时无法提供与“NJM8068RB1-TE1”相匹配的价格&库存,您可以联系我们找货
