S-1135B25-M5T1U
S-1135B25-M5T1U
    ABLIC(艾普凌科)
    SOT23-5
    IC REG LINEAR 2.5V 300MA SOT23-5
S-1135B25-M5T1U 数据手册
S-1135 Series www.ablic.com 5.5 V INPUT, 300 mA VOLTAGE REGULATOR Rev.2.3_00 © ABLIC Inc., 2008-2018 The S-1135 Series, developed using the CMOS technology, is a positive voltage regulator IC which has the low dropout voltage, the high-accuracy output voltage and the low current consumption (300 mA output current). A 1.0 μF small ceramic capacitor can be used. It operates with low current consumption of 45 μA typ. The overcurrent protection circuit prevents the load current from exceeding the current capacity of the output transistor. The ON / OFF circuit ensures longer battery life. Various capacitors, also small ceramic capacitors, can be used for this IC more than for the conventional regulator ICs which have CMOS technology. Furthermore, a small SOT-89-5, SOT-23-5, and HSNT-6A packages realize high-density mounting.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input and output capacitors : • Ripple rejection: • Built-in overcurrent protection circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free, Sn 100%, halogen-free*2 1.0 V to 3.5 V, selectable in 0.05 V step 1.5 V to 5.5 V ±1.0% (1.0 V to 1.45 V output product : ±15 mV) 160 mV typ. (2.6 V output product, IOUT = 300 mA) During operation: 45 μA typ., 65 μA max. During power-off: 0.1 μA typ., 1.0 μA max. Possible to output 300 mA (VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor of 1.0 μF or more can be used. 70 dB typ. (1.0 V output product, f = 1.0 kHz) Limits overcurrent of output transistor. Ensures long battery life. Discharge shunt function “available” / “unavailable” is selectable. Pull-down / pull-up function “available” / “unavailable” is selectable. Ta = −40°C to +85°C *1. Attention should be paid to the power dissipation of the package when the output current is large. *2. Refer to “ Product Name Structure” for details.  Applications • Power supply for battery-powered device • Power supply for cellular phone • Power supply for portable equipment  Packages • SOT-89-5 • SOT-23-5 • HSNT-6A 1 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Block Diagrams 1. S-1135 Series A type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” Available Unavailable Available + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 1 2. S-1135 Series B type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 2 2 Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” Available Unavailable Unavailable 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 3. S-1135 Series C type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” Unavailable Unavailable Available + − Reference voltage circuit VSS *1. Parasitic diode Figure 3 4. S-1135 Series D type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” Unavailable Unavailable Unavailable + − Reference voltage circuit VSS *1. Parasitic diode Figure 4 3 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 5. Rev.2.3_00 S-1135 Series E type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” Available Available Unavailable + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 5 6. S-1135 Series F type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 6 4 Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” Available Unavailable Unavailable 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 7. S-1135 Series G type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” Unavailable Available Unavailable + − Reference voltage circuit VSS *1. Parasitic diode Figure 7 8. S-1135 Series H type *1 VIN VOUT Overcurrent protection circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” Unavailable Unavailable Unavailable + − Reference voltage circuit VSS *1. Parasitic diode Figure 8 5 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Product Name Structure Users can select the product type, output voltage, and package type for the S-1135 Series. Refer to “1. Product name” regarding the contents of product name, “2. Function list of product type” regarding the product type, “3. Packages” regarding the package drawings. 1. Product name 1. 1 SOT-89-5 S-1135 x xx - U5T1 x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) Package abbreviation and IC packing specifications*1 U5T1: SOT-89-5, Tape Output voltage*2 10 to 35 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 A to H *1. *2. *3. 1. 2 Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. SOT-23-5 S-1135 x xx - M5T1 x Environmental code U: Lead-free (Sn 100%), halogen-free S: Lead-free, halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape Output voltage*2 10 to 35 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 A to H *1. *2. *3. 6 Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 1. 3 HSNT-6A S-1135 x xx - A6T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 A6T1: HSNT-6A, Tape Output voltage*2 10 to 35 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 A to H *1. *2. *3. 2. Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. Function list of product type Table 1 Product Type 3. ON / OFF Logic Discharge Shunt Function Pull-up Resistor Pull-down Resistor A Active “H” Available Unavailable Available B Active “H” Available Unavailable Unavailable C Active “H” Unavailable Unavailable Available D Active “H” Unavailable Unavailable Unavailable E Active “L” Available Available Unavailable F Active “L” Available Unavailable Unavailable G Active “L” Unavailable Available Unavailable H Active “L” Unavailable Unavailable Unavailable Packages Package Name SOT-89-5 SOT-23-5 HSNT-6A Package UP005-A-P-SD MP005-A-P-SD PJ006-A-P-SD Tape UP005-A-C-SD MP005-A-C-SD PJ006-A-C-SD Drawing Code Reel UP005-A-R-SD MP005-A-R-SD PJ006-A-R-SD Land ⎯ ⎯ PJ006-A-LM-SD Stencil Opening ⎯ ⎯ PJ006-A-LM-SD 7 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 4. Rev.2.3_00 Product name list 4. 1 S-1135 Series A type ON / OFF logic: Discharge shunt function: Active “H” Available Pull-up resistor: Pull-down resistor: Unavailable Available Table 2 Output Voltage SOT-89-5 SOT-23-5 HSNT-6A 1.0 V ±15 mV S-1135A10-U5T1x S-1135A10-M5T1y S-1135A10-A6T1U 1.1 V ±15 mV S-1135A11-U5T1x S-1135A11-M5T1y S-1135A11-A6T1U 1.2 V ±15 mV S-1135A12-U5T1x S-1135A12-M5T1y S-1135A12-A6T1U 1.3 V ±15 mV S-1135A13-U5T1x S-1135A13-M5T1y S-1135A13-A6T1U 1.4 V ±15 mV S-1135A14-U5T1x S-1135A14-M5T1y S-1135A14-A6T1U 1.5 V ±1.0% S-1135A15-U5T1x S-1135A15-M5T1y S-1135A15-A6T1U 1.6 V ±1.0% S-1135A16-U5T1x S-1135A16-M5T1y S-1135A16-A6T1U 1.7 V ±1.0% S-1135A17-U5T1x S-1135A17-M5T1y S-1135A17-A6T1U 1.8 V ±1.0% S-1135A18-U5T1x S-1135A18-M5T1y S-1135A18-A6T1U 1.85 V ±1.0% S-1135A1J-U5T1x S-1135A1J-M5T1y S-1135A1J-A6T1U 1.9 V ±1.0% S-1135A19-U5T1x S-1135A19-M5T1y S-1135A19-A6T1U 2.0 V ±1.0% S-1135A20-U5T1x S-1135A20-M5T1y S-1135A20-A6T1U 2.1 V ±1.0% S-1135A21-U5T1x S-1135A21-M5T1y S-1135A21-A6T1U 2.2 V ±1.0% S-1135A22-U5T1x S-1135A22-M5T1y S-1135A22-A6T1U 2.3 V ±1.0% S-1135A23-U5T1x S-1135A23-M5T1y S-1135A23-A6T1U 2.4 V ±1.0% S-1135A24-U5T1x S-1135A24-M5T1y S-1135A24-A6T1U 2.5 V ±1.0% S-1135A25-U5T1x S-1135A25-M5T1y S-1135A25-A6T1U 2.6 V ±1.0% S-1135A26-U5T1x S-1135A26-M5T1y S-1135A26-A6T1U 2.7 V ±1.0% S-1135A27-U5T1x S-1135A27-M5T1y S-1135A27-A6T1U 2.8 V ±1.0% S-1135A28-U5T1x S-1135A28-M5T1y S-1135A28-A6T1U 2.85 V ±1.0% S-1135A2J-U5T1x S-1135A2J-M5T1y S-1135A2J-A6T1U 2.9 V ±1.0% S-1135A29-U5T1x S-1135A29-M5T1y S-1135A29-A6T1U 3.0 V ±1.0% S-1135A30-U5T1x S-1135A30-M5T1y S-1135A30-A6T1U 3.1 V ±1.0% S-1135A31-U5T1x S-1135A31-M5T1y S-1135A31-A6T1U 3.2 V ±1.0% S-1135A32-U5T1x S-1135A32-M5T1y S-1135A32-A6T1U 3.3 V ±1.0% S-1135A33-U5T1x S-1135A33-M5T1y S-1135A33-A6T1U 3.4 V ±1.0% S-1135A34-U5T1x S-1135A34-M5T1y S-1135A34-A6T1U 3.5 V ±1.0% S-1135A35-U5T1x S-1135A35-M5T1y S-1135A35-A6T1U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 8 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 4. 2 S-1135 Series B type ON / OFF logic: Discharge shunt function: Active “H” Available Pull-up resistor: Pull-down resistor: Unavailable Unavailable Table 3 Output Voltage SOT-89-5 SOT-23-5 HSNT-6A 1.0 V ±15 mV S-1135B10-U5T1x S-1135B10-M5T1y S-1135B10-A6T1U 1.1 V ±15 mV S-1135B11-U5T1x S-1135B11-M5T1y S-1135B11-A6T1U 1.2 V ±15 mV S-1135B12-U5T1x S-1135B12-M5T1y S-1135B12-A6T1U 1.3 V ±15 mV S-1135B13-U5T1x S-1135B13-M5T1y S-1135B13-A6T1U 1.4 V ±15 mV S-1135B14-U5T1x S-1135B14-M5T1y S-1135B14-A6T1U 1.5 V ±1.0% S-1135B15-U5T1x S-1135B15-M5T1y S-1135B15-A6T1U 1.6 V ±1.0% S-1135B16-U5T1x S-1135B16-M5T1y S-1135B16-A6T1U 1.7 V ±1.0% S-1135B17-U5T1x S-1135B17-M5T1y S-1135B17-A6T1U 1.8 V ±1.0% S-1135B18-U5T1x S-1135B18-M5T1y S-1135B18-A6T1U 1.85 V ±1.0% S-1135B1J-U5T1x S-1135B1J-M5T1y S-1135B1J-A6T1U 1.9 V ±1.0% S-1135B19-U5T1x S-1135B19-M5T1y S-1135B19-A6T1U 2.0 V ±1.0% S-1135B20-U5T1x S-1135B20-M5T1y S-1135B20-A6T1U 2.1 V ±1.0% S-1135B21-U5T1x S-1135B21-M5T1y S-1135B21-A6T1U 2.2 V ±1.0% S-1135B22-U5T1x S-1135B22-M5T1y S-1135B22-A6T1U 2.3 V ±1.0% S-1135B23-U5T1x S-1135B23-M5T1y S-1135B23-A6T1U 2.4 V ±1.0% S-1135B24-U5T1x S-1135B24-M5T1y S-1135B24-A6T1U 2.5 V ±1.0% S-1135B25-U5T1x S-1135B25-M5T1y S-1135B25-A6T1U 2.6 V ±1.0% S-1135B26-U5T1x S-1135B26-M5T1y S-1135B26-A6T1U 2.7 V ±1.0% S-1135B27-U5T1x S-1135B27-M5T1y S-1135B27-A6T1U 2.8 V ±1.0% S-1135B28-U5T1x S-1135B28-M5T1y S-1135B28-A6T1U 2.85 V ±1.0% S-1135B2J-U5T1x S-1135B2J-M5T1y S-1135B2J-A6T1U 2.9 V ±1.0% S-1135B29-U5T1x S-1135B29-M5T1y S-1135B29-A6T1U 3.0 V ±1.0% S-1135B30-U5T1x S-1135B30-M5T1y S-1135B30-A6T1U 3.1 V ±1.0% S-1135B31-U5T1x S-1135B31-M5T1y S-1135B31-A6T1U 3.2 V ±1.0% S-1135B32-U5T1x S-1135B32-M5T1y S-1135B32-A6T1U 3.3 V ±1.0% S-1135B33-U5T1x S-1135B33-M5T1y S-1135B33-A6T1U 3.4 V ±1.0% S-1135B34-U5T1x S-1135B34-M5T1y S-1135B34-A6T1U 3.5 V ±1.0% S-1135B35-U5T1x S-1135B35-M5T1y S-1135B35-A6T1U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 9 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 4. 3 Rev.2.3_00 S-1135 Series C type ON / OFF logic: Discharge shunt function: Active “H” Unavailable Pull-up resistor: Pull-down resistor: Unavailable Available Table 4 Output Voltage SOT-89-5 SOT-23-5 HSNT-6A 1.0 V ±15 mV S-1135C10-U5T1x S-1135C10-M5T1y S-1135C10-A6T1U 1.1 V ±15 mV S-1135C11-U5T1x S-1135C11-M5T1y S-1135C11-A6T1U 1.2 V ±15 mV S-1135C12-U5T1x S-1135C12-M5T1y S-1135C12-A6T1U 1.3 V ±15 mV S-1135C13-U5T1x S-1135C13-M5T1y S-1135C13-A6T1U 1.4 V ±15 mV S-1135C14-U5T1x S-1135C14-M5T1y S-1135C14-A6T1U 1.5 V ±1.0% S-1135C15-U5T1x S-1135C15-M5T1y S-1135C15-A6T1U 1.6 V ±1.0% S-1135C16-U5T1x S-1135C16-M5T1y S-1135C16-A6T1U 1.7 V ±1.0% S-1135C17-U5T1x S-1135C17-M5T1y S-1135C17-A6T1U 1.8 V ±1.0% S-1135C18-U5T1x S-1135C18-M5T1y S-1135C18-A6T1U 1.85 V ±1.0% S-1135C1J-U5T1x S-1135C1J-M5T1y S-1135C1J-A6T1U 1.9 V ±1.0% S-1135C19-U5T1x S-1135C19-M5T1y S-1135C19-A6T1U 2.0 V ±1.0% S-1135C20-U5T1x S-1135C20-M5T1y S-1135C20-A6T1U 2.1 V ±1.0% S-1135C21-U5T1x S-1135C21-M5T1y S-1135C21-A6T1U 2.2 V ±1.0% S-1135C22-U5T1x S-1135C22-M5T1y S-1135C22-A6T1U 2.3 V ±1.0% S-1135C23-U5T1x S-1135C23-M5T1y S-1135C23-A6T1U 2.4 V ±1.0% S-1135C24-U5T1x S-1135C24-M5T1y S-1135C24-A6T1U 2.5 V ±1.0% S-1135C25-U5T1x S-1135C25-M5T1y S-1135C25-A6T1U 2.6 V ±1.0% S-1135C26-U5T1x S-1135C26-M5T1y S-1135C26-A6T1U 2.7 V ±1.0% S-1135C27-U5T1x S-1135C27-M5T1y S-1135C27-A6T1U 2.8 V ±1.0% S-1135C28-U5T1x S-1135C28-M5T1y S-1135C28-A6T1U 2.85 V ±1.0% S-1135C2J-U5T1x S-1135C2J-M5T1y S-1135C2J-A6T1U 2.9 V ±1.0% S-1135C29-U5T1x S-1135C29-M5T1y S-1135C29-A6T1U 3.0 V ±1.0% S-1135C30-U5T1x S-1135C30-M5T1y S-1135C30-A6T1U 3.1 V ±1.0% S-1135C31-U5T1x S-1135C31-M5T1y S-1135C31-A6T1U 3.2 V ±1.0% S-1135C32-U5T1x S-1135C32-M5T1y S-1135C32-A6T1U 3.3 V ±1.0% S-1135C33-U5T1x S-1135C33-M5T1y S-1135C33-A6T1U 3.4 V ±1.0% S-1135C34-U5T1x S-1135C34-M5T1y S-1135C34-A6T1U 3.5 V ±1.0% S-1135C35-U5T1x S-1135C35-M5T1y S-1135C35-A6T1U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 10 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 4. 4 S-1135 Series D type ON / OFF logic: Discharge shunt function: Active “H” Unavailable Pull-up resistor: Pull-down resistor: Unavailable Unavailable Table 5 Output Voltage SOT-89-5 SOT-23-5 HSNT-6A 1.0 V ±15 mV S-1135D10-U5T1x S-1135D10-M5T1y S-1135D10-A6T1U 1.1 V ±15 mV S-1135D11-U5T1x S-1135D11-M5T1y S-1135D11-A6T1U 1.2 V ±15 mV S-1135D12-U5T1x S-1135D12-M5T1y S-1135D12-A6T1U 1.3 V ±15 mV S-1135D13-U5T1x S-1135D13-M5T1y S-1135D13-A6T1U 1.4 V ±15 mV S-1135D14-U5T1x S-1135D14-M5T1y S-1135D14-A6T1U 1.5 V ±1.0% S-1135D15-U5T1x S-1135D15-M5T1y S-1135D15-A6T1U 1.6 V ±1.0% S-1135D16-U5T1x S-1135D16-M5T1y S-1135D16-A6T1U 1.7 V ±1.0% S-1135D17-U5T1x S-1135D17-M5T1y S-1135D17-A6T1U 1.8 V ±1.0% S-1135D18-U5T1x S-1135D18-M5T1y S-1135D18-A6T1U 1.85 V ±1.0% S-1135D1J-U5T1x S-1135D1J-M5T1y S-1135D1J-A6T1U 1.9 V ±1.0% S-1135D19-U5T1x S-1135D19-M5T1y S-1135D19-A6T1U 2.0 V ±1.0% S-1135D20-U5T1x S-1135D20-M5T1y S-1135D20-A6T1U 2.1 V ±1.0% S-1135D21-U5T1x S-1135D21-M5T1y S-1135D21-A6T1U 2.2 V ±1.0% S-1135D22-U5T1x S-1135D22-M5T1y S-1135D22-A6T1U 2.3 V ±1.0% S-1135D23-U5T1x S-1135D23-M5T1y S-1135D23-A6T1U 2.4 V ±1.0% S-1135D24-U5T1x S-1135D24-M5T1y S-1135D24-A6T1U 2.5 V ±1.0% S-1135D25-U5T1x S-1135D25-M5T1y S-1135D25-A6T1U 2.6 V ±1.0% S-1135D26-U5T1x S-1135D26-M5T1y S-1135D26-A6T1U 2.7 V ±1.0% S-1135D27-U5T1x S-1135D27-M5T1y S-1135D27-A6T1U 2.8 V ±1.0% S-1135D28-U5T1x S-1135D28-M5T1y S-1135D28-A6T1U 2.85 V ±1.0% S-1135D2J-U5T1x S-1135D2J-M5T1y S-1135D2J-A6T1U 2.9 V ±1.0% S-1135D29-U5T1x S-1135D29-M5T1y S-1135D29-A6T1U 3.0 V ±1.0% S-1135D30-U5T1x S-1135D30-M5T1y S-1135D30-A6T1U 3.1 V ±1.0% S-1135D31-U5T1x S-1135D31-M5T1y S-1135D31-A6T1U 3.2 V ±1.0% S-1135D32-U5T1x S-1135D32-M5T1y S-1135D32-A6T1U 3.3 V ±1.0% S-1135D33-U5T1x S-1135D33-M5T1y S-1135D33-A6T1U 3.4 V ±1.0% S-1135D34-U5T1x S-1135D34-M5T1y S-1135D34-A6T1U 3.5 V ±1.0% S-1135D35-U5T1x S-1135D35-M5T1y S-1135D35-A6T1U Remark 1. Please contact our sales office for products with specifications other than the above. 2. x: G or U y: S or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 11 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Pin Configurations 1. SOT-89-5 Top view 5 Pin No. 1 2 3 4 5 4 1 2 Table 6 Symbol Description VOUT Output voltage pin VSS GND pin No connection NC*1 ON / OFF ON / OFF pin VIN Input voltage pin 3 Figure 9 *1. 2. The NC pin is electrically open. The NC pin can be connected to VIN pin or VSS pin. SOT-23-5 Top view 5 Pin No. 1 2 3 4 5 4 1 2 3 Table 7 Symbol Description VIN Input voltage pin VSS GND pin ON / OFF ON / OFF pin No connection NC*1 VOUT Output voltage pin Figure 10 *1. 3. The NC pin is electrically open. The NC pin can be connected to VIN pin or VSS pin. HSNT-6A Top view 1 2 3 6 5 4 Bottom view 6 5 4 1 2 3 Pin No. 1 2 3 4 5 6 Table 8 Symbol Description VOUT Output voltage pin VSS GND pin No connection NC*2 ON / OFF ON / OFF pin No connection NC*2 VIN Input voltage pin *1 Figure 11 Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. *2. The NC pin is electrically open. The NC pin can be connected to VIN pin or VSS pin. *1. 12 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Absolute Maximum Ratings Table 9 Item Symbol VIN VON / OFF VOUT Input voltage Output voltage SOT-89-5 PD SOT-23-5 HSNT-6A Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm × 76.2 mm × t1.6 mm (2) Name : JEDEC STANDARD51-7 *2. When mounted on board [Mounted board] (1) Board size : 50 mm × 50 mm × t1.6 mm (2) Wiring ratio : 50% Power dissipation VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VIN + 0.3 VSS − 0.3 to VIN + 0.3 1000*1 600*1 1000*2 −40 to +85 −40 to +125 V V V mW mW mW °C °C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 1200 Power Dissipation (PD) [mW] Caution (Ta = 25°C unless otherwise specified) Absolute Maximum Rating Unit 1000 SOT-89-5 HSNT-6A 800 600 400 SOT-23-5 200 0 0 150 100 50 Ambient Temperature (Ta) [°C] Figure 12 Power Dissipation of Package 13 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Electrical Characteristics Table 10 (1 / 2) Item Output voltage Output current *1 *2 Symbol 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.6 V 2.6 V ≤ VOUT(S) ≤ 3.5 V VOUT(S) − 0.015 VOUT(S) × 0.99 300*5 0.50 ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ ⎯ 1.0 V ≤ VOUT(S) < 1.1 V ⎯ 0.05 0.2 %/V 1 1.1 V ≤ VOUT(S) ≤ 3.5 V ⎯ 0.05 0.2 %/V 1 1.0 V ≤ VOUT(S) ≤ 2.0 V 2.0 V < VOUT(S) ≤ 3.5 V 1.0 V ≤ VOUT(S) ≤ 3.0 V VIN = VOUT(S) + 1.0 V, 1.0 mA ≤ IOUT ≤ 300 mA 3.0 V < VOUT(S) ≤ 3.5 V VIN = VOUT(S) + 1.0 V, IOUT = 100 mA, −40°C ≤ Ta ≤ +85°C ⎯ ⎯ ⎯ ⎯ 15 15 30 30 20 25 40 45 mV mV mV mV 1 1 1 1 ⎯ ±130 ⎯ ppm/°C 1 ISS1 VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load ⎯ 45 65 μA 2 VOUT(E) IOUT Dropout voltage*3 Vdrop Line regulation ΔVOUT1 ΔVIN• VOUT Load regulation Conditions (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit ΔVOUT2 ΔVOUT ΔTa • VOUT VIN = VOUT(S) + 1.0 V, IOUT = 100 mA 1.0 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 3.5 V VIN ≥ VOUT(S) + 1.0 V IOUT = 300 mA 1.6 V ≤ VIN ≤ 5.5 V, IOUT = 100 mA VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 100 mA VIN = VOUT(S) + 1.0 V, 1.0 mA ≤ IOUT ≤ 150 mA ⎯ 0.61 0.49 0.38 0.31 0.27 0.25 0.21 0.16 VOUT(S) + 0.015 VOUT(S) × 1.01 ⎯ 0.72 0.61 0.53 0.47 0.41 0.38 0.32 0.26 VOUT(S) VOUT(S) V 1 V 1 mA V V V V V V V V 3 1 1 1 1 1 1 1 1 Output voltage *4 temperature coefficient Current consumption during operation Current consumption during power-off Input voltage ON / OFF pin input voltage “H” ON / OFF pin input voltage “L” ON / OFF pin input current “H” ISS2 VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load ⎯ 0.1 1.0 μA 2 VIN 1.5 ⎯ 5.5 V ⎯ 1.0 ⎯ ⎯ V 4 ⎯ ⎯ 0.3 V 4 ON / OFF pin input current “L” ISL ⎯ VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level B / D / E / F / G / H type VIN = 5.5 V, VON / OFF = 5.5 V A / C type A / B / C / D / F / H type VIN = 5.5 V, VON / OFF = 0 V E / G type VIN = VOUT(S) + 1.0 V, 1.0 V ≤ VOUT(S) ≤ 1.2 V f = 1.0 kHz, ΔVrip = 0.5 Vrms, 1.2 V < VOUT(S) ≤ 3.5 V IOUT = 50 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V −0.1 1.0 −0.1 1.0 ⎯ 2.5 ⎯ 2.5 0.1 5.0 0.1 5.0 μA μA μA μA 4 4 4 4 ⎯ 70 ⎯ dB 5 ⎯ 65 ⎯ dB 5 ⎯ 100 ⎯ mA 3 Ripple rejection Short-circuit current 14 VSH VSL ISH RR Ishort 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 Table 10 (2 / 2) S-1135 Series A / B / E / F type (With discharge shunt function) Item Discharge shunt resistance during power-off Symbol RLOW Conditions VOUT = 0.1 V, VIN = 5.5 V Min. Typ. Max. Unit Test Circuit ⎯ 35 ⎯ Ω 3 Min. Typ. Max. Unit Test Circuit S-1135 Series A / C / E / G type (With pull-up / pull-down resistor) Item Symbol Conditions Power-off pull-up / RPD ⎯ 1.0 2.2 5.0 MΩ 4 pull-down resistor *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT(= 100 mA) and inputting VOUT(S) +1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 300 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔV ΔVOUT [mV/°C]*1 = VOUT(S)[V]*2 × ΔTa •OUT [ppm/°C]*3 ÷ 1000 ΔTa VOUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 15 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Test Circuits 1. + VOUT VIN ON / OFF V VSS A + Set to ON Figure 13 2. + A VOUT VIN ON / OFF VSS Set to VIN or GND Figure 14 3. VOUT VIN ON / OFF VSS A V + Set to VIN or GND Figure 15 4. VOUT VIN + A ON / OFF VSS V + RL Figure 16 5. VOUT VIN ON / OFF VSS Set to ON Figure 17 16 V + RL 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Standard Circuit Input Output VOUT VIN CIN *1 ON / OFF VSS Single GND *1. *2. CL *2 GND CIN is a capacitor for stabilizing the input. A ceramic capacitor of 1.0 μF or more can be used as CL. Figure 18 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants.  Condition of Application Input capacitor (CIN) : Output capacitor (CL) : 1.0 μF or more 1.0 μF or more Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) The S-1135 Series requires an output capacitor between the VOUT pin and VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 1.0 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 1.0 μF or more. The value of the output overshoot or undershoot transient response varies depending on the value of the output capacitor. The required capacitance of the input capacitor differs depending on the application. The recommended capacitance for an application is CIN ≥ 1.0 μF, CL ≥ 1.0 μF; however, when selecting the output capacitor, perform sufficient evaluation, including evaluation of temperature characteristics, on the actual device. 17 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. *1. *2. When VOUT < 1.5 V : ±15 mV, When 1.5 V ≤ VOUT : ±1.0% Differs depending on the product. Caution 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical Data)” for details. ΔVOUT1  ΔVIN • VOUT  Line regulation  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 18 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 6. ΔVOUT  ΔTa • VOUT  Output voltage temperature coefficient  The shaded area in Figure 19 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±130 ppm/°C. Example of S-1135B30 typ. product VOUT [V] +0.39 mV/°C VOUT(E) *1 −0.39 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 19 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔV ΔVOUT [mV/°C]*1 = VOUT(S)[V]*2 × ΔTa •OUT [ppm/°C]*3 ÷ 1000 ΔTa VOUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 19 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Operation 1. Basic operation Figure 20 shows the block diagram of the S-1135 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 20 2. Output transistor In the S-1135 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 20 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 3. ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and VOUT pin is turned off, reducing current consumption significantly. Since the S-1135 Series A / B / E / F type has a built-in discharge shunt circuit to discharge the output capacitance, the VOUT pin is forcibly set to VSS level. In the S-1135 Series C / D / G / H type, the VOUT pin is set to VSS level through several hundred kΩ internal divided resistors between the VOUT pin and VSS pin. Note that the current consumption increases when a voltage of 0.3 V to 1.0 V (Ta = 25°C) is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figures 21 and 22. In the S-1135 Series A / C / E / G type, the ON / OFF pin is internally pulled up to the VIN pin or pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. In the S-1135 Series B / D / F / H type, the ON / OFF pin is not internally pulled up or pulled down, so do not use the ON / OFF pin in the floating status. When not using the ON / OFF pin, connect it to the VIN pin in the product B / D type, and connect it to the VSS pin in the F / H type. Table 11 Product Type ON / OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption A/B/C/D “H”: ON Operate Set value ISS1*1 A/B/C/D “L”: OFF Stop VSS level ISS2 E/F/G/H “H”: OFF Stop VSS level ISS2 E/F/G/H “L”: ON Operate Set value ISS1*1 *1. Note that the IC’s current consumption increases as much as current flows into the pull-up / pull-down resistor when; the ON / OFF pin is connected to the VIN pin in the A / C type, the ON / OFF pin is connected to the VSS pin in the E / G type (Refer to Figure 21). (1) S-1135 Series A / C / E / G type (2) S-1135 Series B / D / F / H type VIN VIN E / G type ON / OFF ON / OFF A / C type VSS Figure 21 VSS Figure 22 21 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 4. Rev.2.3_00 Discharge shunt function (S-1135 Series A / B / E / F type) The S-1135 Series A / B / E / F type has a built-in discharge shunt circuit to discharge the output capacitance. When the ON / OFF pin is set to OFF level, turns the output transistor off, and turns the discharge shunt circuit on so that the output capacitor discharges. These types allow the VOUT pin to reach the VSS level faster than the S-1135 Series C / D / G / H type that does not have a discharge shunt circuit. S-1135 Series Output transistor : OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF pin : OFF Current flow GND VSS *1. Parasitic diode Figure 23 22 Rev.2.3_00 5. 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Overcurrent protection circuit The S-1135 Series has an overcurrent protection circuit having the characteristics shown in “1. Output Voltage vs. Output Current (When Load Current Increases) (Ta = 25°C)” in “ Characteristics (Typical Data)”, in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 100 mA (typ.), and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 6. Pull-down / pull-up resistor (S-1135 Series A / C / E / G type) In the S-1135 Series A / C / E / G type, the ON / OFF pin is internally pulled up to the VIN pin or pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC’s current consumption increases as much as current flows into the pull-up / pull-down resistor of 2.2 MΩ (typ.) when; the ON / OFF pin is connected to the VIN pin in the A / C type, the ON / OFF pin is connected to the VSS pin in the E / G type. 23 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and VSS pin (CL) and a capacitor for stabilizing the input between the VIN pin and VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1135 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to “5. Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = 25°C)” in “ Reference Data” for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN) : Output capacitor (CL) : 1.0 μF or more 1.0 μF or more • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply’s fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage’s fluctuation with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 10 in “ Electrical Characteristics” and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 24 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Characteristics (Typical Data) Output Voltage vs. Output Current (When Load Current Increases) (Ta = 25°C) VOUT = 2.5 V 3.0 1.0 2.5 0.8 VOUT [V] VOUT = 1.0 V 1.2 VOUT [V] 1. VIN = 1.3 V 1.5 V 2.0 V 3.0 V 5.5 V 0.6 0.4 0.2 1.5 1.0 0.5 0 0 0 100 200 300 400 IOUT [mA] 500 100 200 300 400 IOUT [mA] 0 600 VIN = 3.8 V 4.0 V 4.5 V 5.5 V VOUT [V] VOUT = 3.5 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 0 Remark 500 100 200 300 400 IOUT [mA] 500 600 In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 10 in the “ Electrical Characteristics” 2. The package power dissipation 600 Output Voltage vs. Input Voltage (Ta = 25°C) VOUT = 1.0 V 1.2 1.0 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 0.9 0.8 0.7 0.6 0.6 VOUT = 3.5 V 3.7 3.6 3.5 3.4 3.3 3.2 3.1 3.0 3.0 1.0 1.4 1.8 VIN [V] VOUT = 2.5 V 2.7 2.6 2.5 2.4 2.3 2.2 2.1 2.0 2.0 VOUT [V] VOUT [V] 1.1 VOUT [V] 2. VIN = 2.8 V 3.0 V 3.5 V 4.5 V 5.5 V 2.0 2.2 2.6 5.0 5.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 2.5 3.0 3.5 VIN [V] 4.0 4.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 3.5 4.0 4.5 VIN [V] 25 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Dropout Voltage vs. Output Current −40°C Vdrop [V] VOUT = 1.0 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 0 Vdrop [V] VOUT = 3.5 V 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 0 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 150 200 IOUT [mA] 250 300 250 300 Ta = 85°C 25°C −40°C 50 100 150 200 IOUT [mA] IOUT = 300 mA 150 mA 100 mA 50 mA 1.0 26 100 Dropout Voltage vs. Set Output Voltage Vdrop [V] 4. Ta = 85°C 25°C 50 1.5 30 mA 2.0 2.5 VOUT(S) [V] VOUT = 2.5 V 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 0 Vdrop [V] 3. Rev.2.3_00 10 mA 3.0 1 mA 3.5 Ta = 85°C 25°C −40°C 50 100 150 200 IOUT [mA] 250 300 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 5. Output Voltage vs. Ambient Temperature VOUT = 1.0 V 1.10 VOUT [V] VOUT [V] 1.05 VOUT = 2.5 V 2.70 2.65 2.60 2.55 2.50 2.45 2.40 2.35 2.30 −40 −25 1.00 0.95 0.90 −40 −25 0 25 Ta [°C] 50 75 85 50 75 85 0 25 Ta [°C] 50 75 85 VOUT = 3.5 V 3.8 VOUT [V] 3.7 3.6 3.5 3.4 3.3 3.2 −40 −25 25 Ta [°C] Current Consumption vs. Input Voltage VOUT = 3.5 V 70 60 50 40 30 20 10 0 0 −40°C 1 2 3 VIN [V] 25°C 4 VOUT = 2.5 V 70 60 50 40 30 20 10 0 0 Ta = 85°C ISS1 [μA] Ta = 85°C ISS1 [μA] VOUT = 1.0 V 70 60 50 40 30 20 10 0 0 5 6 −40°C 1 2 3 VIN [V] 4 25°C 5 6 Ta = 85°C ISS1 [μA] 6. 0 25°C −40°C 1 2 3 VIN [V] 4 5 6 27 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 7. Rev.2.3_00 Ripple Rejection (Ta = 25°C) VOUT = 1.0 V VOUT = 2.5 V 100 80 IOUT = 1 mA 60 40 IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 20 0 10 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.5 V Ripple Rejection [dB] VIN = 4.5 V, CL = 1.0 μF 100 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA 80 60 40 20 IOUT = 100 mA 0 10 28 100 1k 10k 100k Frequency [Hz] VIN = 3.5 V, CL = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.0 V, CL = 1.0 μF 1M 100 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA 80 60 40 20 IOUT = 100 mA 0 10 100 1k 10k 100k Frequency [Hz] 1M 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Reference Data 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 VOUT [V] Transient Response Characteristics of Load (Ta = 25°C) IOUT 1.05 1.00 100 2.65 50 2.60 0 VOUT −50 IOUT [mA] VOUT [V] 1.15 1.10 VOUT = 2.5 V VIN = 3.5 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 150 2.70 2.55 2.50 50 0 VOUT 0.95 −100 2.45 0.90 −100 −50 0 −150 2.40 −100 −50 0 50 100 150 200 250 300 350 t [μs] 100 IOUT −50 IOUT [mA] VOUT = 1.0 V VIN = 2.0 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 150 1.20 VOUT [V] 2. 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 VIN [V] VOUT = 3.5 V IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF 3.80 3.75 3.70 VIN 3.65 3.60 3.55 VOUT 3.50 3.45 3.40 −100 −50 0 50 100 150 200 250 300 350 t [μs] VOUT = 2.5 V IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF 2.80 2.75 2.70 VIN 2.65 2.60 2.55 VOUT 2.50 2.45 2.40 −100 −50 0 50 100 150 200 250 300 350 t [μs] VOUT [V] 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT [V] VOUT = 1.0 V IOUT = 100 mA, tr = tf = 5.0 μs, CL = 1.0 μF 1.30 1.25 1.20 1.15 VIN 1.10 1.05 VOUT 1.00 0.95 0.90 −100 −50 0 50 100 150 200 250 300 350 t [μs] VIN [V] Transient Response Characteristics when Input (Ta = 25°C) VIN [V] 1. −100 −150 50 100 150 200 250 300 350 t [μs] VOUT = 3.5 V VIN = 4.5 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 150 3.70 100 IOUT 50 3.60 3.55 3.50 0 VOUT −50 −100 3.45 3.40 −100 −50 0 IOUT [mA] VOUT [V] 3.65 −150 50 100 150 200 250 300 350 t [μs] 29 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Transient Response Characteristics of ON / OFF Pin (Ta = 25°C) 1 0 1.2 0.8 5 2 VON / OFF 1.6 −1 VOUT VON / OFF [V] VOUT [V] 2.0 VOUT = 2.5 V VIN = 3.5 V, tr = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 6 6 −2 1 −3 0 50 100 t [μs] 150 0 2 0 0 −2 VOUT −4 −50 200 2 3 0.4 −50 4 VON / OFF 4 VON / OFF [V] VOUT = 1.0 V VIN = 2.0 V, tr = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 3 2.4 VOUT [V] 3. Rev.2.3_00 −6 0 50 100 t [μs] 150 200 VOUT = 3.5 V VIN = 4.5 V, tr = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 6 6 4 VON / OFF 2 4 0 VOUT 3 2 −2 1 −4 −6 0 −50 4. VON / OFF [V] VOUT [V] 5 0 50 100 t [μs] 150 200 Output Capacitance vs. Characteristics of Discharge Time (Ta = 25°C) S-1135 Series A / B type (with discharge shunt function) VIN = VOUT + 1.0 V, IOUT = no load VON / OFF = VOUT + 1.0 V → VSS, tf = 1 μs 1 μs VON / OFF 2.5 VOUT(s) = 1.0 V 2.5 V 3.5 V tDSC [ms] 2.0 1.5 VSS tDSC VOUT 1.0 0.5 VOUT × 10% 0 0 2 4 6 CL [μF] Figure 24 30 8 10 12 VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 25 Measurement Condition of Discharge Time 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = 25°C) CIN = CL = 1.0 μF 100 VIN RESR [Ω] 5. CIN Stable ON / OFF 0 0.1 S-1135 Series VOUT CL*1 VSS 300 RESR IOUT [mA] *1. Figure 26 CL : TAIYO YUDEN TMK316BJ105KD (1.0 μF) Figure 27 31 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00  Marking Specifications 1. SOT-89-5 Top view 1 (1) to (3) (4) to (6) : Product code (Refer to Product name vs. Product code) : Lot number (4) (5) (6) 4 (1) (2) (3) 5 2 3 Product name vs. Product code (a) S-1135 Series A type Product Name (b) S-1135 Series B type Product code (1) (2) (3) S E A S E B S E C S E D S E E S E F S E G S E H S E I S E J S E K S E L S E M S E N S E O S E P S E Q S E R S E S S E T S E U S E V S E W S E X S E Y S E Z S E 2 S E 3 Product Name Product code (1) (2) (3) S G A S G B S G C S G D S G E S G F S G G S G H S G I S G J S G K S G L S G M S G N S G O S G P S G Q S G R S G S S G T S G U S G V S G W S G X S G Y S G Z S G 2 S G 3 S-1135A10-U5T1x S-1135B10-U5T1x S-1135A11-U5T1x S-1135B11-U5T1x S-1135A12-U5T1x S-1135B12-U5T1x S-1135A13-U5T1x S-1135B13-U5T1x S-1135A14-U5T1x S-1135B14-U5T1x S-1135A15-U5T1x S-1135B15-U5T1x S-1135A16-U5T1x S-1135B16-U5T1x S-1135A17-U5T1x S-1135B17-U5T1x S-1135A18-U5T1x S-1135B18-U5T1x S-1135A1J-U5T1x S-1135B1J-U5T1x S-1135A19-U5T1x S-1135B19-U5T1x S-1135A20-U5T1x S-1135B20-U5T1x S-1135A21-U5T1x S-1135B21-U5T1x S-1135A22-U5T1x S-1135B22-U5T1x S-1135A23-U5T1x S-1135B23-U5T1x S-1135A24-U5T1x S-1135B24-U5T1x S-1135A25-U5T1x S-1135B25-U5T1x S-1135A26-U5T1x S-1135B26-U5T1x S-1135A27-U5T1x S-1135B27-U5T1x S-1135A28-U5T1x S-1135B28-U5T1x S-1135A2J-U5T1x S-1135B2J-U5T1x S-1135A29-U5T1x S-1135B29-U5T1x S-1135A30-U5T1x S-1135B30-U5T1x S-1135A31-U5T1x S-1135B31-U5T1x S-1135A32-U5T1x S-1135B32-U5T1x S-1135A33-U5T1x S-1135B33-U5T1x S-1135A34-U5T1x S-1135B34-U5T1x S-1135A10-U5T1x S-1135B35-U5T1x Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 32 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 (c) S-1135 Series C type Product Name (d) S-1135 Series D type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) A A A B A C A D A E A F A G A H A I A J A K A L A M A N A O A P A Q A R A S A T A U A V A W A X A Y A Z A 2 A 3 Product Name (1) V V V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) B A B B B C B D B E B F B G B H B I B J B K B L B M B N B O B P B Q B R B S B T B U B V B W B X B Y B Z B 2 B 3 S-1135C10-U5T1x S-1135D10-U5T1x S-1135C11-U5T1x S-1135D11-U5T1x S-1135C12-U5T1x S-1135D12-U5T1x S-1135C13-U5T1x S-1135D13-U5T1x S-1135C14-U5T1x S-1135D14-U5T1x S-1135C15-U5T1x S-1135D15-U5T1x S-1135C16-U5T1x S-1135D16-U5T1x S-1135C17-U5T1x S-1135D17-U5T1x S-1135C18-U5T1x S-1135D18-U5T1x S-1135C1J-U5T1x S-1135D1J-U5T1x S-1135C19-U5T1x S-1135D19-U5T1x S-1135C20-U5T1x S-1135D20-U5T1x S-1135C21-U5T1x S-1135D21-U5T1x S-1135C22-U5T1x S-1135D22-U5T1x S-1135C23-U5T1x S-1135D23-U5T1x S-1135C24-U5T1x S-1135D24-U5T1x S-1135C25-U5T1x S-1135D25-U5T1x S-1135C26-U5T1x S-1135D26-U5T1x S-1135C27-U5T1x S-1135D27-U5T1x S-1135C28-U5T1x S-1135D28-U5T1x S-1135C2J-U5T1x S-1135D2J-U5T1x S-1135C29-U5T1x S-1135D29-U5T1x S-1135C30-U5T1x S-1135D30-U5T1x S-1135C31-U5T1x S-1135D31-U5T1x S-1135C32-U5T1x S-1135D32-U5T1x S-1135C33-U5T1x S-1135D33-U5T1x S-1135C34-U5T1x S-1135D34-U5T1x S-1135C35-U5T1x S-1135D35-U5T1x Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 33 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 2. Rev.2.3_00 SOT-23-5 Top view 5 (1) to (3) (4) 4 : Product code (Refer to Product name vs. Product code) : Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code (a) S-1135 Series A type Product Name (b) S-1135 Series B type (1) S S S S S S S S S S S S S S S S S S S S S S S S S S S S Product code (2) (3) E A E B E C E D E E E F E G E H E I E J E K E L E M E N E O E P E Q E R E S E T E U E V E W E X E Y E Z E 2 E 3 Product Name (1) S S S S S S S S S S S S S S S S S S S S S S S S S S S S Product code (2) (3) G A G B G C G D G E G F G G G H G I G J G K G L G M G N G O G P G Q G R G S G T G U G V G W G X G Y G Z G 2 G 3 S-1135A10-M5T1y S-1135B10-M5T1y S-1135A11-M5T1y S-1135B11-M5T1y S-1135A12-M5T1y S-1135B12-M5T1y S-1135A13-M5T1y S-1135B13-M5T1y S-1135A14-M5T1y S-1135B14-M5T1y S-1135A15-M5T1y S-1135B15-M5T1y S-1135A16-M5T1y S-1135B16-M5T1y S-1135A17-M5T1y S-1135B17-M5T1y S-1135A18-M5T1y S-1135B18-M5T1y S-1135A1J-M5T1y S-1135B1J-M5T1y S-1135A19-M5T1y S-1135B19-M5T1y S-1135A20-M5T1y S-1135B20-M5T1y S-1135A21-M5T1y S-1135B21-M5T1y S-1135A22-M5T1y S-1135B22-M5T1y S-1135A23-M5T1y S-1135B23-M5T1y S-1135A24-M5T1y S-1135B24-M5T1y S-1135A25-M5T1y S-1135B25-M5T1y S-1135A26-M5T1y S-1135B26-M5T1y S-1135A27-M5T1y S-1135B27-M5T1y S-1135A28-M5T1y S-1135B28-M5T1y S-1135A2J-M5T1y S-1135B2J-M5T1y S-1135A29-M5T1y S-1135B29-M5T1y S-1135A30-M5T1y S-1135B30-M5T1y S-1135A31-M5T1y S-1135B31-M5T1y S-1135A32-M5T1y S-1135B32-M5T1y S-1135A33-M5T1y S-1135B33-M5T1y S-1135A34-M5T1y S-1135B34-M5T1y S-1135A35-M5T1y S-1135B35-M5T1y Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 34 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 (c) S-1135 Series C type Product Name (d) S-1135 Series D type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) A A A B A C A D A E A F A G A H A I A J A K A L A M A N A O A P A Q A R A S A T A U A V A W A X A Y A Z A 2 A 3 Product Name (1) V V V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) B A B B B C B D B E B F B G B H B I B J B K B L B M B N B O B P B Q B R B S B T B U B V B W B X B Y B Z B 2 B 3 S-1135C10-M5T1y S-1135D10-M5T1y S-1135C11-M5T1y S-1135D11-M5T1y S-1135C12-M5T1y S-1135D12-M5T1y S-1135C13-M5T1y S-1135D13-M5T1y S-1135C14-M5T1y S-1135D14-M5T1y S-1135C15-M5T1y S-1135D15-M5T1y S-1135C16-M5T1y S-1135D16-M5T1y S-1135C17-M5T1y S-1135D17-M5T1y S-1135C18-M5T1y S-1135D18-M5T1y S-1135C1J-M5T1y S-1135D1J-M5T1y S-1135C19-M5T1y S-1135D19-M5T1y S-1135C20-M5T1y S-1135D20-M5T1y S-1135C21-M5T1y S-1135D21-M5T1y S-1135C22-M5T1y S-1135D22-M5T1y S-1135C23-M5T1y S-1135D23-M5T1y S-1135C24-M5T1y S-1135D24-M5T1y S-1135C25-M5T1y S-1135D25-M5T1y S-1135C26-M5T1y S-1135D26-M5T1y S-1135C27-M5T1y S-1135D27-M5T1y S-1135C28-M5T1y S-1135D28-M5T1y S-1135C2J-M5T1y S-1135D2J-M5T1y S-1135C29-M5T1y S-1135D29-M5T1y S-1135C30-M5T1y S-1135D30-M5T1y S-1135C31-M5T1y S-1135D31-M5T1y S-1135C32-M5T1y S-1135D32-M5T1y S-1135C33-M5T1y S-1135D33-M5T1y S-1135C34-M5T1y S-1135D34-M5T1y S-1135C35-M5T1y S-1135D35-M5T1y Remark 1. y: S or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 35 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series 3. Rev.2.3_00 HSNT-6A Top view 6 5 4 (1) to (3) (4) (5) to (9) (1) (2) (3) : Product code (Refer to Product name vs. Product code) : Blank : Lot number (4) (5) (6) (7) (8) (9) 1 2 3 Product name vs. Product code (a) S-1135 Series A type Product Name S-1135A10-A6T1U S-1135A11-A6T1U S-1135A12-A6T1U S-1135A13-A6T1U S-1135A14-A6T1U S-1135A15-A6T1U S-1135A16-A6T1U S-1135A17-A6T1U S-1135A18-A6T1U S-1135A1J-A6T1U S-1135A19-A6T1U S-1135A20-A6T1U S-1135A21-A6T1U S-1135A22-A6T1U S-1135A23-A6T1U S-1135A24-A6T1U S-1135A25-A6T1U S-1135A26-A6T1U S-1135A27-A6T1U S-1135A28-A6T1U S-1135A2J-A6T1U S-1135A29-A6T1U S-1135A30-A6T1U S-1135A31-A6T1U S-1135A32-A6T1U S-1135A33-A6T1U S-1135A34-A6T1U S-1135A35-A6T1U 36 (b) S-1135 Series B type (1) S S S S S S S S S S S S S S S S S S S S S S S S S S S S Product code (2) (3) E A E B E C E D E E E F E G E H E I E J E K E L E M E N E O E P E Q E R E S E T E U E V E W E X E Y E Z E 2 E 3 Product Name S-1135B10-A6T1U S-1135B11-A6T1U S-1135B12-A6T1U S-1135B13-A6T1U S-1135B14-A6T1U S-1135B15-A6T1U S-1135B16-A6T1U S-1135B17-A6T1U S-1135B18-A6T1U S-1135B1J-A6T1U S-1135B19-A6T1U S-1135B20-A6T1U S-1135B21-A6T1U S-1135B22-A6T1U S-1135B23-A6T1U S-1135B24-A6T1U S-1135B25-A6T1U S-1135B26-A6T1U S-1135B27-A6T1U S-1135B28-A6T1U S-1135B2J-A6T1U S-1135B29-A6T1U S-1135B30-A6T1U S-1135B31-A6T1U S-1135B32-A6T1U S-1135B33-A6T1U S-1135B34-A6T1U S-1135B35-A6T1U (1) S S S S S S S S S S S S S S S S S S S S S S S S S S S S Product code (2) (3) G A G B G C G D G E G F G G G H G I G J G K G L G M G N G O G P G Q G R G S G T G U G V G W G X G Y G Z G 2 G 3 5.5 V INPUT, 300 mA VOLTAGE REGULATOR S-1135 Series Rev.2.3_00 (c) S-1135 Series C type Product Name S-1135C10-A6T1U S-1135C11-A6T1U S-1135C12-A6T1U S-1135C13-A6T1U S-1135C14-A6T1U S-1135C15-A6T1U S-1135C16-A6T1U S-1135C17-A6T1U S-1135C18-A6T1U S-1135C1J-A6T1U S-1135C19-A6T1U S-1135C20-A6T1U S-1135C21-A6T1U S-1135C22-A6T1U S-1135C23-A6T1U S-1135C24-A6T1U S-1135C25-A6T1U S-1135C26-A6T1U S-1135C27-A6T1U S-1135C28-A6T1U S-1135C2J-A6T1U S-1135C29-A6T1U S-1135C30-A6T1U S-1135C31-A6T1U S-1135C32-A6T1U S-1135C33-A6T1U S-1135C34-A6T1U S-1135C35-A6T1U (d) S-1135 Series D type (1) V V V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) A A A B A C A D A E A F A G A H A I A J A K A L A M A N A O A P A Q A R A S A T A U A V A W A X A Y A Z A 2 A 3 Product Name S-1135D10-A6T1U S-1135D11-A6T1U S-1135D12-A6T1U S-1135D13-A6T1U S-1135D14-A6T1U S-1135D15-A6T1U S-1135D16-A6T1U S-1135D17-A6T1U S-1135D18-A6T1U S-1135D1J-A6T1U S-1135D19-A6T1U S-1135D20-A6T1U S-1135D21-A6T1U S-1135D22-A6T1U S-1135D23-A6T1U S-1135D24-A6T1U S-1135D25-A6T1U S-1135D26-A6T1U S-1135D27-A6T1U S-1135D28-A6T1U S-1135D2J-A6T1U S-1135D29-A6T1U S-1135D30-A6T1U S-1135D31-A6T1U S-1135D32-A6T1U S-1135D33-A6T1U S-1135D34-A6T1U S-1135D35-A6T1U (1) V V V V V V V V V V V V V V V V V V V V V V V V V V V V Product code (2) (3) B A B B B C B D B E B F B G B H B I B J B K B L B M B N B O B P B Q B R B S B T B U B V B W B X B Y B Z B 2 B 3 37 4.5±0.1 1.5±0.1 1.6±0.2 5 4 0.3 45° 1 2 3 1.5±0.1 1.5±0.1 0.4±0.05 0.4±0.1 0.4±0.1 0.45±0.1 No. UP005-A-P-SD-2.0 TITLE SOT895-A-PKG Dimensions No. UP005-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches : 40.0±0.2) ø1.5 +0.1 -0 2.0±0.05 +0.1 ø1.5 -0 0.3±0.05 8.0±0.1 2.0±0.1 4.75±0.1 3 2 1 4 5 Feed direction No. UP005-A-C-SD-2.0 TITLE SOT895-A-Carrier Tape UP005-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part (60°) (60°) No. UP005-A-R-SD-1.1 TITLE SOT895-A-Reel No. UP005-A-R-SD-1.1 ANGLE UNIT QTY. mm ABLIC Inc. 1,000 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 1.96±0.05 1.78±0.05 6 1 5 0.5 4 2 3 0.5 0.5 0.12±0.04 0.48±0.02 0.22±0.05 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PJ006-A-P-SD-3.1 TITLE HSNT-6A-A-PKG Dimensions No. PJ006-A-P-SD-3.1 ANGLE UNIT mm ABLIC Inc. +0.1 4.0±0.1 2.0±0.05 ø1.5 -0 ø0.5±0.1 2.25±0.05 0.25±0.05 0.65±0.05 4.0±0.1 3 21 0.5 0.5 0.5 0.5 0.5 0.5 4 5 6 Feed direction No. PJ006-A-C-SD-2.0 TITLE HSNT-6A-A-Carrier Tape No. PJ006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PJ006-A-R-SD-1.0 TITLE HSNT-6A-A-Reel No. PJ006-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 Land Recommendation 0.5 0.7 0.7 0.35 0.35 0.3 1.4 2.1 Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Stencil Opening 0.5 0.2 0.8 0.8 0.3 0.2 1.6 2.0 TITLE HSNT-6A-A -Land &Stencil Opening PJ006-A-LM-SD-1.1 No. ANGLE No. PJ006-A-LM-SD-1.1 UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1135B25-M5T1U
物料型号:S-1135 Series
器件简介: - S-1135系列是一款使用CMOS技术开发的正电压调节器集成电路。 - 它具有低 dropout 电压、高精度输出电压和低电流消耗(典型值为45μA)。 - 该系列支持1.0V至3.5V的输出电压,以0.05V为步进可调。
引脚分配: - SOT-89-5、SOT-23-5和HSNT-6A三种封装类型,具体引脚功能如下: - VOUT:输出电压引脚。 - VSS:地线引脚。 - VIN:输入电压引脚。 - ON/OFF:控制开关引脚,用于启动和停止调节器工作。 - NC:无连接引脚,电气上未连接,可以连接到VIN或VSS。
参数特性: - 输出电压精度:±1.0%(1.0V至1.45V输出产品:±15mV)。 - Dropout电压:典型值为160mV(2.6V输出产品,输出电流为300mA)。 - 工作时电流消耗:典型值为45μA,最大为65μA。 - 关闭电源时电流消耗:典型值为0.1μA,最大为1.0μA。 - 输出电流:可达300mA(VIN ≥ VOUT(S) + 1.0V)。
功能详解: - 内置过流保护电路,防止输出电流超出晶体管的电流容量。 - 内置ON/OFF电路,确保更长的电池寿命。 - 可选择是否启用放电分流功能和上拉/下拉功能。
应用信息: - 适用于电池供电设备、手机和便携设备的电源供应。
封装信息: - 提供SOT-89-5、SOT-23-5和HSNT-6A三种封装选项,以实现高密度安装。
S-1135B25-M5T1U 价格&库存
很抱歉,暂时无法提供与“S-1135B25-M5T1U”相匹配的价格&库存,您可以联系我们找货
