PA-830
PRESSURE TRANSDUCERS WITH AMP.
INTERNAL STRUCTURE
PA-830 (G 1/8)
5
3
4
1
2
Part name
■ FEATURES
● High corrosion resistance by double diaphragm structure
● Built-in amplifier circuit
● 2 types to choose from (Gauge and Absolute pressures)
● Incorporating temperature compensation function
(0 ~ 50 °C)
● Voltage output mode
● Available with a ※ VCR® fitting
1
Fitting
2
“O” ring
3
Housing
4
Compensation resistor board
5
Sealed liquid
Material
SUS 316L
(P15 or P12.5)
Fluoro-rubber
Aluminum
Ceramic
Silicone oil
■ MODEL NUMBER DESIGNATION
PA-830-102 A-05
Series name
Thermal error/Fitting
Rated pressure range
05:± 0.05 % F.S./°C, G 1/8
10:± 0.1 % F.S./°C, G 1/8
R2:± 0.05 % F.S./°C, R 1/4
VCR:± 0.05 % F.S./°C, VCR®
101:0 ~ 9.8 kPa {0 ~ 0.1 kgf/cm2}
351:0 ~ 34.3 kPa {0 ~ 0.35 kgf/cm2}
501:0 ~ 49.0 kPa {0 ~ 0.5 kgf/cm2}
102:0 ~ 98.1 kPa {0 ~ 1 kgf/cm2}
352:0 ~ 343 kPa {0 ~ 3.5 kgf/cm2}
103:0 ~ 981 kPa {0 ~ 10 kgf/cm2}
Pressure reference
G:Gauge
A:Absolute
V:Gauge (Vacuum)
※ Please refer to the LIST OF MODEL NUMBERS when placing orders.
※ VCR® is a registered trade name of Cajon Co.
CAJON® is a registered trade name of Swagelok Co.
Note: For handling of VCR fittings, please contact a service center of Swagelok Co.
PA-830
■ LIST OF MODEL NUMBERS
Pressure reference
Output
{% F.S./°C}
Thermal error
kPa {kgf/cm2}
0 ~ 9.8
Rated pressure range {0 ~ 0.1}
± 0.05
Fitting:R 1/4
Fitting:VCR
± 0.10
0 ~ 49.0
{0 ~ 0.5}
PA-830
-501G-05
PA-830
-501G-R2
PA-830
-501G-VCR
PA-830
PA-830
-101G-10 -501G-10
Fitting:G 1/8
Voltage
output
Gauge Absolute
Fitting:G 1/8
0 ~ 98.1
{0 ~ 1}
0 ~ 343
{0 ~ 3.5}
0 ~ 981
{0 ~ 10}
0 ~ − 98.1
{0 ~ − 1}
0 ~ 34.3
{0 ~ 0.35}
0 ~ 98.1
{0 ~ 1}
PA-830
-102G-05
PA-830
-102G-R2
PA-830
-102G-VCR
PA-830
-102G-10
PA-830
-352G-05
PA-830
-352G-R2
PA-830
-352G-VCR
PA-830
-352G-10
PA-830
-103G-05
PA-830
-103G-R2
PA-830
-103G-VCR
PA-830
-103G-10
PA-830
-102V-05
PA-830
-102V-R2
PA-830
-102V-VCR
PA-830
-102V-10
PA-830
-351A-05
PA-830
-351A-R2
PA-830
-351A-VCR
PA-830
-351A-10
PA-830
-102A-05
PA-830
-102A-R2
PA-830
-102A-VCR
PA-830
-102A-10
:Not available
※ Verify the above model numbers when placing orders.
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 12 V DC.
Item
PA-830
Model number
101G 501G 102G 352G 103G 102V 351A 102A
Pressure reference
Maximum pressure
General specifications
Break-down pressure
9.8 49.0 98.1 343 981
− 98.1 34.3 (abs) 98.1 (abs)
kPa {kgf/cm2}
{0.1} {0.5} {1} {3.5} {10} {−1} {0.35} {1}
19.6 98.1 196 686 1961 196
103 (abs)
196 (abs)
kPa {kgf/cm2}
{0.2} {1} {2} {7} {20} {2} {1.05} {2}
147
294
1030
2942
294
147 (abs) 294 (abs)
kPa {kgf/cm2} 29.4
{0.3} {1.5} {3} {10.5}
{30} {3} {1.5} {3}
Operating temp. range
°C
− 20 ~ 70
Compensated temp. range
°C
0 ~ 50
Operating humidity
Storage temp.
%RH
°C
Pressure medium
Insulation resistance
35 ~ 85(No condensation)
− 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum)
Corrosive gases/liquids compatible with SUS 316L
MΩ
minimum
Dielectric strength
100 (500 V DC)
500 V AC, 60 s(Leakage current 1 mA maximum)
Sealed liquid
Silicone oil
Pressure port
G 1/8 (PF 1/8)、R 1/4 (PT 1/4)、1/4 VCR® ※ 2
Net weight
Power
Gauge Absolute
g
Approx. 140
Supply voltage
V DC
12 ~ 24 ± 10 %
Ripple content
maximum
10 % (P-P)
Consumption current
mA
maximum
※ 1 PA-830-VCR : Also compatible with SUS316.
※ 2 An “O” ring is provided for only G1/8 type. (Positive pressure : P15, Negative/Absolute Pressure : P12.5)
※1
PA-830
Item
Output voltage
1~5
V DC
Zero voltage
V
1 ± 0.04 (at 25 °C)
Span voltage
V
4 ± 0.04 (at 25 °C)
mA
maximum
Output current
Analog output
PA-830
Model number
Linearity/Hysteresis
Thermal error
0 ~ 50 °C
(Reference temp.: 25 °C)
Supply voltage effect
Response
1(Load resistance 5 kΩ minimum)
%F.S. ± 0.5
± 0.3
± 0.5
ZERO %F.S./°C
± 0.05/± 0.1 ※ 3
SPAN %F.S./°C
± 0.05/± 0.1 ※ 3
V
maximum
± 0.3 ± 0.5
± 0.1
Approx. 2
ms
Gravitational effect
%F.S.
(From vertical position to horizontal position) max. Approx. 1 Approx. 0.5 Approx. 0.3 Approx. 0.1 Approx. 0.05 Approx. 0.3 Approx. 0.5 Approx. 0.3
※ 3 The thermal error of the PA-830-101G will be ± 0.1 %F.S./°C only.
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions (At 25 ± 5 °C)
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s ,
3 directions for 2 hours each
Shock
490 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
2
Zero voltage, Span voltage:
± 1 %F.S. maximum each
and ±3 %F.S. (101G) each
■ INTERNAL ELECTRICAL SCHEMATICS
Power B
Pressure
Sensor
Main circuit
Output
Common
Shield
PA-830
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
PA-830
● G1/8 type
22.5
12
22
AWG26 ULNo.2844 (φ 3.8)
4 – core shielded cable
L = 1500 ± 50
Part No. label
8
Wire color
Red
White
Green
Black
Shield
Cable bush (ESS-1)
“O” ring groove depth 1.8
P 12.5
P 15
M 5 depth 6
Pressure port
G 1/8 (PF 1/8)
(SUS 316L)
φ 30
8
1/4 外形図
5 ± 51
SN plate label
(10)
Housing (Aluminum with alumite finish)
● R1/4 type
(10)
56 ± 1
SN plate label
23.5
22
13.5
AWG26 ULNo.2844(φ 3.8)
L = 1500 ± 50
Part No. label
VCR) 外形図
φ 30
(25.4)
8
8
Cable bush (ESS-1)
M 5 depth 6
Pressure port
R 1/4 (PT 1/4)
(SUS 316L)
● VCR type
(10)
59 ± 1
(26.5)
(16)
8.5
SN plate label
Part No. label
L = 1500 50
φ 30
8
19
Cable bush (ESS-1)
1/4 VCR
(SUS 316)
Connection
Power B
Output
N.C.
Common
Fitting
很抱歉,暂时无法提供与“PA-830-351A-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2336.88240
- 200+2187.91800
- 500+2111.03280
- 1000+2073.03840
