PRESSURE TRANSDUCERS WITH AMP.
PA-850
INTERNAL STRUCTURE
PA-850 (R 1/4)
4
1
3
2
Part name
■ FEATURES
● High corrosion resistance and drip-proof construction
Pressure port attachment made of SUS 316L
Proven IP-65 grade gauge body (IP-65 in accordance with IEC)
● Standard product provides both a switch output
(hysteresis adjustable) and an analog output
● Absolute pressure type and compound pressure type
which can control negative to positive pressure with only
a single pressure gauge are all in line
● Three standard types of joint are provided
R2 : R 1/4 (M 5 female screw)
GF : G 3/8 with flash diaphragm
G2 : G 1/4 (M 5 female screw)
Material
1
Fitting
SUS 316L
2
Housing
SUS 316L
3
Plastic cover
4
Stainless steel diaphragm
ABS (Acrylonitrile butadiene
styrene) + PC (Polycarbonate)
SUS 316L
■ MODEL NUMBER DESIGNATION
PA-850 - 102 R - N R2
Series name
Fitting
Pressure reference
Rated pressure range
R2:R 1/4 with M 5 female screw
GF:G 3/8 with flash diaphragm
G2:G 1/4 with M 5 female screw
G:Gauge
102:0 ~ 100 kPa
352:0 ~ 350 kPa
103:0 ~ 1000 kPa
V :Gauge (Vacuum)
102:0 ~ − 100 kPa
R:Compound
102:− 100 ~ 100 kPa
302:− 100 ~ 300 kPa
A :Absolute
102:0 ~ 100 kPa abs
※ Please refer to the LIST OF MODEL NUMBERS when placing orders.
Switch output interface
N:NPN open collector(Upper limit mode)
P:PNP open collector(Upper limit mode)
PA-850
■ LIST OF MODEL NUMBERS
Fitting
Pressure reference
Gauge
kPa
SW output interface
NPN
R2
(R 1/4)
PNP
NPN
GF
(G 3/8)
PNP
NPN
G2
(G 1/4)
PNP
Absolute
0 ~ 100
0 ~ 350
0 ~ 1000
0 ~ − 100
PA-850102G-NR2
PA-850102G-PR2
PA-850102G-NGF
PA-850102G-PGF
PA-850102G-NG2
PA-850102G-PG2
PA-850352G-NR2
PA-850352G-PR2
PA-850352G-NGF
PA-850352G-PGF
PA-850352G-NG2
PA-850352G-PG2
PA-850103G-NR2
PA-850103G-PR2
PA-850103G-NGF
PA-850103G-PGF
PA-850103G-NG2
PA-850103G-PG2
PA-850102V-NR2
PA-850102V-PR2
PA-850102V-NGF
PA-850102V-PGF
PA-850102V-NG2
PA-850102V-PG2
− 100 ~ 100 − 100 ~ 300
PA-850102R-NR2
PA-850102R-PR2
PA-850102R-NGF
PA-850102R-PGF
PA-850102R-NG2
PA-850102R-PG2
PA-850302R-NR2
PA-850302R-PR2
PA-850302R-NGF
PA-850302R-PGF
PA-850302R-NG2
PA-850302R-PG2
0 ~100
PA-850102A-NR2
PA-850102A-PR2
PA-850102A-NGF
PA-850102A-PGF
PA-850102A-NG2
PA-850102A-PG2
※ Verify the above model numbers when placing orders.
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 12 V DC.
Item
Model number
General specifications
Pressure reference
PA-850
102G 352G 103G 102V 102R 302R 102A
Gauge Absolute
kPa 100
350
1000
− 100
Maximum pressure
200 700 2000 200 200 600
200 (abs)
kPa
Break-down pressure
300 1050 3000 300 300 900
300 (abs)
kPa
Operating temp. range
°C
− 20 ~ 80
Compensated temp. range
°C
0 ~ 50
Operating humidity
Storage temp.
%RH
°C
35 ~ 85(No condensation)
− 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum)
Corrosive gases/liquids compatible with SUS 316L
Pressure medium
Insulation resistance
MΩ
minimum
100 (500 V DC)
800 V AC, 60 s(Leakage current 1 mA maximum)
Dielectric strength
Sealed liquid
Silicone oil
Pressure port
R 1/4、G 3/8(Flash diaphragm)
、G 1/4 ※ 1
Net weight
g
Protection grade
※ 1 An “O” ring provided.(G 3/8 : P18、G 1/4 : P15)
R2 : Approx. 165, GF : Approx. 180, G2 : Approx. 170
IP65
100 (abs)
PA-850
Power
Item
Model number
Supply voltage
V DC
10.8 ~ 30(Including ripple voltage)
maximum
20 mA
Output voltage
V
1~5
Zero voltage
V 1 ± 0.04 3 ± 0.1 2 ± 0.1 1 ± 0.04
Consumption current
V 4 ± 0.04 4 ± 0.1 4 ± 0.04
Span voltage
mA
maximum
Output current
Analog output
PA-850
%F.S.
± 0.5
ZERO %F.S./°C
± 0.06
SPAN %F.S./°C
± 0.06
V
maximum
± 0.02
Linearity/Hysteresis
Thermal error
1(Load resistance 5 kΩ minimum)
Supply voltage effect
ms
Response
Gravitational effect
%F.S.
(From horizontal position to vertical position)
Approx. 2
± 0.3
± 0.1
± 0.05
Output interface
NPN or PNP open collector output
Setting method
Adjustable by VR
0 ~ 100 % of rated pressure range
Adjustable range
Red LED
Display
Accuracy
0 〜 50 °C
(Reference temp.: 25 °C)
±3
%F.S.
Approx. 1 ~ 15 % of set value
Hysteresis
Hysteresis setting method
Adjustable by VR
Switching capacity
30 V DC 100 mA
NPN : 0.8 V, PNP : 1.2 V
Residual voltage
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Vibration
Shock
Pressure cycling
Moisture resistance
± 0.1
± 0.3
1
No. of outputs
Switch output
± 0.3
Test conditions (At 25 ± 5 °C)
Permissible change
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s ,
3 directions for 2 hours each
490 m/s2
3 directions for 3 times each
106 cycles
0 〜 Rated pressure/Rated pressure range
2
40 °C, 90 ~ 95 %RH, 240 hrs.
Switch output setting and analog output
(Zero voltage, Span voltage)
: ± 1 %F.S. maximum each
0 ~ 108 % of rated
pressure range
PA-850
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● Configurations of joint R2 (R1/4) type
48.5 ± 1
(8)
27
13.5
Pressure port M5 depth 6
Indicator LED
(14)
Label 2 Lot. No.
Hysteresis setting VR
Pressure setting VR
R 1/4 (PT 1/4)
(SUS 316L)
19 –0.3
Housing
(SUS 316L)
φ 35.2
10
(21.9)
Cable nut
Brass + Ni-plated
Label 1
4-core shielded cable ( φ 4.5)
L = 2000 ± 100 AWG22 ULNo.2547
Plastic cover
(ABS+PC)
Wire color
Brown
White
Black
Blue
Shield
● Configurations of joint GF (G 3/8) type
Diaphragm (SUS 316L)
49 ± 1
11
“O” rirg groove
Outside : φ 22.8
Inside : φ 18
(11)
(14)
Pressure setting VR
Indicator LED
27
Label 2 Lot No.
φ 35.2
(10)
φ 27
φ 13.2
(31.2)
Cable nut
Brass + Ni-plated
Label 1
27
G 3/8 (PF 3/8)
(SUS 316L)
–0.3
Housing
(SUS 316L)
L = 2000 100 AWG22 ULNo.2547
Plastic cover (ABS+PC)
Extra care should be taken with the diaphragm part. Do not touch the diaphragm directly to avoid damaging the diaphragm.
● Configurations of joint G2 (G 1/4) type
48 ± 1
Pressure port M 5 depth 6
12
(9)
(14)
27
Indicator LED
Label 2
Lot No.
“O” rirg groove
Outside : 20 φ
Inside : 15 φ
Pressure setting VR
φ 35.2
(10)
φ 22
(25.4)
Cable nut
Brass + Ni-plated
Label 1
22 –0.3
G 1/4 (PF 1/4)
(SUS 316L)
Housing
(SUS 316L)
Connection
Power B
Analog output
Switch output
Common
Fitting
PA-850
■ INTERNAL ELECTRICAL SCHEMATICS
● PNP output
● NPN output
LED Indicator
LED Indicator
Pressure
Power B
Sensor
Pressure
Power B
Sensor
A.Output
Main circuit
S.Output
A.Output
Main circuit
S.Output
Common
Common
Shield
Shield
■ SWITCH OUTPUT SCHEMATICS
Turns on at the set pressure and turns off at the set pressure minus the hysteresis.
● PA-850- *** G
● PA-850-102V
Hysteresis
Hysteresis
ON
ON
OFF
OFF
Atmospheric
pressure
Set value
Rated pressure
● PA-850- *** R
-100 kPa
Barometic
pressure
● PA-850- *** A
Hysteresis
Hysteresis
ON
ON
OFF
OFF
-100 kPa
Set value
Set value
Rated pressure
Absolute
vacuun
Set value
108 kPa
※ Adjustable hysteresis
很抱歉,暂时无法提供与“PA-850-352G-NG2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1417.08960
- 200+1326.75840
- 500+1280.13480
- 1000+1257.09840
