PG-30-103R-P
PG-30-103R-P
    NIDEC(尼得科)
    Module Box with Display
    PG-30-103R-P
PG-30-103R-P 数据手册
PRESSURE GAUGES PG-30 ϚʔΩϯά &.$ࢦྩద߹ INTERNAL STRUCTURE marking 1 5 Compatible with EMC directive 2 6 Part name 3 4 Material ① Pressure sensor P-2000 ② Sensor “O” ring NBR ③ Adaptor ④ Case “O” ring ⑤ Case ⑥ Panel sheet Aluminum Die-casting NBR PBT (Polybutyleneterephthalate) Polyester ■ FEATURES ● Compact and lightweight general-purpose pressure gauges Innovative general-purpose gauges of compact design (30mm sq.) and drip-proof structure (IP65). ● Clear indication by LED Easy-to-see LED assures clear readings on the panel and even in a dark place. ● Meet EMC standards EN 55011 (EMI) EN 61326-1 (EMS) ● Low consumption by nondisplay mode ● Set data protection by panel lock function ● Various modes and units can be selected according to applications Eight different pressure units Three analog output modes Eight switch output modes ■ MODEL NUMBER DESIGNATION Non-corrosive gases type PG-30-101 R-N Switch output interface Series name Pressure range 101:− 10 ~ 10 kPa 102:− 100 ~ 100 kPa 103:− 100 ~ 1000 kPa N:NPN open collector P:PNP open collector Pressure reference R:Compound pressure (Negative pressure ~ Positive pressure) PG-30 PRESSURE GAUGES ■ LIST OF MODEL NUMBERS Pressure medium Non-corrosive gases Fitting Gauge Pressure reference Switch output interface Rc 1/8 Rated pressure range −10 ~ 10 kPa −100 ~ 100 kPa −100 ~ 1000 kPa NPN PG-30-101R-N PG-30-102R-N PG-30-103R-N PNP PG-30-101R-P PG-30-102R-P PG-30-103R-P ※ Verify the above model numbers when placing orders. ■ ACCESSORIES (Sold separately) Name Series name Contents Applicable model Rear panel bracket set ACPG-001 Rear panel bracket and M 3 × 4 male screw (2pcs.) PG-30 · PS30 Panel bracket set ACPG-002 Panel bracket and M 3 × 4 male screw (2pcs.) PG-30 · PS30 Panel holder set ACPG-003 Panel holder cover Panel holder Panel stopper (2pcs.) PG-30 · PG-35 · PG-75 PG-35H · PG-35L · PS30 Holder cover set (For protecting gauge operating panel) ACPG-004 Panel holder cover Panel holder PG-30 · PG-35 · PG-75 PG-35H · PG-35L · PS30 holder stopper set ACPG-007 Panel holder PG-30 · PG-35 · PG-75 PG-35H · PG-35L · PS30 Panel stopper (2pcs.) ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 12 VDC. Item PG-30 101R 102R 103R Model number Pressure reference Gauge Non-corrosive gases General specifications Pressure medium Rated pressure range kPa −10 ~ 10 Maximum pressure kPa 20 Break-down pressure kPa 50 Operating temp. range Compensated temp. range Operating humidity °C °C %RH Dielectric strength Input voltage Consumption current 500 2000 −10 ~ 50 0 ~ 50 35 ~ 85 Aluminum die-casting, silicone Material of pressure port attachment Insulation resistance 1500 2-Rc 1/8 Pressure port Thermal error −100 ~ 1000 200 In accordance with IEC IP65 Protection grade Net weight −100 ~ 100 g Approx. 80(Including 2 m cable) ±3 %F.S. (0 ~ 50 °C) 100 MΩ minimum(500 VDC) 500 VAC 1 minute(Leakage current 1 mA maximum) 10.8 ~ 30 VDC(Including ripple percentage) 50 mA maximum PG-30 PRESSURE GAUGES ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 12 VDC. Item Model number PG-30 101R 102R 103R Display Display element Full 3-digit LED Rated display range − 9.99 ~ 9.99 kPa − 99.9 ~ 99.9 Max. 11 settings Negative pressure display Red LED is ON. ± 1 %F.S. Display accuracy NPN/PNP Switch output Output status 2-point output (Transistor, Open collector output) Separate mode / window comparator mode Output mode Switching capacity 30 VDC 100 mA Short-circuit protection Residual voltage 1.2 V maximum (NPN), 2.2 V maximum (PNP)(At load current of 100 mA) State indication Output 1 (Green LED),Output 2 (Red LED) Lighted when output is ON. 0 ~ 300 counts(Adjustable) Switch hysteresis Repeatability ± 0.2 %F.S. ± 1 count (± 0.3 %F.S. maximum) Approx. 5, 25, 250, 2500 ms Adjustable Response Analog output − 100 ~ 999 Multiplier settings 3 modes Output mode Output voltage V zero : Pin=0, V span : Pin=0 〜 Pin (H) 1 ~ 5 V G/V mode ZERO : 1 ± 0.2 V, SPAN : 4 ± 0.2 V R mode ZERO : 3 ± 0.2 V, SPAN : 2 ± 0.2 V ( R (R mode) ZERO : 1.36 ± 0.2 V ) 103 SPAN : 3.64 ± 0.2 V Impedance 10 kΩ Resolution 1/204 Response Approx. 5, 25, 250, 2500 ms Adjustable Accessories Seal screw, M 5 connecting joint screw ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Permissible change 10 ~ 500 Hz, 98.1 m/s2 or 1.5 mm P-P, 3 directions for 2 hours each Vibration Shock Pressure cycling Moisture resistance 490 m/s2, 3 directions for 3 times each 0 ~ Rated pressure、106 cycles 40 °C, 90 ~ 95 %RH, 240 hrs. EMI : EN55011: 2007, A2 : 2007 Group 1, class B EMS : EN61326-1 : 2006 Table 2 EMC [ ± 2 %F.S. maximum after test Amount of analog output fluctuation is permitted by adding conversion error of 20 mV. Pressure indication, switch operating pressure and analog output : ± 5 %F.S. maximum during test ※ 1 ※1 Change in the pressure indication, switch operating points and analog output. ■ INTERNAL ELECTRICAL SCHEMATICS ● NPN ● PNP 1 2 1 動作LED Indicator 2 動作LED Indicator Power • A.Output S.Output1 Power • Load Pressure Main circuit Sensor Load S.Output1 S.Output2 Pressure Main circuit S.Output2 Sensor Load A.Output LED LED 圧力表示 Pressure indication FG Load Common Common 圧力表示 Pressure indication ] FG PG-30 PRESSURE GAUGES ■ SELECTION OF DISPLAY MULTIPLIER The last digit/letter represents the selection code : Blinking red LED indicates negative pressure. (− Pr 〜+ Pr) Pressure range 101R 102R 1 ×1 – 9.99 ~ 9.99 – 99.9 ~ 99.9 2 × 0.0102 3 × 10.2 – 99.9 ~ 99.9 – 999 ~ 999 4 × 7.501 – 75.0 ~ 75.0 – 750 ~ 750 5 × 102    – 999 ~ 999 6 × 0.01 7 × 10 – 99.9 ~ 99.9 – 999 ~ 999 8 × 0.145 – 1.45 ~ 1.45 – 14.5 ~ 14.5 9 × 0.000145 A × 0.001 b × 0.2953 – 2.95 ~ 2.95 – 29.5 ~ 29.5 Selection code Display multiplier 103R – 100 ~ 999 – 1.02 ~ 9.99 – 1.00 ~ 9.99 Diagonal column: Display multiplier cannot be selected due to resolution and number of digits. (Selection code is not indicated either.) Selection code is set at “1” prior to shipment. – 14 ~ 145 – 0.10 ~ 1.00 – 29 ~ 295 ■ ANALOG OUTPUT MODE Pressure range −Pr 0 When shipped from our factory-101R : R mode is set at “1”, 102R : V mode is set at “3” and 103R : G mode is set at “2”. The above 3 types can be set at “1”, “2” or “3”. However, the accu­racy at V mode of 103R can’t be guaranteed. Pr Display 1 R mode 2 G mode 1 V 1 V 3 V mode 1V 5 V 5V 5V ■ SWITCH OUTPUT MODE SW1 Output Mode Operation S-1 S-2 S-3 S-4 Separate HI LO Window comparator A B Separate HI LO Separate mode A ○ ○ ○ ○ ○ ○ ○ ○ Setting 1 -Pr ○ (Lower limit):setting1 (Upper limit):setting2 ○ Setting 2 P1: SW1 P2: SW2 H H Pr ON -Pr ON H ○ ○ -Pr P2 Pr H (B operation) ON (Lower limit):setting1 (Upper limit):setting2 ON P1: SW1 P2: SW2 H H P1 ≦ P2 or P1 ≧ P2 H:Swich hysteresis、 P1=Setting1、Setting2 Note 1. In the Separate Mode, setting 1 corresponds to SW1, and Setting 2 corresponds to SW2. Note 2. In the Window Comparator Mode, the minimum value for SW1 and SW2 corresponds to Setting 1 and the maximum value corresponds to Setting 2. OFF P1 (LO operation) ○ ○ ○ (A operation) ON B ○ Window comparator mode (HI operation) Window comparator OFF C-5 C-6 C-7 C-8 Pressure setting (Operating Point) SW2 OFF Pr OFF -Pr P1 P2 H H P1 ≦ P2-2H OFF Pr PG-30 PRESSURE GAUGES ■ OUTLINE DIMENSIONS Unless otherwise specified tolerance : ± 0.5 (Unit: mm) ● PG-30 20 Vent hole 35.5 30 9 20 30 2 – M3 Depth 3 6.5 Pressure Port 2 – Rc 1/8 depth 7 (Φ4) 5-core shielded cable L = 2000±100 AWG26 UL No.2844 Wire color Brown Gray Black White Blue Shield ■ HOW TO MOUNT OPTIONAL ACCESSORIES (Sold separately) ● PG-30 Rear panel mounting bracket(ACPG-001) (Unit: mm) ● PG-30 Panel mounting bracket(ACPG-002) 装着図 Fixed 18 30 Connection Power ⊕ Analog output Switch output 1 Switch output 2 Common Fitting 2-φ3.5 18 20 φ4.2 20 15 20 30 20 40 39 2-φ3.5 6 15 30 φ4.2 5.2 長穴 Slot 装着図 Fixed 18 S304 材質 Mate t = 1.6 材質 Material:SUS304 t = 1.5 18 20 装着図 φ3.5 2-Fixed 20 装着図 Fixed 15 φ4.2 φ4.2 5.2 長穴 Slot φ4.2 5.2 長穴 Slot 20 15 20 25 20 20 15 40 40 φ4.2 φ4.2 20 30 30 材質 Material:SUS304 t = 1.6 材質 Material:SUS304 t = 1.6 PG-30 PRESSURE GAUGES ■ HOW TO MOUNT OPTIONAL ACCESSORIES (Sold separately) (Unit: mm) ● PG-30 • PG-35 • PG-35H • PG-35L • PG-75 • PS30 Panel cut holder set & holder cover set (5.7) 4.5 36 23.5 +0.5 0 36 +0.5 0 (□42.6) □ 40 Panel cut dimension (Panel board thickness : 1 ~ 3.6 mm) ● Panel holder cover set Panel holder cover Panel holder Body (PG-30 • PG-35 • PG-35H • PG-35L • PG-75 • PS30) Holder cover set Panel holder set Mounting panel Panel stopper 2 pcs.
PG-30-103R-P 价格&库存
很抱歉,暂时无法提供与“PG-30-103R-P”相匹配的价格&库存,您可以联系我们找货
PG-30-103R-P
  • 1+2035.732071+262.77280
  • 5+1905.668595+245.98417
  • 10+1857.1702510+239.72399
  • 25+1799.1068225+232.22915
  • 50+1759.3528450+227.09770
库存:2
