PS60-102R-PMCN
PS60-102R-PMCN
    NIDEC(尼得科)
    Module Box with Display
    PS60-102R-PMCN
PS60-102R-PMCN 数据手册
PRESSURE SWITCHES WITH GAUGE PS60 マーキング EMC指令適合 INTERNAL STRUCTURE marking 1 Compatible with EMC directive 2 5 3 4 6 Part name ■ FEATURES ● Applicable for negative through positive pressure with 10 mm thick slim housing ● Suitable for use in clean rooms with easy-to-use push keys ● Plug-in connector is provided for easy installation and maintenance ● Space saving and mountable on DIN rails ● Data protection by panel lock system ● Low consumption by nondisplay mode 1 Pressure port 2 “O” ring 3 Sensor module board 4 Housing 5 Display board 6 Operation panel seet Material Polyamide (Resin of MXD6 series) Brass (Ni-plated) Fluoro-rubber ——— PBT (Polybutyleneterephtalate) ——— Polyester ■ MODEL NUMBER DESIGNATION P S 6 0 - 1 0 2 R - N M C N Signal / power cable pullout method Series name CN:Connector pullout Rated pressure range 102:−100 ~ 100 kPa 302:−100 ~ 300 kPa 103:−100 ~ 1000 kPa Pressure port M:M5 female screw Pressure reference R:Compound pressure (Negative pressure ~ Positive pressure) Switch output interface N:NPN open collector P:PNP open collector ■ LIST OF MODEL NUMBERS Pressure port Switch output M 5 female screw NPN open collector output PNP open collector output ※ Verify the above model numbers when placing orders. 102R 302R 103R −100 ~ 100 kPa −100 ~ 300 kPa −100 ~ 1000 kPa PS60-102R-NMCN PS60-302R-NMCN PS60-103R-NMCN PS60-102R-PMCN PS60-302R-PMCN PS60-103R-PMCN PS60 PRESSURE SWITCHES WITH GAUGE ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 24 V DC. Item PS60 Model number 102R 302R 103R General specifications Pressure reference Gauge Rated pressure range kPa Maximum pressure kPa 200 600 1500 Break-down pressure kPa 500 1000 2000 Operating temp. range −100 ~ 100 Storage temp. 0 ~ 50 35 ~ 85(No condensation) %RH −20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum) °C Pressure medium Insulation resistance Non-corrosive gases MΩ min. 100 (500 V DC) ± 3 %F.S. (0 ~ 50 °C) Thermal error 500 V AC, 60 s(Leakage current 1 mA maximum) Dielectric strength Pressure port Power Net weight Supply voltage Consumption current M5 Female screw Approx. 50(Includihg cable) g V DC 12 ~ 24 V ± 10 %(Including ripple percentage) mA max. 30 Display Display element 3-digit LED Rated display range Display accuracy No. of outputs Switch output −100 ~ 300 kPa 1 count Resolution 2 Output interface Open collector output (NPN or PNP) Setting method Adjustable by panel switch Adjustable range −110 kPa (approx.) ~ “999” counts Red LED ON Display Repeatability ± 0.3 %F.S. maximum Switch hysteresis 0 ~ 30 counts 30 V 100 mA maximum Switching capacity V maximum Responsems −100 ~ 100 kPa ± 1 %F.S. 0 〜 50℃ (Reference temp. 25 °C) Residual voltage Accessories −100 ~ 1000 −10 ~ 50 °C Compensated temp. range °C Operating humidity −100 ~ 300 1.2 (NPN), 2.2 (PNP) Approx. 5, 25, 250 PS60 cable, DIN rail adaptor −0.10 ~ 1.00 MPa PS60 PRESSURE SWITCHES WITH GAUGE ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Permissible change Vibration 10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s2, 3 directions for 2 hours each Shock 490 m/s2, 3 directions for 3 times each Moisture resistance 40 °C, 90 ~ 95 %RH, 240 hrs. Pressure cycling 0 ~ Rated pressure, 106 cycles EMC EMI : EN55011: 2007, A2 : 2007 Group 1, class B  EMS : EN61326-1 : 2006 Table 2 Pressure indication and switch operating output : ± 2 %F.S., maximum each after test Pressure indication and switch operating output, alalog output : ± 5 %F.S., maximum during test ■ CIRCUIT DIAGRAMS ● NPN open collector 1 2 ● PNP open collector LED Indicator 1 LED Indicator 2 Power B Load Pressure Sensor Power B Load Pressure S.Output1 S.Output2 Main circuit S.Output1 Main circuit S.Output2 Sensor Load Load Common Common LED LED Pressure indication Pressure indication ■ SWITCH OUTPUT MODE SW1 Output Mode Operation Separate HI LO Separate mode SW2 Window comparator A B Separate HI LO A B S- 1 S- 2 S- 3 S- 4 C- 5 C- 6 C- 7 C- 8 Pressure setting (Operating point) (HI operation) Window comparator OFF -Pr P2: SW2 H H ON ON Pr -Pr (LO operation) ON -Pr P1: SW1 Window comparator mode (A operation) P1 H (Lower limit) : Setting 1 (Upper limit) : Setting 2 Setting 2 (Lower limit) : Setting 1 (Upper limit) : Setting 2 ON P2 Pr H (B operation) ON P1: SW1 P2: SW2 H H OFF OFF Pr -Pr P1 OFF P2 H P1≦P2 or P1≧P2 Setting 1 OFF Pr H P1≦P2–2H H:Switch hysteresis、 P1=Setting 1、P2=Setting 2 Note 1. In the Separate Mode, setting 1 corresponds to SW1, and Setting 2 corresponds to SW2. Note 2. In the Window Comparator Mode, the minimum value for SW1 and SW2 corresponds to Setting 1 and the maximum value corresponds to Setting 2. ■ DISPLAY RANGE ● Display range can be selected as the table. Note) “–” on the table indicates that it is not selectable in relation to resolution and display lines. ※ : In terms of setting display range, please verify the default mode. Rated pressure range Number 102R 302R 1 (kPa) –100 ~ 100 –100 ~ 300 — 2 (MPa) — — –0.10 ~ 1.00 3 –75 ~ 75 –75 ~ 225 4 –1.00 ~ 1.00 –1.00 ~ 3.00 –1.0 ~ 10.0 5 –14.5 ~ 14.5 –14.5 ~ 43.5 –14 ~ 145 6 29.5 ~ 0.0 ※ ※ Atmospheric pressure 103R — 29.5 ~ 0.0 ※ — PS60 PRESSURE SWITCHES WITH GAUGE ■ OUTLINE DIMENTIONS Unless otherwise specified, tolerance : ± 0.5 (Unit: mm) ● Pressure port M type (NMCN, PMCN) 10.2 0 –0.2 Panel seet (Polyester) 4.5 Terminal no. Connection 4 SW output 1 (7) (52.5) Housing (PBT) 4.5 2 – φ 3.1 Mounting hole SW output 2 2 Power (DC10.8 ~ 26.4 V) 1 Common < Terminal No. > 4 1.1 12 1 9 4.6 0 25 –0.2 13.2 Pressure port (PA MXD6) 3 8 Part No. (Laser marking) Pressure port (BSBM, Ni-plated) Insert screw : M5 depth 5 4 DIN rail adapter (accessory) Connector : Pitch / 4 poles(□0.64) Housing : Manufactured by JST (XAP-04V-1) ■ Accessories ● Connector cable Length : 1500 ± 50 70 ± 20 Heat shrink tube (Black) 50 ± 10 (5) 4 1 Housing : Manufactured by JST (XAP-04V-1) Contact : Manufactured by JST (SXA-001T-P0.6L) Pin no. Wire color Connection 4 Black SW output 1 3 White SW output 2 2 Blown Power B 1 Blue Common 4-core cable ( φ 4) AWG26 ULNo.2844 ● DIN rail adapter 1.1 10 3.7 5 1.5 PS60 6.5 DIN rail (width 35) adaptaion Tolerated stroke 2 maximuum 54.2 DIN base : PBT Slide (DIN stopper) : POM
PS60-102R-PMCN 价格&库存
很抱歉,暂时无法提供与“PS60-102R-PMCN”相匹配的价格&库存,您可以联系我们找货
PS60-102R-PMCN
    • 1+1144.73520
    • 201+443.00520
    • 501+427.43160
    • 999+419.74200
    PS60-102R-PMCN
    • 1+1334.221671+173.44450
    • 6+1233.877476+160.40008
    • 12+1200.6773812+156.08418
    • 27+1165.2767727+151.48221
    • 51+1139.8951351+148.18268
    库存:1
