NJW4187DL1-33B-TE1
NJW4187DL1-33B-TE1
    JRC(⽇本无线)
    TO-252(DPAK)
    IC REG LINEAR 3.3V 1A TO252-3
NJW4187DL1-33B-TE1 数据手册
NJW4187 High Voltage Io=1000mA Low Dropout Regulator GENERAL DESCRIPTION The NJW4187 is a high voltage and low current consumption low dropout regulator. It has two lineups as A version (built-in ON/OFF function type) and B version (3-terminal / compatible with 78 series) PACKAGE OUTLINE NJW4187 is mounted to TO-252-3/-5 packages and corresponded to Low ESR capacitor (MLCC). The wide input range makes NJW4187 suitable for a Car accessory, industrial supplies, battery equipment and various applications. FEATURES Wide Operating Voltage Range Low Current Consumption NJW4187DL3 NJW4187DL1 4.0V to 40V 55μA typ. (A version) 48μA typ. (B version) VO 1.0% IO (min.)=1000mA 2.0V to 15V High Precision Output Output Current Output Voltage Range Correspond to Low ESR capacitor (MLCC) ON/OFF Control (apply only the A version) Internal Thermal Overload Protection Internal Over Current Protection Package Outline A ver. TO-252-5 B ver. TO-252-3 PRODUCT CLASSIFICATION Device Name Version NJW4187DL3-xxA A NJW4187DL1-xxB B xx=Output Voltage ex) 33=3.3V 05=5.0V ON/OFF Function Yes - Package TO-252-5 TO-252-3 PIN CONFIGURATION 4 VOUT NC 3 GND 2 CONTROL VIN 5 3 1 NJW4187DL3-A Ver.2016-02-15 2 3 VOUT 2 GND 1 VIN NJW4187DL1-B -1- NJW4187 BLOCK DIAGRAM ・A version VOUT VIN Current Limit CONTROL Bandgap Reference Thermal Protection GND ・B version VIN VOUT Current Limit Bandgap Reference Thermal Protection GND OUTPUT VOLTAGE RANK LIST ・A version Device Name Output Voltage NJW4187DL3-33A 3.3V NJW4187DL3-05A 5.0V ・B version Device Name NJW4187DL1-33B NJW4187DL1-05B -2- Output Voltage 3.3V 5.0V Ver.2016-02-15 NJW4187 ABSOLUTE MAXIMUM RATINGS PARAMETER SYNBOL Input Voltage VIN Control Voltage(*1) VCONT Output Voltage VOUT Power Dissipation Junction Temperature Operating Temperature Storage Temperature PD Tj Topr Tstg RATINGS -0.3 to +45 -0.3 to +45 -0.3 to VIN 17 1190 (*2) 3125 (*3) -40 to +150 -40 to +125 -40 to +150 (Ta=25 C) UNIT V V V mW C C C (*1): Apply only the A version. 2 (*2): Mounted on glass epoxy board. (76.2 114.3 1.6mm:based on EIA/JDEC standard size, 2Layers, Cu area 100mm ) (*3): Mounted on glass epoxy board. (76.2 114.3 1.6mm:based on EIA/JDEC standard, 4Layers) (For 4Layers: Applying 74.2 x 74.2mm inner Cu area and thermal via hole to a board based on JEDEC standard JESD51-5) INPUT VOLTAGE RANGE VIN=4.0V to 40V ELECTRICAL CHARACTERISTICS Unless otherwise noted, VIN =VO+1V, CIN=1.0μF, CO=4.7μF(3V VO 3.4V: CO=10μF), Ta=25°C PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT Output Voltage VO IO =200mA -1.0% +1.0% V 55 90 A version, IO =0mA, except ICONT μA Quiescent Current IQ B version, IO =0mA 48 83 Quiescent Current at Control OFF (*4) IQ (OFF) VCONT=0V - - 1 μA Output Current Line Regulation Load Regulation IO VO/ VIN VO/ IO VO 0.9 1000 - 0.03 0.004 0.42 mA %/V %/mA Ripple Rejection Dropout Voltage (*5) Average Temperature Coefficient of Output Voltage Control Current (*4) Control Voltage for ON-state (*4) Control Voltage for OFF-state (*4) IO=600mA - 58 54 0.27 VO/ Ta Ta=0 to 85 C, IO =200mA - 50 - ppm/ C ICONT VCONT=1.6V - 1 3 μA VCONT(ON) 1.6 - - V VCONT(OFF) - - 0.6 V RR VIO VIN = VO+1V to 40V, IO=200mA IO=0mA to 1000mA VIN = VO+1V ,ein=200mVrms, f=1kHz, IO =10mA VO=3.3V VO=5.0V dB V (*4): Apply only the A version. (*5): The output voltage excludes under 3.8V The above specification is a common specification for all output voltages. Therefore, it may be different from the individual specification for a specific output voltage. * These parameters are tested by Pulse Measurement. Ver.2016-02-15 -3- NJW4187 THERMAL CHARACTERISTICS PARAMETER SYMBOL Junction-to-Ambient ja thermal resistance Junction-to-Top of package jt characterization parameter VALUE 105 (*6) 40 (*7) 17 (*6) 12 (*7) UNIT C/W C/W 2 (*6): Mounted on glass epoxy board. (76.2 114.3 1.6mm:based on EIA/JDEC standard size, 2Layers, Cu area 100mm ) (*7): Mounted on glass epoxy board. (76.2 114.3 1.6mm:based on EIA/JDEC standard, 4Layers) (For 4Layers: Applying 74.2 74.2mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) POWER DISSIPATION vs. AMBIENT TEMPERATURE NJW4187DL1/DL3 PowerDissipation (Topr=-40~+125°C,Tj=150°C) 3500 Power Dissipation PD(mW) 3000 on 4 layers board 2500 2000 on 2 layers board 1500 1000 500 0 -50 -25 0 25 50 75 100 125 150 Temperature : Ta( C) -4- Ver.2016-02-15 NJW4187 TEST CIRCUIT ・A version A IIN VIN VOUT *8 VIN 1.0μF A ICONT NJW4187-A 4.7μF IOUT V VOUT (Ceramic) *8 : Vo
NJW4187DL1-33B-TE1 价格&库存
很抱歉,暂时无法提供与“NJW4187DL1-33B-TE1”相匹配的价格&库存,您可以联系我们找货
