PA-20
PRESSURE TRANSDUCERS WITH AMP.
マーキング
EMC指令適合
INTERNAL STRUCTURE
marking
(Universal joint)
Compatible with
EMC directive
6
1
4
3
5
2
Part name
■ FEATURES
● Ultra-small size pressure transducer with Amp.
● 2 types of pressure ports are available
● Meet EMC standards
Material
SUS 304
1
Pressure Port
2
Housing
3
Sensor module
4
“O” ring
Fluoro-rubber
5
Cable
Vynyl chloride
6
Gasket
POM (Polyoxymethylene)
PC (Polycarbonate)
PPS (Polyphenylene sulphide)
■ MODEL NUMBER DESIGNATION
PA-20-102V-U-3M
Series name
Cable length
Blank:1.5 m
3M:3 m
Rated pressure range
Pressure port
102V:0 ~ −100 kPa(Gauge – Vacuum)
302R:−100 ~ 300 kPa(Gauge – Compound)
U:Universal joint (M5 male screw)
M:2-M5 female screw
■ LIST OF MODEL NUMBERS
Pressure port
Universal joint
2-M5 female screw
Cable length
Rated pressure range [kPa]
0 ~ – 100 – 100 ~ 300
1.5 m
PA-20-102V-U
PA-20-302R-U
3 m
PA-20-102V-U-3M
PA-20-302R-U-3M
1.5 m
PA-20-102V-M
PA-20-302R-M
3 m
PA-20-102V-M-3M
PA-20-302R-M-3M
※ Verify the above model numbers when placing orders.
48
PA-20
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 24 V DC.
Item
PA-20
Model number
102V
General specifications
Pressure reference
Gauge
kPa
Maximum pressure
kPa 200
0 ~ –100
–100 ~ 300
°C
–10 ~ 60
Compensated temp. range
°C
0 ~ 50
%RH
Operating humidity
35 ~ 85(No condensation)
°C
Storage temp.
–20 ~ 70
Pressure medium
Non-corrosive gases
MΩ
minimum
100
500 V AC, 60 s
Dielectric strength
Net weight (Without cable)
Power
600
Operating temp. range
Insulation resistance
Analog output
302R
g
V DC
Supply voltage
10.8 ~ 30(Including ripple percentage)
mA
maximum
Consumption current
Output voltage
V
Output current
mA
maximum
1~5
1(Load resistance : 5 kΩ minimum)
%F.S.
Linearity/Hysteresis
Thermal error
(Reference temp.: 25 °C)
Response
Approx. 5 (PA-20- **** -U) Approx. 8 (PA-20- **** -M)
0.5
ZERO %F.S.
2
SPAN %F.S.
2
ms
Approx.1
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Vibration
10 ~ 55 Hz, 1.5 mm, 3 directions for 2 hours each
Shock
1000 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 h.
EMC
EMI : EN55011: 2007, A2 : 2007 Group 1, class B
EMS : EN61326-1 : 2006/EN61326-2-3 : 2006 Table 2
permissible change
Analog output : ± 2 %F.S. maximum after test
Analog output ± 5 %F.S. maximum during test
PA-20
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● Universal joint type
3.53.5
10.5
10.5
Housing
Housing
1010
M5
M5
Pressure
port:SUS 304
Pressure port:SUS 304
Gasket
Gasket
10.8
10.8
0.50.5
0 0
1010
–0.3 –0.3
φ 6.5
φ 6.5
8 –0.3
8 –0.3
5.5
3-core cable (φ 3.2) AWG26 UL No.2851
3-core
I = 1500cable
75 (PA-20-****-*)
II == 1500
3000 75
150(PA-20-****-*)
(PA-20-****-*-3M)
I = 3000 150 (PA-20-****-*-3M)
● M5 female screw type
2 – M5 depth 5
2 – M5 depth
Pressure
port :5AI Alumite
Pressure port : AI Alumite
10
10
2 – φ 3.5
2 – φ 3.5hole
Through
Through hole
20.5
20.5
5
5
5 5
3.33.3
0 0
1010
–0.3 –0.3
Wire color
Brown
Blue
Black
■ INTERNAL ELECTRICAL SCHEMATICS
Power B
Pressure
Sensor
Main circuit
Output
Common
Connection
Power B
Common
Output
很抱歉,暂时无法提供与“PA-20-102V-U-3M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+865.079871+111.91129
