PRESSURE TRANSDUCERS WITH AMP.
PA-750
マーキング
EMC指令適合
INTERNAL STRUCTURE
PA-750 (R 1/4)
marking
Compatible with
EMC directive
③
①
②
Part name
■ FEATURES
Material
①
Fitting
②
Housing
③
Stainless steel diaphragm
SUS 304
PPS
SUS 316L
● High corrosion resistance and drip-proof construction
Pressure port attachment made of SUS 316L
Proven IP65 grade gauge body (IP65 in accordance with
IEC)
● Cable connector connection
● Buit-in temperature compensation function (0 ~ 50°C)
● Absolute pressure type and compound pressure type
which can control negative to positive pressure with only
a single pressure gauge are all in line
● Voltage output mode
■ MODEL NUMBER DESIGNATION
PA-750 - 102 R - R2 - 1
Series name
Cable
Blank:1.5m cable
1:Not attached
Pressure reference Rated pressure range
G:Gauge
102:0
352:0
103:0
353:0
100 kPa
350 kPa
1 MPa
3.5 MPa
V:Gauge(Vacuum)
102:0 ~ − 100 kPa
R:Compound
102:− 100 ~ 100 kPa
302:− 100 ~ 300 kPa
A:Absolute
102:0 ~ 100 kPa abs
※ Please refer to the LIST OF MODEL NUMBERS when placing orders.
Fitting
R1:R 1/8 with M 5 female screw
R2:R 1/4 with M 5 female screw
PA-750
■ LIST OF MODEL NUMBERS
Fitting
R1
R2
Pressure reference
Cable
Gauge
0 ~ 100
0 ~ 350
PA-750102G-R1
PA-750102G-R1-1
PA-750102G-R2
PA-750102G-R2-1
Attached
Not attached
Attached
Not attached
0 ~ 1000
PA-750 103G-R1
PA-750 103G-R1-1
PA-750 103G-R2
PA-750 103G-R2-1
PA-750352G-R1
PA-750352G-R1-1
PA-750352G-R2
PA-750352G-R2-1
Absolute
0 ~ 3500
0 ~ − 100
PA-750 353G-R1
PA-750 353G-R1-1
PA-750 353G-R2
PA-750 353G-R2-1
PA-750102V-R1
PA-750102V-R1-1
PA-750102V-R2
PA-750102V-R2-1
− 100 ~ 100
− 100 ~ 300
0 ~ 100 (abs)
PA-750 102R-R1
PA-750 102R-R1-1
PA-750 102R-R2
PA-750 102R-R2-1
PA-750 302R-R1
PA-750 302R-R1-1
PA-750 302R-R2
PA-750 302R-R2-1
PA-750 102A-R1
PA-750 102A-R1-1
PA-750 102A-R2
PA-750 102A-R2-1
※ Verify the above model numbers when placing orders.
are manufactured upon receipt of order basis.
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 12 V DC.
Item
Model number
General specifications
Pressure reference
PA-750
102G
352G
103G
353G
102V
102R
302R
Gauge
102A
Absolute
− 100 ~ 100 − 100 ~ 300
kPa
100
350
1000
3500
− 100
Maximum pressure
kPa
200
700
2000
5000
200
200
600
200 (abs)
Break-down pressure
kPa
300
1050
3000
7000
300
300
900
300 (abs)
Operating temp. range
°C
− 20 ~ 80
Compensated temp. range
°C
0 ~ 50
Operating humidity
Storage temp.
%RH
°C
Pressure medium
Insulation resistance
35 ~ 85(No condensation)
− 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum)
Corrosive gases/liquids compatible with SUS316L and SUS304
MΩ
minimum
100 (500 V DC)
500 V AC, 60 s(Leakage current 1 mA maximum)
Dielectric strength
Sealed liquid
Silicone oil
Pressure port
R 1/8、R 1/4
Net weight
Drip-proof structure
g
R2 : Approx. 50
IP65
100 (abs)
PA-750
Power
Item
Model number
Supply voltage ※
102G
352G
103G
353G
102V
Consumption current maximum
10 mA
Output voltage
V
1~5
Zero voltage
V
Span voltage
V
1 ± 0.04
302R
102A
3 ± 0.04
2 ± 0.04
1 ± 0.04
± 0.1
± 0.3
4 ± 0.04
mA
maximum
Linearity/Hysteresis
102R
10.8 ~ 30
V DC
Output current
Analog output
PA-750
1(Load resistance 5 kΩ minimum)
± 0.3
%F.S.
ZERO %F.S./°C
± 0.05
SPAN %F.S./°C
± 0.05
Thermal error
Response
ms
Approx. 2
Approx. 0.004V
(Approx. 0.1%F.S.)
resolving power
Gravitational effect
%F.S.
(From horizontal position to vertical position)
± 0.3
± 0.1
± 0.05
± 0.3
※ The type of drive voltage of 5V and output voltage of 0.5 to 4.5V (ratiometric output) are also available.
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Permissible change
Test conditions (At 25 ± 5 °C)
Shock
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s ,
3 directions for 2 hours each
490 m/s2
3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure/Rated pressure range 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
Vibration
2
Analog output
(Zero voltage, Span voltage)
: ± 1 %F.S. maximum each
PA-750
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● Configurations of joint R1 (R1/8) type
φ23.5
43.6
11
7
Plug Housing 2822390-1
①
②
PRESSURE TRANSDUCER
L O T . N o . ***
PA- 750-***□- R1
MADE IN
JAPAN
R1/8 Fitting
(SUS304)
14
Output connector
Plug
Tyco Electronics Japan G.K.
Econoseal Series〔Mark ll(+)〕
Label 2
14
Pressure Port
M5 depth 6
18
Label 1
③
Power(+)
Common
Output
Housing
(PPS)
Wire color
Brown
Blue
White
Plug Housing:2822390-1
Receptacle contact:171630-5
30.9
With connector
3-core shield cable (φ5.3)
L O T . N o . ***
PA- 750-***□-*
MADE IN
JAPAN
PRESSURE TRANSDUCER
AWG22UL2517
50±10
L = 1500±100
● Configurations of joint R2 (R1/4) type
φ23.5
45.5
18
Label 1
Pressure Port
M5 depth 6
13
7
14
LOT.No.
①
②
PRESSURE TRANSDUCER
PA-750-***□-R2
R1/4 Fitting
(SUS304)
Label 2
MADE IN
JAPAN
14
③
Housing
(PPS)
■ INTERNAL ELECTRICAL SCHEMATICS
Power ⊕
Output
N. C.
Power ⊕
Pressure
Sensor
Main circuit
Output connector
Plug
Output
Common
Power(+)
Common
Output
Connection
Power ⊕
Common
Output
PA-750
■ CUSTOMIZATION
We also offer customized solutions. Please contact your local sales office for details.
Example of customizations
Available with cable assembly (standard length:1.5m)
Customized pressure range 402A(0~400kPa abs)*for sterilizer use
5V operation
Customized joint (7/16-20UNF Male/Female screw etc.)
■ AVAILABLE WITH CABLE ASSEMBLY : REFERENCE DRAWING
Unless otherwise specified, tolerance : ±0.5 (Unit: mm)
Φ 23.5
11
7
30.6
(20)
(Φ 5.5)
Heat shrink tube
14
(Φ 7)
Pressure port
14
R1/8 Fitting
(SUS304)
Housing
(PPS)
L=1500 ± 100
Φ 23.5
13
7
30.6
(20)
Pressure port
14
14
Connection
Blown Power
Blue Common
White Output
Shield
R1/4 Fitting
(SUS304)
Housing
(PPS)
L=1500 ± 100
(Φ 5.5)
(Φ 7)
Heat shrink tube
很抱歉,暂时无法提供与“PA-750-102V-R1-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1960.10280
- 200+758.53800
- 500+731.88360
- 1000+718.70760
