PS20
PRESSURE SWITCHES
マーキング
EMC指令適合
INTERNAL STRUCTURE
marking
(2-M5 female screw)
Compatible with
EMC directive
1
4
3
5
2
6
Part name
■ FEATURES
● Ultra-small size pressure transducer with Amp.
● With 1 switch output
● 2 types of pressure ports are available
● Meet EMC standards
1
Pressure port
2
Housing
3
Sensor module
4
“O” ring
5
Cable
6
VR
Material
Aluminum
PC (Polycarbonate)
PPS (Polyphenylenesulphide)
Fluoro-rubber
Vinyl chloride resin
POM (polyoxymethylene)
■ MODEL NUMBER DESIGNATION
PS20-102V-NU
Series name
Pressure port
U:Universal joint
M:2-M5 female screw
Rated pressure range
102V:0 ~ -100 kPa(Gauge - Vacuum)
302R:-100 ~ 300 kPa(Gauge - Compound)
Switch output interface
P:PNP open collector
N:NPN open collector
■ LIST OF MODEL NUMBERS
Pressure port
Universal joint
2-M5 female screw
Pressure reference
Rated pressure range [kPa]
0 ~ – 100
– 100 ~ 300
NPN
PS20-102V-NU
PS20-302R-NU
PNP
PS20-102V-PU
PS20-302R-PU
NPN
PS20-102V-NM
PS20-302R-NM
PNP
PS20-102V-PM
PS20-302R-PM
※ Verify the above model numbers when placing orders.
PS20
PRESSURE SWITCHES
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 24 V DC.
Item
PS20
Model number
102V
General specifications
Pressure reference
Gauge
kPa
Maximum pressure
kPa 200
Operating temp. range
0 ~ − 100
°C
0 ~ 50
%RH
35 ~ 85
Storage temp.
Non-corrosive gases
100
MΩ minimum
Dielectric strength
500 V AC, 60 s
Power
Net weight
Without cable)
Supply voltage
Consumption current
g
Approx. 4 (PS20- **** - * U) 7 (PS20- **** - * M)
V DC
10.8 ~ 30(Including ripple percentage)
maximum
20 mA
No. of output
Switch output
600
− 20 ~ 70
°C
Pressure medium
Insulation resistance
− 100 ~ 300
− 10 ~ 60
°C
Compensated temp. range
Operating humidity
302R
1
Output interface
NPN/PNP open collector output
Setting method
Adjustable by VR
Adjustable range
Zero through rated pressure, minimum
Display
Red LED (lighted when output is ON.)
Accuracy
0 ~ 50 °C
(Reference temp.: 25 °C)
Hysteresis
% F.S.
% F.S. maximum
Switching capacity
±3
2
30 V DC 80 mA maximum
Residual voltage
V
Response
ms
0.8 (NPN), 1.8 (PNP)
Approx. 1
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Vibration
10 ~ 55 Hz, 1.5 mm maximum, 3 directions for 2 hours each
Shock
1000 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 106 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
EMC
EMI : EN55011: 2007, A2 : 2007 Group 1, class B
EMS : EN61326-1 : 2006 Table 2
Permissible change
Switch output pressure :
± 2 %F.S., maximum after test
Switch operating pressure : ± 5 %F.S., maximum during tset
PS20
PRESSURE SWITCHES
8
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
q 6.5
–0.3
● Universal joint type
3.5
M5:SUS 304
Pressure port
10
Housing Gasket
● M5 female screw type
10.5
5.5
10.5
Housing
10.8
Gasket
3.5
M5:SUS 304
Pressure port
0.5
10.8
10
10
–0.3
10
–0.3
q 6.5
8 –0.3
( q 3.2) AWG26 ULNo.2844
5.5 cable L = 1500 ± 75
20 3-core shielded
3-core shielded cable L = 1500 ± 75
PS20
10
–0.3
10
–0.3
Wire color
5
5
2 – q 3.5
Through hole
Black
Switch output
Blue
Common
2 – q 3.5
Through hole
20.5
10
3.3
5
Power B
20.5
10
3.3
5
2 – M5 depth 5
Pressure port : AI / Alumite
2 – M5 depth 5
Connection
Brown
■ INTERNAL ELECTRICAL SCHEMATICS
■ SWITCH OUTPUT SCHEMATICS
● NPN open collector
Turns on at the set pressure and turns off at the set
pressure minus the hysteresis.
LED Indicator
Pressure
Sensor
Power B
Main circuit
● 102V
Hysteresis
Load
S.Output
Common
ON
OFF
-100 kPa
● PNP open collector
Power B
Pressure
Sensor
Main circuit
S.Output
Load
Common
Barometic
pressure
Hysteresis
● 302R
LED Indicator
Set value
ON
OFF
-100 kPa
Set value
300 kPa
很抱歉,暂时无法提供与“PS20-102V-PU”相匹配的价格&库存,您可以联系我们找货
