PS80-K2-F0307
PS80-K2-F0307
    SENSATA(森萨塔)
    Cylinder
PS80-K2-F0307 数据手册
APPLICATION NOTE AIR CONDITIONING & REFRIGERATION Background AC and refrigeration systems require precise and reliable pressure control to ensure safe, reliable, and efficient operation. As AC and refrigeration equipment utilizes compression and evaporation of refrigerants to produce a cooling effect, therefore it is critical that the refrigerant pressures in these system are managed carefully to ensure the equipment operates properly and will not become unsafe due to excessive pressures. New AC and refrigeration systems also manage pressure with pressure sensors and variable speed compressors to ensure the highest possible energy efficiency. Solution For decades, Sensata has been a leading provider of pressure sensing solutions used in AC and refrigeration systems. The PS80 is a UL listed automatic reset pressure switch that provides electro-mechanical pressure control for both low pressure and high pressure control in refrigerant loops. The PS80 is available in a wide range of pressure settings and configurations which can be used with a wide range of refrigerants. The 2CP5 is a device designed for today’s most efficient AC and Refrigeration equipment that use pressure sensing, electronic controls, and variable speed compressors to precisely manage the refrigerant pressure for lower power consumption, quieter operation and more pressure temperature control. Both the PS80 and 2CP5 are ideal for demanding applications where long-term reliability and accuracy is critical. New AC and refrigeration systems manage pressure with pressure sensors to ensure the highest possible energy efficiency Commercial Fridge & Freezer Rooftop AC System Page 1 RELATED PRODUCTS Reference on Diagram Product Features Function Technology Operating Range 1 2CP5 • UL recognized • Low cost Pressure Sensor Ceramic capacitive 0-15 to 0-750 psi 2 2HMP • Hermetic • 1% accuracy Pressure Sensor MEMS 0-100 to 0-750 psi 3 PS80 • UL recognized automatic reset Pressure Switch Klixon (snap-acting switch) 0-750 psi 4 3NT • Dry seal (ideal for condensing environments) Thermostat Klixon (snap-acting switch) -20 to 135°C GENERAL REFRIGERATION CYCLE DIAGRAM Page 2 Sensata Technologies, Inc. (“Sensata”) data sheets and application notes are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets and application notes have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet and application notes. Sensata may make corrections, enhancements, improvements and other changes to its data sheets and application notes or components without notice. Buyers are authorized to use Sensata data sheets and application notes with the Sensata component(s) identified in each particular data sheet and application notes. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS AND APPLICATION NOTES ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS AND APLICATION NOTES, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS AND APPLICATION NOTES OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. Rev:03/01/18 CONTACT US Americas +1 (877) 350 2727 sensors@sensata.com switches@sensata.com Europe, Middle East & Africa +359 (2) 809 1826 pressure-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
PS80-K2-F0307 价格&库存
很抱歉,暂时无法提供与“PS80-K2-F0307”相匹配的价格&库存,您可以联系我们找货
