PRESSURE SWITCHES WITH GAUGE
PS60
マーキング
EMC指令適合
INTERNAL STRUCTURE
marking
1
Compatible with
EMC directive
2
5
3
4
6
Part name
■ FEATURES
● Applicable for negative through positive pressure with 10
mm thick slim housing
● Suitable for use in clean rooms with easy-to-use push keys
● Plug-in connector is provided for easy installation and
maintenance
● Space saving and mountable on DIN rails
● Data protection by panel lock system
● Low consumption by nondisplay mode
1
Pressure port
2
“O” ring
3
Sensor module board
4
Housing
5
Display board
6
Operation panel seet
Material
Polyamide (Resin of MXD6 series)
Brass (Ni-plated)
Fluoro-rubber
PBT (Polybutyleneterephtalate)
Polyester
■ MODEL NUMBER DESIGNATION
P S 6 0 - 1 0 2 R - N M C N
Signal / power cable pullout method
Series name
CN:Connector pullout
Rated pressure range
102:−100 ~ 100 kPa
302:−100 ~ 300 kPa
103:−100 ~ 1000 kPa
Pressure port
M:M5 female screw
Pressure reference
R:Compound pressure (Negative pressure ~ Positive pressure)
Switch output interface
N:NPN open collector
P:PNP open collector
■ LIST OF MODEL NUMBERS
Pressure port
Switch output
M 5 female screw
NPN open collector output
PNP open collector output
※ Verify the above model numbers when placing orders.
102R 302R 103R
−100 ~ 100 kPa
−100 ~ 300 kPa
−100 ~ 1000 kPa
PS60-102R-NMCN PS60-302R-NMCN PS60-103R-NMCN
PS60-102R-PMCN PS60-302R-PMCN PS60-103R-PMCN
PS60
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 24 V DC.
Item
PS60
Model number
102R 302R 103R
General specifications
Pressure reference
Gauge
kPa
Maximum pressure
kPa 200
600
1500
Break-down pressure
kPa 500
1000
2000
Operating temp. range
−100 ~ 100
Storage temp.
0 ~ 50
35 ~ 85(No condensation)
%RH
−20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum)
°C
Pressure medium
Insulation resistance
Non-corrosive gases
MΩ min.
100 (500 V DC)
± 3 %F.S. (0 ~ 50 °C)
Thermal error
500 V AC, 60 s(Leakage current 1 mA maximum)
Dielectric strength
Pressure port
Power
Net weight
Supply voltage
Consumption current
M5 Female screw
Approx. 50(Includihg cable)
g
V DC
12 ~ 24 V ± 10 %(Including ripple percentage)
mA max.
30
Display
Display element
3-digit LED
Rated display range
Display accuracy
No. of outputs
Switch output
−100 ~ 300 kPa
1 count
Resolution
2
Output interface
Open collector output (NPN or PNP)
Setting method
Adjustable by panel switch
Adjustable range
−110 kPa (approx.) ~ “999” counts
Red LED ON
Display
Repeatability
± 0.3 %F.S. maximum
Switch hysteresis
0 ~ 30 counts
30 V 100 mA maximum
Switching capacity
V maximum
Responsems
−100 ~ 100 kPa
± 1 %F.S.
0 〜 50℃
(Reference temp. 25 °C)
Residual voltage
Accessories
−100 ~ 1000
−10 ~ 50
°C
Compensated temp. range °C
Operating humidity
−100 ~ 300
1.2 (NPN), 2.2 (PNP)
Approx. 5, 25, 250
PS60 cable, DIN rail adaptor
−0.10 ~ 1.00 MPa
PS60
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s2, 3 directions for 2 hours each
Shock
490 m/s2, 3 directions for 3 times each
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
Pressure cycling
0 ~ Rated pressure, 106 cycles
EMC
EMI : EN55011: 2007, A2 : 2007 Group 1, class B
EMS : EN61326-1 : 2006 Table 2
Pressure indication and switch operating output :
± 2 %F.S., maximum each after test
Pressure indication and switch operating output, alalog
output : ± 5 %F.S., maximum during test
■ CIRCUIT DIAGRAMS
● NPN open collector
1
2
● PNP open collector
LED Indicator
1
LED Indicator
2
Power B
Load
Pressure
Sensor
Power B
Load
Pressure
S.Output1
S.Output2
Main circuit
S.Output1
Main circuit
S.Output2
Sensor
Load
Load
Common
Common
LED
LED
Pressure indication
Pressure indication
■ SWITCH OUTPUT MODE
SW1
Output
Mode
Operation
Separate
HI
LO
Separate mode
SW2
Window comparator
A
B
Separate
HI
LO
A
B
S- 1
S- 2
S- 3
S- 4
C- 5
C- 6
C- 7
C- 8
Pressure setting
(Operating point)
(HI operation)
Window comparator
OFF
-Pr
P2: SW2
H
H
ON
ON
Pr
-Pr
(LO operation)
ON
-Pr
P1: SW1
Window comparator mode
(A operation)
P1
H
(Lower limit) : Setting 1
(Upper limit) : Setting 2
Setting 2
ON
P2
Pr
H
(B operation)
ON
P1: SW1
P2: SW2
H
H
OFF
OFF
Pr
-Pr
P1
OFF
P2
H
P1≦P2 or P1≧P2
Setting 1
OFF
Pr
H
P1≦P2–2H
H:Switch hysteresis、
P1=Setting 1、P2=Setting 2
Note 1. In the Separate Mode, setting 1 corresponds to SW1, and
Setting 2 corresponds to SW2.
Note 2. In the Window Comparator Mode, the minimum value for
SW1 and SW2 corresponds to Setting 1 and the maximum
value corresponds to Setting 2.
■ DISPLAY RANGE
● Display range can be selected as the table.
Note) “–” on the table indicates that it is not selectable in relation to resolution and display lines.
※ : In terms of setting display range, please verify the default mode.
Number
102R
302R
1 (kPa)
–100 ~ 100
–100 ~ 300
2 (MPa)
–0.10 ~ 1.00
3
–75 ~ 75
–75 ~ 225
4
–1.00 ~ 1.00 –1.00 ~ 3.00
–1.0 ~ 10.0
5
–14.5 ~ 14.5 –14.5 ~ 43.5
–14 ~ 145
6
29.5 ~ 0.0 ※
※ Atmospheric pressure
103R
29.5 ~ 0.0 ※ —
PS60
■ OUTLINE DIMENTIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● Pressure port M type (NMCN, PMCN)
10.2
–0.2
Panel seet (Polyester)
4.5
Terminal no.
Connection
4
SW output 1
(7)
(52.5)
Housing (PBT)
4.5
2 – φ 3.1 Mounting hole
SW output 2
2
Power (DC10.8 ~ 26.4 V)
1
Common
< Terminal No. >
4
1.1
12
1
9
4.6
25 –0.2
13.2
Pressure port (PA MXD6)
3
8
Part No. (Laser marking)
Pressure port (BSBM, Ni-plated)
Insert screw : M5 depth 5
4
DIN rail adapter (accessory)
Connector : Pitch / 4 poles(□0.64)
Housing : Manufactured by JST (XAP-04V-1)
■ Accessories
● Connector cable
Length : 1500 ± 50
70 ± 20
Heat shrink tube (Black)
50 ± 10
(5)
4
1
Contact : Manufactured by JST (SXA-001T-P0.6L)
Pin no.
Wire color
Connection
4
Black
SW output 1
3
White
SW output 2
2
Blown
Power B
1
Blue
Common
4-core cable ( φ 4)
AWG26 ULNo.2844
● DIN rail adapter
1.1
10
3.7
5
1.5
PS60
6.5
DIN rail (width 35)
adaptaion
Tolerated stroke 2 maximuum
54.2
DIN base : PBT
Slide (DIN stopper) : POM
很抱歉,暂时无法提供与“PS60-103R-NMCN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1334.221671+173.44450
- 6+1233.877476+160.40008
- 12+1200.6773812+156.08418
- 27+1165.2767727+151.48221
- 51+1139.8951351+148.18268
- 国内价格
- 1+1337.60160
- 201+517.63320
- 501+499.44600
- 999+490.46040
