P-7100
Ultra-miniature pressure sensors
P-7100 構造図
INTERNAL STRUCTURE
①
③ ⑤
⑥
Pressure
②
Part name
■ FEATURES
● Suitable for installing inside the narrow space of the
equipment thanks to its small size and light weight
outline dimensions φ 17×18.7mm, Net weight: Approx
19 g (M5 type)
● High reliability (SUS316L diaphragm, oil-filled) by using
double diaphragm structure
● Supply voltage and analog output is 5±0.5V and the 0.5
~ 4.5V(ratiometric output)
● High accuracy by using a digital compensation circuit
employing the COB (chip on board) mounting
● Variety pressure range: 0 ~ 100kPa, -100 ~ 100kPa, 0 ~
1MPa, 0 ~ 133.3kPa abs
④
⑦
Material
1
Fitting
SUS304
2
Stainless steel diaphragm
SUS316L
3
Sealed liquid
Silicone oil
4
Sensor chip
Silicon
5
Housing
6
Resin compound
7
Vent hole
SUS 304
Epoxy resin
Iron + gold-plated
※⑦ is applicable to gauge type only.
■ MODEL NUMBER DESIGNATION
P-7100 - 102 G - R1
Series name
Fitting
R 1:R1/8
M5:Female
Rated pressure range
Pressure reference
102G:0 ~ 100kPa
103G:0 ~ 1.0MPa
102R:-100 ~ 100kPa
132A:0 ~ 133.3kPa abs
G:Gauge (Positive)
R:Gauge (Compound)
A:Absolute
■ LIST OF MODEL NUMBERS
Fitting
R1/8
M5
102G
P-7100-102G-R1
P-7100-102G-M5
102R
103G
P-7100-102R-R1
P-7100-103G-R1
P-7100-102R-M5
P-7100-103G-M5
※ Verify the above model numbers when placing orders.
132A
P-7100-132A-R1
P-7100-132A-M5
P-7100
PRESSURE TRANSDUCERS
■ STANDARD SPECIFICATIONS
Item
P-7100
Model number
102G
103G
General specifications
Absolute
0 ~ 100kPa
0 ~ 1.0MPa
-100 ~ 100kPa
0 ~ 133.3kPa abs
Maximum pressure
200kPa
2.0MPa
200kPa
200kPa abs
Break-down pressure
300kPa
3.0MPa
300kPa
300kPa abs
Operating temp.range
°C
− 20 ~ 70
Compensated temp. range
°C
0 ~ 50
Operating humidity range
%RH
35 ~ 85(No condensation)
°C
Storage temp. range
− 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum)
Corrosive gases/liquids compatible with SUS316L and SUS304
Media
MΩ
minimum
Insulation resistance
100(500V DC)
500V AC 60 s(Leakage current 1mA maximum)
Dielectric strength
Sealed liquid
Silicone oil
Pressure port
R1/8, M5(SUS304)
g
Net weight
Voltage
132A
Gauge
Pressure reference
R1:Approx.22, M5:Approx.19
V DC
Operating voltage
5±0.5
mA
Maximum
Current consumption
3
V
Output voltage ※
0.5 ~ 4.5
16.5mV ~ 95% Vopr
Output limit
V
Zero voltage ※
Analog output
102R
V
Span voltage ※
0.5±0.1
4.0±0.1
1(Load resistance 5kΩ minimum)
%F.S.
Linearity / Hysteresis
Response time
2.5±0.04
4.0±0.04
mA
Maximum
Output current
Thermal error
(Reference temp.25°C)
0.5±0.04
±0.5
Zero
%F.S./°C
±0.05
±0.06
Span
%F.S./°C
±0.05
±0.06
ms
%F.S.
Gravitational(From horizontal position to vertical position)
Approx.2
±0.3
±0.05
±0.3
±0.3
※ Output voltage is proportional to the operating voltage.(ratiometric output) The resolving power of the analog output is 11 Bits (about 0.002V/0.05%F.S).
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s2,
3 directions for 2 hours each
Shock
Pressure cycling
Moisture resistance
490 m/s2, 3 directions for 3 times each
106 cycles
0 ~ Rated pressure
40 °C, 90 ~ 95 %RH, 240 hrs.
Permissible change
Analog output (Vzero, Vspan)
± 1 %F.S. maximum each after test
P-7100
P-7100-102G-R1 外形寸法図
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● P-7100-102G-R1
27.7
17
150±20
White
Potting(epoxy)
P-7100-102G-R1 3J2
Nidec COPAL ELECTRONICS
MADE IN JAPAN
Black
Red
Cable AWG26
Pressure port M5 depth6
P-7100-102G-M5 外形寸法図
Joint (R1/8)
● P-7100-102G-M5
18.7
17
150±20
Potting(epoxy)
White
P-7100-102G-M5 3J2
MADE IN JAPAN
Black
Red
Cable AWG26
※ Product with 1.5m cable is also available as customized product.
Wire color
Red
White
Black
P-7100内部回路図
■ INTERNAL ELECTRICAL SCHEMATICS
Pressure
Sensor
Main circuit
Power +
Output
Common -
Connection
Power B
Output
Common
很抱歉,暂时无法提供与“P-7100-103G-R1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1382.75640
- 200+535.10760
- 500+516.30480
- 1000+507.01680
