SEN0257
SEN0257
    DFROBOT
    Cylinder, Metal
    SEN0257
SEN0257 数据手册
Gravity: Water Pressure Sensor SKU: SEN0257 Gravity: Analog Water Pressure Sensor SKU: SEN0257 This is a water pressure sensor that adopts DFRobot Gravity 3-pin interface. It supports standard 5V voltage input and 0.5~4.5V linear voltage output. It is compatible with multiple Arduino controllers. Coordinate with a DFRobot Gravity IO Expansion Shield, the water pressure sensor can be plugged into an Arduino board, wiring-free. Put it with a Solenoid Valve , a Water Turbine Generator and other sensors, you can build a smart water control system. Briefly speaking, this water pressure sensor is a stethoscope to a water pipe. It will help you to diagnose whether there is water, how strong the water pressure is. It can be widely applied to smart home control systems (SCS), Internet of Things (IoT) and device detection. Features • • • • Support water pressure detection of living environmental water systems, such as houses, gardens and farms. Support water pressure detection of outdoor environment, such as rivers, lakes and sea. Support water pressure detection of tanks. Support liquid level detection in special situation. Specification • • • • • • • • • • • • • • • Medium: liquid/gas without corrosion Wiring: Gravity-3Pin (Signal-VCC-GND) Pressure Measurement Range: 0~1.6 Mpa Input Voltage: +5 VDC Output Voltage: 0.5~4.5 V Measurement Accuracy: 0.5%~1%FS (0.5%, 0~55°C) Threadably: G1/4 Adapter: G1/2 to G1/4 Waterproof Level: IP68 Operating Temperature: -20~85°C Response Time:
SEN0257 价格&库存
很抱歉,暂时无法提供与“SEN0257”相匹配的价格&库存,您可以联系我们找货
