PA-750-103G-R2
PA-750-103G-R2
    NIDEC(尼得科)
    Cylinder
    PA-750-103G-R2
PA-750-103G-R2 数据手册
PRESSURE TRANSDUCERS WITH AMP. PA-750 マーキング EMC指令適合 INTERNAL STRUCTURE PA-750 (R 1/4) marking Compatible with EMC directive ③ ① ② Part name ■ FEATURES Material ① Fitting ② Housing ③ Stainless steel diaphragm SUS 304 PPS SUS 316L ● High corrosion resistance and drip-proof construction Pressure port attachment made of SUS 316L Proven IP65 grade gauge body (IP65 in accordance with IEC) ● Cable connector connection ● Buit-in temperature compensation function (0 ~ 50°C) ● Absolute pressure type and compound pressure type which can control negative to positive pressure with only a single pressure gauge are all in line ● Voltage output mode ■ MODEL NUMBER DESIGNATION PA-750 - 102 R - R2 - 1 Series name Cable Blank:1.5m cable 1:Not attached Pressure reference Rated pressure range G:Gauge 102:0 352:0 103:0 353:0 ~ ~ ~ ~ 100 kPa 350 kPa 1 MPa 3.5 MPa V:Gauge(Vacuum) 102:0 ~ − 100 kPa R:Compound 102:− 100 ~ 100 kPa 302:− 100 ~ 300 kPa A:Absolute 102:0 ~ 100 kPa abs ※ Please refer to the LIST OF MODEL NUMBERS when placing orders. Fitting R1:R 1/8 with M 5 female screw R2:R 1/4 with M 5 female screw PA-750 PRESSURE TRANSDUCERS WITH AMP. ■ LIST OF MODEL NUMBERS Fitting R1 R2 Pressure reference Cable Gauge 0 ~ 100 Rated pressure range 0 ~ 350 PA-750102G-R1 PA-750102G-R1-1 PA-750102G-R2 PA-750102G-R2-1 Attached Not attached Attached Not attached 0 ~ 1000 PA-750   103G-R1 PA-750   103G-R1-1 PA-750   103G-R2 PA-750   103G-R2-1 PA-750352G-R1 PA-750352G-R1-1 PA-750352G-R2 PA-750352G-R2-1 Absolute 0 ~ 3500 0 ~ − 100 PA-750   353G-R1 PA-750   353G-R1-1 PA-750   353G-R2 PA-750   353G-R2-1 PA-750102V-R1 PA-750102V-R1-1 PA-750102V-R2 PA-750102V-R2-1 − 100 ~ 100 − 100 ~ 300 0 ~ 100 (abs) PA-750   102R-R1 PA-750   102R-R1-1 PA-750   102R-R2 PA-750   102R-R2-1 PA-750   302R-R1 PA-750   302R-R1-1 PA-750   302R-R2 PA-750   302R-R2-1 PA-750   102A-R1 PA-750   102A-R1-1 PA-750   102A-R2 PA-750   102A-R2-1 ※ Verify the above model numbers when placing orders. are manufactured upon receipt of order basis. ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 12 V DC. Item Model number General specifications Pressure reference PA-750 102G 352G 103G 353G 102V 102R 302R     Gauge 102A Absolute − 100 ~ 100 − 100 ~ 300 Rated pressure range kPa 100 350 1000 3500 − 100 Maximum pressure kPa 200 700 2000 5000 200 200 600 200 (abs) Break-down pressure kPa 300 1050 3000 7000 300 300 900 300 (abs) Operating temp. range °C − 20 ~ 80 Compensated temp. range °C 0 ~ 50 Operating humidity Storage temp. %RH °C Pressure medium Insulation resistance 35 ~ 85(No condensation) − 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum) Corrosive gases/liquids compatible with SUS316L and SUS304 MΩ minimum 100 (500 V DC) 500 V AC, 60 s(Leakage current 1 mA maximum) Dielectric strength Sealed liquid Silicone oil Pressure port R 1/8、R 1/4 Net weight Drip-proof structure g R2 : Approx. 50 IP65 100 (abs) PA-750 PRESSURE TRANSDUCERS WITH AMP. Power Item Model number Supply voltage ※ 102G 352G 103G 353G 102V Consumption current maximum 10 mA Output voltage V 1~5 Zero voltage V Span voltage V 1 ± 0.04 302R 102A 3 ± 0.04 2 ± 0.04 1 ± 0.04 ± 0.1 ± 0.3 4 ± 0.04 mA maximum Linearity/Hysteresis 102R 10.8 ~ 30 V DC Output current Analog output PA-750 1(Load resistance 5 kΩ minimum) ± 0.3 %F.S. ZERO %F.S./°C ± 0.05 SPAN %F.S./°C ± 0.05 Thermal error Response ms Approx. 2 Approx. 0.004V (Approx. 0.1%F.S.) resolving power Gravitational effect %F.S. (From horizontal position to vertical position) ± 0.3 ± 0.1 ± 0.05 ± 0.3 ※ The type of drive voltage of 5V and output voltage of 0.5 to 4.5V (ratiometric output) are also available. ■ ENVIRONMENTAL CHARACTERISTICS Test item Permissible change Test conditions (At 25 ± 5 °C) Shock 10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s , 3 directions for 2 hours each 490 m/s2 3 directions for 3 times each Pressure cycling 0 ~ Rated pressure/Rated pressure range 106 cycles Moisture resistance 40 °C, 90 ~ 95 %RH, 240 hrs. Vibration 2 Analog output (Zero voltage, Span voltage) : ± 1 %F.S. maximum each PA-750 PRESSURE TRANSDUCERS WITH AMP. ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.5 (Unit: mm) ● Configurations of joint R1 (R1/8) type φ23.5 43.6 11 7 Plug Housing 2822390-1 ① ② PRESSURE TRANSDUCER L O T . N o .  *** PA- 750-***□- R1 MADE IN JAPAN R1/8 Fitting (SUS304) 14 Output connector Plug Tyco Electronics Japan G.K. Econoseal Series〔Mark ll(+)〕 Label 2 14 Pressure Port M5 depth 6 18 Label 1 ③ Power(+) Common Output Housing (PPS) Wire color Brown Blue White Econoseal Series〔Mark ll(+)〕 Tyco Electronics Japan G.K Plug Housing:2822390-1 Receptacle contact:171630-5 30.9 With connector 3-core shield cable (φ5.3) L O T . N o .  *** PA- 750-***□-* MADE IN JAPAN PRESSURE TRANSDUCER AWG22UL2517 50±10 L = 1500±100 ● Configurations of joint R2 (R1/4) type φ23.5 45.5 18 Label 1 Pressure Port M5 depth 6 13 7 Plug Housing 2822390-1 14 LOT.No. ① ②  *** PRESSURE TRANSDUCER PA-750-***□-R2 R1/4 Fitting (SUS304) Tyco Electronics Japan G.K. Econoseal Series〔Mark ll(+)〕 Label 2 MADE IN JAPAN 14 ③ Housing (PPS) ■ INTERNAL ELECTRICAL SCHEMATICS Power ⊕ Output N. C. Power ⊕ Pressure Sensor Main circuit Output connector Plug Output Common Power(+) Common Output Connection Power ⊕ Common Output PA-750 PRESSURE TRANSDUCERS WITH AMP. ■ CUSTOMIZATION We also offer customized solutions. Please contact your local sales office for details. Example of customizations Available with cable assembly (standard length:1.5m) Customized pressure range 402A(0~400kPa abs)*for sterilizer use 5V operation Customized joint (7/16-20UNF Male/Female screw etc.) ■ AVAILABLE WITH CABLE ASSEMBLY : REFERENCE DRAWING Unless otherwise specified, tolerance : ±0.5 (Unit: mm) ● Configurations of joint R1 (R1/8) type Φ 23.5 11 7 30.6 (20) (Φ 5.5) Heat shrink tube 14 (Φ 7) Pressure port 14 R1/8 Fitting (SUS304) Housing (PPS) L=1500 ± 100 ● Configurations of joint R2 (R1/4) type Φ 23.5 13 7 30.6 (20) Pressure port 14 14 Connection Blown Power Blue Common White Output Shield R1/4 Fitting (SUS304) Housing (PPS) L=1500 ± 100 (Φ 5.5) (Φ 7) Heat shrink tube
PA-750-103G-R2 价格&库存
很抱歉,暂时无法提供与“PA-750-103G-R2”相匹配的价格&库存,您可以联系我们找货
PA-750-103G-R2
  • 1+1632.692521+212.21022
