PS30-102R-N
PS30-102R-N
    NIDEC(尼得科)
    Module Box with Display
    PS30-102R-N
PS30-102R-N 数据手册
PRESSURE SWITCHES WITH GAUGE PS30 ϚʔΩϯά &.$ࢦྩద߹ INTERNAL STRUCTURE 5 marking Compatible with EMC directive 1 4 2 3 6 Part name ■ FEATURES ● Optimum for pneumatic equipment and semiconductor manufacturing equipment ● Larger size display and high luminance LED for best visibility ● Eight switch output modes ● Low consumption by nondisplay mode ① Pressure transducer ② “O” ring ③ Pressure port ④ Base ⑤ Housing ⑥ Panel sheet Material P-2000 Fluoro-rubber Brass (Ni-plated) ABS (Acrylonitrile-butadiene-styrene) Polyester ■ MODEL NUMBER DESIGNATION P S 3 0 - 1 0 2 R - N Series name Switch output interface Rated pressure range N:NPN open collector P:PNP open collector 102R:−100 ~ 100 kPa 103R:−0.1 MPa ~ 1.00 MPa ■ LIST OF MODEL NUMBERS Gauge Pressure reference Switch output interface −100 ~ 100 kPa −100 ~ 1000 kPa NPN PS30-102R-N PS30-103R-N PNP PS30-102R-P PS30-103R-P Rated pressure range ※ Please refer to the LIST OF MODEL NUMBERS when placing orders. PS30 PRESSURE SWITCHES WITH GAUGE ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 24 V DC. Item PS30 Model number 102R 103R General specifications Pressure reference Gauge − 100 ~ 100 kPa Maximum pressure kPa 200 1500 Break-down pressure kPa 500 2000 Operating temp. range °C Compensated temp. range °C − 10 ~ 50 0 ~ 50 ± 3 %F.S. (0 ~ 50 °C) Thermal error Operating humidity 35 ~ 85(No condensation) %RH Storage temp. − 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum) °C Non-corrosive gases Pressure medium Insulation resistance 100 (DC 500 V) MΩminimum 500 V AC, 60 s(Leakage current 1 mA maximum) Dielectric strength Pressure port M5 female screw, “O” ring groove (P8) Net weight Power − 100 ~ 1000 Rated pressure range Supply voltage Consumption current Approx. 60(Including 1.5 m cable) g 12 ~ 24 V ± 10 %(Including ripple voltage) V DC 40 mA maximum Display Display element Rated display range LED(2 and 1/2 digit) − 100 ~ 100 ——— kPa MPa ——— − 0.10 ~ 1.00 Display accuracy ± 1 %F.S. Resolution 1 count No. of outputs 2 Open collector output (NPN or PNP) Switch output Output interface Output 1 (SW1), Output 2 (SW2) Light on when output is ON. Display Repeatability %F.S. ± 0.3 maximum 0 ~ 30 counts(Adjustable) Switch hysteresis 30 V DC 100 mA maximum Short-circuit protection Switching capacity Residual voltage 1.2 V (NPN), 2.2 V (PNP) V maximum Response ms Approx 5, 25, 250(Adjustable) ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Vibration 10 ~ 500 Hz, 98.1 m/s2 or 1.5 mm P-P, 3 directions for 2 hours each Shock 490 m/s2, 3 directions for 3 times each Pressure cycling 0 ~ Rated pressure、106 cycles Moisture resistance 40 °C, 90 ~ 95 %RH, 240 hrs. EMC EMI : EN55011: 2007, A2 : 2007 Group 1, class B EMS : EN61326-1 : 2006 Table 2 ※1 Change in the pressure indication, switch operating points. Permissible change ± 2 %F.S. maximum after test Switch operating pressure : ± 5 %F.S., maximum during tset ※ 1 PS30 PRESSURE SWITCHES WITH GAUGE ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.5 (Unit : mm) 29 □31 SW1 2–M 3 Depth 6 20 “O” ring groove (P8) 4 PS30 PS30 SW2 kPa 20 □30 Wire color Base ABS Housing ABS Pressure port (Brass, Ni-plated) M5 female depth 5 4-core cable(φ4) L = 1500 100 AWG26 ULNo.2844 ■ INTERNAL ELECTRICAL SCHEMATICS ● NPN 1 Brown Power ⊕ Black Switch output 1 White Switch output 2 Blue Common ● PNP 動作LED Indicator 2 Connection 1 動作LED Indicator 2 Power • Power • Load Pressure Pressure S.Output1 S.Output2 Main circuit Sensor Load Sensor S.Output1 Main circuit S.Output2 Load Load Common Common LED 圧力表示 Pressure indication LED 圧力表示 Pressure indication ■ SELECTION OF DISPLAY MULTIPLIER Please refer to the right list. Selection number (Note) Diagonal column : No unit can be selected due to resolution and number of digits. 102R 103R Display multiplier Display range Display multiplier Display range ×1 −100 ~ 100 × 0.75 75 ~ 75 0 1 2 −1.00 ~ 1.00 3 × 0.01 4 × 0.145 −14.5 ~ 14.5 ×1 −0.10 ~ 1.00 × 10 −1.0 ~ 10.0 −14 ~ 145 × 145 ■ SWITCH OUTPUT MODE Output Mode SW 1 Separate HI 0 1 2 3 4 5 6 7 ○ ○ Selection number Operation LO SW 2 Window comparator A B Separate HI ○ ○ ○ Setting 1 Note 1 ○ ○ ○ LO A ○ OFF -Pr ○ ○ Setting 1 Note 1 (HI operation) B ○ ○ ○ Lower limit : Setting 1 Upper limit : Setting 1 Note 2 Separate mode Window comparator ON ○ -Pr ○ Lower limit : Setting 1 Upper limit : Setting 1 Note 2 P1: SW1 P2: SW2 H H Window comparator mode ON Pr ON -Pr (A operation) OFF P1 H P2 ON Pr H (B operation) (LO operation) ON P1: SW1 H P2: SW2 H P1≦P2 or P1≧P2 OFF Pr OFF -Pr P1 P2 H H OFF Pr P1≦P2+2H P1:Setting 1、P2:Setting 2、H:Switch hysteresis (Note 1) In the Separte Mode, setting 1 corresponds to SW1, and Setting 2 corresponds to SW2. (Note 2) In the Window Comparator Mode, the minimum value for SW1 and SW2 corresponds to Setting 1 and the maximum value corresponds to Settng 2. PS30 PRESSURE SWITCHES WITH GAUGE ■ HOW TO MOUNT OPTIONAL ACCESSORIES (Sold separately) ● Port block ● How to mount port block □31 15 20 (PS30) Body 10 4 – φ3.3 (P8) “O” ring Port block 20 M3×10 Male screw (2 pcs.) Pressure port 2 – Rc1/8 Material : Zink die-casting / nickel plate ● Rear panel mounting bracket (ACPG-001) Fixed 18 30 ● Panel mounting bracket (ACPG-002) 18 2-φ3.5 20 20 15 Fixed 15 φ4.2 25 20 30 6 15 20 30 40 39 2- φ 3.5 20 φ 4.2 x 5.2 Slot Material : SUS304 t = 1.5 φ4.2 φ 4.2 x 5.2 Slot Material : SUS304 t = 1.5 ● Panel mounting bracket (Option) (□42.6) □ 40 (5.7) 4.5 PS30 SW2 kPa +0.5 0 36 +0.5 0 SW1 36 23.5 Panel cut dimension (Panel board thickness : 1 ~ 3.6 mm) ● How to mount panel holder cover set Panel holder cover Name Description ACPG-001 Rear panel bracket set ACPG-002 Panel bracket set Holder cover set Panel holder set Applicable model Rear panel bracket and M3 x 4 male screw (2 pcs.) PG-30·PS30 Panel bracket and M3 x 4 male screw (2 pcs.) PG-30·PS30 ACPG-003 Panel holder cover Holder cover set Panel holder (For protecting operating panel) Panel stopper (2 pcs.) PG-30·PG-35 PG-75·PG-35H PG-35L·PS30 ACPG-004 Holder cover set Panel holder cover (For protecting operating panel) Panel holder PG-30·PG-35 PG-75·PG-35H PG-35L·PS30 Panel holder Body (PS30) Contents Mounting panel ACPG-005 Port block ACPG-007 holder stopper set Panel stopper 2 pcs. Port block “O” ring (P8) M3 x 10 Male screw 2 pcs. Seal screw 1 pc. PS30 Panel holder Panel stopper (2pcs.) PG-30·PG-35 PG-75·PG-35H PG-35L·PS30
PS30-102R-N 价格&库存
很抱歉,暂时无法提供与“PS30-102R-N”相匹配的价格&库存,您可以联系我们找货
