P158-300A-C2C
P158-300A-C2C
    SENSATA(森萨塔)
    Cylinder
P158-300A-C2C 数据手册
P158 Refrigeration Pressure Transducers Typical Applications High and Low Side Pressure Measurements in Refrigeration Systems Product Refrigeration Refrigerant Recovery Transport Refrigeration Environmental Test Equipment Standard Full Scale Pressure Ranges 0-100, 150, 300, 400, 500 and 750 PSIA, PSIS Features SAE female Process Connection with Built-in Schrader Deflator Linear Amplified Output Temperature Compensated Superior Long Term Stability Excellent Repeatability/Hysteresis EMI/RFI Rejection Low Power Consumption Ten Million Cycle Life Expectancy Outstanding Shock & Vibration Performance Over Voltage, Reverse Polarity and Short Circuit Protection Potsdamer Str. 14, 32423 Minden, Germany Tel: +49 571 3859-0 - Fax: +49 571 3859-119 Email: info@kavlico.de www.kavlico.com 235 E. Main St., Suite 102A, Northville, MI 48167, USA Tel: +1 (248) 465-0815 - Fax: +1 (248) 465-0810 Email: pressure.sensors@kavlico.com Description The model P158 is based on Kavlico’s ceramic capacitive technology with a custom ASIC. The Brass housing surrounds a pressure transducer designed specifically for refrigeration applications. It can endure the high vibration, broad temperature ranges and humidity conditions found in refrigeration systems while withstanding high overpressures and pressure pulsations without damage or degradation. The P158 package has a built-in Metri-Pack 150, electrical connector and supports male and female process connections. The P158 is offered with seal materials that are suitable for many of the latest refrigerants such as R134a, R22, R123, R12, including many of the proprietary blends, and assocated lubricants. Technical Specifications Note: Performance Specifications with 5v ± 0.002 Vdc supply at 25°C Pressure Ranges: Proof Pressure: Burst Pressure: Supply Voltage: Supply Current: Linearity Error: Response Time: Output Voltage Zero/Null Pressure: Full Pressure: Ratiometricity: Total Error Band: Output Impedance: Operating Temperature: Storage Temperature: Service Life: Vibration: Ingress Protection: Shock: Stability: Weight: Electrical Termination: Pressure Connection: Output Load: Over-Voltage Protection: Reverse Polarity Protection: Main Housing Material: How to Order P158 Pressure Transducer 0 – 100 PSI through 0 – 1,000 PSI Absolute or Sealed Gage 3x (FSO) (100 through 300 PSI) 2x (FSO) (400 through 750 PSI) 5x (100 through 300 PSI) 2250 PSI (400 through 750 PSI) 5.0 ± .5 V 5 mA (Max) ±0.5% of Full Span Max. 15ms Max to 63% of F.S. Pressure with Step Change on Input 0.50 ±0.08 Vdc 4.50 ±0.08 Vdc ±0.51% of Span 2.0% of Span (-20˚C to +100˚C) < 100 Ω -30°C to +100°C -40°C to +135°C 10 Million Full Pressure Cycles 10G’s P-P Sinusoidal, from 10-2000 Hz IP67 75 G’s ½ Sine Wave ±0.5% of Full Span over 1-Year 100 grams (Max) Packard Electric Metri-Pack 150 Series See “How to Order” >25k Ω 16 Vdc -5 Vdc CA3600 Brass Pressure Range 100 150 300 400 500 750 0 - 100 PSI 0 - 150 PSI 0 - 300 PSI 0 - 400 PSI 0 - 500 PSI 0 - 750 PSI Reference A Absolute S Sealed Gage Seal Material C Neoprene -40 to + 125° C F Ethylene Propylene -40 to + 121° C H HNBR -30 to + 135° C Pressure Connection 1 1/4 - 18 NPT (External Threads) 2 1/4 SAE Female Flare w/Schrader Deflator (7/16 - 20 UNF Internal Threads) 4 1/8 - 27 NPT Electrical Connection A With Mating Connector, w/12”, 18 AWG Leads C Without Mating Connector P158 - 500 - S - F - 1 - A Example: P158 - 500 - S - F - 1 - A Description: P158 Pressure Transducer, 0 - 500 PSIS (Sealed Gage), with Ethylene Propylene Seal Material, 1/4 - 18 NPT Pressure Connection, and Mating Connector Don’t see what you want? Before installation and operation, ensure that the appropriate pressure sensor has been selected in terms of pressure range, design and specific measuring conditions. Non-compliance can result in serious injury and/or damage to the equipment. Call us at +1 (619) 710-2068 to customize this product to meet your application-specific needs! Warning: The product information contained in this catalogue is given purely as information and does not constitute a representation, warranty or any form of contractual commitment. Kavlico reserve the right to modify their products without notice. It is imperative that we should be consulted over any particular use or application of our products and it is the responsibility of the buyer to establish, particularly through all the appropriate tests, that the product is suitable for the use or application. Under no circumstances will our warranty apply, nor shall we be held responsible for any application (such as any modification, addition, deletion, use in conjunction with other electrical or electronic components, circuits or assemblies, or any other unsuitable material or substance) which has not been expressly agreed by us prior to the sale of our products. © 2013 Kavlico. All rights reserved. Potsdamer Str. 14, 32423 Minden, Germany Tel: +49 571 3859-0 - Fax: +49 571 3859-119 Email: info@kavlico.de www.kavlico.com 235 E. Main St., Suite 102A, Northville, MI 48167, USA Tel: +1 (248) 465-0815 - Fax: +1 (248) 465-0810 Email: pressure.sensors@kavlico.com
P158-300A-C2C 价格&库存
很抱歉,暂时无法提供与“P158-300A-C2C”相匹配的价格&库存,您可以联系我们找货
