Freescale Semiconductor
Data Sheet
Document Number: SCF5249EC
Rev. 0, 04/2005
SCF5249 Integrated ColdFire®
Microprocessor Data Sheet
1
Introduction
This document provides an overview of the SCF5249
ColdFire® processor and general descriptions of
SCF5249 features and its various modules.
The SCF5249 was designed as a system
controller/decoder for MP3 music players, especially
portable MP3 CD players. The 32-bit ColdFire core with
Enhanced Multiply Accumulate (EMAC) unit provides
optimum performance and code density for the
combination of control code and signal processing
required for MP3 decode, file management, and system
control.
Low power features include a hardwired CD ROM
decoder, advanced 0.18um CMOS process technology,
1.8V core power supply, and on-chip 96KByte SRAM.
MP3 decode requires less than 20MHz CPU bandwidth
and runs in on-chip SRAM with external access only for
data input and output.
The SCF5249 is also an excellent general purpose
system controller with over 125 Dhrystone 2.1 MIPS @
140MHz performance at a very competitive price. The
© Freescale Semiconductor, Inc., 2004. All rights reserved.
Table of Contents
1
2
3
4
5
6
7
8
9
10
Introduction..........................................................1
SCF5249 Block Diagram .....................................3
SCF5249 Feature Details ....................................3
160 MAPBGA Ball Assignments .........................6
SCF5249 Functional Overview............................7
General Device Information...............................12
Documentation ..................................................12
Signal Descriptions............................................13
Electrical Characteristics ...................................28
Pin-Out and Package Information .....................46
Introduction
integrated peripherals and EMAC allow the SCF5249 to replace both the microcontroller and the DSP in
certain applications. Most peripheral pins can also be remapped as General Purpose I/O pins.
1.1
Orderable Parts Numbers
1.1.1
Orderable Part Table
Table 1. Orderable Part Numbers
Orderable Part
Number
Maximum Clock
Frequency
Package Type
Operating
Temperature Range
Part Status
SCF5249LPV120
120 MHz
144 pin QFP
-20°C to 70°C
Leaded
SCF5249LAG120
120 MHz
144 pin QFP
-20°C to 70°C
Lead Free
SCF5249VF140
140 MHz
160 ball MAPBGA
-20°C to 70°C
Leaded
SCF5249VM140
140 MHz
160 ball MAPBGA
-20°C to 70°C
Lead Free
1.2
SCF5249 Features
The SCF5249 integrated microprocessor combines a Version 2 ColdFire® processor core operating at
140MHz with the following modules.
• DMA controller with 4 DMA channels
• Integrated Enhanced Multiply-accumulate Unit (EMAC)
• 8-KByte Direct Mapped Instruction Cache
• 96-KByte SRAM (A 64K and a 32K bank)
• Operates from external crystal oscillator
• Supports 16-bit wide SDRAM memories
• Serial Audio Interface which supports IIS and EIAJ audio protocols
• Digital audio transmitter and two receivers compliant with IEC958 audio protocol
• CD-ROM and CD-ROM XA block decoding and encoding function
• Two UARTS
• Queued Serial Peripheral Interface (QSPI) (Master Only)
• Two timers
• IDE and SmartMedia interfaces
• Analog/Digital Converter
• Flash Memory Card Interface
• Two I2C modules
System debug support
General Purpose I/O pins shared with other functions
SCF5249 Integrated ColdFire® Microprocessor Data Sheet, Rev. 3
2
2
1.8V core, 3.3V I/O
160 pin MAPBGA package (qualified at 140 MHz) and 144 pin QFP package (qualified at 120
MHz)
-200 C to 700 C ambient operating temperature range
CD ROM
Block
Decoder
Encoder
CD Text
Interface
QSPI
8K
byte
I-Cache
ColdFire V2
I Addr Gen
I Fetch
96K
Byte
SRAM
Instr Buf
Dec&Sel Op
A Gen & Ex
B
u
s
Serial Audio
Interface
3 x I2S Rx
2 x I2S Tx
C
o
n
t
r
o
l
SPDIF/EBU
Transmitter
12-bit ADC
IDE
Interface
Flash
Media
Interface
DUART
EMAC
Timers
Debug
Module
DMA
M-bus
(I2C)
SDRAM
Cntr
& Chip
Selects
General
Purpose
I/O
SPDIF/EBU
Receiver
PLL
Frequency
Synthesizer
Figure 1. SCF5249 Block Diagram
3
The primary features of the SCF5249 integrated processor include the following:
• ColdFire V2 Processor Core operating at 140MHz
— Clock-doubled Version 2 microprocessor core
— 32-bit internal data bus, 16 bit external data bus
— 16 user-visible, 32-bit general-purpose registers
— Supervisor/user modes for system protection
— Vector base register to relocate exception-vector table
— Optimized for high-level language constructs
3
DMA controller
— Four fully programmable channels: Two dedicated to the audio interface module and two
dedicated to the UART module (External requests are not supported.)
— Supports dual- and single-address transfers with 32-bit data capability
— Two address pointers that can increment or remain constant
16-/24-bit transfer counter
Operand packing and unpacking support
Auto-alignment transfers supported for efficient block movement
Supports bursting and cycle stealing
All channels support memory to memory transfers
Interrupt capability
Provides two clock cycle internal access
Enhanced Multiply-accumulator Unit
— Single-cycle multiply-accumulate operations for 32 x 32 bit and 16 x 16 bit operands
— Support for signed, unsigned, integer, and fixed-point fractional input operands
— Four 48-bit accumulators to allow the use of a 40-bit product
— The addition of 8 extension bits to increase the dynamic number range
— Fast signed and unsigned integer multiplies
8-KByte Direct Mapped instruction cache
— Clock-doubled to match microprocessor core speed
— Flush capability
— Non-blocking cache provides fast access to critical code and data
96-KByte SRAM
— Provides one-cycle access to critical code and data
— Split into two banks, SRAM0 (32K), and SRAM1 (64K)
— DMA requests to/from internal SRAM1 supported
Crystal Trim
— The XTRIM output can be used to trim an external crystal oscillator circuit which would
allow lock with an incoming IEC958 or serial audio signal
Audio Interfaces
— IEC958 input and output
— Four serial Philips IIS/Sony EIAJ interfaces
– One with input and output, one with output only, two with input only (Three inputs, two
outputs)
– Master and Slave operation
4
CD Text Interface
— Allows the interface of CD subcode (transmitter only)
Dual Universal Synchronous/asynchronous Receiver/Transmitter (Dual UART)
— Full duplex operation
— Baud-rate generator
— Modem control signals: clear-to-send (CTS) and request-to-send (RTS)
— DMA interrupt capability
— Processor-interrupt capability
— Programmable queue to support up to 16 transfers without user intervention
— Supports transfer sizes of 8 to 16 bits in 1-bit increments
— Four peripheral chip-select lines for control of up to 15 devices
— Baud rates from 273 Kbps to 17.5 Mbps at 140MHz
— Programmable delays before and after transfers
— Programmable clock phase and polarity
— Supports wraparound mode for continuous transfers
— Master mode only
Dual 16-bit General-purpose Multimode Timers
— Clock source selectable from external, CPU clock/2 and CPU clock/32.
— 8-bit programmable prescaler
— 2 timer inputs and 2 outputs
— 14.3 nS resolution with CPU clock at 140MHz
IDE/ SmartMedia Interface
— Allows direct connection to an IDE hard drive or other IDE peripheral
— 12-Bit Resolution
— 4 Muxed inputs
— Allows connection to Sony MemoryStick compatible devices
— Support SD cards and other types of flash media
Dual I2C Interfaces
— Interchip bus interface for EEPROMs, LCD controllers, A/D converters, keypads
— Master and slave modes, support for multiple masters
— Automatic interrupt generation with programmable level
5
4
— Real-time instruction trace for determining dynamic execution path
— Background debug mode (BDM) for debug features while halted
— Debug exception processing capability
— Real-time debug support
System Interface
— Glueless bus interface with four chip selects and DRAMC support for interface to
16-bit for DRAM, SRAM, ROM, FLASH, and I/O devices
– Two programmable chip-select signals for static memories or peripherals, with
programmable wait states and port sizes.
– Two dedicated chip selects for 16-bit wide DRAM /SDRAM.
– CS0 is active after reset to provide boot-up from external FLASH/ROM.
— Programmable interrupt controller
– Low interrupt latency
– Eight external interrupt requests
– Programmable autovector generator
— 44 programmable general-purpose inputs*
— 46 programmable general-purpose outputs*
– * For the 160 MAPBGA package
— IEEE 1149.1 Test (JTAG) Module
Clocking
— Clock-multiplied PLL, programmable frequency
1.8V Core, 3.3V I/O
MHz)
The following signals are not available on the 144 QFP package.
NOTE
The 144 QFP part is qualified for 120 MHz operation. The 160MAPBGA
part is qualified for 140 MHz.
6
Table 2. 160 MAPBGA Ball Assignments
160 MAPBGA
Ball Number
Function
GPIO
E3
cmd_sdio2
gpio34
G4
sdata0_sdio1
gpio54
H3
RSTO/sdata2_bs2
K3
A25
gpo8
L4
QSPI_CS1
gpio24
L8
QSPI_CS3
gpio22
N8
SDRAM_CS2
gpio7
P9
EbuOut2
gpo 37
K11
BUFENb2
gpio17
G12
subr
gpio 53
F13
sfsy
gpio 52
F12
rck
gpio 51
E8
SRE
gpio11
B8
lrck3
gpio 45
E7
SWE
gpio12
A7
sclk3
gpio 49
5
5.1
ColdFire V2 Core
The ColdFire processor Version 2 core consists of two independent, decoupled pipeline structures to
maximize performance while minimizing core size.The instruction fetch pipeline (IFP) is a two-stage
pipeline for prefetching instructions. The prefetched instruction stream is then gated into the two-stage
operand execution pipeline (OEP), which decodes the instruction, fetches the required operands, and then
executes the required function. Because the IFP and OEP pipelines are decoupled by an instruction buffer
that serves as a FIFO queue, the IFP can prefetch instructions in advance of their actual use by the OEP,
which minimizes time stalled waiting for instructions. The OEP is implemented in a two-stage pipeline
featuring a traditional RISC data path with a dual-read-ported register file feeding an arithmetic/logic unit
(ALU).
5.2
DMA Controller
The SCF5249 provides four fully programmable DMA channels for quick data transfer. Single and dual
address mode is supported with the ability to program bursting and cycle stealing. Data transfer is
selectable as 8, 16, 32, or 128-bits. Packing and unpacking is supported.
7
Two internal audio channels and the dual UART can be used with the DMA channels. All channels can
perform memory to memory transfers. The DMA controller has a user-selectable, 24- or 16-bit counter and
a programmable DMA exception handler.
5.3
Enhanced Multiply and Accumulate Module (EMAC)
The integrated EMAC unit provides a common set of DSP operations and enhances the integer multiply
instructions in the ColdFire architecture. The EMAC provides functionality in three related areas:
1. Faster signed and unsigned integer multiplies
2. New multiply-accumulate operations supporting signed and unsigned operands
3. New miscellaneous register operations
Multiplies of 16x16 and 32x32 with 48-bit accumulates are supported in addition to a full set of extensions
for signed and unsigned integers plus signed, fixed-point fractional input operands. The EMAC has a
single-clock issue for 32x32-bit multiplication instructions and implements a four-stage execution
pipeline.
5.4
Instruction Cache
The instruction cache improves system performance by providing cached instructions to the execution unit
in a single clock. The SCF5249 processor uses a 8K-byte, direct-mapped instruction cache to achieve 125
MIPS at 140 Mhz. The cache is accessed by physical addresses, where each 16-byte line consists of an
address tag and a valid bit. The instruction cache also includes a bursting interface for 16-bit and 8-bit port
sizes to quickly fill cache lines.
5.5
Internal 96-KByte SRAM
The 96-KByte on-chip SRAM is split over two banks, SRAM0 (32k) and SRAM1 (64K). It provides one
clock-cycle access for the ColdFire core. This SRAM can store processor stack and critical code or data
segments to maximize performance. Memory in the second bank can be accessed under DMA.
5.6
DRAM Controller
The SCF5249 DRAM controller provides a glueless interface for up to two banks of DRAM, each of which
can be up to 32 MBytes. The controller supports a 16-bit data bus. A unique addressing scheme allows for
increases in system memory size without rerouting address lines and rewiring boards. The controller
operates in page mode, non-page mode, and burst-page mode and supports SDRAMS.
5.7
System Interface
The SCF5249 provides a glueless interface to 16-bit port size SRAM, ROM, and peripheral devices with
independent programmable control of the assertion and negation of chip-select and write-enable signals.
The SCF5249 also supports bursting ROMs.
8
5.8
External Bus Interface
The bus interface controller transfers information between the ColdFire core or DMA and memory,
peripherals, or other devices on the external bus. The external bus interface provides 23 bits of address bus
space, a 16-bit data bus, Output Enable, and Read/Write signals. This interface implements an extended
synchronous protocol that supports bursting operations.
5.9
Serial Audio Interfaces
The SCF5249 digital audio interface provides four serial Philips IIS/Sony EIAJ interfaces. One interface
is a 4-pin (1 bit clock, 1 word clock, 1 data in, 1 data out), the other three interfaces are 3-pin (1 bit clock,
1 word clock, 1 data in or out). The serial interfaces have no limit on minimum sampling frequency.
Maximum sampling frequency is determined by maximum frequency on bit clock input. This is 1/3 the
frequency of the internal system clock.
5.10 IEC958 Digital Audio Interfaces
The SCF5249 has two digital audio input interfaces, and one digital audio output interface. There are four
digital audio input pins, two digital audio output pins. An internal multiplexer selects one of the four inputs
to the digital audio input interface. There is one digital audio output interface but it has two IEC958
outputs. One output carries the professional “c” channel, and the other carries the consumer “c” channel.
The rest carry identical data.
The IEC958 output can take the output from the internal IEC958 generator, or multiplex out one of the
four IEC958 inputs.
5.11 Audio Bus
The audio interfaces connect to an internal bus that carries all audio data. Each receiver places its received
data on the audio bus and each transmitter takes data from the audio bus for transmission. Each transmitter
has a source select register.
In addition to the audio interfaces, there are six CPU accessible registers connected to the audio bus. Three
of these registers allow data reads from the audio bus and allow selection of the audio source. The other
three register provide a write path to the audio bus and can be selected by transmitters as the audio source.
Through these registers, the CPU has access to the audio samples for processing.
Audio can be routed from a receiver to a transmitter without the data being processed by the core so the
audio bus can be used as a digital audio data switch. The audio bus can also be used for audio format
conversion.
5.12 CD-ROM Encoder/Decoder
The SCF5249 is capable of processing CD-ROM sectors in hardware. Processing is compliant with
CD-ROM and CD-ROM XA standards.
9
The CD-ROM decoder performs following functions in hardware:
• Sector sync recognition
• Descrambling of sectors
• Verification of the CRC checksum for Mode 1, Mode 2 Form 1, and Mode 2 Form 2 sectors
• Third-layer error correction is not performed
The CD-ROM encoder performs following functions in hardware:
• Scrambling of sectors
• Insertion of the CRC checksum for Mode 1, Mode 2 Form 1, and Mode 2 Form 2 sectors.
• Third-layer error encoding needs to be done in software. This can use approximately 5-10 Mhz of
performance for single-speed.
5.13 Dual UART Module
Two full-duplex UARTs with independent receive and transmit buffers are in this module. Data formats
can be 5, 6, 7, or 8 bits with even, odd, or no parity, and up to 2 stop bits in 1/16 increments. Four-byte
receive buffers and two-byte transmit buffers minimize CPU service calls. The Dual UART module also
provides several error-detection and maskable-interrupt capabilities. Modem support includes
request-to-send (RTS) and clear-to-send (CTS) lines.
The system clock provides the clocking function from a programmable prescaler. You can select full
duplex, auto-echo loopback, local loopback, and remote loopback modes. The programmable Dual UARTs
can interrupt the CPU on various normal or error-condition events.
5.14 Queued Serial Peripheral Interface QSPI
The QSPI module provides a serial peripheral interface with queued transfer capability. It supports up to
16 stacked transfers at a time, making CPU intervention between transfers unnecessary. Transfers of up to
37 Mbits/second are possible at a CPU clock of 140 MHz. The QSPI supports master mode operation only.
5.15 Timer Module
The timer module includes two general-purpose timers, each of which contains a free-running 16-bit timer
for use in any of three modes:
1. Timer Capture. This mode captures the timer value with an external event.
2. Output Capture. This mode triggers an external signal or interrupts the CPU when the timer
reaches a set value
3. Event Counter. This mode counts external events.
The timer unit has an 8-bit prescaler that allows programming of the clock input frequency, which is
derived from the system clock. In addition to the ÷1 and ÷16 clock derived from the bus clock
(CPU clock / 2), the programmable timer-output pins either generate an active-low pulse or toggle the
outputs.
10
5.16 IDE and SmartMedia Interfaces
The SCF5249 system bus allows connection of an IDE hard disk drive and SmartMedia flash card with a
minimum of external hardware. The external hardware consists of bus buffers for address and data and are
intended to reduce the load on the bus and prevent SDRAM and Flash accesses to propagate to the IDE
bus. The control signals for the buffers are generated in the SCF5249.
5.17 Analog/Digital Converter (ADC)
The four channel ADC is a based on the Sigma-Delta concept with 12-bit resolution. The digital portion
of the ADC is provided internally. The analog voltage comparator must be provided externally as well as
an external integrator circuit (resistor/capacitor) which is driven by the ADC output. A software interrupt
is provided when the ADC measurement cycle is complete.
5.18 Flash Memory Card Interface
The interface is Sony MemoryStick and SecureDigital compatible. However, there is no hardware support
for MagicGate.
5.19 I2C Module
The two-wire I2C bus interface, which is compliant with the Philips I2C bus standard, is a bidirectional
serial bus that exchanges data between devices. The I2C bus minimizes the interconnection between
devices in the end system and is best suited for applications that need occasional bursts of rapid
communication over short distances among several devices. Bus capacitance and the number of unique
addresses limit the maximum communication length and the number of devices that can be connected.
5.20 Chip-Selects
Two programmable chip-select outputs provide signals that enable glueless connection to external memory
and peripheral circuits. The base address, access permissions and automatic wait-state insertion are
programmable with configuration registers. These signals also interface to 16-bit ports.
5.21 GPIO Interface
A total of 44 General Purpose inputs and 46 General Purpose outputs are available. These are multiplexed
with various other signals. Eight of the GPIO inputs have edge sensitive interrupt capability.
5.22 Interrupt Controller
The interrupt controller provides user-programmable control of a total of 57 interrupts. There are 49
internal interrupt sources. In addition, there are 8 GPIOs where interrupts can be generated on the rising
or falling edge of the pin. All interrupts are autovectored and interrupt levels are programmable.
11
5.23 JTAG
To help with system diagnostics and manufacturing testing, the SCF5249 includes dedicated
user-accessible test logic that complies with the IEEE 1149.1A standard for boundary scan testability,
often referred to as Joint Test Action Group, or JTAG. For more information, refer to the IEEE 1149.1A
standard. Freescale provides BSDL files for JTAG testing.
5.24 System Debug Interface
The ColdFire processor core debug interface supports real-time instruction trace and debug, plus
background-debug mode. A background-debug mode (BDM) interface provides system debug.
In real-time instruction trace, four status lines provide information on processor activity in real time (PST
pins). A four-bit wide debug data bus (DDATA) displays operand data and change-of-flow addresses,
which helps track the machine’s dynamic execution path.
5.25 Crystal and On-chip PLL
Typically, an external 16.92 Mhz or 33.86 Mhz clock input is used for CD R/W applications, while an
11.2896 MHz clock is more practical for Portable CD player applications. However, the on-chip
programmable PLL, which generates the processor clock, allows the use of almost any low frequency
external clock (5-35 Mhz).
Two clock outputs (MCLK1 and MCLK2) are provided for use as Audio Master Clock. The output
frequencies of both outputs are programmable to Fxtal, Fxtal/2, Fxtal/3, and Fxtal/4. The Fxtal/3 option is
only available when the 33.86 Mhz crystal is connected.
The SCF5249 supports VCO operation of the oscillator by means of a 16-bit pulse density modulation
output. Using this mode, it is possible to lock the oscillator to the frequency of an incoming IEC958 or IIS
signal. The maximum trim depends on the type and design of the oscillator. Typically a trim of +/- 100
ppm can be achieved with a crystal oscillator and over +/- 1000 ppm with an LC oscillator.
6
The SCF5249 is available in a 160-pin MAP BGA package, or a 144-pin QFP package.
7
Documentation
Table 3 lists the documents that provide a complete description of the SCF5249 and are required to design
properly with the part. Documentation is available from a local Freescale distributor, a Freescale
semiconductor sales office, a Freescale Literature Distribution Center, or through the Freescale DSP home
page on the internet; http://www.freescale.com/
(the source for the latest information).
12
Signal Descriptions
Table 3. SCF5249 Documentation
Document Name
Description
Order Number
CFPRM/D
ColdFire Family Programmer’s Reference Manual
CFPRM/D
ColdFire2UM
Version 2/2M ColdFire Core
Processor User’s Manual
ColdFire2UM/D
ColdFire2UMAD
Processor User’s Manual Addendum
ColdFire2UMAD/D
SCF5249UM
SCF5249 User’s Manual
SCF5249UM/D
8
Signal Descriptions
8.1
Introduction
This section describes the SCF5249 input and output signals. The signal descriptions as shown in Table 4
are grouped according to relevant functionality.
Table 4. SCF5249 Signal Index
Signal Name
Mnemonic
Function
Input/
Output
Reset
State
Address
A[23:1]
A[25]/GPO8
23 address lines, address line 25
multiplexed with gpo8.
Out
X
Read-write control
RW_b
Bus write enable - indicates if read or
write cycle in progress
Out
H
Output enable
OE
Output enable for asynchronous
memories connected to chip selects
Out
negated
Data
D[31:16]
Data bus used to transfer word data
In/Out
Hi-Z
Synchronous row address SDRAS
strobe
Row address strobe for external
SDRAM.
Out
negated
Synchronous column
address strobe
SDCAS
Column address strobe for external
SDRAM
Out
negated
SDRAM write enable
SDWE
Write enable for external SDRAM
Out
negated
SDRAM upper byte
enable
SDUDQM
Indicates during write cycle if high
byte is written
Out
SDRAM lower byte enable SDLDQM
Indicates during write cycle if low byte
is written
Out
SDRAM chip selects
SDRAMCS1
SDRAM chip select
Outt
negated
SDRAM chip selects
SDRAMCS2/GPIO7
SDRAM chip select
In/Out
negated
SDRAM clock enable
BCLKE
SDRAM clock enable
Out
System clock
SCLK/GPIO10
SDRAM clock output
In/Out
13
Signal Descriptions
Table 4. SCF5249 Signal Index (continued)
Signal Name
Mnemonic
Input/
Output
Function
There are 2 ISA bus read strobes and
2 ISA bus write strobes. They allow
connection of two independent ISA
bus peripherals, e.g. an IDE slave
device and a SmartMedia card.
In/Out
IDE-IORDY/GPIO16
ISA bus wait line - available for both
busses
In/Out
Chip Selects[1:0]
CS0
CS1/GPIO58
Enables peripherals at programmed
addresses.
CS[1:0]. CS[0]provides boot ROM
selection
Out
In/Out
Buffer enable 1
BUFENB1/GPIO57
In/Out
Buffer enable 2
BUFENB2/GPIO7
Two programmable buffer enables
allow seamless steering of external
buffers to split data and address bus
in sections.
Transfer acknowledge
TA/GPIO20
Transfer Acknowledge signal
In/Out
CS2/IDE-DIOR/GPIO13
CS3/SRE/GPIO11
IDE-DIOW/GPIO14
SWE/GPIO12
ISA bus wait signal
2
Reset
State
In/Out
negated
In/Out
Serial Clock Line
SCL0/QSPI_CLK
Clock signal for first I C module
operation
Signal is also QSPI clock
In/Out
Serial Data Line
SDA0/QSPI_DIN
Serial data port first I2C module
operation
Signal is also QSPI data in
In/Out
Serial Clock Line
SCL1_GPIO_3
Clock signal for second I2C module
operation
In/Out
Serial Data Line
SDA1_GPIO55
Serial data port for second I2C
module operation
In/Out
Receive Data
RXD1/GPI28/ADIN2
RXD0/GPI27
Signal is receive serial data input for
DUART
In
Transmit Data
TXD1/GPO28
TXD0/GPO27
Signal is transmit serial data output
for DUART
Out
asserted
Request-To-Send
RTS1/GPO31
RTS2/GPO30
DUART signals a ready to receive
data query
Out
negated
Clear-To-Send
CTS1/ADIN3/GPI31
CTS0/GPI30
Signals to DUART that data can be
transmitted to peripheral
CTS2 is multiplexed with an A/D
input
In
Timer Input
TIN0/GPI33
TIN1/GPIO23
Provides clock input to timer or
provides trigger to timer value
capture logic
Timer Output
TOUT0/GPO33
TOUT1/ADOUT/GPO35
Capable of output waveform or pulse
generation
In
In/Out
Out
14
Signal Descriptions
Signal Name
Mnemonic
Function
Input/
Output
IEC958 inputs
EBUIN1/GPI36
EBUIN2/GPI37
EBUIN3/ADIN0/GPI38
EBUIN4/ADIN1/GPI39
Audio interfaces IEC958 inputs
multiplexed with some A/D inputs
In
IEC958 outputs
EBUOUT1/GPO36
EBUOUT2/GPO37
Audio interfaces IEC958 outputs
Out
Serial data in
SDATAI1
SDATAI3/GPI41
SDATA14/GPI42
Audio interfaces serial data inputs
Serial data out
SDATAO1/GPIO25
SDATAO2/GPO41
Audio interfaces serial data outputs
In/Out
Out
Word clock
LRCK1
LRCK2/GPIO44
LRCK3/GPIO45
LRCK4/GPIO46
Audio interfaces serial word clocks
In/Out
Bit clock
SCLK1
SCLK2/GPIO48
SCLK3/GPIO49
SCLK4/GPIO50
Audio interfaces serial bit clocks
In/Out
Serial input
EF/GPIO19
Error flag serial in
In/Out
Serial input
CFLG/GPIO18
C-flag serial in
In/Out
Subcode clock
RCK/GPIO51
Audio interfaces subcode clock
In/Out
Subcode sync
SFSY/GPIO52
Aaudio interfaces subcode sync
In/Out
Subcode data
SUBR/GPIO53
Audio interfaces subcode data
In/Out
Clock frequency trim
XTRIM/GPO38
Clock trim control
Out
Audio clocks out
MCLK1/GPIO39
MCLK2/GPIO42
DAC output clocks
Out
MemoryStick/SecureDigit CMDSDIO2/GPIO34
al interface
Reset
State
In
Secure Digital command lane
MemoryStick interface 2 data i/o
In/Out
SCLKOUT/GPIO15
Clock out for both MemoryStick
interfaces and for Secure Digital
In/Out
SDATA0_SDIO1/GPIO54
SecureDigital serial data bit 0
MemoryStick interface 1 data i/o
In/Out
SDATA1_BS1/GPIO9
SecureDigital serial data bit 1
MemoryStick interface 1 strobe
In/Out
RSTO/SDATA2_BS2
SecureDigital serial data bit 2
MemoryStick interface 2 strobe
Reset output signal
In/Out
SDATA3/GPIO56
SecureDigital serial data bit 3
In/Out
15
Signal Descriptions
Signal Name
Mnemonic
Input/
Output
Function
Reset
State
ADC
EBUIN3/ADIN0/GPI38
EBUIN4/ADIN1/GPI39
RXD2/ADIN2/GPI28
CTS2/ADIN3/GPI31
Analog to Digital converter input
signals
In/Out
ADC
TOUT1/ADOUT/GPO35
Analog to digital convertor output
signal.
In/Out
QSPI clock
SCL/QSPI_CLK
QSPI clock signal
In/Out
QSPI data in
SDA/QSPI_DIN
QSPI data input
In/Out
QSPI data out
QSPIDOUT/GPIO26
QSPI data out
In/Out
QSPI chip selects
QSPICS0/GPIO29
QSPICS1/GPIO24
QSPICS2/GPIO21
QSPICS3/GPIO22
QSPI chip selects
In/Out
Crystal in
CRIN
Crystal input
In
Reset In
RSTI
Processor Reset Input
In
Freescale Test Mode
TEST[3:0]
Should always be low.
In
High Impedance
HIZ
Assertion three-states all output
signal pins.
In
Debug Data
DDATA3/GPIO4
DDATA2/GPIO2
DDATA1/GPIO1
DDATA0/GPIO0
Displays captured processor data
and break-point status.
In/Out
Hi-Z
Processor Status
PST3/GPIO62
PST2/GPIO61
PST1/GPIO60
PST0/GPIO59
Indicates internal processor status.
In/Out
Hi-Z
Processor clock
PSTCLK/GPO63
Processor clock output
Test Clock
TCK
Clock signal for IEEE 1149.1A JTAG.
In
Test Reset/Development
Serial Clock
TRST/DSCLK
Multiplexed signal that is
asynchronous reset for JTAG
controller. Clock input for debug
module.
In
Test Mode Select/ Break
Point
TMS/BKPT
Multiplexed signal that is test mode
select in JTAG mode and a hardware
break-point in debug mode.
In
Test Data Input /
TDI/DSI
Development Serial Input
Multiplexed serial input for the JTAG
or background debug module.
In
Test Data
Output/Development
Serial Output
Multiplexed serial output for the JTAG
Out
TDO/DSO
Out
Note: The CMD_SDIO2, SDATA0_SDIO1, RSTO/SDATA2_BS2, A25, QSPI_CS1, QSPI_CS3, SDRAM_CS2, EBUOUT2,
BUFENB2, SUBR, SFSY, RCK, SRE, LRCK3, SWE, and the SCLK3 signals are only used in the 160 MAPBGA package.
16
Signal Descriptions
8.2
GPIO
Many pins have a GPIO as first or second function. If GPIO is second function, following rules apply:
• General purpose input is always active, regardless of state of pin.
• General purpose output or primary output is determined by value written to GPIO function select
register.
• Power-on reset function is not GPIO.
8.3
SCF5249 Bus Signals
These signals provide the external bus interface to the SCF5249.
8.3.1
8.3.2
Address Bus
The address bus provides the address of the byte or most significant byte of the word or longword
being transferred.The address lines also serve as the DRAM address pins, providing multiplexed
row and column address signals.
Bits 23 down to 1 and 25 of the address are available. A25 is intended to be used with 256 Mbit
DRAM’s. Signals are named:
A[23:1]
A[25]/GPO8
Read-Write Control
This signal indicates during any bus cycle whether a read or write is in progress. A low is write cycle and
a high is a read cycle.
8.3.3
Output Enable
The OE signal is intended to be connected to the output enable of asynchronous memories connected to
chip selects. During bus read cycles, the ColdFire processor will drive OE low.
8.3.4
Data Bus
The data bus (D[31:16]) is bi-directional and non-multiplexed. Data is registered by the SCF5249 on the
rising clock edge. The port width for each chip-select and DRAM bank are programmable. The data bus
uses a default configuration if none of the chip-selects or DRAM bank match the address decode. All 16
bits of the data bus are driven during writes, regardless of port width or operand size.
8.3.5
The TA/GPIO20 pin is the transfer acknowledge signal.
17
Signal Descriptions
8.4
SDRAM Controller Signals
The following SDRAM signals provide a seamless interface to external SDRAM. An SDRAM width of
16 bits is supported and can access as much as 64 Mybtes of memory. ADRAMs are not supported.
Table 5. SDRAM Controller Signals
SDRAM Signal
Description
Synchronous DRAM row address strobe
The SDRAS active low pin provides a seamless interface to the RAS
input on synchronous DRAM
Synchronous DRAM Column Address
Strobe
The SDCAS active low pin provides a seamless interface to CAS input
on synchronous DRAM.
Synchronous DRAM Write
Synchronous DRAM Chip Enable
Synchronous DRAM UDQM and LQDM
signals
Synchronous DRAM clock
Synchronous DRAM Clock Enable
The SDWE active-low pin is asserted to signify that a SDRAM write
cycle is underway. This pin outputs logic ‘1’ during read bus cycles.
The SD_CS1 and The SDRAM_CS2/GPIO7 active-low output signal is
used during synchronous mode to route directly to the chip select of up
to two SDRAM devices.
The SDRAM_CS2/gpio7 can be programmed to be gpio using
the GPIO-FUNCTION register.
The DRAM byte enables UDMQ and LDQM are driven by the
SDUDQM and SDLDQM byte enable outputs.
The DRAM clock is driven by the SCLK signal
The BCLKE active high output signal is used during synchronous
mode to route directly to the SCKE signal of external SDRAMs. This
signal provides the clock enable to the SDRAM.
NOTE
The SDRAM_CS2 signal is only used on the 160 MAPBGA package.
8.5
Chip Selects
There are two chip select outputs on the SCF5249 device. CS0 and CS1/GPIO58. The second signal is
multiplexed with a GPIO signal. The active low chip selects can be used to access asynchronous memories.
The interface is glueless.
8.6
ISA Bus
The SCF5249 supports an ISA bus. (No ISA DMA channel). Using the ISA bus protocol, reads and writes
to up to two ISA bus peripherals are possible. For the first peripheral, CS2/IDE-DIOR/GPIO13 and
IDE-DIOW/GPIO14 are the read and write strobe. For the second peripheral, CS3/SRE/GPIO11 and
SWE/GPIO12 are the read and write strobe. Either peripheral can insert wait states by pulling
IDE-IORDY/GPIO16
18
Signal Descriptions
8.7
Bus Buffer Signals
As the SCF5249 has a quite complicated slave bus, with the possibility to put DRAM on the bus, put
asynchronous memories on the bus, and to put ISA bus peripherals on the bus, it may become necessary
to introduce a bus buffer on the bus. The SCF5249 has a glueless interface to steer these bus buffers with
2 bus buffer output signals BUFENB1/GPIO57 and BUFENB2/GPIO7.
NOTE
The BUFENB2 signal is only used in the 160 MAPBGA package.
8.8
I2C Module Signals
There are two I2C interfaces on this device.
The I2C module acts as a quick two-wire, bidirectional serial interface between the SCF5249 processor
and peripherals with an I2C interface (e.g., LED controller, A-to-D converter, D-to-A converter). When
devices connected to the I2C bus drive the bus, they will either drive logic-0 or high-impedance. This can
be accomplished with an open-drain output.
Table 6. I2C Module Signals
I2c Module Signal
I2C Serial Clock
Description
The SCL/QPSICLK and SCL2/GPIO3 bidirectional signals are
the clock signal for first and second I2C module operation. The
I2C module controls this signal when the bus is in master
mode; all I2C devices drive this signal to synchronize I2C
timing.
Signals are multiplexed
Function select is done via PLLCR register.
I2C Serial Data
8.9
The SDA/QSPI_DIN and SDA2/GPIO55 bidirectional signals
are the data input/output for the first and second serial I2C
interface.
Serial Module Signals
The following signals transfer serial data between the two UART modules and external peripherals.
All serial module signals can be used as gpi or gpo. The GPIO-FUNCTION and GPIO1-FUNCTION
registers must be programmed to determine pin functions of the inputs and outputs. If used as gpo or gpi,
UART functionality is lost.
19
Signal Descriptions
Table 7. Serial Module Signals
Description
Receive Data
The RXD1_GPI27 and RXD2/ADIN2/GPI28 are the inputs on which
serial data is received by the DUART. Data is sampled on RxD[1:0] on
the rising edge of the serial clock source, with the least significant bit
received first.
Transmit Data
The DUART transmits serial data on the TXD1/GPO27 and
TXD2/GPO28 output signals. Data is transmitted on the falling
transmitted (LSB) first. When no data is being transmitted or
the transmitter is disabled, these two signals are held high.
TxD[1:0] are also held high in local loopback mode.
Request To Send
The RTS1/GPO30 and RTS2/GPO31 request-to-send outputs
indicate to the peripheral device that the DUART is ready to
send data and requires a clear-to-send signal to initiate
transfer.
Clear To Send
Peripherals drive the CTS1/GPI30 and CTS2/ADIN3/GPI31
inputs to indicate to the SCF5249 serial module that it can
begin data transmission.
8.10 Timer Module Signals
The following signals are external interface to the two general-purpose SCF5249 timers. These 16-bit
timers can capture timer values, trigger external events, or internal interrupts, or count external events.
These pins can be reused as GPO or GPI. Registers GPIO-FUNCTION and GPIO1-FUNCTION must be
programmed for this.
Table 8. Timer Module Signals
Timer Input
Timer Output
Description
Users can program the TIN0/GPI33 and TIN1/GPIO23 inputs
as clocks that cause events in the counter and prescalars.
They can also cause capture on the rising edge, falling edge,
or both edges.
The TOUT0/GPO33 and TOUT1/ADOUT/GPO35
programmable outputs pulse or toggle on various timer events.
8.11 Serial Audio Interface Signals
All serial audio interface signals can be programmed to serve as general purpose I/Os or as serial audio
interface signals. The function is programmed using GPIO-FUNCTION and GPIO1-FUNCTION
registers.
NOTE
The LRCK3 and SCLK3 signals are only used in the 160 MAPBGA
package..
Signal Descriptions
Table 9. Serial Audio Interface Signals
Description
Serial Audio Bit Clock
The SCLK1, SCLK2/GPIO48 and SCLK3/GPIO49, and
SCLK4/GPIO50 multiplexed pins can serve as general purpose I/Os or
serial audio bit clocks. As bit clocks, these bidirectional pins can be
programmed as outputs to drive their associated serial audio (IIS) bit
clocks. Alternately, these pins can be programmed as inputs when the
serial audio bit clocks are driven internally. The functionality is
programmed within the Audio module. During reset, these pins are
configured as input serial audio bit clocks.
Serial Audio Word Clock
The LRCK1, LRCK2/GPIO44, LRCK3/GPIO45, and LRCK/GPIO46
multiplexed pins can serve as general purpose I/Os or serial audio
word clocks. As word clocks, the bidirectional pins can be programmed
as inputs to drive their associated serial audio word clock. Alternately,
these pins can be programmed as outputs when the serial audio word
clocks are derived internally. The functionality is programmed within
the Audio module. During reset, these pins are configured as input
serial audio word clocks.
Serial Audio Data In
The SDATAI1, SDATAI3/GPIO41, and SDATAI4/GPI42 multiplexed pins
can serve as general purpose I/Os or serial audio inputs. As serial
audio inputs the data is sent to interfaces 1and 3 respectively. The
functionality of these pins is programmed with the GPIO-FUNCTION
and GPIO1-FUNCTION registers. During reset, the pins are configured
as serial data inputs.
Serial Audio Data Out
The SDATAO1/GPIO25 AND SDATAO2/GPI41 multiplexed pins can
serve as general purpose I/Os or serial audio outputs. The functionality
of these pins is programmed with registers GPIO-FUNCTION and
GPIO1-FUNCTION. During reset, the pins are configured as serial
data outputs..
Serial audio error flag
The EF/GPIO19 multiplexed pin can serve as general purpose I/Os or
error flag input. As error flag input, this pin will input the error flag
delivered by the CD-DSP. EF/GPIO19 is only relevant for serial
interface interface 1.
Serial audio CFLG
The CFLG/GPIO18 multiplexed pin can serve as general purpose I/O
or CFLG input. As CFLG input, the pin will input the CFLG flag
delivered by the CD-DSP. CFLG/GPIO18 is only relevant for serial
interface 1.
21
Signal Descriptions
8.12 Digital Audio Interface Signals
Table 10. Digital Audio Interface Signals
Description
Digital Audio In
The EBUIN1/GPI36, EBUIN2/GPI37, EBUIN3/ADIN0/GPI38, and
EBUIN4/ADIN1/GPI39 multiplexed signals can serve as general
purpose input or can be driven by various digital audio (IEC958) input
sources. Both functionalities are always active. Input chosen for
IEC958 receiver is programmed within the audio module. Input value
on the 4 pins can always be read from the appropriate gpio register..
Digital Audio Out
The EBUOUT1_GPO36 and EBUOUT2_GPO37 multiplexed pins can
serve as general purpose I/O or as digital audio (IEC958) output.
EBUOUT1 is digital audio out for consumer mode, EBUOUT2 is digital
audio out for professional mode. The functionality of the pins is
programmed with the GPIO-FUNCTION and GPIO1-FUNCTION
register. During reset, the pin is configured as a digital audio output.
NOTE
The EBUOUT2 signal is only used on the 160 MAPBGA package.
8.13 Subcode Interface
There is a 3-line subcode interface on the SCF5249. This 3-line subcode interface allows the device to
format and transmit subcode in EIAJ format to a CD channel encoder device. The three signals are
described in Table 11.
Table 11. Subcode Interface Signal
Signal name
Description
RCK/GPIO51
Subcode clock input. When pin is used as subcode clock, this pin is
driven by the CD channel encoder.
SFSY/GPIO52
Subcode sync output
This signal is driven high if a subcode sync needs to be inserted in the
EFM stream.
SUBR/GPIO53
Subcode data output
This signal is a subcode data out pin.
NOTE
The SUBR, SFSY, and the RCK signals are only used in the 160 MAPBGA
package.
22
Signal Descriptions
8.14 Analog to Digital Converter (ADC)
The single output on the TOUT1/ADOUT/GPO35 pin provides the reference voltage in PDM format
therefore this output requires an external integrator circuit (resistor/capacitor) to convert it to a DC level to
be used by the external comparator circuit. Four external comparators compare the DC level obtained after
filtering TOUT1/ADOUT/GPO35 with the relevant input signals. The outputs of the comparators are fed
to the 4 ADIN inputs on the SCF5249: EBUIN3/ADIN0/GPI38, EBUIN4/ADIN1/GPI39,
RXD2/ADIN2/GPI38 and CTS2/ADIN3/GPI31. Selection of function for pin TOUT1/ADOUT/GPO35 is
done by writing GPIO function select register (determines if function is GPIO or not), and differentiation
between timer and adout functions is done in the ADCONFIG Register.
8.15 Secure Digital/ MemoryStick Card Interface
The device has a versatile flash card interface that supports both SecureDigital and MemoryStick cards.
The interface can either support one SecureDigital or two MemoryStick cards. No mixing of card types is
possible. Table 12 gives the pin descriptions.
Table 12. Flash Memory Card Signals
Flash Memory Signal
SCLKOUT/GPIO15
Description
Clock out for both MemoryStick interfaces and for SecureDigital
CMD_SDIO2/GPIO34
Secure Digital command line
SDATA0_SDIO1/GPIO54
SDATA1_BS1/GPIO9
RSTO/SDATA2_BS2
Reset output signal
Selection between Reset function and SDATA2_BS2 is done by
programming PLLCR register.
SDATA3/GPIO57
NOTE
The SDATA0_SDIO1 and RSTO/SDATA2_BS2 signals are only used in the
160 MAPBGA package.
23
Signal Descriptions
8.16 Queued Serial Peripheral Interface (QSPI)
Table 13. Queued Serial Peripheral Interface (QSPI) Signals
Description
SCL_QSPICLK
Multiplexed signal IIC interface clock or QSPI clock output
SDA_QSPIDIN
Multiplexed signal IIC interface data or QSPI data input.
QSPIDOUT_GPIO26
QSPICS0_GPIO29
QSPI data output
4 different QSPI chip selects
QSPICS1_GPIO24
QSPICS2_GPIO21
QSPICS3_GPIO22
NOTE
The QSPI interface is a high-speed serial interface allowing transmit and
receive of serial data.
8.17 Crystal Trim
The XTRIM_GPIO38 output produces a pulse-density modulated phase/frequency difference signal to be
used after low-pass filtering to control varicap-voltage to control crystal oscillation frequency. This will
lock the crystal to the incoming digital audio signal.
8.18 Clock Out
The MCLK1/GPO39 and /MCLK2/GPO42 can serve as general purpose I/Os or as DAC clock outputs.
When programmed as DAC clock outputs, these signals are directly derived from the crystal.
8.19 Debug and Test Signals
These signals interface with external I/O to provide processor status signals.
8.19.1 Test Mode
The TEST[3:0] inputs are used for various manufacturing and debug tests. For normal mode these inputs
should be always be tied low. Use TEST0 to switch between background debug mode and JTAG mode.
Drive TEST0 high for debug mode.
8.19.2 High Impedance
The assertion of HI_Z will force all output drivers to a high-impedance state. The timing on HI_Z is
independent of the clock.
24
Signal Descriptions
NOTE
JTAG operation will override the HI_Z pin.
8.19.3 Processor Clock Output
The internal PLL generates this PSTCLK/GPO63 and output signal, and is the processor clock output that
is used as the timing reference for the Debug bus timing (DDATA[3:0] and PST[3:0]). The
PSTCLK/GPO63 is at the same frequency as the core processor and cache memory. The frequency will be
twice the bus clock (SCLK) frequency.
8.19.4 Debug Data
The debug data pins, DDATA0_GPIO0, DDATA1_GPIO1, DDATA2_GPIO2, and DDATA3_GPIO4, are
four bits wide. This nibble-wide bus displays captured processor data and break-point status.
25
Signal Descriptions
8.19.5 Processor Status
The processor status pins, PST0_GPIO59, PST1_GPIO60, PST2_GPIO61, and PST3_GPIO62, indicate
the SCF5249 processor status. During debug mode, the timing is synchronous with the processor clock
(PSTCLK) and the status is not related to the current bus transfer. .
Table 14. Processor Status Signal Encodings
PST[3:0]
Definition
(HEX)
(BINARY)
$0
0000
Continue execution
$1
0001
Begin execution of an instruction
$2
0010
Reserved
$3
0011
Entry into user-mode
$4
0100
Begin execution of PULSE and WDDATA instructions
$5
0101
Begin execution of taken branch or Synch_PC1
$6
0110
Reserved
$7
0111
Begin execution of RTE instruction
$8
1000
Begin 1-byte data transfer on DDATA
$9
1001
Begin 2-byte data transfer on DDATA
$A
1010
Begin 3-byte data transfer on DDATA
$B
1011
Begin 4-byte data transfer on DDATA
$C
1100
Exception processing2
$D
1101
Emulator mode entry exception processing2
$E
1110
Processor is stopped, waiting for interrupt2
$F
1111
Processor is halted2
Notes:
4.
Rev. B enhancement.
5.
These encodings are asserted for multiple cycles.
8.20 BDM/JTAG Signals
The SCF5249 complies with the IEEE 1149.1A JTAG testing standard. The JTAG test pins are multiplexed
with background debug pins.
8.20.1 Test Clock
TCK is the dedicated JTAG test logic clock that is independent of the SCF5249 processor clock. Various
JTAG operations occur on the rising or falling edge of TCK. The internal JTAG controller logic is designed
such that holding TCK high or low for an indefinite period of time will not cause the JTAG test logic to
lose state information. If TCK will not be used, it should be tied to ground.
26
Signal Descriptions
8.20.2 Test Reset/Development Serial Clock
The TEST[3:0] signals determine the function of the TRST/DSCLK dual-purpose pin. If
TEST[3:0]=0001, the DSCLK function is selected. If TEST[3:0]= 0000, the TRST function is selected.
TEST[3:0] should not be changed while RSTI = 1. When used as TRST, this pin will asynchronously reset
the internal JTAG controller to the test logic reset state, causing the JTAG instruction register to choose
the ìbypassî command. When this occurs, all the JTAG logic is benign and will not interfere with the
normal functionality of the SCF5249 processor. Although this signal is asynchronous, Freescale
recommends that TRST make only a 0 to 1 (asserted to negated) transition while TMS is held at a logic 1
value. TRST has an internal pullup so that if it is not driven low its value will default to a logic level of 1.
However, if TRST will not be used, it can either be tied to ground or, if TCK is clocked, it can be tied to
VDD. If it is tied to ground, it will place the JTAG controller in the test logic reset state immediately. If it
is tied to VDD, it will cause the JTAG controller (if TMS is a logic 1) to eventually end up in the test logic
reset state after 5 clocks of TCK. This pin is also used as the development serial clock (DSCLK) for the
serial interface to the Debug Module.The maximum frequency for the DSCLK signal is 1/5 the BCLKO
frequency.
8.20.3 Test Mode Select/Break Point
The TEST[3:0] signals determine the TMS/BKPT pin function. If TEST[3:0] =0001, the BKPT function
is selected. If TEST[3:0] = 0000, then the TMS function is selected. TEST[3:0] should not change while
RSTI = 1. When used as TMS, this input signal provides the JTAG controller with information to determine
which test operation mode should be performed. The value of TMS and current state of the internal
16-state JTAG controller state machine at the rising edge of TCK determine whether the JTAG controller
holds its current state or advances to the next state. This directly controls whether JTAG data or instruction
operations occur. TMS has an internal pullup so that if it is not driven low, its value will default to a logic
level of 1. However, if TMS will not be used, it should be tied to VDD. This pin also signals a hardware
breakpoint to the processor when in the debug mode.
8.20.4 Test Data Input/Development Serial Input
The TDI/DS is a dual-function pin. If TEST[3:0] = 0001, then DSI is selected. If TEST[3:0] = 0000, then
TDI is selected. When used as TDI, this input signal provides the serial data port for loading the various
JTAG shift registers composed of the boundary scan register, the bypass register, and the instruction
register. Shifting in of data depends on the state of the JTAG controller state machine and the instruction
currently in the instruction register. This data shift occurs on the rising edge of TCK. TDI also has an
internal pullup so that if it is not driven low its value will default to a logic level of 1. However, if TDI will
not be used, it should be tied to VDD. This pin also provides the single-bit communication for the debug
module commands.
8.20.5 Test Data Output/Development Serial Output
The TDO/DSO is a dual-function pin. When TEST[3:0] = 0001, then DSO is selected. When TEST[3:0]
= 0000, TDO is selected. When used as TDO, this output signal provides the serial data port for outputting
27
data from the JTAG logic. Shifting out of data depends on the state of the JTAG controller state machine
and the instruction currently in the instruction register. This data shift occurs on the falling edge of TCK.
When TDO is not outputting test data, it is three-stated. TDO can also be placed in three-state mode to
allow bussed or parallel connections to other devices having JTAG. This signal also provides single-bit
communication for the debug module responses.
8.21 Clock and Reset Signals
These signals configure the SCF5249 and provide interface signals to the external system.
8.21.1 Reset In
Asserting RSTI causes the SCF5249 to enter reset exception processing. When RSTI is recognized, the
data bus is tri-stated.
8.21.2 System Bus Input
The CRIN signal is the system clock input. The device has no on-chip clock oscillator, and needs an
external oscillator.
9
Table 15. Maximum Ratings
Rating
Symbol
Value
Units
Supply Core Voltage
Vcc
-0.5 to +2.5
V
Maximum Core Operating Voltage
Vcc
+1.98
V
Minimum Core Operating Voltage
Vcc
+1.62
V
Supply I/O Voltage
Vcc
-0.5 to +4.6
V
Maximum I/O Operating Voltage
Vcc
+3.6
V
Minimum I/O Operating Voltage
Vcc
+3.0
V
Input Voltage
Vin
-0.5 to +6.0
Storage Temperature Range
V
o
-65 to150
Tstg
C
Table 16. Operating Temperature
Characteristic
Symbol
Value
Units
Maximum Operating Ambient Temperature
TAmax
851
οC
Minimum Operating Ambient Temperature
TAmin
oC
Note:
This published maximum operating ambient temperature should be used only as a system design guideline. All device
operating parameters are guaranteed only when the junction temperature does not exceed 105°C.
28
Table 17. DC Electrical Specifications (Vcc = 3.3 Vdc + 0.3 Vdc)
Characteristic
Symbol
Min
Max
Units
Operation Voltage Range for I/O
Vcc
3.0
3.6
V
Input High Voltage
VIH
2
5.5
V
Input Low Voltage
VIL
-0.3
0.8
V
Input Leakage Current @ 0.0 V /3.3 V
During Normal Operation
Iin
±1
µµA
Hi-Impedance (Three-State) Leakage Current
@ 0.0 V/3.3 V During Normal Operation
ITSI
±1
µµA
Output High Voltage IOH = 8mA1, 4mA2, 2mA3
VOH
2.4
V
Output Low Voltage IOL = 8mA1, 4mA2, 2mA3
VOL
0.4
V
Schmitt Trigger Low to High Threshold Point6
VT+
1.47
V
Schmitt Trigger High to Low Threshold Point6
VT-
.95
V
Load Capacitance (DATA[31:16], DCL0, DCL1, SCLK[4:1],
SCLKOUT, EBUOUT[2:1], LRCK[4:1], SDATAO[2:1], CFLG, EF,
DBCDDATA[3:0], DBCPST[3:0], CNPSTCLK, IDEDIOR,
IDEDIOW, IORDY, SRE, SWE)
CL
50
pF
Load Capacitance (ADDR[25, 23:9], SCLK)
CL
40
pF
Load Capacitance (BCLKE, SDCAS, SDRAS, SDLDQM,
SDRAMCS[2:1],, SDUDQM, SDWE, BUFENB[2:1])
CL
30
pF
Load Capacitance (SDA, SDA2, SCL, SCL2, CMDSDIO2,
SDATA2BS2, SDATA1BS1, SDATA0SDIO1, CS[1:0], OE, R/W,
TA, TXD[2:0], XTRIM, TDO/DSO, RCK, SFSY, SUBR, SDATA3,
TOUT[1:0], QSPIDOUT, QSPICS[3:0], GP[6:5])
CL
pF
Capacitance5, Vin = 0 V, f = 1 MHz
CIN
6
pF
1. DATA[31:16], ADDR[25, 23:9], PSTCLK, SCLK
2. SCL, SDA, PST[3:0], DDATA[3:0], TDSO, SDRAS, SDCAS, SDWE, SDRAMCS[2:1], SDLDQM, SDUDQM,
R/W
3. TOUT[1:0], RTS[2:0], TXD[2:1], SCLK[4:1]
4. BKPT/TMS, DSI/TDI, DSCLK/TRST
5. Capacitance CIN is periodically sampled rather than 100% tested.
6. SCLK[4:1], SCL, SCL2, SDA, SDA2, CRIN, RSTI
29
9.1
Supply Voltage Sequencing and Separation Cautions
Figure 2 shows two situations to avoid in sequencing the CoreVdd and PADVdd (I/O) and PLLL supplies.
Figure 2. Supply Voltage Sequencing and Separation Cautions
CoreVdd supply should not be allowed to rise early (1). This is usually avoided by running the regulator
for the CoreVdd supply (1.8 V) from the voltage generated by the 3.3V supply (PADVdd). This keeps the
CoreVdd supply from rising faster than PADVdd supply.
Also CoreVdd, PLLGVdd, PLLCVdd supply should not rise so late that a large voltage difference is
allowed between the two supplies (2). Typically this situation is avoided by using external discrete diodes
in series between supplies. The series diodes forward bias when the difference between PADVdd and
CoreVdd reaches approximately 2.1V, causing CoreVdd to rise as PADVdd ramps up. When the CoreVdd
regulator begins proper operation, the difference between supplies should not exceed 1.5 V and conduction
through the diode chain reduces to essentially leakage current.
During supply sequencing, the following general relationship should be adhered to: PADVdd, >=
CoreVdd, PLLGVdd, >= (PADVdd - 2.1 V).
The PLL core supplies (PLLGVdd and PLLCVdd) should comply with these constraints just as the
CoreVdd does. In practice, PLLGVdd and PLLCVdd are typically connected directly to the CoreVdd with
some filtering. Further, the PLL PAD supply (PLL1VDD) would be connected directly to the PAD supply
via some filtering.
30
Figure 3. Example Circuit to Control Supply Sequencing
When a DC-DC convertor is used in the system to generate the 1.8V supply, additional care is required. If
possible, the 1.8V DC-DC convertor should be supplied by the 3.3V supply. If this is impossible or
considered inefficient, the designer needs to ensure that the rise time of the 1.8V supply still complies with
the recommendations stated above. Adding the 3 diodes will help resolve issues associated with a slow rise
time of the 1.8V supply. Further, a Schotty diode could be added between the supplies, which would have
the effect of holding the 1.8V supply to match the 3.3V supply should the 1.8V supply come-up first. This
diode also has the function of ensuring that there is not a large voltage differential between the Core supply
and the PAD supply during power-down.
Refer to the M5249C3 Reference Board Userís Manual for the recommended diode types.
A further note is the recommendation for hard resetting of the device. Freescale recommends using a
dynamic reset circuit. This allows for control of the voltage at which the reset will be released and ensure
that the correct voltage level at the RESET pin is achieved in all cases. Passive (RC) reset networks do not
always achieve the desired results.
Figure 4. SCF5249 Power Supply
NOTE
Table 18. 160 MAPBGA Ball Assignments
160MAPBGA Ball
Number
Function
GPIO
E3
CMD_SDIO2
GPIO34
G4
SDATA0-SDIO1
GPIO54
H3
RSTO/SDATA2_BS2
K3
A25
GPO8
31
Table 18. 160 MAPBGA Ball Assignments (continued)
160MAPBGA Ball
Number
Function
GPIO
L4
QSPI_CS1
GPIO24
L8
QSPI_CS3
GPIO22
N8
SDRAM_CS2
GPIO7
P9
EBUOUT2
GPO37
K11
BUFENB2
GPIO17
G12
SUBR
GPIO53
F13
SFSY
GPIO52
F12
RCK
GPIO51
E8
SRE
GPIO11
B8
LRCK3
GPIO45
E7
SWE
GPIO12
A7
SCLK3
GPIO49
Table 19. Clock Timing Specification
NUM
Characteristic
CRIN Frequency1
Units
Min
Max
11.29
33.86
MHz
C5
PSTCLK cycle time
7.1
nSec
C6
PSTCLK duty cycle
40
60
C7
BCLK cycle time
14.2
nSec
C8
BCLK duty cycle
45
55
Note:
There are only three choices for the valid Audio frequencies 11.29 MHz, 16.93 MHz, or
33.86 MHz; no other values are allowed. The System Clock is derived from one of these
crystals via an internal PLL.
32
CRIN
PSTCLK
C6
C6
C7
BCLK
C8
C8
Figure 5. Clock Timing Definition
NOTE
Signals above are shown in relation to the clock. No relationship between
signals is implied or intended.
9.1.1
Processor Bus Input Timing Specification
Table 20 lists processor bus input timings.
NOTE
All processor bus timings are synchronous; that is, input setup/hold and
output delay with respect to the rising edge of a reference clock. The
reference clock is the SCLK output. All other timing relationships can be
derived from these values.
Table 20. External Bus Input Timing Specifications
Characteristica
Num
Units
Symbol
Min
Max
tCYC
14.26
ns
B0
SCLK
B1
Control input valid to SCLK highb
tCVCH
10
ns
B2
SCLK high to control inputs validb
tCHCII
2
ns
B4
Data input (D[31:0]) valid to SCLK high
tDIVCH
6
ns
33
Table 20. External Bus Input Timing Specifications (continued)
Num
B5
Characteristica
SCLK high to data input (D[31:0]) invalid
Units
Symbol
Min
Max
tCHDII
2
ns
a. Timing specifications have been indicated taking into account the full drive strength for the pads.
b. TA pin is being referred to as control input.
9.1.2
Processor Bus Output Timing Specifications
Table 21 lists processor bus output timings.
Table 21. External Bus Output Timing Specifications
34
Figure 6. Read/Write (Internally Terminated) Timing
Figure 7. Read Bus Cycle Terminated by TA
35
Table 22. SDRAM Timing
Figure 8. SDRAM Read Cycle
36
Figure 9. SDRAM Write Cycle
Table 23. Debug AC Timing Specification
Num
Characteristic
Units
Min
Max
D1
PSTCLK to signal Valid (Output valid)
6
nSec
D2
PSTCLK to signal Invalid (Output hold)
1.8
nSec
D31
Signal Valid to PSTCLK (Input setup)
3
nSec
D4
PSTCLK to signal Invalid (Input hold)
5
nSec
1.
DSCLK and DSI are internally synchronized. This setup time must be met only if recognition
on a particular clock is required.
2.
AC timing specs assume 50pF load capacitance on PSTCLK and output pins. If this value is
different, the input and output timing specifications would need to be adjusted to match the
clock load.
37
PSTCLK
D4
D3
DSCLK
D4
D3
D1
DSI
PST[3:0]
DDATA[3:0]
DSO
D2
Figure 10. Debug Timing Definition
Table 24. Timer Module AC Timing Specification
Num
Characteristic
Units
Min
Max
T1
TIN Cycle time
tbd
bus clocks
T2
TIN Valid to BCLK (input setup)
tbd
nSec
T3
SCLK to TIN Invalid (input hold)
tbd
nSec
T4
SCLK to TOUT Valid (output valid)
tbd
nSec
T5
SCLK to TOUT Invalid (output hold)
tbd
nSec
T6
TIN Pulse Width
tbd
bus clocks
T7
TOUT Pulse Width
tbd
bus clocks
38
SCLK
TIN
T6
T2
T3
TIN
T1
T7
TOUT
T4
T5
Figure 11. Timer Module Timing Definition
Table 25. UART Module AC Timing Specifications
Num
Characteristic
Units
Min
Max
U1
RXD Valid to BCLK (input setup)
tbd
nSec
U2
SCLK to RXD Invalid (input hold)
tbd
nSec
U3
CTS Valid to SCLK (input setup)
tbd
nSec
U4
SCLK to CTS Invalid (input hold)
tbd
nSec
U5
SCLK to TXD Valid (output valid)
tbd
nSec
U6
SCLK to TXD Invalid (output hold)
tbd
nSec
U7
SCLK to RTS Valid (output valid)
tbd
nSec
U8
SCLK to RTS Invalid (output hold)
tbd
nSec
39
SCLK
U1
RXD
U2
U3
CTS
U4
U5
TXD
U6
U7
RTS
U8
Figure 12. UART Timing Definition
Table 26. I2C-Bus Input Timing Specifications Between SCL and SDA
Num
Characteristic
Units
Min
Max
M1
Start Condition Hold Time
tbd
bus clocks
M2
Clock Low Period
tbd
bus clocks
M3
SCL/SDA Rise Time
(VIL= 0.5 V to VIH = 2.4 V)
tbd
mSec
M4
Data Hold Time
tbd
nSec
M5
SCL/SDA Fall Time
(VIH= 2.4 V to VIL = 0.5 V)
tbd
mSec
M6
Clock High time
tbd
bus clocks
M7
Data Setup Time
tbd
nSec
M8
Start Condition Setup Time
(for repeated start condition only)
tbd
bus clocks
40
Num
Characteristic
M9
Units
Stop Condition Setup Time
Min
Max
tbd
bus clocks
Table 27. I2C-Bus Output Timing Specifications Between SCL and SDA
Num
Characteristic
Max
M11
tbd
bus clocks
M21
Clock Low Period
tbd
bus clocks
M32
SCL/SDA Rise Time
tbd
mSec
M41
Data Hold Time
tbd
bus clocks
SCL/SDA Fall Time
tbd
nSec
M61
Clock High time
tbd
bus clocks
M71
Data Setup Time
tbd
bus clocks
M81
tbd
bus clocks
M91
tbd
bus clocks
M5
3
1.
Note: Output numbers are dependent on the value programmed into the MFDR; an MFDR programmed
with the maximum frequency (MFDR = 0x20) will result in minimum output timings as shown in the above
table. The MBUS interface is designed to scale the actual data transition time to move it to the middle of
the SCL low period. The actual position is affected by the prescale and division values programmed into
the MFDR; however, numbers given in the above table are the minimum values.
2.
Since SCL and SDA are open-collector-type outputs, which the processor can only actively drive low, the
time required for SCL or SDA to reach a high level depends on external signal capacitance and pull-up
resistor values.
3.
Specified at a nominal 20 pF load.
M2
SCL
Units
Min
M1
M6
M4
M5
M7
M8
M3
M9
SDA
Figure 13. I2C Timing Definition
41
Table 28. I2C Output Bus Timings
Num
Characteristic
Units
Min
Max
M103
SCL, SDA Valid to SCLK (input setup)
tbd
nSec
M11
SCLK to SCL, SDA Invalid (input hold)
tbd
nSec
M121
SCLK to SCL, SDA Low (output valid)
tbd
nSec
M132
SCLK to SCL, SDA Invalid (output hold)
tbd
nSec
1.
Since SCL and SDA are open-collector-type outputs, which the processor can only actively drive low, this
specification applies only when SCL or SDA are driven low by the processor. The time required for SCL or
SDA to reach a high level depends on external signal capacitance and pull-up resistor values.
2.
specification applies only when SCL or SDA are actively being driven or held low by the processor.
3.
SCL and SDA are internally synchronized.This setup time must be met only if recognition on a particular
clock is required.
SCLK
SCL, SDA IN
SCL, SDA OUT
M10
M11
M12
SCL, SDA OUT
M13
Figure 14. I2C and System Clock Timing Relationship
Table 29. General-Purpose I/O Port AC Timing Specifications
Num
Characteristic
Units
Min
Max
P1
GPIO Valid to SCLK (input setup)
tbd
nSec
P2
SCLK to GPIO Invalid (input hold)
tbd
nSec
42
Freescale Semiconductor
Electrical Characteristics
Num
Characteristic
Units
Min
Max
P3
SCLK to GPIO Valid (output valid)
tbd
nSec
P4
SCLK to GPIO Invalid (output hold)
tbd
nSec
SCLK
P1
GPIO IN
P2
P3
GPIO OUT
P4
Figure 15. General-Purpose Parallel Port Timing Definition
Table 30. IEEE 1149.1 (JTAG) AC Timing Specifications
Num
Characteristic
TCK Frequency of Operation
Units
Min
Max
MHz
J1
TCK Cycle Time
100
nSec
J2a
TCK Clock Pulse High Width
25
nSec
J2b
TCK Clock Pulse Low Width
25
nSec
J3a
TCK Fall Time
(VIH=2.4 V to VIL=0.5 V)
5
nSec
J3b
TCK Rise Time
(VIL=0.5 v to VIH=2.4 V)
5
nSec
J4
TDI, TMS to TCK rising (Input Setup)
8
nSec
J5
TCK rising to TDI, TMS Invalid (Hold)
10
nSec
J6
Boundary Scan Data Valid to TCK (Setup)
tbd
nSec
J7
TCK to Boundary Scan Data Invalid to rising edge (Hold)
tbd
nSec
43
Num
Characteristic
Units
Min
Max
J8
TRST Pulse Width
(asynchronous to clock edges)
12
nSec
J9
TCK falling to TDO Valid
(signal from driven or three-state)
15
nSec
J10
TCK falling to TDO High Impedance
15
nSec
J11
TCK falling to Boundary Scan Data Valid
tbd
nSec
J12
Data High Impedance
tbd
nSec
J1
TCK
J3A
J2A
J2B
J3B
J4
TDI, TMS
J5
BOUNDARY
SCAN DATA
INPUT
J6
J7
TRST
J8
J9
TDO
J10
BOUNDARY
SCAN DATA
OUTPUT
J11
J12
Figure 16. JTAG Timing
SCF5249 Integrated ColdFire® Microprocessor Data Sheet, Rev. 3
44
9.2
JTAG Timing Definition IIS Module AC Timing
Specifications
Table 31. SCLK INPUT, SDATAO OUTPUT Timing Specifications
Name
TU
TD
SCLK
Characteristic
SCLK fall to SDATAO rise
SCLK fall to SDATAO fall
Unit
Min
Max
25
25
ns
ns
(INPUT)
SDATAO1, 2 (OUTPUT)
TU
TD
Figure 17. SCLK Input, SDATA Output Timing
Table 32. SCLK OUTPUT, SDATA0 OUTPUT Timing Specifications
Name
TU
TD
SCLK
Characteristic
Unit
Min
Max
3
3
ns
ns
(OUTPUT)
SDATAO1, 2 (OUTPUT)
TU
TD
Figure 18. SCLK Output, SDATAO Output Timing Diagram
45
Pin-Out and Package Information
Table 33. SCLK INPUT, SDATAI INPUT Timing Specifications
Name
TSU
TH
Characteristic
Unit
SDATAI IN to SCLKn
SCLK rise to SDATAI
Min
Max
-5
3
ns
ns
SCLK
(INPUT OR OUTPUT)
SDATA1, 3, 4 (INPUT)
TSU
TH
Figure 19. SCLK Input/Output, SDATAI Input Timing Diagram
10
10.1 Pinning Chart
Table 34. 144 QFP Pin Assignments
144 QFP
Pin
Number
Name
Type
01
SCL/QSPI_CLK
I/O
IIC clock/QSPI clock pin function
select is PLLCR(11)
02
CS0
O
static chip select 0
03
A21
O
SDRAM address / static adr
04
A11
O
05
A10
O
06
A9
O
07
A18
O
08
A17
O
09
BCLK/GPIO10
I/O
sdram clock output
Description
46
Table 34. 144 QFP Pin Assignments (continued)
144 QFP
Pin
Number
Name
Type
10
SCLK_OUT/GPIO15
I/O
MemoryStick/SD
11
BCLKE
O
sdram clock enable output
12
SDA/QSPI_DIN
I/O
IIC data/QSPI data in function select
is PLLCR(11)
13
DATA24
I/O
data
14
A22
O
15
SDUDQM
O
SDRAM UDQM
16
EF/GPIO19
I/O
error flag input
17
DATA25
I/O
data
18
DATA26
I/O
data
19
DATA27
I/O
data
PAD-GND
21
DATA28
I/O
data
22
DATA29
I/O
data
23
SDATA3/GPIO56
I/O
SD interface data line
24
DATA30
I/O
data
25
BUFENB1/GPIO57
I/O
external buffer 1 enable
26
DATA31
I/O
data
27
CORE-VDD
28
A13
29
CORE-GND
30
A23
O
31
A14
O
32
A15
O
33
A16
O
34
PAD-VDD
35
A19
Description
PAD-GND
CORE-VDD
O
CORE-GND
PAD-VDD
O
47
144 QFP
Pin
Number
Name
Type
36
A20
O
37
TEST2
I
test
38
SDRAM-CS1
O
SDRAM chip select out 1
39
SDATA1_BS1/GPIO9
I/O
Memory Stick / SD
40
SDRAS
O
SDRAM RAS
41
SDCAS
O
SDRAM CAS
42
SDWE
O
SDRAM write enable
43
SDLDQM
O
SDRAM LDQM
44
GPIO5
I/O
GPIO5
45
QSPI_CS0/GPIO29
I/O
QSPI chip select 0
46
QSPI_DOUT/GPIO26
I/O
QSPI data out
47
GPIO6
I/O
GPIO6
48
DATA21
I/O
data
49
DATA19
I/O
data
50
QSPI_CS2/GPIO21
I/O
QSPI chip select 2
51
DATA20
I/O
data
52
DATA22
I/O
data
53
DATA18
I/O
data
54
DATA23
I/O
data
55
DATA17
I/O
data
56
PADD-VDD
57
DATA16
I/O
data
58
CFLG/GPIO18
I/O
CFLG input
59
EBUOUT1/GPO36
O
audio interfaces EBU out 1
60
CORE-GND
61
EBUIN3/ADIN0/GPI38
Description
PAD-VDD
CORE-GND
I
audio interfaces EBU in 3 / AD
convertor input0
48
144 QFP
Pin
Number
Name
Type
62
EBUIN2/GPI37
I
63
CORE-VDD
64
SCL2/GPIO3
I/O
65
RSTI
I
Reset
66
TOUT1/ADOUT/GPO35
O
timer output 1 / AD output
67
LRCK2/GPIO44
O
68
OE
O
Output Enable
69
SDA2/GPIO55
I/O
IIS2 data
70
SDATAO2/GPO41
O
audio interfaces serial data output 2
71
SCLK2/GPIO48
I/O
audio interfaces serial clock 2
72
PAD-GND
73
TEST3
I
74
SDATAO1/GPIO25
I/O
audio interfaces serial data output 1
75
LRCK1
I/O
audio interfaces word clock 1
76
LRCK4/GPIO46
I/O
audio interfaces word clock 4
77
SDATAI4/GPI42
I
78
SCLK1
I/O
audio interfaces serial clock 1
79
SCLK4/GPIO50
I/O
audio interfaces serial clock 4
80
TA/GPIO20
I/O
81
SDATAI1
I
audio interfaces serial data in 1
82
EBUIN1/GPI36
I
audio interfaces EBU in 1
83
PLLGRDVDD
PLLGRDVDD
84
PLLGRDGND
PLLGRDGND
85
PLLPADGND
PLLPADGND
86
PLLPADVDD
PLLPADVDD
87
PLLCOREGND
PLLCOREGND
88
PLLCOREVDD
PLLCOREVDD
Description
audio interfaces EBU in 2
CORE-VDD
IIS2 clock line
PAD-GND
test
audio interfaces serial data in 4
49
144 QFP
Pin
Number
Name
Type
89
IDE-DIOW/GPIO14
I/O
90
CRIN
I
crystal
91
IDE-DIOR/GPIO13
I/O
ide dior
92
IDE-IORDY/GPIO16
I/O
ide iordy
93
MCLK1/GPO39
O
Audio master clock output 1
94
MCLK2/GPO42
O
Audio master clock output 2
95
XTRIM/GPO38
O
audio interfaces X-tal trim
96
TRST/DSCLK
I
Debug / interrupt monitor output 2
97
CORE-VDD
98
RW_B
O
Bus write enable
99
TMS/BKPT
I
JTAG/debug
100
CORE-GND
101
TCK
102
PAD-GND
103
PST3/GPIO62
I/O
debug
104
CNPSTCLK/GPO63
O
debug
105
PST1/GPIO60
I/O
debug
106
PAD-VDD
107
PST2/GPIO61
I/O
debug
108
PST0/GPIO59
I/O
debug
109
TDI/DSI
I
jtag/debug
110
TEST0
I
test
111
TIN0/GPI33
I
timer input 0
112
HI-Z
I
jtag
113
DDATA3/GPIO4
I/O
debug
114
TOUT0/GPO33
O
timer output 0
115
DDATA1/GPIO1
I/O
debug
Description
ide diow
CORE-VDD
CORE-GND
I
JTAG
PAD-GND
PAD-VDD
50
144 QFP
Pin
Number
Name
Type
116
DDATA2/GPIO2
I/O
117
CTS2_B/ADIN3/GPI31
I
118
DDATA0/GPIO0
I/O
119
RXD2/GPI28/ADIN2
I
second UART receive data input /
AD input 2
120
TDSO
O
JTAG/debug
121
RTS2_B/GPO31
O
second UART request to send
122
SDATAI3/GPI41
I
audio interfaces serial data input 3
123
CTS1_B/GPI30
I
first UART clear to send
124
TXD2/GPO28
O
second UART transmit data output
125
RTS1_B/GPO30
O
first UART request to send
126
EBUIN4/ADIN1/GPI39
I
audio interfaces EBU input 4 / AD
input 1
127
TXD1/GPO27
O
first UART transmit data output
128
128 RXD1/GPI27
I
first UART receive data input
129
CS1/GPIO58
I/O
130
CORE-GND
131
A1
O
132
TIN1/GPIO23
I/O
Timer input 1
133
A2
O
address
134
A3
O
address
135
PAD-GND
136
A4
O
address
137
A6
O
address
138
A5
O
address
139
A8
O
address
140
A7
O
address
Description
debug
second UART clear /
AD input 3
debug
chip select 1
CORE-GND
PAD-GND
51
144 QFP
Pin
Number
Name
141
CORE-VDD
142
A12
O
address
143
TEST1
I
test
144
PAD-VDD
Type
Description
CORE-VDD
PAD-VDD
10.2 Package
The SCF5249 is assembled in 144-pin QFP package. Thermal characteristics are not available at this time.
52
THIS PAGE INTENTIONALLY LEFT BLANK
53
54
55
How to Reach Us:
Home Page:
www.freescale.com
E-mail:
support@freescale.com
USA/Europe or Locations Not Listed:
Technical Information Center, CH370
1300 N. Alma School Road
Chandler, Arizona 85224
+1-800-521-6274 or +1-480-768-2130
Europe, Middle East, and Africa:
Freescale Halbleiter Deutschland GmbH
Schatzbogen 7
81829 Muenchen, Germany
+44 1296 380 456 (English)
+46 8 52200080 (English)
+49 89 92103 559 (German)
+33 1 69 35 48 48 (French)
Japan:
Freescale Semiconductor Japan Ltd.
Headquarters
ARCO Tower 15F
1-8-1, Shimo-Meguro, Meguro-ku,
Tokyo 153-0064, Japan
0120 191014 or +81 3 5437 9125
support.japan@freescale.com
Asia/Pacific:
Freescale Semiconductor Hong Kong Ltd.
2 Dai King Street
Tai Po Industrial Estate
Tai Po, N.T., Hong Kong
+800 2666 8080
support.asia@freescale.com
For Literature Requests Only:
Freescale Semiconductor Literature Distribution Center
P.O. Box 5405
Denver, Colorado 80217
1-800-441-2447 or 303-675-2140
Fax: 303-675-2150
LDCForFreescaleSemiconductor@hibbertgroup.com
Information in this document is provided solely to enable system and
software implementers to use Freescale Semiconductor products. There are
no express or implied copyright licenses granted hereunder to design or
fabricate any integrated circuits or integrated circuits based on the
information in this document.
Freescale Semiconductor reserves the right to make changes without further
notice to any products herein. Freescale Semiconductor makes no warranty,
representation or guarantee regarding the suitability of its products for any
particular purpose, nor does Freescale Semiconductor assume any liability
arising out of the application or use of any product or circuit, and specifically
disclaims any and all liability, including without limitation consequential or
incidental damages. “Typical” parameters that may be provided in Freescale
Semiconductor data sheets and/or specifications can and do vary in different
applications and actual performance may vary over time. All operating
parameters, including “Typicals”, must be validated for each customer
application by customer’s technical experts. Freescale Semiconductor does
not convey any license under its patent rights nor the rights of others.
Freescale Semiconductor products are not designed, intended, or authorized
for use as components in systems intended for surgical implant into the body,
or other applications intended to support or sustain life, or for any other
application in which the failure of the Freescale Semiconductor product could
create a situation where personal injury or death may occur. Should Buyer
purchase or use Freescale Semiconductor products for any such unintended
or unauthorized application, Buyer shall indemnify and hold Freescale
Semiconductor and its officers, employees, subsidiaries, affiliates, and
distributors harmless against all claims, costs, damages, and expenses, and
reasonable attorney fees arising out of, directly or indirectly, any claim of
personal injury or death associated with such unintended or unauthorized
use, even if such claim alleges that Freescale Semiconductor was negligent
regarding the design or manufacture of the part.
Freescale™ and the Freescale logo are trademarks of Freescale
Semiconductor, Inc. All other product or service names are the property
of their respective owners.© Freescale Semiconductor, Inc. 2005. All rights
reserved.
Document Number: SCF5249EC
Rev. 0
04/2005
