PRESSURE SWITCHES WITH GAUGE
PS6
マーキング
EMC指令適合
INTERNAL STRUCTURE (M5 female screw)
marking
Compatible with
EMC directive
13 4
2
6
5
Part name
■ FEATURES
● Solidstate pressure switch with no mechanical moving parts
● 2 types of pressure ports are available
● Open collector output of either NPN or PNP is available
● Analog output type available
Material
POM (Polyoxymethylene)
1
Pressure port
2
Housing
PC (Polycarbonate)
3
“O” ring
Fluoro-rubber
4
Sensor module board
5
Protection panel
6
Main panel
PET (Polyethyleneterephthalate)
■ MODEL NUMBER DESIGNATION
P S 6 - 1 0 2 V - N A R
Series name
Pressure port
Rated pressure range
R:R1/8 male screw with M5 female screw
M:M5 female screw
102:100 kPa
103:1000 kPa
Output
Pressure reference
A:1 SW output and adjustable hysteresis + Analog output
W:2 SW outputs
G:Gauge
V:Gauge (Vacuum)
Switch output interface
N:NPN open collector
P:PNP open collector
■ LIST OF MODEL NUMBERS
Pressure port
R 1/8 male
screw
M 5 female
screw
Switch output
Outputs
Adjustable hysteresis switch output + Analog output
Switch outputs (2 points)
102V
0 ~ −100 kPa
102G
0 ~ 100 kPa
103G
0 ~ 1000 kPa
NPN open collector output PS6-102V-NAR PS6-102G-NAR PS6-103G-NAR
PNP open collector output PS6-102V-PAR PS6-102G-PAR
PS6-103G-PAR
NPN open collector output PS6-102V-NWR PS6-102G-NWR
PS6-103G-NWR
PNP open collector output PS6-102V-PWR PS6-102G-PWR
PS6-103G-PWR
NPN open collector output PS6-102V-NAM PS6-102G-NAM
PS6-103G-NAM
PNP open collector output PS6-102V-PAM PS6-102G-PAM
PS6-103G-PAM
NPN open collector output PS6-102V-NWM PS6-102G-NWM
PS6-103G-NWM
PNP open collector output PS6-102V-PWM PS6-102G-PWM
PS6-103G-PWM
※ Verify the above model numbers when placing orders.
PS6
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 12 V DC.
Item
PS6
Model number
102V
General specifications
Pressure reference
Gauge
kPa
Maximum pressure
kPa 200
200
1500
Break-down pressure
kPa 500
500
2000
Operating temp. range
0 ~ −100
0 ~ 100
Operating humidity
Storage temp.
0 ~ 50
35 ~ 85(No condensation)
%RH
−20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum)
°C
Pressure medium
Insulation resistance
Power
Net weight
Supply voltage
Consumption current
Non-corrosive gases
MΩ min.
100 (500 V DC)
500 V AC, 60 s(Leakage current 1 mA maximum)
R 1/8(Female screw)or M5
Approx. 50(Including cable)
g
V DC
12 ~ 24 V ± 10 %(Including ripple percentage)
mA max.
35
Display element
Display
0 ~ 1000
−10 ~ 60
°C
Compensated temp. range °C
Pressure port
2-digit LED
Rated display range
−0 ~ −99 kPa
0 ~ 99 kPa
Display accuracy
.0 ~ .99 MPa
± 3 %F.S. ± 2counts
0 〜 50℃
(Reference temp. 25 °C)
1 count
Resolution
No. of outputs
1 or 2
Output interface
Switch output
103G
Dielectric strength
(NPN/PNP)
Open collector output (NPN or PNP)
Setting method
Adjustable by VR
※1
Adjustable range
0 ~ 100 of rated pressure
※2
Red LED ON (W type only : SW1 Red, SW2 Green)
Display
Accuracy
0 〜 50℃
±3
%F.S.
Switch hysteresis
Approx. 0 ~ 15 % of the set value (W type only 2 % F.S. maximum)
30 V 80 mA maximum
Switching capacity
Residual voltage
V maximum
Responsems
Analog output
102G
0.8 (NPN), 1.2 (PNP)
Approx. 2
Output voltage
V
1~5
Zero voltage
V
1 ± 0.1
Span voltage
V
4 ± 0.1
Output current
mA maximum
1(Load resistance 5 kΩ minmum)
※ 1:Please set adjusting torque at 30 mN·m maximum.
※ 2:The actual setting range adjustable by VR has a little overrunning margin beyond the rated display of 0 through 99.
This could cause the setting value of VR may be under “0” or over “99”.
PS6
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s2, 3 directions for 2 hours each
Shock
196 m/s2, 3 directions for 3 times each
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
Pressure cycling
0 ~ Rated pressure, 106 cycles
EMC
EMI : EN55011: 2007, A2 : 2007 Group 1, class B
EMS : EN61326-1 : 2006 Table 2
Pressure indication, switch operating pressure and
analog output variation :
± 2 %F.S., maximum each after test
Pressure indication, switch operating pressure and analog
output variation : ± 5 %F.S., maximum during test
■ CIRCUIT DIAGRAMS
● NAM, NAR (NPN/Adjustable hysteresis switch)
1
● PAM, PAR (PNP/Adjustable hysteresis switch)
LED Indicator
LED Indicator
1
Power B
Power B
Load
Pressure
Sensor
Main circuit
S.Output
A.Output
Pressure
Sensor
Main circuit
A.Output
S.Output
Load
Common
LED
Common
FG
LED
Pressure indication
Pressure indication
● NWM, NWR (NPN/2 switch outputs)
1
2
FG
● PWM, PWR (PNP/2 switch outputs)
LED Indicator
1
2
LED Indicator
Power B
Sensor
Main circuit
Power B
Load
Load
Pressure
S.Output1
S.Output2
Pressure
Sensor
Main circuit
S.Output1
S.Output2
Load
Common
Load
Common
FG
FG
■ SWITCHING OPERATION
● The switch turns on at the set pressure and turns off at the set pressure minus the hysteresis.
● PS6-102V
● PS6- *** G
Hysteresis
ON
ON
OFF
OFF
-100 kPa
Set value
Barometic
pressure
Barometic
pressure
※* A * is adjustable hysteresis type.
Hysteresis
Set value
Rated pressure
PS6
■ OUTLINE DIMENTIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● (NAR, PAR, NWR, PWR)
Switch status LED 2 (Green) ※Only for two-switch output model
Switch status LED 1 (Red)
Pressure indication
Polyacetal
Hysteresis setting VR ※Used to set the switch 2 for two-switch output model
Recommended adjusting torque 30 mN·m maximum
Display selector switch (ME/SW) ※For two-output switch (ME/S1/S2)
Recommended adjusting torque 25 mN·m maximum
Pressure setting VR ※Used to set the switch 1 for two-output type
2 – φ 3.3
Mounting hole
R1/8
12
25
Polycarbonate
Pressure port
M5 depth 5
10
8.5
4.5
( φ 3.8)
4-core shielded cable
L = 1500 ± 50 AWG26 ULNo.2844
52.5
● (NAM, PAM, NWM, PWM)
Pressure indication
Polyacetal
Pressure setting VR ※Used to set the switch 1 for two-switch output model
10
5
2 – φ 3.3
Mounting hole
Pressure port
M5 Depth 5
12
25
19
Polycarbonate
4.5
2 – M3
Depth 4.5
52.5
PS6 (NAM,NAR, PAM, PAR)
Wire color
Connection
( φ 3.8)
PS6 (NWM, NWR, PWM, PWR)
Wire color
Connection
Brown
Power B
Brown
Power B
Black
Switch output
Black
Switch output 1
White
Analog output
White
Switch output 2
Blue
Common
Blue
Common
Shield
N.C.
Shield
N.C.
很抱歉,暂时无法提供与“PS6-102G-NAM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1035.363501+131.86690
- 5+996.180505+126.87650
- 10+964.4260010+122.83210
- 25+940.2748025+119.75610
- 50+930.7123050+118.53820
- 100+926.10600100+117.95160
