PS8/PA-800 構造図
PRESSURE TRANSDUCERS WITH AMP.
PA-800
INTERNAL STRUCTURE
PA-800
2
1
5
4
3
Part name
Material
■ FEATURES
①
Stainless steel diaphragm
SUS 316L
● High corrosion resistance by double diaphragm structure
● Built-in amplifier circuit
● Built-in temperature compensation function
②
Sealed liquid
Silicone oil
③
“O” ring
④
Sensor chip
Silicone
⑤
Fitting
SUS 316
(0 ~ 50 °C)
● Voltage output mode
Fluoro-rubber
■ MODEL NUMBER DESIGNATION
PA-800 - 102 G - 05
Series name
Thermal error
05:0.05 % F.S./°C
10:0.1 % F.S./°C
Rated pressure range
102:0 ~ 98.1 kPa {0 ~ 1 kgf/cm2}
352:0 ~ 343 kPa {0 ~ 3.5 kgf/cm2}
103:0 ~ 981 kPa {0 ~ 10 kgf/cm2}
Pressure reference
G:Gauge
V:Gauge (Vacuum)
■ LIST OF MODEL NUMBERS
Pressure reference
Output
Thermal error
Voltage output
Gauge
kPa {kgf/cm } 0 ~ 98.1
Rated pressure range {0 ~ 1}
2
0 ~ 343
{0 ~ 3.5}
0 ~ 981
{0 ~ 10}
0 ~ − 98.1
{0 ~ − 1}
± 0.05 % F.S./°C
PA-800-102G-05
PA-800-352G-05
PA-800-103G-05
PA-800-102V-05
± 0.1 % F.S./°C
PA-800-102G-10
PA-800-352G-10
PA-800-103G-10
PA-800-102V-10
※ Verify the above model numbers when placing orders.
PA-800
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 12 V DC.
Item
Model number
PA-800
102G 102V 352G 103G
Pressure reference
Maximum pressure
General specifications
Break-down pressure
Gauge
98.1
− 98.1
kPa {kgf/cm2}
{1}
{−1}
kPa {kgf/cm2} 196
{2}
2
kPa {kgf/cm } 294
{3}
Operating temp. range
°C
− 20 ~ 70
Compensated temp. range
°C
0 ~ 50
Operating humidity
− 20 ~ 80(Atmospheric pressure, humidity 65 %RH maximum)
°C
Pressure medium
Insulation resistance
35 ~ 85(No condensation)
%RH
Storage temp.
Corrosive gases/liquids compatible with SUS316L and SUS304
MΩ
minimum
100 (500 V DC)
500 V AC, 60 s(Leakage current 1 mA maximum)
Dielectric strength
Sealed liquid
Silicone oil
G 3/8 (PF 3/8) ※ 1
Pressure port
Power
Net weight
g
Approx. 125
12 ~ 24 ± 10 %
Supply voltage
V DC
Ripple content
maximum
10 % (P-P)
Consumption current
mA
maximum
Output voltage
Analog output
343
981
{3.5}
{10}
686 1961
{7} {20}
1030 2942
{10.5} {30}
1~5
V DC
Zero voltage
V
1 ± 0.04 (at 25 °C)
Span voltage
V
4 ± 0.04 (at 25 °C)
Output current
mA
maximum
%F.S.
Linearity/Hysteresis
Thermal error
0 ~ 50 °C
(Reference temp.: 25 °C)
Supply voltage effect
1(Load resistance 5 kΩ minimum)
± 0.3
± 0.5
ZERO %F.S./°C
± 0.05/± 0.1
SPAN %F.S./°C
± 0.05/± 0.1
V
maximum
Response
Approx. 2
ms
Gravitational effect
%F.S.
(From vertical position to horizontal position) max.
※ 1 An “O” ring is provided. (P18)
± 0.1
Approx. 0.5
Approx. 0.15
Approx. 0.05
PA-800
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions (At 25 ± 5 °C)
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s ,
3 directions for 2 hours each
Shock
981 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 10 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
2
8 外形図
Zero voltage, Span voltage:
± 1 %F.S. maximum each
6
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● PA-800
Gauge type
PA-800
(50.2)
∅ 28
27
11
11
28.2
Wire color Connection
Red
Power ⊕
White
Output
Green
N.C.
Black
Common
Shield
Fitting
Housing
Aluminium with
alumite finish
ZERO SPAN
Span adjustment VR
Stainless steel diaphragm (SUS 316L)
Zero adjustment VR
“0” ring P 18
Fluoro – rubber
G 3/8 (PF 3/8)
(SUS 316)
( ∅3.6) AWG26
4-core shielded cable L = 600 +100
Extra care should be taken with the diaphragm part. Do not touch the diaphragm directly to avoid damaging the diaphragm.
■ INTERNAL ELECTRICAL SCHEMATICS
“0” ring P 18
Fluoro – rubber
27
11 11
Pressure
Sensor
(79)
∅ 28
57
Main circuit
(35)
Lead
wire •Approx. 2000
Power
Output
Common
Shield
Stainless steel
diaphragm
(SUS 316 L)
G 3/8 (PF 3/8)
(SUS 316)
Brass + Ni-plated
很抱歉,暂时无法提供与“PA-800-102V-05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1898.99640
- 200+1777.95000
- 500+1715.46120
- 1000+1684.59480
- 国内价格 香港价格
- 1+4034.028301+522.54775
