PAC50-FNC
PAC50-FNC
    SICK
    Module
PAC50-FNC 数据手册
Product data sheet PAC50-FNC PAC50 PRESSURE SENSORS PAC50-FNC | PAC50 PRESSURE SENSORS A B C D E F Ordering information Type Part no. PAC50-FNC 1083737 Other models and accessories www.sick.com/PAC50 Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Medium Dry compressed air Pressure type Gauge pressure Pressure unit bar Measuring range –1 bar ... 10 bar Overpressure safety 15 bar Process temperature 0 °C ... +60 °C Analog signal output and ohmic load RA Optional, 4 mA ... 20 mA / 0 V… 10 V. Automatic detection depending on connected load or programmable. Output signals can be inverted: 20 mA ... 4 mA / 10 V ... 0 V Load resistance for current output < 600 Ohm Load resistance with current output > 3 kOhm Zero point adjustment Max. + 5 % of span Output signal 2 x PNP/NPN/Push-Pull + 4 mA ... 20 mA / 0 V ... 10 V Diagnostics output Switching output 2 can be set as diagnostics output Display LCD with LED backlight (green/red), can be rotated electronically by 180° Pressure display: 4 digits, 16 segments Pressure unit in display can be switched: bar, MPa, kPa, psi and inHg Update: 1,000, 500, 200, 100 ms (adjustable) Initialization time 300 ms Mechanics/electronics Process connection ¼" NPT female 1) Housing material Housing: polycarbonate, Buttons: TPE, DIN rail mounting: POM, seals: NBR Connection type Round connector M12 x 1, 5-pin Supply voltage 17 V DC ... 30 V DC Power consumption Max. 40 mA at L+ = 24 VDC Electrical safety Protection class: III Overvoltage protection: 32 V DC 1) 2) 2  Bottom: ¼” NPT female thread, pre-installed NPT adapter in G ¼ female thread; rear: G ¼ female thread.  When plugged in with a suitable mating connector. FLUID SENSORS | SICK Product data sheet | 2021-07-13 17:31:24 Subject to change without notice PAC50-FNC | PAC50 PRESSURE SENSORS Short-circuit protection: QA, Q1, Q2 towards M and L+ Reverse polarity protection: L+ to M CE-conformity EMC directive: 2004/108/EC, EN 61326-2-3 Weight sensor Approx. 40 g Enclosure rating IP65 / IP67 (according to IEC 60529) 2) Protection class III ✔ RoHS certificate ✔ CRUus certificate ✔ 1) 2)  Bottom: ¼” NPT female thread, pre-installed NPT adapter in G ¼ female thread; rear: G ¼ female thread.  When plugged in with a suitable mating connector. Performance Non-linearity ≤ ± 0.5 %, of span (Best Fit Straight Line, BFSL) according to IEC 61298-2 Accuracy ≤ ± 1.5 % of the span Setting accuracy of switching outputs ≤ ± 0.2 % of span Non-repeatability ≤ ± 0.2 % of the span Rated temperature range +10 °C ... +60 °C Ambient data Ambient temperature 0 °C ... +60 °C Storage temperature –20 °C ... +80 °C Relative humidity ≤ 90 % Shock load Max. 30 g, xyz according to IEC 60068-2-27 (11 ms, mechanical shock) Vibration load Max. 5 g (10 ... 150 Hz), xyz, to DIN EN 60068-2-6 Classifications ECl@ss 5.0 27200620 ECl@ss 5.1.4 27200620 ECl@ss 6.0 27200620 ECl@ss 6.2 27200620 ECl@ss 7.0 27200620 ECl@ss 8.0 27200620 ECl@ss 8.1 27200620 ECl@ss 9.0 27200620 ECl@ss 10.0 27200620 ECl@ss 11.0 27200620 ETIM 5.0 EC000243 ETIM 6.0 EC000243 ETIM 7.0 EC000243 ETIM 8.0 EC000243 UNSPSC 16.0901 41112409 2021-07-13 17:31:24 | Product data sheet  Subject to change without notice FLUID SENSORS | SICK 3 PAC50-FNC | PAC50 PRESSURE SENSORS Dimensional drawing (Dimensions in mm (inch)) ¼" NPT female G 1/4 19,6 ±0,2 19 8 ±0,2 27,6 Bottom: ¼” NPT female thread, pre-installed NPT adapter in G ¼ female thread; rear: G ¼ female thread seal 10 min. G 1/4 1/4" NPT 6,86 ±0,1 H I J K L M N O P Q R S T seal 10 min. 6,86 ±0,1 1/4" NPT A B C D E F 19,6 ±0,2 19 8 ±0,2 27,6 Instruction for installation . 3 . 2 . 6 . A2:1 5 . 4 A . 4 1 FLUID SENSORS | SICK Product data sheet | 2021-07-13 17:31:24 Subject to change without notice PAC50-FNC | PAC50 PRESSURE SENSORS Opening in the switch panel +3 0 m ax .R 2 54 +3 0 40 d 4 d 3 d2 a 1 Mounting bracket 2021-07-13 17:31:24 | Product data sheet  Subject to change without notice FLUID SENSORS | SICK 5 PAC50-FNC | PAC50 PRESSURE SENSORS A B C D E F H I J K L M N O P Q R S T Recommended accessories Other models and accessories www.sick.com/PAC50 Brief description Type Part no. BEF-MA-WLMNTS-PAC5 2069198 BEF-MACTRLPX-PAC5 2099916 Mounting brackets and plates Wall-mounting kit; mounting element for wall-mounting of pressure switch PAC50, Mounting element: polycarbonate, screws: steel, zinc-coated Terminal and alignment brackets Switch panel installation set for rugged applications (shock, vibration) for installing the PAC50 pressure switch. Maximum switch panel thickness: 5 mm, Stainless steel, aluminum, plastic 6 FLUID SENSORS | SICK Product data sheet | 2021-07-13 17:31:24 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
PAC50-FNC 价格&库存
很抱歉,暂时无法提供与“PAC50-FNC”相匹配的价格&库存,您可以联系我们找货
