IA18FLF05NOM1
IA18FLF05NOM1
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE 5MM CYLIND
IA18FLF05NOM1 数据手册
Proximity Inductive Sensors DC Metal Face Types IA, M8, M12, M18 and M30 • • • • • • • • • Ordering Key Product Description A family of metal face inductive proximity switches in industrial standard stainless steel housings (M8, M12, M18 and M30 types). Output indication: by yellow LED. Outputs are open collector NPN or PNP transistors. Available with cable and M8 or M12 plug. These sensors stand up to Sensing distance: 1 to 15 mm Flush and non-flush types Long and short housing Rated operational voltage: 10 - 30 VDC Output: DC 100 mA, NPN or PNP Normally open, Normally closed Output indication: by yellow LED Protection: reverse polarity, short circuit, transients Cable and plug versions abrasion and impact caused by flying metal chips, grit and misaligned or vibrating targets. In addition, the stainless steel body resists against corrosion and chemical attack, by offering a higher level of protection for more reliable operation and longer life in harsh environments. IA08FLF01NOM5 Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Type Selection M8, M12 and M18 Housing Connec- Housing Rated Ordering no. diameter tion style operating NPN distance Sn Normally open Ordering no. PNP Normally open Ordering no. NPN Normally closed Ordering no. PNP Normally closed M8 M8 M8 M8 M8 M8 M8 M8 Cable Plug Cable Plug Cable Plug Cable Plug Short Short Long Long Short Short Long Long 1 mm 1) 1 mm 1) 1 mm 1) 1 mm 1) 2 mm 2) 2 mm 2) 2 mm 2) 2 mm 2) IA 08 FSF 01 NO IA 08 FSF 01 PO IA 08 FSF 01 NOM5 IA 08 FSF 01 POM5 IA 08 FLF 01 NO IA 08 FLF 01 PO IA 08 FLF 01 NOM5 IA 08 FLF 01 POM5 IA 08 FSN 02 NO IA 08 FSN 02 PO IA 08 FSN 02 NOM5 IA 08 FSN 02 POM5 IA 08 FLN 02 NO IA 08 FLN 02 PO IA 08 FLN 02 NOM5 IA 08 FLN 02 POM5 IA 08 FSF 01 NC IA 08 FSF 01 NCM5 IA 08 FLF 01 NC IA 08 FLF 01 NCM5 IA 08 FSN 02 NC IA 08 FSN 02 NCM5 IA 08 FLN 02 NC IA 08 FLN 02 NCM5 IA 08 FSF 01 PC IA 08 FSF 01 PCM5 IA 08 FLF 01 PC IA 08 FLF 01 PCM5 IA 08 FSN 02 PC IA 08 FSN 02 PCM5 IA 08 FLN 02 PC IA 08 FLN 02 PCM5 M12 M12 M12 M12 M12 M12 M12 M12 Cable Plug Cable Plug Cable Plug Cable Plug Short Short Long Long Short Short Long Long 2 mm 1) 2 mm 1) 2 mm 1) 2 mm 1) 4 mm 2) 4 mm 2) 4 mm 2) 4 mm 2) IA 12 FSF 02 NO IA 12 FSF 02 PO IA 12 FSF 02 NOM1 IA 12 FSF 02 POM1 IA 12 FLF 02 NO IA 12 FLF 02 PO IA 12 FLF 02 NOM1 IA 12 FLF 02 POM1 IA 12 FSN 04 NO IA 12 FSN 04 PO IA 12 FSN 04 NOM1 IA 12 FSN 04 POM1 IA 12 FLN 04 NO IA 12 FLN 04 PO IA 12 FLN 04 NOM1 IA 12 FLN 04 POM1 IA 12 FSF 02 NC IA 12 FSF 02 NCM1 IA 12 FLF 02 NC IA 12 FLF 02 NCM1 IA 12 FSN 04 NC IA 12 FSN 04 NCM1 IA 12 FLN 04 NC IA 12 FLN 04 NCM1 IA 12 FSF 02 PC IA 12 FSF 02 PCM1 IA 12 FLF 02 PC IA 12 FLF 02 PCM1 IA 12 FSN 04 PC IA 12 FSN 04 PCM1 IA 12 FLN 04 PC IA 12 FLN 04 PCM1 M18 M18 M18 M18 M18 M18 M18 M18 Cable Plug Cable Plug Cable Plug Cable Plug Short Short Long Long Short Short Long Long 5 mm 1) 5 mm 1) 5 mm 1) 5 mm 1) 8 mm 2) 8 mm 2) 8 mm 2) 8 mm 2) IA 18 FSF 05 NO IA 18 FSF 05 PO IA 18 FSF 05 NOM1 IA 18 FSF 05 POM1 IA 18 FLF 05 NO IA 18 FLF 05 PO IA 18 FLF 05 NOM1 IA 18 FLF 05 POM1 IA 18 FSN 08 NO IA 18 FSN 08 PO IA 18 FSN 08 NOM1 IA 18 FSN 08 POM1 IA 18 FLN 08 NO IA 18 FLN 08 PO IA 18 FLN 08 NOM1 IA 18 FLN 08 POM1 IA 18 FSF 05 NC IA 18 FSF 05 NCM1 IA 18 FLF 05 NC IA 18 FLF 05 NCM1 IA 18 FSN 08 NC IA 18 FSN 08 NCM1 IA 18 FLN 08 NC IA 18 FLN 08 NCM1 IA 18 FSF 05 PC IA 18 FSF 05 PCM1 IA 18 FLF 05 PC IA 18 FLF 05 PCM1 IA 18 FSN 08 PC IA 18 FSN 08 PCM1 IA 18 FLN 08 PC IA 18 FLN 08 PCM1 1) For flush mounting in metal 2) For non-flush mounting in metal Specifications are subject to change without notice (09.11.12) 1 DC Metal Face Type Selection M30 Housing Connec- Housing Rated Ordering no. diameter tion style operating NPN distance Sn Normally open M30 M30 M30 M30 M30 M30 M30 M30 1) Cable Plug Cable Plug Cable Plug Cable Plug Short Short Long Long Short Short Long Long For flush mounting in metal 10 mm 1) 10 mm 1) 10 mm 1) 10 mm 1) 15 mm 2) 15 mm 2) 15 mm 2) 15 mm 2) 2) Ordering no. PNP Normally open IA 30 FSF 10 NO IA 30 FSF 10 PO IA 30 FSF 10 NOM1 IA 30 FSF 10 POM1 IA 30 FLF 10 NO IA 30 FLF 10 PO IA 30 FLF 10 NOM1 IA 30 FLF 10 POM1 IA 30 FSN 15 NO IA 30 FSN 15 PO IA 30 FSN 15 NOM1 IA 30 FSN 15 POM1 IA 30 FLN 15 NO IA 30 FLN 15 PO IA 30 FLN 15 NOM1 IA 30 FLN 15 POM1 Ordering no. NPN Normally closed Ordering no. PNP Normally closed IA 30 FSF 10 NC IA 30 FSF 10 NCM1 IA 30 FLF 10 NC IA 30 FLF 10 NCM1 IA 30 FSN 15 NC IA 30 FSN 15 NCM1 IA 30 FLN 15 NC IA 30 FLN 15 NCM1 IA 30 FSF 10 PC IA 30 FSF 10 PCM1 IA 30 FLF 10 PC IA 30 FLF 10 PCM1 IA 30 FSN 15 PC IA 30 FSN 15 PCM1 IA 30 FLN 15 PC IA 30 FLN 15 PCM1 For non-flush mounting in metal Specifications Rated operational voltage (UB) Ripple Output current (Ie) No load supply current (IO) IA08, IA12FxF, IA18FxF, IA30FxF IA12FxN, IA18FxN, IA30FxN Voltage drop (Ud) IA08 IA12, IA18, IA30 Protection Voltage transient Power ON delay (tv) Operating frequency (f) IA08Fxxxxxx IA12FxFxxxx IA12FxNxxxx IA18FxFxx IA18FxNxx IA18FxFxxM1 IA18FxNxxM1 IA30FSFxx IA30FSNxx IA30FLFxx IA30FLNxx IA30FxFxxM1 IA30FxNxxM1 Indication for output ON Operating sensing distance (Sa) Effective operating distance (Sr) Usable operating distance (Su) Repeated accuracy (R) Differential travel (H) (Hysteresis) Ambient temperature Operating Storage Humidity (non-condensing) 2 10 to 30 VDC < 10% ≤ 100 mA @ 50°C < 10 mA < 20 mA < 1.5 V < 2.0 V Reverse polarity, short-circuit, transients 1 kV < 10 ms 500 Hz 2000 Hz 1000 Hz 2000 Hz 1000 Hz 1000 Hz 500 Hz 2000 Hz 1000 Hz 300 Hz 150 Hz 2000 Hz 1000 Hz LED, yellow 0 ≤ Sa ≤ 0.81 x Sn 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr ≤ 5% 1 to 20% of sensing dist. -25° to +70°C (-13° to +158°F) -25° to +70°C (-13° to +158°F) 35 to 95% RH Housing material Body, Front Backpart Plug Cable Nuts Connection Cable IA08 IA12, IA18 IA30 Plug IA08 IA12, IA18, IA30 Cables for plug (-1) Degree of protection Weight IA08FSFxx IA08FSFxxM5 IA08FLFxx IA08FLFxxM5 IA08FSNxx IA08FSNxxM5 IA08FLNxx IA08FLNxxM5 IA12FSFxx IA12FSFxxM1 IA12FLFxx IA12FLFxxM1 IA12FSNxx IA12FSNxxM1 IA12FLNxx IA12FLNxxM1 IA18FSFxx IA18FSFxxM1 IA18FLFxx IA18FLFxxM1 IA18FSNxx IA18FSNxxM1 IA18FLNxx IA18FLNxxM1 Stainless steel AISI 304 PA-66 PVC Stainless steel 2 m, 3 x 0.15 mm2, Ø 3 mm, Grey PVC 2 m, 3 x 0.15 mm2, Ø 4 mm, Grey PVC 2 m, 3 x 0.50 mm2, Ø 5.8 mm, Grey PVC M8 x 1 M12 x 1 CONH1A/CONH1O series IP 67 33 g 33 g 33 g 18 g 32 g 32 g 32 g 17 g 31 g 40 g 67 g 153 g 30 g 38 g 65 g 144 g 110 g 74 g 153 g 94 g 92 g 70 g 144 g 91 g Specifications are subject to change without notice (09.11.12) DC Metal Face Specifications (cont.) Weight (cont.) IA30FSFxx IA30FSFxxM1 IA30FLFxx IA30FLFxxM1 IA30FSNxx IA30FSNxxM1 IA30FLNxx IA30FLNxxM1 Tightening torque IA08 IA12 IA18 IA30 CE-marking 146 g 200 g 217 g 187 g 138 g 200 g 207 g 179 g 4.5 Nm 25.0 Nm 60.0 Nm 230.0 Nm Yes Dimensions Type Description A (mm) B (mm) C (mm) D (mm) E (mm) IA 08 FSF 01 xx IA 08 FSF 01 xx M5 IA 08 FLF 01 xx IA 08 FLF 01 xx M5 IA 08 FSN 02 xx IA 08 FSN 02 xx M5 IA 08 FLN 02 xx IA 08 FLN 02 xx M5 M8 x 1 x 30 M8 x 1 x 45 M8 x 1 x 45 M8 x 1 x 60 M8 x 1 x 30 M8 x 1 x 45 M8 x 1 x 45 M8 x 1 x 60 M8 x 1 M8 x 1 M8 x 1 M8 x 1 M8 x 1 M8 x 1 M8 x 1 M8 x 1 30 45 45 60 30 45 45 60 40 26 41 41 56 4 4 4 4 M8 x 1 M8 x 1 M8 x 1 M8 x 1 IA 12 FSF 02 xx IA 12 FSF 02 xx M1 IA 12 FLF 02 xx IA 12 FLF 02 xx M1 IA 12 FSN 04 xx IA 12 FSN 04 xx M1 IA 12 FLN 04 xx IA 12 FLN 04 xx M1 M12 x 1 x 30 M12 x 1 x 50 M12 x 1 x 50 M12 x 1 x 68 M12 x 1 x 30 M12 x 1 x 50 M12 x 1 x 50 M12 x 1 x 68 M12 x 1 M12 x 1 M12 x 1 M12 x 1 M12 x 1 M12 x 1 M12 x 1 M12 x 1 30 50 50 68 30 50 50 68 42 22 42 42 60 8 8 8 8 M12 x 1 M12 x 1 M12 x 1 M12 x 1 IA 18 FSF 05 xx IA 18 FSF 05 xx M1 IA 18 FLF 05 xx IA 18 FLF 05 xx M1 IA 18 FSN 08 xx IA 18 FSN 08 xx M1 IA 18 FLN 08 xx IA 18 FLN 08 xx M1 M18 x 1 x 35 M18 x 1 x 48 M18 x 1 x 55 M18 x 1 x 79 M18 x 1 x 35 M18 x 1 x 48 M18 x 1 x 55 M18 x 1 x 79 M18 x 1 M18 x 1 M18 x 1 M18 x 1 M18 x 1 M18 x 1 M18 x 1 M18 x 1 35 48 55 79 35 48 55 79 65 23 36 43 67 12 12 12 12 M12 x 1 M12 x 1 M12 x 1 M12 x 1 IA 30 FSF 10 xx IA 30 FSF 10 xx M1 IA 30 FLF 10 xx IA 30 FLF 10 xx M1 IA 30 FSN 15 xx IA 30 FSN 15 xx M1 IA 30 FLN 15 xx IA 30 FLN 15 xx M1 M30 x 1.5 x 35 M30 x 1.5 x 48 M30 x 1.5 x 55 M30 x 1.5 x 78 M30 x 1.5 x 35 M30 x 1.5 x 48 M30 x 1.5 x 55 M30 x 1.5 x 78 M30 x 1.5 M30 x 1.5 M30 x 1.5 M30 x 1.5 M30 x 1.5 M30 x 1.5 M30 x 1.5 M30 x 1.5 35 48 55 78 35 48 55 78 25 38 45 68 10 10 10 10 M12 x 1 M12 x 1 M12 x 1 M12 x 1 Specifications are subject to change without notice (09.11.12) 3 DC Metal Face Dimensions: cable type A A A A D D B B C IA xx FSF xx B B C IA xx FSN xx IA xx FLF xx IA xx FLN xx Dimensions: plug type A A B C B B C E IA xx FSF xx Mx IA xx FSN xx Mx A B C 4 4 LED LED E D A D 4 LED 4 LED E E IA xx FLN xx Mx IA xx FLF xx Mx Wiring Diagrams 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 WH 2 WH 4 BK 3 BU - NPN - Normally open 4 3 BU - NPN - Normally closed 3 BU 3 BU PNP - Normally open PNP - Normally closed Specifications are subject to change without notice (09.11.12) DC Metal Face Installation Hints Relief of cable strain To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Delivery Contents • • • • Inductive proximity switch IA.. 2 stainless steel nuts 1 stainless steel washer Packaging: plastic bag Specifications are subject to change without notice (09.11.12) 5
IA18FLF05NOM1 价格&库存
很抱歉,暂时无法提供与“IA18FLF05NOM1”相匹配的价格&库存,您可以联系我们找货
