Datasheet
8XC196KC
Commercial/Express CHMOS Microcontroller
The 80C196KC 16-bit microcontroller is a high performance member of the MCS® 96
microcontroller family. The 80C196KC is an enhanced 80C196KB device with 488 bytes RAM,
16 and 20 MHz operation and an optional 16 Kbytes of ROM/OTPR OM. This CHMOS III process
provides a high performance processor along with low power consumption.
Rochester Electronics
Manufactured Components
Rochester branded components are
manufactured using either die/wafers
purchased from the original suppliers
or Rochester wafers recreated from the
original IP. All re-creations are done with
the approval of the Original Component
Manufacturer (OCM).
Parts are tested using original factory
test programs or Rochester developed
test solutions to guarantee product
meets or exceeds the OCM data sheet.
Quality Overview
• ISO-9001
• AS9120 certification
• Qualified Manufacturers List (QML) MIL-PRF-35835
• Class Q Military
• Class V Space Level
• Qualified Suppliers List of Distributors (QSLD)
• Rochester is a critical supplier to DLA and
meets all industry and DLA standards.
Rochester Electronics, LLC is committed to supplying
products that satisfy customer expectations for
quality and are equal to those originally supplied by
industry manufacturers.
The original manufacturer’s datasheet accompanying this document reflects the performance
and specifications of the Rochester manufactured version of this device. Rochester Electronics
guarantees the performance of its semiconductor products to the original OCM specifications.
‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be
based on product characterization, design, simulation, or sample testing.
FOR REFERENCE ONLY
© 2018 Rochester Electronics, LLC. All Rights Reserved 10082018
To learn more, please visit www.rocelec.com
8XC196KC/8XC196KC20
COMMERCIAL/EXPRESS CHMOS
MICROCONTROLLER
87C196KC-16 Kbytes of On-Chip OTPROM
83C196KC-16 Kbytes ROM
80C196KC-ROMless
16 and 20 MHz Available
Dynamically Configurable 8-Bit or
16-Bit Buswidth
488 Byte Register RAM
Register-to-Register
Architecture
28 Interrupt Sources/16 Vectors
Peripheral Transaction Server
1.4 s 16 x 16 Multiply (20 MHz)
2.4 s 32/16 Divide (20 MHz)
Powerdown and Idle Modes
Five 8-Bit I/O Ports
16-Bit Watchdog Timer
Extended Temperature Available
Full Duplex Serial Port
High Speed I/O Subsystem
16-Bit Timer
16-Bit Up/Down Counter with Capture
3 Pulse-Width-Modulated
Outputs
Four 16-Bit Software Timers
8- or 10-Bit A/D Converter with
Sample/Hold
HOLD/HLDA Bus Protocol
OTPROM One-Time Programmable
Version
The 80C196KC 16-bit microcontroller is a high performance member of the MCS 96 microcontroller family.
The 80C196KC is an enhanced 80C196KB device with 488 bytes RAM, 16 and 20 MHz operation and an
optional 16 Kbytes of ROM/OTPR OM. Intel's CHMOS III process provides a high performance processor
The 87C196KC is an 80C196KC with 16 Kbytes on-chip OTPROM. The 83C196KC is an 80C196KC with 16
Kbytes factory programmed ROM. In this document, the 80C196KC will refer to all products unless otherwise
stated.
Four high-speed capture inputs are provided to record times when events occur. Six high-speed outputs are
available for pulse or waveform generation. The high-speed output can also generate four software timers or
start an A/D conversion. Events can be based on the timer or up/down counter.
With the commercial (standard) temperature option, operational characteristics are guaranteed over the temperature range of 0 C to 70 C. With the extended (Express) temperature range option, operational characteristics are guaranteed over the temperature range of 40 C to 85 C. Unless otherwise noted, the specifications are the same for both options.
See the Packaging information for extended temperature designators.
Other brands and names are the property of their respective owners.
Information in this document is provided in connection with Intel products. Intel assumes no liability whatsoever, including infringement of any patent or
copyright, for sale and use of Intel products except as provided in Intel's Terms and Conditions of Sale for such products. Intel retains the right to make
changes to these specifications at any time, without notice. Microcomputer Products may have minor variations to this specification known as errata.
COPYRIGHT
July 2004
Order Number:270942-006
8XC196KC/8XC196KC20
270942 ±1
Figure 1. 8XC196KC Block Diagram
IOC3 (0CH HWIN1 READ/WRITE)
270942 ±45
NOTE:
RSV-Reserved bits must be
Figure 2. 8XC196KC New SFR Bit (CLKOUT Disable)
2
8XC196KC/8XC196KC20
Table 2. 8XC196KC Memory Map
PROCESS INFORMATION
Description
NOTE:
Figure 3. The 8XC196KC Family Nomenclature
Table 1. Thermal Characteristics
Package
Type
ja
jc
NOTES
Address
8XC196KC/8XC196KC20
Figure 6. 80-Pin SQFP Package
8XC196KC/8XC196KC20
PIN DESCRIPTIONS
Symbol
Name and Function
VCC
Main supply voltage (5V).
VSS
Digital circuit ground (0V). There are multiple VSS pins, all of which must be connected.
VREF
Reference voltage for the A/D converter (5V). VREF is also the supply voltage to the analog
portion of the A/D converter and the logic used to read Port 0. Must be connected for A/D
and Port 0 to function.
ANGND
Reference ground for the A/D converter. Must be held at nominally the same potential as
VSS.
VPP
Timing pin for the return from powerdown circuit. This pin also supplies the programming
voltage on the EPROM device.
XTAL1
Input of the oscillator inverter and of the internal clock generator.
XTAL2
Output of the oscillator inverter.
CLKOUT
Output of the internal clock generator. The frequency of CLKOUT is
frequency.
RESET
Reset input and open drain output.
BUSWIDTH
Input for buswidth selection. If CCR bit 1 is a one, this pin selects the bus width for the bus
cycle in progress. If BUSWIDTH is a 1, a 16-bit bus cycle occurs. If BUSWIDTH is a 0 an
8-bit cycle occurs. If CCR bit 1 is a 0, the bus is always an 8-bit bus.
NMI
A positive transition causes a vector through 203EH.
INST
Output high during an external memory read indicates the read is an instruction fetch. INST
is valid throughout the bus cycle. INST is activated only during external memory accesses
and output low for a data fetch.
EA
Input for memory select (External Access). EA equal high causes memory accesses to
locations 2000H through 5FFFH to be directed to on-chip ROM/E PROM. EA equal to low
causes accesses to those locations to be directed to off-chip memory. Also used to enter
programming mode.
ALE/ADV
Address Latch Enable or Address Valid output, as selected by CCR. Both pin options
provide a signal to demultiplex the address from the address/data bus. When the pin is
ADV, it goes inactive high at the end of the bus cycle. ALE/ADV is activated only during
external memory accesses.
RD
Read signal output to external memory. RD is activated only during external memory reads.
WR/WRL
Write and Write Low output to external memory, as selected by the CCR. WR will go low for
every external write, while WRL will go low only for external writes where an even byte is
being written. WR/WRL is activated only during external memory writes.
BHE/WRH
Bus High Enable or Write High output to external memory, as selected by the CCR. BHE will
go low for external writes to the high byte of the data bus. WRH will go low for external
writes where an odd byte is being written. BHE/WRH is activated only during external
memory writes.
READY
Ready input to lengthen external memory cycles, for interfacing to slow or dynamic memory,
or for bus sharing. When the external memory is not being used, READY has no effect.
HSI
Inputs to High Speed Input Unit. Four HSI pins are available: HSI.0, HSI.1, HSI.2 and HSI.3.
Two of them (HSI.2 and HSI.3) are shared with the HSO Unit.
HSO
Outputs from High Speed Output Unit. Six HSO pins are available: HSO.0, HSO.1, HSO.2,
HSI.3, HSO.4 and HSO.5. Two of them (HSO.4 and HSO.5) are shared with the HSI Unit.
Port 0
8-bit high impedance input-only port. These pins can be used as digital inputs and/or as
analog inputs to the on-chip A/D converter.
Port 1
8-bit quasi-bidirectional I/O port.
Port 2
8-bit multi-functional port. All of its pins are shared with other functions in the 80C196KC.
Pins 2.6 and 2.7 are quasi-bidirectional.
the oscillator
7
8XC196KC/8XC196KC20
PIN DESCRIPTIONS (Continued)
Symbol
8
Name and Function
Ports 3 and 4
8-bit bidirectional I/O ports with open drain outputs. These pins are shared with the
multiplexed address/data bus which has strong internal pullups.
HOLD
Bus Hold input requesting control of the bus.
HLDA
Bus Hold acknowledge output indicating release of the bus.
BREQ
Bus Request output activated when the bus controller has a pending external memory
cycle.
PMODE
Determines the EPROM programming mode.
PACT
A low signal in Auto Programming mode indicates that programming is in process. A high
signal indicates programming is complete.
CPVER
Cummulative Program Output Verification. Pin is high if all locations have programmed
correctly since entering a programming mode.
PALE
A falling edge in Slave Programming Mode and Auto Configuration Byte Programming Mode
indicates that ports 3 and 4 contain valid programming address/command information
(input to slave).
PROG
A falling edge in Slave Programming Mode indicates that ports 3 and 4 contain valid
programming data (input to slave).
PVER
A high signal in Slave Programmig Mode and Auto Configuration Byte Programming Mode
indicates the byte programmed correctly.
AINC
Auto Increment. Active low input signal indicates that the auto increment mode is enabled.
Auto Increment will allow reading or writing of sequential EPROM locations without address
transactions across the PBUS for each read or write.
8XC196KC/8XC196KC20
ELECTRICAL CHARACTERISTICS
ABSOLUTE MAXIMUM RATINGS
NOTICE: This is a production data sheet. It is valid for
the devices indicated in the revision history. The
specifications are subject to change without notice.
Ambient Temperature
Under Bias.....................................-55° to +125°C
Storage Temperature.........................-65° to +150°C
Voltage On Any Pin to VSS.................-0.5V to +7.0V(1)
Voltage from EA or
VPP to VSS or ANGND..............................+13.00V
Power Dissipation...........................................1.5W (2)
NOTE:
1. This includes VPP and EA on ROM or CPU only devices.
2. Power dissipation is based on package heat transfer limitations, not device power consumption.
OPERATING CONDITIONS
Symbol
Description
Min
TA
Ambient Temperature Under Bias Commercial Temp.
TA
Ambient Temperature Under Bias Extended Temp.
VCC
Digital Supply Voltage
Max
Units
C
40
85
C
4.50
5.50
V
VREF
Analog Supply Voltage
ANGND
Analog Ground Voltage
4.00
FOSC
Oscillator Frequency (8XC196KC)
8
16
MHz
FOSC
Oscillator Frequency (8XC196KC20)
8
MHz
VSS
5.50
0.4
VSS
0.4
V
V(1)
NOTE:
1. ANGND and VSS should be nominally at the same potential.
DC CHARACTERISTICS
(Over Specified Operating Conditions)
Symbol
Description
Min
Typ
VIL
Input Low Voltage
VIH
Input High Voltage (Note 1)
VIH1
Input High Voltage on XTAL 1
VIH2
Input High Voltage on RESET
VHYS
Hysteresis on RESET
300
VOL
Output Low Voltage
VOL1
Output Low Voltage
in RESET on P2.5 (Note 2)
VOH
Output High Voltage
(Standard Outputs)
0.5
0.2 VCC
Max
Units
0.8
V
VCC
0.5
V
0.7 VCC
VCC
0.5
V
2.2
VCC
0.5
V
VCC
VCC
VCC
1.0
0.3
0.7
1.5
TestConditions
mV
VCC
5.0V
0.3
0.45
1.5
V
V
V
IOL
IOL
IOL
200 A
2.8 mA
7 mA
0.8
V
IOL
0.4 mA
V
V
V
IOH
IOH
IOH
200 A
3.2 mA
7 mA
9
8XC196KC/8XC196KC20
DC CHARACTERISTICS
(Over Specified Operating Conditions) (Continued)
Symbol Description
Min
VOH1
Output High Voltage
(Quasi-bidirectional Outputs)
VCC
VCC
VCC
IOH1
Logical 1 Output Current in Reset.
on P2.0. Do not exceed this
or device may enter test modes.
IIL2
Logical 0 Input Current in Reset
on P2.0. Maximum current that
must be sunk by external
device to ensure test mode entry.
IIH1
Logical 1 Input Current.
Maximum current that external
device must source to initiate NMI.
ILI
ILI1
ITL
Typ Max
0.3
0.7
1.5
Units TestConditions
V
V
V
IOH
IOH
IOH
mA
VIH
VCC
mA
VIN
0.45V
200
A
VIN
VCC
Input Leakage Current (Std. Inputs)
10
A
VIN
VCC
Input Leakage Current (Port 0)
3
A
VIN
VREF
1 to 0 Transition Current (QBD Pins)
650
A
VIN
2.0V
IIL
Logical 0 Input Current (QBD Pins)
70
A
VIN
0.45V
IIL1
Ports 3 and 4 in Reset
70
A
VIN
0.45V
ICC
Active Mode Current in Reset
(8XC196KC)
65
ICC
(8XC196KC20)
80
92
mA
IIDLE
Idle Mode Current (8XC196KC)
17
25
mA
XTAL1
16 MHz
VCC
VPP VREF
5.5V
IIDLE
Idle Mode Current (8XC196KC20)
21
30
mA
5.5V
IPD
Powerdown Mode Current
8
15
A
XTAL1
20 MHz
VCC
VPP VREF
VCC
VPP VREF
IREF
A/D Converter Reference Current
5
mA
VCC
VPP
5.5V
RRST
Reset Pullup Resistor
VCC
5.5V, VIN
CS
Pin Capacitance (Any Pin to VSS)
0.8
TBD
2
6K
75
mA
65K
10
10 A
30 A
60 A
1.5V
2.4V
0.3V
XTAL1
16 MHz
VCC
VPP VREF
XTAL1
20 MHz
VCC
VPP VREF
VREF
5.5V
5.5V
5.5V
4.0V
pF
NOTES:
1. All pins except RESET and XTAL1.
2. Violating these specifications in Reset may cause the part to enter test modes.
3. Commercial specifications apply to express parts except where noted.
4. QBD (Quasi-bidirectional) pins include Port 1, P2.6 and P2.7.
5. Standard Outputs include AD0 ±15, RD, WR, ALE, BHE, INST, HSO pins, PWM/P2.5, CLKOUT, RESET, Ports 3 and 4,
TXD/P2.0 and RXD (in serial mode 0). The VOH specification is not valid for RESET. Ports 3 and 4 are open-drain outputs.
6. Standard Inputs include HSI pins, READY, BUSWIDTH, RXD/P2.1, EXTINT/P2.2, T2CLK/P2.3 and T2RST/P2.4.
7. Maximum current per pin must be externally limited to the following values if VOL is held above 0.45V or VOH is held
below VCC
0.7V:
IOL on Output pins: 10 mA
IOH on quasi-bidirectional pins: self limiting
IOH on Standard Output pins: 10 mA
8. Maximum current per bus pin (data and control) during normal operation is 3.2 mA.
9. During normal (non-transient) conditions the following total current limits apply:
Port 1, P2.6
IOL: 29 mA
IOH is self limiting
HSO, P2.0, RXD, RESET IOL: 29 mA
IOH: 26 mA
P2.5, P2.7, WR, BHE
IOL: 13 mA
IOH: 11 mA
AD0 ±AD15
IOL: 52 mA
IOH: 52 mA
RD, ALE, INST±CLKOUT IOL: 13 mA
IOH: 13 mA
10
8XC196KC/8XC196KC20
270942 ±17
ICC Max
4.13
Frequency
9 mA
ICC Typ
3.50
Frequency
9 mA
IIDLE Max
1.25
Frequency
5 mA
IIDLE Typ
0.88
Frequency
3 mA
NOTE:
Frequencies below 8 MHz are shown for reference only; no testing is performed.
Figure 7. I CC and I IDLE vs Frequency
AC CHARACTERISTICS
For use over specified operating conditions.
Test Conditions: Capacitive load on all pins
100 pF, Rise and fall times
The system must meet these specifications
Symbol
Description
10 ns, FOSC
16 MHz
to work with the 80C196KC:
Min
Max
Units
2 TOSC
68
Notes
TAVYV
Address Valid to READY Setup
TYLYH
Non READY Time
TCLYX
READY Hold after CLKOUT Low
TLLYX
READY Hold after ALE Low
TAVGV
Address Valid to Buswidth Setup
TCLGX
Buswidth Hold after CLKOUT Low
TAVDV
Address Valid to Input Data Valid
ns
(Note 2)
TRLDV
RD Active to Input Data Valid
TOSC
22
ns
(Note 2)
TCLDV
CLKOUT Low to Input Data Valid
TOSC
45
ns
TRHDZ
End of RD to Input Data Float
TRXDX
Data Hold after RD Inactive
No upper limit
TOSC
TOSC
15
30
2 TOSC
40
2 TOSC
68
ns
(Note 1)
ns
(Note 1)
ns
ns
3 TOSC
TOSC
ns
ns
55
ns
ns
NOTES:
1. If max is exceeded, additional wait states will occur.
2. If wait states are used, add 2 TOSC N, where N
number of wait states.
11
8XC196KC/8XC196KC20
AC CHARACTERISTICS
(Continued)
For user over specified operating conditions.
10 ns, FOSC
16 MHz
The 80C196KC will meet these specifications:
Symbol
Description
Min
Max
Units
Notes
FXTAL
Frequency on XTAL1 (8XC196KC)
8
16
MHz
(Note 1)
FXTAL
Frequency on XTAL1 (8XC196KC20)
8
MHz
(Note 1)
TOSC
I/F XTAL (8XC196KC)
62.5
125
ns
TOSC
I/F XTAL (8XC196KC20)
50
125
ns
TXHCH
XTAL1 High to CLKOUT High or Low
TCLCL
CLKOUT Cycle Time
TCHCL
CLKOUT High Period
TCLLH
CLKOUT Falling Edge to ALE Rising
TLLCH
ALE Falling Edge to CLKOUT Rising
TLHLH
ALE Cycle Time
TLHLL
ALE High Period
TOSC
10
TAVLL
Address Setup to ALE Falling Edge
TOSC
15
TLLAX
Address Hold after ALE Falling Edge
TOSC
35
ns
TLLRL
ALE Falling Edge to RD Falling Edge
TOSC
30
ns
TRLCL
RD Low to CLKOUT Falling Edge
TRLRH
RD Low Period
TRHLH
RD Rising Edge to ALE Rising Edge
TRLAZ
RD Low to Address Float
TLLWL
ALE Falling Edge to WR Falling Edge
TCLWL
CLKOUT Low to WR Falling Edge
TQVWH
Data Stable to WR Rising Edge
TCHWH
CLKOUT High to WR Rising Edge
TWLWH
WR Low Period
TOSC
ns
TWHQX
Data Hold after WR Rising Edge
TOSC
25
ns
TWHLH
WR Rising Edge to ALE Rising Edge
TOSC
10
TWHBX
BHE, INST after WR Rising Edge
TOSC
10
ns
TWHAX
AD8±15 HOLD after WR Rising
TOSC
30
ns
TRHBX
BHE, INST after RD Rising Edge
TOSC
10
ns
TRHAX
AD8±15 HOLD after RD Rising
TOSC
25
ns
ns
2 TOSC
TOSC
10
ns
TOSC 15
ns
5
15
ns
ns
4 TOSC
ns
TOSC 10
4
TOSC
30
TOSC
TOSC
25
ns
(Note 4)
ns
(Note 2)
5
ns
25
ns
15
ns
10
ns
TOSC
ns
ns
5
TOSC
23
(Note 4)
5
TOSC
15
ns
NOTES:
1. Testing performed at 8 MHz. However, the device is static by design and will typically operate below 1 Hz.
2. Assuming back-to-back bus cycles.
3. 8-Bit bus only.
4. If wait states are used, add 2 TOSC N, where N
12
(Note 4)
(Note 4)
(Note 2)
(Note 3)
(Note 3)
8XC196KC/8XC196KC20
System Bus Timings
270942 ±18
13
8XC196KC/8XC196KC20
READY Timings (One Wait State)
270942 ±20
Buswidth Timings
270942 ±35
14
8XC196KC/8XC196KC20
HOLD/HLDA Timings
Symbol
Description
Min
Max
Units
THVCH
HOLD Setup
55
TCLHAL
CLKOUT Low to HLDA Low
15
15
ns
ns
TCLBRL
CLKOUT Low to BREQ Low
15
15
ns
THALAZ
HLDA Low to Address Float
15
ns
THALBZ
HLDA Low to BHE, INST, RD, WR Weakly Driven
ns
TCLHAH
CLKOUT Low to HLDA High
15
15
ns
TCLBRH
CLKOUT Low to BREQ High
15
15
THAHAX
HLDA High to Address No Longer Float
15
THAHBV
HLDA High to BHE, INST, RD, WR Valid
10
15
ns
TCLLH
CLKOUT Low to ALE High
5
15
ns
Notes
(Note 1)
ns
ns
NOTE:
1. To guarantee recognition at next clock.
DC SPECIFICATIONS IN HOLD
Description
Min
Max
Units
Weak Pullups on ADV, RD,
WR, WRL, BHE
50K
250K
VCC
5.5V, VIN
0.45V
Weak Pulldowns on
ALE, INST
10K
50K
VCC
5.5V, VIN
2.4
15
8XC196KC/8XC196KC20
270942 ±36
Maximum Hold Latency
Bus Cycle Type
Internal Execution
1.5 States
16-Bit External Execution
2.5 States
8-Bit External Execution
4.5 States
EXTERNAL CLOCK DRIVE (8XC196KC)
16
Symbol
Parameter
Min
Max
Units
1/T XLXL
TXLXL
Oscillator Period
TXHXX
High Time
ns
TXLXX
Low Time
ns
TXLXH
Rise Time
10
ns
TXHXL
Fall Time
10
ns
8
16.0
MHz
62.5
125
ns
8XC196KC/8XC196KC20
EXTERNAL CLOCK DRIVE (8XC196KC20)
Symbol
Parameter
Min
Max
Units
1/T XLXL
8
20.0
MHz
TXLXL
Oscillator Period
50
125
ns
TXHXX
High Time
17
ns
TXLXX
Low Time
17
ns
TXLXH
Rise Time
8
ns
TXHXL
Fall Time
8
ns
EXTERNAL CLOCK DRIVE WAVEFORMS
270942 ±21
EXTERNAL CRYSTAL CONNECTIONS
EXTERNAL CLOCK CONNECTIONS
270942 ±41
NOTE:
Keep oscillator components close to chip and use
short, direct traces to XTAL1, XTAL2 and VSS. When
using crystals, C1
C2
20 pF. When using ceramic
resonators, consult manufacturer for recommended circuitry.
AC TESTING INPUT, OUTPUT WAVEFORMS
270942 ±22
AC Testing inputs are driven at 2.4V for a Logic ``1'' and 0.45V for
a Logic ``0'' Timing measurements are made at 2.0V for a Logic
``1'' and 0.8V for a Logic ``0''.
270942 ±42
NOTE:
Required if TTL driver used.
Not needed if CMOS driver is used.
FLOAT WAVEFORMS
270942 ±23
For Timing Purposes a Port Pin is no Longer Floating when a
150 mV change from Load Voltage Occurs and Begins to Float
when a 150 mV change from the Loaded VOH/V OL Level occurs;
IOL/I OH
15 mA.
17
8XC196KC/8XC196KC20
EXPLANATION OF AC SYMBOLS
Each symbol is two pairs of letters prefixed by ``T'' for time. The characters in a pair indicate a signal and its
condition, respectively. Symbols represent the time between the two signal/condition points.
Conditions:
Signals:
L-
H-
High
A-
Address
BR- BREQ
ALE/ADV
L-
Low
B-
BHE
R-
RD
V-
Valid
C-
CLKOUT
W-
WR/WRH /WRL
X-
No Longer Valid
D-
DATA
X-
XTAL1
Z-
Floating
G-
Buswidth
Y-
READY
H-
HOLD
Q-
Data Out
HA- HLDA
AC CHARACTERISTICS-SERIAL PORT-SHIFT REGISTER MODE
SERIAL PORT TIMING-SHIFT REGISTER MODE (MODE 0)
Symbol
Parameter
Min
TXLXL
Serial Port Clock Period (BRR
TXLXH
Serial Port Clock Falling Edge
to Rising Edge (BRR 8002H)
TXLXL
TXLXH
to Rising Edge (BRR
8001H)
2 TOSC
50
TQVXH
Output Data Setup to Clock Rising Edge
2 TOSC
50
ns
TXHQX
Output Data Hold after Clock Rising Edge
2 TOSC
50
ns
TXHQV
Next Output Data Valid after Clock Rising Edge
TDVXH
Input Data Setup to Clock Rising Edge
TXHDX
Input Data Hold after Clock Rising Edge
TXHQZ
Last Clock Rising to Output Float
8002H)
Max
Units
6 TOSC
4 TOSC
8001H)
ns
50
4 TOSC
50
4 TOSC
ns
2 TOSC
2 TOSC
TOSC
ns
50
50
50
ns
ns
ns
ns
1 TOSC
ns
WAVEFORM-SERIAL PORT-SHIFT REGISTER MODE
SERIAL PORT WAVEFORM-SHIFT REGISTER MODE (MODE 0)
270942 ±24
18
8XC196KC/8XC196KC20
A to D CHARACTERISTICS
The A/D converter is ratiometric, so absolute accuracy is dependent on the accuracy and stability of VREF.
10-BIT MODE A/D OPERATING CONDITIONS
Symbol
Description
Min
Max
Units
C
TA
Ambient Temperature Commercial Temp.
TA
Ambient Temperature Extended Temp.
40
85
C
VCC
4.50
5.50
V
VREF
4.00
5.50
TSAM
Sample Time
TCONV
Conversion Time
10
FOSC
8.0
16.0
MHz
FOSC
8.0
20.0
MHz
V
s(1)
1.0
s(1)
NOTE:
ANGND and VSS should nominally be at the same potential, 0.00V.
1. The value of AD_TIME is selected to meet these specifications.
10-BIT MODE A/D CHARACTERISTICS (Over Specified Operating Conditions)
Parameter
Typical (1)
Resolution
Minimum
1024
10
Absolute Error
0.25
Zero Offset Error
0.25
0.5
Non-Linearity
1.0
2.0
3
0.1
Repeatability
0.25
LSBs
LSBs
LSBs
2
LSBs
1
LSBs
LSBs
0.009
0.009
0.009
Off Isolation
LSB/ C
LSB/ C
LSB/ C
60
Feedthrough
60
VCC Power Supply Rejection
60
Input Series Resistance
ANGND
DC Input Leakage
dB
1, 2
dB
1
dB
750
Voltage on Analog Input Pin
*Notes
LSBs
1
Channel-to-Channel Matching
Units
Levels
Bits
0.5
Differential Non-Linearity Error
Sampling Capacitor
1024
10
Full Scale Error
Temperature Coefficients:
Offset
Full Scale
Maximum
1.2K
0.5
VREF
0.5
3.0
1
4
V
5, 6
A
pF
NOTES:
An ``LSB'' as used here has a value of approxiimately 5 mV. (See Embedded Microcontrollers and Processors Handbook
for A/D glossary of terms).
1. These values are expected for most parts at 25 C but are not tested or guaranteed.
2. DC to 100 KHz.
3. Multiplexer Break-Before-Make is guaranteed.
4. Resistance from device pin, through internal MUX, to sample capacitor.
5. These values may be exceeded if the pin current is limited to 2 mA.
6. Applying voltages beyond these specifications will degrade the accuracy of all channels being converted.
7. All conversions performed with processor in IDLE mode.
19
8XC196KC/8XC196KC20
8-BIT MODE A/D OPERATING CONDITIONS
Symbol
Description
Min
Max
TA
70
TA
VCC
4.50
5.50
VREF
4.00
5.50
TSAM
Sample Time
TCONV
Conversion Time
FOSC
FOSC
40
85
Units
C
C
V
V
s(1)
1.0
7
s(1)
8.0
16.0
MHz
8.0
20.0
MHz
NOTE:
8-BIT MODE A/D CHARACTERISTICS
Parameter
Typical
Resolution
Minimum
256
8
Absolute Error
Maximum
Levels
Bits
1
LSBs
Full Scale Error
0.5
Zero Offset Error
0.5
LSBs
1
Offset
Full Scale
Notes
LSBs
Non-Linearity
Repeatability
Units
256
8
1
LSBs
1
LSBs
1
LSBs
0.25
LSBs
0.003
0.003
0.003
LSB/ C
LSB/ C
LSB/ C
Off Isolation
dB
2, 3
Feedthrough
60
60
dB
2
60
dB
2
750
VSS
DC Input Leakage
Sampling Capacitor
1.2K
0.5
VREF
s
0.5
3.0
V
4
5, 6
A
pF
NOTES:
An ``LSB'' as used here has a value of approximately 20 mV. (See Embedded Microcontrollers and Processors Handbook
2. DC to 100 KHz.
5. These values may be exceeded if pin current is limited to 2 mA.
8XC196KC/8XC196KC20
EPROM SPECIFICATIONS
OPERATING CONDITIONS DURING PROGRAMMING
Symbol
Description
Min
Max
Units
TA
Ambient Temperature During Programming
C
VCC
Supply Voltage During Programming
4.5
5.5
V(1)
VREF
Reference Supply Voltage During Programming
4.5
5.5
V(1)
VPP
Programming Voltage
12.25
12.75
V(2)
VEA
EA Pin Voltage
12.25
12.75
V(2)
FOSC
Oscillator Frequency During Auto and Slave
Mode Programming
6.0
8.0
MHz
FOSC
Run-Time Programming (8XC196KC)
6.0
16.0
MHz
FOSC
Run-Time Programming (8XC196KC20)
6.0
20.0
MHz
NOTES:
1. VCC and VREF should nominally be at the same voltage during programming.
2. VPP and VEA must never exceed the maximum specification, or the device may be damaged.
3. VSS and ANGND should nominally be at the same potential (0V).
4. Load capacitance during Auto and Slave Mode programming
150 pF.
AC EPROM PROGRAMMING CHARACTERISTICS
Symbol
Description
Min
Max
1100
Units
TSHLL
Reset High to First PALE Low
TOSC
TLLLH
PALE Pulse Width
50
TOSC
TAVLL
Address Setup Time
TOSC
TLLAX
Address Hold Time
100
TPLDV
PROG Low to Word Dump Valid
TPHDX
Word Dump Data Hold
TDVPL
Data Setup Time
TOSC
TPLDX
Data Hold Time
400
TOSC
TPLPH(1)
PROG Pulse Width
50
TOSC
TPHLL
PROG High to Next PALE Low
220
TOSC
TLHPL
PALE High to PROG Low
220
TOSC
TPHPL
PROG High to Next PROG Low
220
TOSC
TPHIL
PROG High to AINC Low
TILIH
AINC Pulse Width
TILVH
PVER Hold after AINC Low
50
TOSC
TILPL
AINC Low to PROG Low
170
TOSC
TPHVL
PROG High to PVER Valid
TOSC
50
TOSC
50
TOSC
TOSC
240
TOSC
220
TOSC
NOTE:
1. This specification is for the Word Dump Mode. For programming pulses, use the Modified Quick Pulse Algorithm. See
user's manual for further information.
21
8XC196KC/8XC196KC20
DC EPROM PROGRAMMING CHARACTERISTICS
Symbol
IPP
Description
Min
VPP Supply Current (When Programming)
Max
Units
100
mA
NOTE:
Do not apply VPP until VCC is stable and within specifications and the oscillator/clock has stabilized or the device may be
damaged.
EPROM PROGRAMMING WAVEFORMS
SLAVE PROGRAMMING MODE DATA PROGRAM MODE WITH SINGLE PROGRAM PULSE
270942 ±27
NOTE:
P3.0 must be high (``1'')
SLAVE PROGRAMMING MODE IN WORD DUMP WITH AUTO INCREMENT
270942 ±28
NOTE:
P3.0 must be low (``0'')
22
8XC196KC/8XC196KC20
SLAVE PROGRAMMING MODE TIMING IN DATA PROGRAM
WITH REPEATED PROG PULSE AND AUTO INCREMENT
270942 ±29
8XC196KB TO 8XC196KC DESIGN
CONSIDERATIONS
1. Memory Map. The 8XC196KC has 512 bytes of
RAM/SFRs
and
an
optional
16K
of
ROM/OTPR OM. The extra 256 bytes of RAM will
reside in locations 100H ±1FFH and the extra 8K
of ROM/OTPR OM will reside in locations
4000H ±5FFFH. These locations are external
memory on the 8XC196KB.
2. The CDE pin on the KB has become a VSS pin on
the KC to support 16/20 MHz operation.
3. EPROM programming. The 8XC196KC has a different programming algorithm to support 16K of
on-board memory. When performing Run-Time
Programming, use the section of code in the
8XC196KC User's Guide.
4. ONCE Mode Entry. The ONCE mode is entered
on the 8XC196KC by driving the TXD pin low on
the rising edge of RESET. The TXD pin is held
high by a pullup that is specified by IOH1. This
Pullup must not be overridden or the 8XC196KC
will enter the ONCE mode.
5. During the bus HOLD state, the 8XC196KC
weakly holds RD, WR, ALE, BHE and INST in
their inactive states. The 8XC196KB only holds
ALE in its inactive state.
6. A RESET pulse from the 8XC196KC is 16 states
rather than 4 states as on the 8XC196KB (i.e., a
watchdog timer overflow). This provides a longer
RESET pulse for other devices in the system.
8XC196KC ERRATA
1. Missed EXTINT on P0.7.
The 80C196KC20 could possibly miss
EXTINT on P0.7. See techbit MC0893.
an
2. HSI_MODEdivide-by-eight.
See Faxback 2192.
3. IPD hump.
See Faxback
2311.
23
8XC196KC/8XC196KC20
DATA SHEET REVISION HISTORY
This data sheet is valid for devices with a ``H'', ``L'' or ``M'' at the end of the topside tracking number. The
topside tracking number consists of nine characters and is the second line on the top side of the device. Data
sheets are changed as new device information becomes available. Verify with your local Intel sales office that
you have the latest version before finalizing a design or ordering devices.
The following are differences between the 270942-006 datasheet and the 270942-005 datasheet:
1. Package prefix variables have changed. Variables are now indicated by an "x"
The following are differences between the 270942-004 and 270942-005 datasheets:
1. Removed ``Word Addressable Only'' from Port 3 and 4 in Table 2.
2. Renamed PVAL to CPVER.
3. Removed TLLYV and TLLGV from the waveform diagrams.
4. Added HSI_MODE divide-by-eight and IPD hump to 8XC196KC errata.
The following are important differences between the 270942-002 and 270942-004 data sheets:
1. NMI during PTS, QBD port glitch and Divide HOLD/READY erratas were fixed and have been removed
from the data sheet. The HSI errata is also removed as this is now considered normal operation.
2. Combined 16 and 20 MHz data sheets. Data sheet 270924-001 (20 MHz) is now obsolete.
3. Added 80-lead SQFP package pinout.
4. Added documentation for CLKOUT disable bit.
5.
JA for QFP package was changed to 55 C/W from 42 C/W.
6.
JC for QFP package was changed to 16 C/W from TBD C/W.
7. TSAM (MIN) in 10-bit mode was changed to 1.0 s from 3.0 s.
8. TSAM (MIN) in 8-bit mode was changed to 1.0 s from 2.0 s.
9. IIL1 specification for port 2.0 was renamed IIL2.
10. IIL2 (MAX) is changed to TBD from
11. IIH1 (MAX) is changed to
6 mA.
200 A from
12. IIH1 test condition changes to VIN
100 A.
2.4V from VIN
5.5V.
13. VHYS is changed to 300 mV from 150 mV.
14. ICC (TYP) at 16 MHz is changed to 65 mA from 50 mA.
15. ICC (MAX) at 16 MHz is changed to 75 mA from 70 mA.
16. ICC (TYP) at 20 MHz is changed to 80 mA from 60 mA.
17. ICC (MAX) at 20 MHz is changed to 92 mA from 86 mA.
18. IIDLE (TYP) at 16 MHz is changed to 17 mA from 15 mA.
19. IIDLE (MAX) at 16 MHz is changed to 25 mA from 30 mA.
20. IIDLE (TYP) at 20 MHz is changed to 21 mA from 15 mA.
21. IIDLE (MAX) at 20 MHz is changed to 30 mA from 35 mA.
22. IPD (TYP) at 16 MHz is changed to 8 A from 15 A.
23. IPD (MAX) at 16 MHz is changed to 15 A from TBD.
24. IPD (TYP) at 20 MHz is changed to 8 A from 18 A.
25. IPD (MAX) at 20 MHz is changed to 15 A from TBD.
26. TCLDV (MAX) is changed to TOSC
27. TLLAX (MIN) is changed to TOSC
28. TCHWH (MIN) is changed to
45 ns from TOSC
35 ns from TOSC
5 ns from
29. TRHAX (MIN) is changed to TOSC
50 ns.
40 ns.
10 ns.
25 ns from TOSC
30. THALAZ (MAX) is changed to
15 ns from
10 ns.
31. THALBZ (MAX) is changed to
20 ns from
15 ns.
30 ns.
8XC196KC/8XC196KC20
32. THAHBV (MAX) is now specified at
15 ns, was formerly unspecified.
33. The TLLYV and TLLGV specifications were removed. These specifications are not required in high-speed
systems designs.
34. Added EXTINT, P0.7 errata to Errata section.
The following are the important differences between the -001 and -002 versions of data sheet 270942.
1. Express and Commercial devices are combined into one data sheet. The Express only data sheet
270794-001 is obsolete.
2. Removed KB/KC feature set differences, pin definition table, and SFR locations and bitmaps.
3. Added programming pin function to package drawings and pin descriptions.
4. Changed absolute maximum temperature under bias from 0 C to
70 C to
55 C to
125 C.
5. Replaced VOH2 specification with IOH1 and IIL1 specifications.
6. Added IIH1 specification for NMI pulldown resistors.
7. Added maximum hold latency table.
8. Added external oscillator and external clock circuit drawings.
9. Changed Clock Drive TXHXX and TXLXX Min spec to 20 ns.
10. Fixed Serial Port TXLXH specification.
11. Added 8- and 10-bit mode A/D operating conditions tables.
12. Specified operating range for sample and convert times.
13. Added specification for voltage on analog input pin.
14. Put operating conditions for EPROM programming into tabular format.
25
