NBB4-F1-E2-V3
NBB4-F1-E2-V3
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 4MM PNP
NBB4-F1-E2-V3 数据手册
Inductive sensor NBB4-F1-E2-V3 < 4 mm flush < 3-wire DC Dimensions 26 12 LED 10 4 4 3.2 x 5 40 4 M3 16 M3 4.5 ø 3.2 Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 184370_eng.pdf M 8 x 4 1 Technical Data General specifications Switching function Normally open (NO) Output type PNP Rated operating distance sn 4 mm Installation flush Output polarity DC Assured operating distance sa 0 ... 3.24 mm Reduction factor rAl 0.4 Reduction factor rCu 0.45 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB4-F1-E2-V3 Technical Data Reduction factor r304 0.8 Reduction factor rBrass 0.55 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 0 ... 1400 Hz Hysteresis H typ. 5% Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤ 2.5 V Rated insulation voltage UBIS 60 V Operating current IL 0 ... 250 mA Off-state current Ir 0 ... 0.01 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 15 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1640 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates Protection class II Rated insulation voltage Ui 60 V Rated impulse withstand voltage Uimp 800 V UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 184370_eng.pdf Mechanical specifications Connection type Connector M8 x 1 , 3-pin Housing material PA Sensing face PA Degree of protection IP67 Tightening torque, fastening screws Threading M3 max: 1.1 Nm Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB4-F1-E2-V3 Connection Assignment 4 1 3 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Accessories Female cordset single-ended, M8, 3-pin, PUR cable Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 184370_eng.pdf V3-WM-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB4-F1-E2-V3 价格&库存
很抱歉,暂时无法提供与“NBB4-F1-E2-V3”相匹配的价格&库存,您可以联系我们找货
