NBB10-30GM40-Z0
NBB10-30GM40-Z0
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    INDUCTIVE SEN 20MM PNP
NBB10-30GM40-Z0 数据手册
Inductive sensor NBB10-30GM40-Z0 < 10 mm flush < 2-wire DC Dimensions 5 37 40 M30x1,5 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 088210_eng.pdf 36 LED Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation 10 mm flush Output polarity DC Assured operating distance sa 0 ... 8.1 mm Actual operating distance sr 9 ... 11 mm typ. Reduction factor rAl 0.3 Reduction factor rCu 0.25 Reduction factor r304 0.7 Output type 2-wire Nominal ratings Operating voltage UB 5 ... 60 V Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB10-30GM40-Z0 Technical Data Switching frequency f 0 ... 150 Hz Hysteresis H 1 ... 10 typ. 5 % Reverse polarity protection reverse polarity tolerant Short-circuit protection pulsing Voltage drop Ud ≤5V Operating current IL 2 ... 100 mA Lowest operating current Im 2 mA Off-state current Ir 0 ... 0.5 mA typ. Time delay before availability tv ≤ Switching state indicator all direction LED, yellow Functional safety related parameters MTTFd 1710 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.34 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Cable Cable diameter 4.8 mm ± 0.2 mm Bending radius > 10 x cable diameter Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 088210_eng.pdf Connection BN L+ BU L- Accessories BF 30 Mounting flange, 30 mm EXG-30 Quick mounting bracket with dead stop Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB10-30GM40-Z0 价格&库存
很抱歉,暂时无法提供与“NBB10-30GM40-Z0”相匹配的价格&库存,您可以联系我们找货
