IME08-02BPSZW2S
IME08-02BPSZW2S
    SICK
    Cylinder,Threaded-M8
    SENSOR PROX INDUCTIVE 2MM CYLIND
IME08-02BPSZW2S 数据手册
Product data sheet IME08-02BPSZW2S IME INDUCTIVE PROXIMITY SENSORS IME08-02BPSZW2S | IME INDUCTIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. IME08-02BPSZW2S 1040872 Included in delivery: BEF-MU-M08 (1) Other models and accessories www.sick.com/IME Illustration may differ Detailed technical data Features Housing Cylindrical thread design Housing Standard Thread size M8 x 1 Diameter Ø 8 mm Sensing range Sn 2 mm Safe sensing range Sa 1.62 mm Installation type Flush Switching frequency 4,000 Hz Connection type Cable, 3-wire, 2 m Switching output PNP Output function NO Electrical wiring DC 3-wire Enclosure rating IP67 1) 1)  According to EN 60529. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple ≤ 10 % Voltage drop ≤ 2 V 1) Current consumption 10 mA 2) 1) 2) 3) 4) 2  At Ia max.  Without load.  Ub and Ta constant.  Of Sr. INDUCTIVE PROXIMITY SENSORS | SICK Product data sheet | 2021-11-17 16:52:59 Subject to change without notice IME08-02BPSZW2S | IME INDUCTIVE PROXIMITY SENSORS Time delay before availability ≤ 100 ms Hysteresis 5 % ... 15 % Reproducibility ≤ 2 % 3) 4) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 Continuous current Ia ≤ 200 mA Cable material PVC Conductor size 0.25 mm² Cable diameter Ø 3.9 mm Short-circuit protection ✔ Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms/10 Hz ... 55 Hz, 1 mm Ambient operating temperature –25 °C ... +75 °C Housing material Brass, nickel-plated Sensing face material Plastic, PA 66 Housing length 52 mm Thread length 34 mm Tightening torque, max. ≤ 5 Nm Items supplied Mounting nut, brass, nickel-plated (2x) UL File No. NRKH.E181493 1) 2) 3) 4)  At Ia max.  Without load.  Ub and Ta constant.  Of Sr. Safety-related parameters MTTFD 1,735 years DCavg 0 % Reduction factors Note The values are reference values which may vary St37 steel (Fe) 1 Stainless steel (V2A, 304) Approx. 0.8 Aluminum (Al) Approx. 0.45 Copper (Cu) Approx. 0.4 Brass (Br) Approx. 0.4 Installation note Remark Associated graphic see "Installation" B 16 mm C 8 mm D 6 mm F 16 mm 2021-11-17 16:52:59 | Product data sheet  Subject to change without notice INDUCTIVE PROXIMITY SENSORS | SICK 3 IME08-02BPSZW2S | IME INDUCTIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Classifications ECl@ss 5.0 27270101 ECl@ss 5.1.4 27270101 ECl@ss 6.0 27270101 ECl@ss 6.2 27270101 ECl@ss 7.0 27270101 ECl@ss 8.0 27270101 ECl@ss 8.1 27270101 ECl@ss 9.0 27270101 ECl@ss 10.0 27270101 ECl@ss 11.0 27270101 ETIM 5.0 EC002714 ETIM 6.0 EC002714 ETIM 7.0 EC002714 ETIM 8.0 EC002714 UNSPSC 16.0901 39122230 Installation note Flush installation F B C D Connection diagram Cd-001 BN BK BU 4 + (L+) NO - (M) INDUCTIVE PROXIMITY SENSORS | SICK Product data sheet | 2021-11-17 16:52:59 Subject to change without notice IME08-02BPSZW2S | IME INDUCTIVE PROXIMITY SENSORS Dimensional drawing (Dimensions in mm (inch)) 3 2 1 34 (1.34) M8 x 1 (0.15) Ø 3.9 IME08 Standard, cable, flush 52 (2.05) ①  Connection ②  Display LED ③  Fastening nuts (2x); width across 13, metal Recommended accessories Other models and accessories www.sick.com/IME Brief description Type Part no. Mounting plate for M8 sensors, steel, zinc coated, without mounting hardware BEF-WG-M08 5321722 Mounting bracket for M8 sensors, steel, zinc coated, without mounting hardware BEF-WN-M08 5321721 Clamping block for round sensors M8, without fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KH-M08 2051477 Clamping block for round sensors M8, with fixed stop, plastic (PA12), glass-fiber reinforced, mounting hardware included BEF-KHF-M08 2051478 Mounting brackets and plates Terminal and alignment brackets 2021-11-17 16:52:59 | Product data sheet  Subject to change without notice INDUCTIVE PROXIMITY SENSORS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
IME08-02BPSZW2S 价格&库存
很抱歉,暂时无法提供与“IME08-02BPSZW2S”相匹配的价格&库存,您可以联系我们找货
