NJ2-PD-US-2.875-V93
NJ2-PD-US-2.875-V93
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN CYLINDER POSITION
NJ2-PD-US-2.875-V93 数据手册
Inductive sensor NJ2-PD-US-2.875-V93 < < < < 2-wire AC/DC Weld Immune Sensing range 2 mm 3000 psi rating Cylinder Position Switch Dimensions LEDs Ø48 35 2 x Ø6.5 Ø31.75 7/8"-16 Ø25 37.5 26.5 34.5 15.06 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 906643_eng.pdf "X" Ø12.7 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation flush Output polarity Assured operating distance 2 mm AC/DC sa 0 ... 1.62 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ2-PD-US-2.875-V93 Technical Data Reduction factor rAl 0.4 Reduction factor r304 0.85 Nominal ratings Operating voltage UB 20 ... 250 V AC/20 ... 300 V DC Switching frequency f 0 ... 20 Hz Hysteresis H 10 ... 20 % 15 typ. Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud Momentary current (20 ms, 0.1 Hz) ≤7V max. 3 A Operating current IL 8 ... 300 mA Off-state current Ir < 1.7 mA Mag. Field strength, AC fields 250 mT Mag. Field strength, DC fields 100 mT Limit data Operating pressure dynamically 3000 psi Indicators/operating means LED green Power on LED red Output status LED red/green Short circuit/overload indication Standard conformity Standards EN 60947-5-2 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector 7/8"-16 UN , 3-pin Degree of protection IP67 Material Housing: zinc Probe: aluminum Note X = 2.875 in (73 mm) Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 906643_eng.pdf Connection 2 AC/DC 3 1 Connection Assignment 1 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NJ2-PD-US-2.875-V93 Wire colors 1 2 3 GN BK WH (green) (black) (white) Additional Information NPT Type Mounting Holes: 1000 and 3000 psi NPT Types: Mounting hole screw thread shall be 1/4" - 20. Minimum thread engagement depth is 0.250" (6.35 mm) Hole spacing is 35 mm center to center. Sensor through-hole Mounting hole (x2) Mounting hole spacing Cylinder End-Cap Overhead View Mounting Screws: Standard 1000 and 3000 psi models use two, self-locking 1/4"- 20 socket head cap screws (provided). Recommended tightening torque: 150 in lb (16.95 N-m). Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 906643_eng.pdf Important: When using spacers, make certain to maintain the 0.250" (6.35 mm) minimum mounting screw thread engagement. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NJ2-PD-US-2.875-V93 价格&库存
很抱歉,暂时无法提供与“NJ2-PD-US-2.875-V93”相匹配的价格&库存,您可以联系我们找货
