EC3025TBASL
EC3025TBASL
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX CAPACITIVE 25MM CYL
EC3025TBASL 数据手册
Proximity Sensors Capacitive Stainless Steel Housing Type EC, M30, AC LD™ E I SH PLE TRI • Featuring TRIPLESHIELD™ sensor protection • Rated operational voltage: 20-250 VAC • Adjustable sensing distance 2-16 mm or 4-25 mm • Output: SCR • Make and break switching function • LED indication • High noise immunity • Flush and non-flush types • Plug and cable versions available • DC versions in the same housing Product Description Ordering Key Capacitive proximity switch­ es with either sensing distance 16 mm flush mount­ ed or 25 mm sensing distance non-flush mount­ed. 2-wire AC output with a switch for choos­ ing NO and NC Capacitive prox­im­ity switch Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Housing type Connection type switch­­ing. M30 stainless steel housing with 2 m PVC cable or plug. Ideal for use in level and plas­tic ma­chin­ ery applications. Both types are available in polyester housings. EC 3025 TBA S L-6 Type Selection Housing diameter M 30 M30 1) Rated Mounting operating dist. (Sn) 1) Ordering no. SCR, cable Make & break switching Ordering no. SCR, plug Make & break switching 16 mm 25 mm EC 3016 TBASL EC 3025 TBASL EC 3016 TBASL-6 EC 3025 TBASL-6 Flush (built-in) Non-flush Object: Grounded steel plate Specifications Rated operating dist. (Sn) 3016: 3025: Sensitivity Effective operating dist. (Sr) Usable operating dist. (Su) Repeat accuracy (R) Hysteresis (H) Rated operational volt. (UB) Ripple Rated operational current (Ie) Continuous Short-time Min. load current OFF-state current (Ir) Voltage drop (Ud) Protection 2 to 16 mm factory set at 16 mm 4 to 25 mm factory set at 25 mm Adj. multiturn pot.meter 0.9 x Sn ≤ Sr ≤ 1.1 x S 0.8 x Sr ≤ Sn > 1.2 x Sr ≤ 5% 4 to 20% of sensing distance 20 to 250 VAC (ripple included) ≤ 10% ≤ 500 mA < 2.5 A (max. 20 ms) 10 mA < 2.5 mA (@ 240 VAC) 1.7 mA (@ 120 VAC) ≤ 10 VAC (at loads ≥ 20 mA) Transients Specifications are subject to change without notice (16.08.2018) Power ON delay ≤ 100 ms Frequency of operating cycles (f) 10 Hz Indication for output ON LED, yellow Environment Degree of protection IP 67 (Nema 1, 3, 4, 6, 13) Temperature Operating temperature -25° to +80°C ( -13° to +176°F) Storage temperature -40° to +85°C (-40° to +185°F) Housing material Body Stainless steel (St 304) Front Grey, polyester Cable end Polyester Nuts Nickel plated brass Connection Cable Grey, 2 m, 2 x 0.5 mm2 Oil proof, PVC Plug (-6) M12 x 1 double keyed Cable for plug (-6) CON.-6A-series Weight (incl. nuts) 3016: 140 g 3025: 150 g Approvals UL CE-marking Yes 1 EC, M30, AC Dimensions D E C D E B C M12x F SW Cable LED SW A Plug Type A LED A B C D E F SW Ø mm mm mm mm mm mm EC 3016TBASL(-6) M30 x 1.5 x 50 36 EC 3025TBASL(-6) M30 x 1.5 x 50 28 50 13.6 15.4 5 28 62 13.6 15.4 5 36 Adjustment Guide The environments in which capacitive sensors are install­ ed can often be un­stable re­ garding temperature, humi­dity­, object distance and industrial (noise) interference. Because of this, Carlo Ga­ vazzi offers as standard features in all TRIP­LESHIELD™ capacitive sensors a user-friendly sensitivity adjustment instead of having a fixed sensing range, extend­ ed sen­ sing range to accommodate mechanically demand­­ing are­as, temperature stability to en­sure minimum need for adjusting sensitivity if temperature varies and high immunity to elec­tro­magnetic interference (EMI). Note: Sensors are factory set (default) to maximum rated sensing range. EC3016TBASL(-6) EC3025TBASL(-6) Tripleshield Sensitivity Adjustment AC models Max. Min. Dist. Output Programmable NO or NC (by selector switch backview) (2-wire device backview) Sensitivity Installation Hints Capacitive sensors have the unique ability to detect al­ most all materials, either in li­ quid or solid form. Capa­ ci­ tive sensors can detect metallic as well as non-metallic ob­ jects, how­ ever, their traditional use is for non-metallic materials such as: • Plastic Industry Resins, regrinds or mould­ ed products. To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables • Chemical Industry Cleansers, fertilisers, liquid soaps, corrosives and pe­­­-­t­­ro­­­chemicals. • Wood Industry Saw dust, paper products, door and window frames. • Ceramic & Glass ­Industry Raw material, clay or finish­ed products, bottles. Relief of cable strain • Packaging Industry Package inspection for level or contents, dry goods, fruits and vegetables, dairy products. Materials are detected due to their dielectric constant. The bigger the size of an object, the higher the density of ma­terial, the better or easier it is to detect the obje- ct. Nominal sensing di­stan­ ce for a capacitive sensor is refe­­r­enced to a grounded me­tal plate (ST37). For addi­ tional information regarding di­elec­­tric ratings of materials please re­fer to Technical Information. Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (16.08.2018) EC, M30, AC Wiring Diagram Delivery Contents 2 BU NO, NC selector switch 20 - 265 VAC 10 - 500 mA • Capacitive switch: EC 30.. TBASL(-6) • Screw driver • 2 nuts • Packaging: Cardboard box • Installation & Adjustment Guide (MAN CAP ENG/GER) Accessories 3 BN • Plugs CON.6A.. serie For further information refer to “Accessories”. Specifications are subject to change without notice (16.08.2018) 3
EC3025TBASL 价格&库存
很抱歉,暂时无法提供与“EC3025TBASL”相匹配的价格&库存,您可以联系我们找货
