NMB1.5-8GM65-E2-FE-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M8
    INDUCTIVE SEN 1.5MM PNP
NMB1.5-8GM65-E2-FE-V1 数据手册
Inductive sensor NMB1,5-8GM65-E2-FE-V1 < < < < Stainless steel sensing face Sensing range 1.5 mm 3-wire DC Ferrous targets Dimensions 40 44 4 M8x1 65 13 LED Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 904077_eng.pdf M12x1 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 1.5 mm DC sa 0 ... 1.215 mm Actuating element Ferrous targets Reduction factor rAl 0 Reduction factor rCu 0 Reduction factor r304 0.6 Reduction factor rSt37 1 Nominal ratings Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NMB1,5-8GM65-E2-FE-V1 Technical Data Operating voltage UB 10 ... 30 V DC Switching frequency f 80 Hz Hysteresis H 3 ... 15 typ. 5 % Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud ≤2V Operating current IL ≤ 100 mA Current consumption ≤ 15 mA Off-state current Ir ≤ 10 µA Indicators/operating means Operation indicator LED red: output Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face Stainless steel 1.4305 / AISI 303 Degree of protection IP67 Connection 1 L+ 4 3 L- Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 904077_eng.pdf Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NMB1,5-8GM65-E2-FE-V1 Accessories Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 904077_eng.pdf V1-G-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NMB1.5-8GM65-E2-FE-V1 价格&库存
很抱歉,暂时无法提供与“NMB1.5-8GM65-E2-FE-V1”相匹配的价格&库存,您可以联系我们找货
