NRN35-L3-A2-C-V1
NRN35-L3-A2-C-V1
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 35MM PNP
NRN35-L3-A2-C-V1 数据手册
Inductive sensor NRN35-L3-A2-C-V1 Technical Data Model Number NRN35-L3-A2-C-V1 Features • • • • • 35 mm non-flush Reduction factor = 1 Weld Immune Quick mounting bracket 4-way LED indicator Accessories V1-G Female connector, M12, 4-pin, field attachable V1-W Female connector, M12, 4-pin, field attachable V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable General specifications Switching function Output type Rated operating distance sn Installation Output polarity Assured operating distance sa Actual operating distance sr Reduction factor rAl Reduction factor rCu Reduction factor r304 Reduction factor rSt37 Output type Nominal ratings Operating voltage UB Switching frequency f Hysteresis H Reverse polarity protection Short-circuit protection Voltage drop Ud Operating current IL Off-state current Ir No-load supply current I0 Time delay before availability tv Constant magnetic field B Alternating magnetic field B Operating voltage indicator Switching state indicator Functional safety related parameters MTTFd Mission Time (TM) Diagnostic Coverage (DC) Ambient conditions Ambient temperature Storage temperature Mechanical specifications Connection type Housing material Sensing face Degree of protection Mass Compliance with standards and directives Standard conformity Standards V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable MHW 01 Modular mounting bracket MH 02-L Mounting aid MH 04-2681F Mounting aid for VariKont, +U1+ and +U9* Approvals and certificates Protection class Rated insulation voltage Ui Rated impulse withstand voltage Uimp UL approval CCC approval complementary PNP 35 mm non-flush DC 0 ... 28.35 mm 31.5 ... 38.5 mm 1 1 1 1 4-wire 10 ... 30 V DC 0 ... 100 Hz 3 ... 15 % reverse polarity protected pulsing ≤ 2.5 V 0 ... 200 mA 0 ... 0.5 mA typ. 0.01 mA ≤ 25 mA 80 ms 200 mT 200 mT LED, green LED, yellow 880 a 20 a 0% -25 ... 70 °C (-13 ... 158 °F) -40 ... 85 °C (-40 ... 185 °F) Connector plug M12 x 1 , 4-pin GD-ZnAl4Cu1, coated mounting flange PA6-GF35 PA 6 Grivory GVN-35H IP67 180 g EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 II 60 V 800 V cULus Listed, General Purpose CCC approval / marking not required for products rated ≤36 V Dimensions LED gn LED ye Refer to “General Notes Relating to Pepperl+Fuchs Product Information”. Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 4411 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com 7 M12 x 1 20 30 4 67 LED gn 40 40 5.5 ø 5.5 46 Release date: 2018-11-13 10:42 Date of issue: 2018-11-13 132324_eng.xml 28 LED ye 60 Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NRN35-L3-A2-C-V1 Electrical Connection 1 L+ 4 2 3 L- Pinout 1 4 2 3 Wire colors in accordance with EN 60947-5-2 BN WH BU BK (brown) (white) (blue) (black) Release date: 2018-11-13 10:42 Date of issue: 2018-11-13 132324_eng.xml 1 2 3 4 2 Refer to “General Notes Relating to Pepperl+Fuchs Product Information”. Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 4411 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com
NRN35-L3-A2-C-V1 价格&库存
很抱歉,暂时无法提供与“NRN35-L3-A2-C-V1”相匹配的价格&库存,您可以联系我们找货
