NBB10-30GM60-A2
NBB10-30GM60-A2
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    INDUCTIVE SEN 10MM PNP
NBB10-30GM60-A2 数据手册
Inductive sensor NBB10-30GM60-A2 < 10 mm flush Dimensions 60 5 M30 x 1.5 36 LED(s) Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 083859_eng.pdf Technical Data General specifications Switching function complementary Output type Rated operating distance PNP sn Installation flush Output polarity Assured operating distance 10 mm DC sa 0 ... 8.1 mm Reduction factor rAl 0.25 Reduction factor rCu 0.15 Reduction factor r304 0.66 Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 200 Hz Hysteresis H typ. 5% Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB10-30GM60-A2 Technical Data Voltage drop Ud ≤3V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 20 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 1140 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type cable PVC , 2 m Core cross-section 0.34 mm2 Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 Connection BN L+ BK WH BU L- Release date: 2020-03-20 Date of issue: 2020-03-30 Filename: 083859_eng.pdf Accessories BF 30 Mounting flange, 30 mm EXG-30 Quick mounting bracket with dead stop Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
NBB10-30GM60-A2 价格&库存
很抱歉,暂时无法提供与“NBB10-30GM60-A2”相匹配的价格&库存,您可以联系我们找货
