ICB18L50F12POM1
ICB18L50F12POM1
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE 12MM CYL
ICB18L50F12POM1 数据手册
ICB, M18 Proximity Inductive Sensors Increased Operating Distance, Nickel-Plated Brass Housing - Types ICB, M18 • Sensing distance: 12 to 20 mm • Quasi-flush or non-flush mountable • Short or long body versions • Rated operational voltage (Ub): 10 - 36 VDC • Output: DC 200 mA, NPN or PNP • Normally open or Normally closed • LED indication for output ON, short-circuit and overload • Protection: reverse polarity, short circuit, transients • Cable or M12 plug versions • According to IEC 60947-5-2 • Setup indicator • Laser engraved on front cap, permanently legible • CSA certified for Hazardous Locations Product Description A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are able to handle applications where very long operating distance is requested. Ordering Key Output is open collector NPN or PNP transistors. Less machine downtime thanks to lower risk of mechanical damage. Type Housing style Housing material Housing size Housing length Thread length Detection principle Sensing distance Output type Output configuration Connection ICB18S30F12NOM1 Type Selection Connec- Body tion style Rated operating distance Sn Ordering no. NPN, Normally open Cable Cable Plug Plug Cable Cable Plug Plug 12 mm 1) 20 mm 2) 12 mm 1) 20 mm 2) 12 mm 1) 20 mm 2) 12 mm 1) 20mm 2) ICB18S30F12NO ICB18S30F12PO ICB18S30N20NO ICB18S30N20PO ICB18S30F12NOM1 ICB18S30F12POM1 ICB18S30N20NOM1 ICB18S30N20POM1 ICB18L50F12NO ICB18L50F12PO ICB18L50N20NO ICB18L50N20PO ICB18L50F12NOM1 ICB18L50F12POM1 ICB18L50N20NOM1 ICB18L50N20POM1 1) Short Short Short Short Long Long Long Long For quasi-flush mounting in metal 2) Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed ICB18S30F12NC ICB18S30F12PC ICB18S30N20NC ICB18S30N20PC ICB18S30F12NCM1 ICB18S30F12PCM1 ICB18S30N20NCM1 ICB18S30N20PCM1 ICB18L50F12NC ICB18L50F12PC ICB18L50N20NC ICB18L50N20PC ICB18L50F12NCM1 ICB18L50F12PCM1 ICB18L50N20NCM1 ICB18L50N20PCM1 For non-flush mounting in metal Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% Output current (Ie) ≤ 200 mA @ 50°C (≤ 150 mA @ 50-70°C) OFF-state current (Ir) ≤ 50 μA No load supply current (Io) ≤ 15 mA Voltage drop (Ud) Max. 2.5 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) ≤ 20 ms Operating frequency (f) ≤ 1500 Hz Specifications are subject to change without notice (16.01.2017) Indication for output ON Activated LED, yellow NO version Target present NC version Target not present Indication for short circuit/ overload LED blinking (f = 2 Hz) Assured operating sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn Effective operating distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr Repeat accuracy (R) ≤ 10% Differential travel (H) (Hysteresis) 1 to 20% of sensing dist. 1 ICB, M18 Specifications (cont.) Ambient temperature Operating Storage Shock and vibration Housing material Body Front Connection Cable Plug Degree of protection Weight (cable/nuts included) Cable Plug Dimensions Tightening torque Distance from sensing face from 0 mm to 9 mm > 9 mm Setup function NO version LED flashing (f=0.67 Hz) LED lights continuously NC version LED flashing (f=0.67 Hz) LED OFF -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IEC 60947-5-2/7.4 Nickel-plated brass Grey thermoplastic polyester Ø4.1 x 2 m, 3 x 0.25 mm2, grey PVC, oil proof M12 x 1 IP 67 Max. 150 g Max. 80 g See diagrams below 15 Nm 25 Nm 0.8 Sn < Sr ≤ Sn 0 ≤ Sr ≤ 0.8 Sn (*) Approvals cULus (UL508) cCSAus As Process Control Equipment for Hazardous Locations. Note: The terminal connector - Class I, Division 2, (version ...M1) was not Groups A, B, C and D. evaluated. The suitability of - T5 up to 150mA, T4A for a the terminal connector should load current > 150mA and be determined in the end-use up to 200 mA, Enclosure application. Type 4. Ambient temperature Ta: -25° to +60°C CCC is not required for products with a maximum operating voltage of ≤ 36 V EMC protection According to IEC 60947-5-2 IEC 61000-4-2 (ESD) 8 KV air discharge, 4 KV contact discharge IEC 61000-4-3 3 V/m IEC 61000-4-4 2 kV IEC 61000-4-6 3 V IEC 61000-4-8 30 A/m MTTFd 850 years @ 50°C (122°F) 0.8 Sn < Sr ≤ Sn 0 ≤ Sr ≤ 0.8 Sn (*) (*): safer installation Dimensions (mm) LED 1.0 30.0 LED 30.0 20.1 10.0 53.0 Short body, quasi-flush version, cable 20.1 53.0 Short body, non-flush version, cable LED (4 x 90°) LED (4 x 90°) 4 3 4 3 1 2 1 2 1.0 30.0 30.0 54.0 Short body, quasi-flush version, plug 2 10.0 54.0 Short body, non-flush version, plug Specifications are subject to change without notice (16.01.2017) ICB, M18 Dimensions (mm) (cont.) LED 1.0 LED 7.5 7.5 50.0 50.0 73.1 73.1 10.0 Long body, quasi-flush version, cable Long body, non-flush version, cable LED (4 x 90°) LED (4 x 90°) 4 3 4 3 1 2 1 2 1.0 50.0 50.0 10.0 74.0 74.0 Long body, quasi-flush version, plug Long body, non-flush version, plug Installation Quasi-flush mountable proximity switches, when installed in damping material, must be according to Picture 1A. Picture 1A Non-flush mountable proximity switches, when installed in damping material, must be according to Picture 1B. Picture 1B d ≥2xd Sn : nominal sensing distance d : sensor diameter (18 mm) d ≥2xd Sn : nominal sensing distance d : sensor diameter (18 mm) Quasi-flush mountable proximity switches, when installed together in damping material, must be according to Picture 2A. Picture 2A d ≥ 2 x Sn ≥4 mm 4 mm ≥2xd Non-flush mountable proximity switches, when installed together in damping material, must be according to Picture 2B. Picture 2B d ≥2xd d ≥3xd d ≥2xd ≥ 4 mm 4 mm d : sensor diameter (18 mm) Specifications are subject to change without notice (16.01.2017) d : sensor diameter (18 mm) 3 ICB, M18 Installation For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 ≥ 6 x Sn Sn : nominal sensing distance Wiring Diagram 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU 3 BU - NPN - Normally open - NPN - Normally closed Reduction Factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 PNP - Normally open - 3 BU - PNP - Normally closed Accessories for Plug Versions The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance Delivery Contents • Inductive proximity switch ICB. • 2 nuts NPB • 2 washers • Packaging: plastic bag 4 3 BU 3-wire angled connector, 2 m cable 3-wire angled connector, 5 m cable 3-wire angled connector, 10 m cable 3-wire angled connector, 15 m cable 3-wire straight connector, 2 m cable 3-wire straight connector, 5 m cable 3-wire straight connector, 10 m cable 3-wire straight connector, 15 m cable PVC PUR CONB13NF-A2 CONB13NF-A2P CONB13NF-A5 CONB13NF-A5P CONB13NF-A10 CONB13NF-A10P CONB13NF-A15 CONB13NF-A15P CONB13NF-S2 CONB13NF-S2P CONB13NF-S5 CONB13NF-S5P CONB13NF-S10 CONB13NF-S10P CONB13NF-S15 CONB13NF-S15P For any additional information or different options, please refer to the “General Accessories Connector Cables -Type CONB1...” datasheets. Specifications are subject to change without notice (16.01.2017)
ICB18L50F12POM1 价格&库存
很抱歉,暂时无法提供与“ICB18L50F12POM1”相匹配的价格&库存,您可以联系我们找货
