ICB12S30F04NA
ICB12S30F04NA
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 4MM CYLIND
ICB12S30F04NA 数据手册
 ICS08, ICB12, ICB18 and ICB30 4-wire DC Proximity inductive sensors with complementary output function Benefits Description • A complete family. Available in M8, M12, M18 and M30 housings with an operating distance from 2 to 22 mm. • Less machine downtime. Lower risk of mechanical damage thanks to the extended range sensors with 2 times the standard operating distance. • Easy to install. ICB sensors have a milled section for wrench grip and two different thread lengths. The user can choose between 2 m PVC cable and M12-disconnect plug versions. • High precision. The onboard advanced microcontroller ensures better stability with respect to environmental influences, with highly repeatable measurements between -25 and +70°C (up to +80°C for ICS). • Easy customization to specific OEM requests. Special sensing distance and timing functions or pigtail solutions with special cables and connectors are possible on request. • Product traceability. Permanently legible part number and serial number, laser engraved on the plastic cap, guarantee the traceability of every sensor. A complete family of high performance inductive sensors and represents Carlo Gavazzi standard solution for industrial automation equipments. It is available in 4 diameters: M8, M12, M18 and M30, in standard and extended sensing ranges, long and short rugged housings. Main functions • Non contact detection of metal objects in general position-sensing and presence-sensing in industrial applications • Particularly suitable for rotational speed monitoring thanks to the high operating frequency • Simultaneous availability of both make and break switching functions with maximum connection flexibility to the control unit • Integrated diagnostic function with flashing LED in the event of a short circuit or overload 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Carlo Gavazzi Automation S.p.A. 1 ICS08, ICB12, ICB18 and ICB30 4-wire DC  References Order code IC A Enter the code, replacing the symbol Code I C A Option B S 08 12 18 30 S30 L45 L50 F N 02 04 05 08 10 14 15 22 N P M5 M1 with the selected option (e.g.: ICB12S30F04NAM1). Description Inductive sensor Cylindrical housing Nickel-plated brass housing Stainless steel housing M8 housing M12 housing M18 housing M30 housing Short housing with thread length of 30 mm Long housing with thread length of 45 mm Long housing with thread length of 50 mm Flush Non-flush Sensing distance: 2mm Sensing distance: 4mm Sensing distance: 5mm Sensing distance: 8mm Sensing distance: 10mm Sensing distance: 14mm Sensing distance: 15mm Sensing distance: 22mm NPN PNP Output: N.O. and N.C. 2 m cable M8 plug M12 plug Additional characters can be used for customized versions. 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Carlo Gavazzi Automation S.p.A. 2 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Type selection M8 Extended range Connection Body style Detection principle Flush Cable Short Plug Non-flush Flush Non-flush Flush Cable Long Plug Non-flush Flush Non-flush Output type NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP Ordering no. Extended range ICS08S30F02NA ICS08S30F02PA ICS08S30N04NA ICS08S30N04PA ICS08S30F02NAM5 ICS08S30F02PAM5 ICS08S30N04NAM5 ICS08S30N04PAM5 ICS08L45F02NA ICS08L45F02PA ICS08L45N04NA ICS08L45N04PA ICS08L45F02NAM5 ICS08L45F02PAM5 ICS08L45N04NAM5 ICS08L45N04PAM5 Output type NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP Ordering no. Standard range ICB12S30F02NA ICB12S30F02PA ICB12S30N04NA ICB12S30N04PA ICB12S30F02NAM1 ICB12S30F02PAM1 ICB12S30N04NAM1 ICB12S30N04PAM1 ICB12L50F02NA ICB12L50F02PA ICB12L50N04NA ICB12L50N04PA ICB12L50F02NAM1 ICB12L50F02PAM1 ICB12L50N04NAM1 ICB12L50N04PAM1 M12 Standard and extended range Connection Body style Flush Cable Short Plug Non-flush Flush Non-flush Flush Cable Long Plug Detection principle Non-flush Flush Non-flush 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Ordering no. Extended range ICB12S30F04NA ICB12S30F04PA ICB12S30N08NA ICB12S30N08PA ICB12S30F04NAM1 ICB12S30F04PAM1 ICB12S30N08NAM1 ICB12S30N08PAM1 ICB12L50F04NA ICB12L50F04PA ICB12L50N08NA ICB12L50N08PA ICB12L50F04NAM1 ICB12L50F04PAM1 ICB12L50N08NAM1 ICB12L50N08PAM1 Carlo Gavazzi Automation S.p.A. 3 ICS08, ICB12, ICB18 and ICB30 4-wire DC  M18 Standard and extended range Connection Body style Detection principle Flush Cable Short Plug Non-flush Flush Non-flush Flush Cable Long Plug Non-flush Flush Non-flush Output type NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP Ordering no. Standard range ICB18S30F05NA ICB18S30F05PA ICB18S30N08NA ICB18S30N08PA ICB18S30F05NAM1 ICB18S30F05PAM1 ICB18S30N08NAM1 ICB18S30N08PAM1 ICB18L50F05NA ICB18L50F05PA ICB18L50N08NA ICB18L50N08PA ICB18L50F05NAM1 ICB18L50F05PAM1 ICB18L50N08NAM1 ICB18L50N08PAM1 Ordering no. Extended range ICB18S30F08NA ICB18S30F08PA ICB18S30N14NA ICB18S30N14PA ICB18S30F08NAM1 ICB18S30F08PAM1 ICB18S30N14NAM1 ICB18S30N14PAM1 ICB18L50F08NA ICB18L50F08PA ICB18L50N14NA ICB18L50N14PA ICB18L50F08NAM1 ICB18L50F08PAM1 ICB18L50N14NAM1 ICB18L50N14PAM1 Output type NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP NPN PNP Ordering no. Standard range ICB30S30F10NA ICB30S30F10PA ICB30S30N15NA ICB30S30N15PA ICB30S30F10NAM1 ICB30S30F10PAM1 ICB30S30N15NAM1 ICB30S30N15PAM1 ICB30L50F10NA ICB30L50F10PA ICB30L50N15NA ICB30L50N15PA ICB30L50F10NAM1 ICB30L50F10PAM1 ICB30L50N15NAM1 ICB30L50N15PAM1 Ordering no. Extended range ICB30S30F15NA ICB30S30F15PA ICB30S30N22NA ICB30S30N22PA ICB30S30F15NAM1 ICB30S30F15PAM1 ICB30S30N22NAM1 ICB30S30N22PAM1 ICB30L50F15NA ICB30L50F15PA ICB30L50N22NA ICB30L50N22PA ICB30L50F15NAM1 ICB30L50F15PAM1 ICB30L50N22NAM1 ICB30L50N22PAM1 M30 Standard and extended range Connection Body style Flush Cable Short Plug Non-flush Flush Non-flush Flush Cable Long Plug Detection principle Non-flush Flush Non-flush 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Carlo Gavazzi Automation S.p.A. 4 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Structure ICS08 Element A B Component Sensing face 2 nuts C LED D M8, 4 pin, male connector Function Flush or non-flush For sensor mounting Yellow LED: Output flashing: short circuit or overload indication For plug versions only ICB12 A B C D E A B C D A B D C E Element A B C Component Sensing face 2 nuts Milled section D LED E M12 x 1, 4 pin, male connector 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Function Flush or non-flush For sensor mounting For wrench grip Yellow LED: Output flashing: short circuit or overload indication For plug versions only Carlo Gavazzi Automation S.p.A. 5 ICS08, ICB12, ICB18 and ICB30 4-wire DC  ICB18 A B C D A E B C A D B C D E Element A B C Component Sensing face 2 nuts Milled section D LED E M12 x 1, 4 pin, male connector Function Flush or non-flush For sensor mounting For wrench grip Yellow LED: Output flashing: short circuit or overload indication For plug versions only ICB30 A B D E A B D A B D E Element A B Component Sensing face 2 nuts D LED E M12 x 1, 4 pin, male connector 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Function Flush or non-flush For sensor mounting Yellow LED: Output flashing: short circuit or overload indication For plug versions only Carlo Gavazzi Automation S.p.A. 6 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Sensing Detection Rated operating distance Sn Reference target Assured operating sensing distance (Sa) Effective operating distance (Sr) Usable operating distance (Su) Hysteresis (H) 2 to 22 mm: depending on housing diameter and version (flush or nonflush; standard or extended range) The operating distance is measured according to IEC 60947-5-2, using a standard target moving axially. This target is square shape 1 mm thickness, made of steel e.g. type Fe 360 as defined in ISO 630 and it shall be of the rolled finish. The length of the side of the square is equal to – the diameter of the circle inscribed on the active surface of the sensing face, or – three times the rated operating distance Sn whichever is greater 0 ≤ Sa ≤ 0.81 x Sn (e.g. with Sn of 15 mm, Sa is 0 ... 12.15 mm) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr 1...20% Correction factors The specific operating distance Sn refers to defined measuring conditions. The following data have to be considered as general guidelines. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance Fig. 1 The rated operating distance is reduced by the use of metals and alloys other than Fe360. The most important reduction factors for inductive proximity sensors are shown in the figure. Accuracy Repeat accuracy (R) 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN ICB: ≤ 10% ICS: < 5% (Sr) Carlo Gavazzi Automation S.p.A. 7 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Features Power Supply Rated operational voltage (Ub) Ripple (Urpp) No load supply current (Io) Power ON delay (tv) 10 to 36 VDC (ripple included) ≤ 10% ICB: ≤ 16 mA ICS: ≤ 15 mA ICB: ≤ 50 ms ICS: ≤ 20 ms Outputs Output functions Output configuration Output current (Ie) OFF-state current (Ir) NPN or PNP by sensor type Open collector N.O. and N.C. Complementary ≤ 200 mA @ 50°C; ≤ 150 mA @ 50...70°C ≤ 50 μA ICB: Max. 2.5 VDC @ 200 mA ICS: Max. 1.6 VDC @ 200 mA Short-circuit, reverse polarity and transients 1 kV/0.5 J Voltage drop (Ud) Protection Voltage transient Response times ≤ 2000 Hz ≤ 1500 Hz ≤ 1000 Hz Operating frequency (f) ICS08, ICB12 ICB18 ICB30 Indication Yellow LED Output OFF OFF ON ON Blinking (f = 2 Hz) 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Description N.O. output, target not present N.C. output, target present N.O. output, target present N.C. output, target not present Short-circuit or overload Carlo Gavazzi Automation S.p.A. 8 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Environmental Ambient temperature ICS Ambient temperature ICB Ambient temperature ICB30 plug version only Vibration Shock Degree of protection Operating: -25° to +80°C, (-13° to +176°F) Storage: -30° to +80°C (-22° to +176°F) Operating: -25° to +70°C (-13° to +158°F) Storage: -30° to +80°C (-22° to +176°F) Operating: -40° to +70°C (-40° to +158°F) Storage: -40° to +80°C (-40° to +176°F) 10 to 55 Hz, amplitude 1.0 mm; sweep IEC 60068-2-6 cycle 5 min; in X, Y and Z direction 30 G /11 ms. 10 shocks in X, Y and Z diIEC 60068-2-27 rection IP67 IEC 60529; EN 60947-1 Compatibility and conformity EMC protection MTTFd IEC 61000-4-2 Electrostatic dis- 8 kV air discharge charge 4 kV contact discharge IEC 61000-4-3 Radiated radiofre3 V/m quency IEC 61000-4-4 Burst immunity 2 kV IEC 61000-4-6 Conducted radio 3V frequency IEC 61000-4-8 Power frequency 30 A/m magnetic fields M8: 2813 years @ 50°C (122°F); M12: 750 years @ 50°C (122°F); M18, M30: 850 years @ 50°C (122°F) Approvals CCC is not required for products rated ≤ 36 V Mechanical data Weight (including 2 nuts) max. Mounting Material Max tightening torque 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Cable version: M8 49 g; M12 120 g; M18 150 g; M30 185 g Plug version: M8 19 g; M12 30 g; M18 70 g, M30 195 g Flush or non flush mountable ICB: Housing: Nickel-plated brass ICS: Housing: stainless steel AISI304 Front cap: Grey thermoplastic polyester ICS08: 7 Nm ICB12: 10 Nm ICB18 Non-flush version: 25 Nm; Flush version: from 0 to 7 mm: 20 Nm; > 7 mm: 25 Nm ICB30: 25 Nm Carlo Gavazzi Automation S.p.A. 9 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Electrical connection Cable Plug 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN ICS: 2m grey PVC, oil proof, laser write, 4x0.14mm2 ICB12 & ICB18: 2m, 4 x 0.25 mm2, Ø4.4 mm, PVC, grey, oil proof ICB30: 2m, 4 x 0.34 mm2, Ø5.2 mm, PVC, grey, oil proof ICS: M8 x 1, 4 pin, male connector ICB: M12 x 1, 4 pin, male connector Carlo Gavazzi Automation S.p.A. 10 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Connection Diagrams Colour code BN Brown 1BN 1BN 2WH 4BK 4BK 2WH 3BU 3BU Fig. 2 NPN Fig. 3 PNP WH White BK Black BU Blue Wire colors in accordance with EN 60947-5-2 4 3 2 1 Fig. 4 ICS 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN 4 1 3 2 Fig. 5 ICB Carlo Gavazzi Automation S.p.A. 11 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Dimensions ICS08 [mm] LED M8X1 M8X1 LED 3 30 31 Fig. 6 Short body, flush version, cable 30 34 Fig. 7 Short body, non-flush version, cable Ø2 LEDx4 M8X1 M8X1 Ø2 LEDx4 3 7 29 40 Fig. 8 Short body, flush version, plug 29 43 7 Fig. 9 Short body, non-flush version, plug LED M8X1 M8X1 LED 45 46 Fig. 10 Long body, flush version, cable 3 45 49 Fig. 11 Long body, non-flush version, cable Ø2 LEDx4 M8X1 M8X1 Ø2 LEDx4 44 55 7 Fig. 12 Long body, flush version, plug 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN 3 44 58 7 Fig. 13 Long body, non-flush version, plug Carlo Gavazzi Automation S.p.A. 12 ICS08, ICB12, ICB18 and ICB30 4-wire DC  ICB12 [mm] 7.5 M12x1 M12x1 7.5 30.0 14.3 4.0 30.0 14.3 50.8 46.8 Fig. 14 Short body, flush version, cable Fig. 15 Short body, non-flush version, cable 7.5 M12x1 M12x1 7.5 30.0 11.2 4.0 50.2 30.0 11.2 54.2 Fig. 16 Short body, flush version, plug Fig. 17 Short body, non-flush version, plug 7.5 M12x1 M12x1 7.5 50.0 4.0 50.0 70.8 66.8 Fig. 18 Long body, flush version, cable Fig. 19 Long body, non-flush version, cable 7.5 M12x1 M12x1 7.5 50.0 4.0 70.2 Fig. 20 Long body, flush version, plug 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN 50.0 74.2 Fig. 21 Long body, non-flush version, plug Carlo Gavazzi Automation S.p.A. 13 ICS08, ICB12, ICB18 and ICB30 4-wire DC  ICB18 [mm] 7.5 M18x1 M18x1 7.5 30.0 20.1 10.0 30.0 53.0 20.1 63.0 Fig. 22 Short body, flush version, cable Fig. 23 Short body, non-flush version, cable 7.5 M18x1 M18x1 7.5 30.0 10.0 54.0 30.0 64.0 Fig. 24 Short body, flush version, plug Fig. 25 Short body, non-flush version, plug 7.5 M18x1 M18x1 7.5 50.0 10.0 50.0 73.1 83.1 Fig. 26 Long body, flush version, cable Fig. 27 Long body, non-flush version, cable 7.5 M18x1 M18x1 7.5 50.0 10.0 74.0 Fig. 28 Long body, flush version, plug 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN 50.0 84.0 Fig. 29 Long body, non-flush version, plug Carlo Gavazzi Automation S.p.A. 14 ICS08, ICB12, ICB18 and ICB30 4-wire DC  ICB30 [mm] 59 M30x1.5 M30x1.5 71 30 12 10,6 Fig. 30 Short body, flush version, cable 30 10,6 Fig. 31 Short body, non-flush version, cable 67 M30x1.5 M30x1.5 55 30 12 9,8 Fig. 32 Short body, flush version, plug 30 9,8 Fig. 33 Short body, non-flush version, plug 79 M30x1.5 M30x1.5 91 10,6 50 12 Fig. 34 Long body, flush version, cable 10,6 50 Fig. 35 Long body, non-flush version, cable 87 M30x1.5 M30x1.5 75 50 9,8 Fig. 36 Long body, flush version, plug 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN 12 50 9,8 Fig. 37 Long body, non-flush version, plug Carlo Gavazzi Automation S.p.A. 15 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Installation M8, M12, M18 and M30 flush d ≥ 3 x Sn d d d ** Fig. 38 Flush sensor, when installed in damping material Fig. 39 Flush sensors, when installed together in damping material M8, M12 and M18 non-flush ≥ 2 x Sn ≥ 3 x Sn ≥3xd d ** Fig. 40 Non-flush sensor, when installed in damping material 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN d d 2xd d d Fig. 41 Non-flush sensors, when installed together in damping material Carlo Gavazzi Automation S.p.A. 16 ICS08, ICB12, ICB18 and ICB30 4-wire DC  M30 non-flush ≥ 2 x Sn ≥ 3 x Sn ≥4xd d d ** Fig. 42 Non-flush sensor, when installed in damping material d 4xd d d Fig. 43 Non-flush sensor, when installed together in damping material Sensors installed opposite each other ≥ 6 x Sn Fig. 44 For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed ** Free zone or non-damping material Sn: nominal sensing distance d : sensor diameter (8 mm for ICS08, 12 mm for ICB12, 18 mm for ICB18, 30 mm for ICB30) 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Carlo Gavazzi Automation S.p.A. 17 ICS08, ICB12, ICB18 and ICB30 4-wire DC  Delivery contents and compatible components Delivery contents • Inductive proximity switch • 2 nuts • Packaging: plastic bag CARLO GAVAZZI compatible components • Mounting bracket AMB... to be purchased separately • Connector type: CO..14NF... series to be purchased separately COPYRIGHT ©2019 Content subject to change. Download the PDF: www.productselection.net 14/03/2019 ICS08, ICB12, ICB18 and ICB30 4-wire DC DS EN Carlo Gavazzi Automation S.p.A. 18
ICB12S30F04NA 价格&库存
很抱歉,暂时无法提供与“ICB12S30F04NA”相匹配的价格&库存,您可以联系我们找货
