IA12DSF04DO
IA12DSF04DO
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 4MM CYLIND
IA12DSF04DO 数据手册
Proximity Sensors Inductive Extended Range, Nickel Plated Brass Housing Types IA, DC, M12, M18 and M30, 2-wire • • • • • • • • Product Description Proximity switch M12, M18 and M30 in nickel-plated brass housings. Made in Sensing distance: 4 to 22 mm Flush and non-flush types Power supply: 10 to 40 VDC Output: Transistor Make or break switching Protection: Reverse polarity, short-circuit and transients 2 m cable or plug M12 Diameter: M12, M18, M30 Ordering Key accordance with Euronorm EN 60 947-5-2. IA12ASF04DOM1 Cap. proximity switch Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection Type Selection Housing diameter Body style Connection Rated operating dist. (Sn) Ordering no. 2 wire DC Normally open Ordering no. 2 wire DC Normally closed M12 M12 M12 M12 Short Short Short Short Cable Plug Cable Plug 4 mm 1) 4 mm 1) 8 mm 2) 8 mm 2) IA 12 DSF 04 DO IA 12 ASF 04 DO M1 IA 12 DSN 08 DO IA 12 ASN 08 DO M1 IA 12 DSF 04 DC IA 12 ASF 04 DC M1 IA 12 DSN 08 DC IA 12 ASN 08 DC M1 M18 M18 M18 M18 Short Short Short Short Cable Plug Cable Plug 8 mm 1) 8 mm 1) 14 mm 2) 14 mm 2) IA 18 DSF 08 DO IA 18 ASF 08 DO M1 IA 18 DSN 14 DO IA 18 ASN 14 DO M1 IA 18 DSF 08 DC IA 18 ASF 08 DC M1 IA 18 DSN 14 DC IA 18 ASN 14 DC M1 M30 M30 M30 M30 Short Short Short Short Cable Plug Cable Plug 15 mm 1) 15 mm 1) 22 mm 2) 22 mm 2) IA 30 DSF 15 DO IA 30 ASF 15 DO M1 IA 30 DSN 22 DO IA 30 ASN 22 DO M1 IA 30 DSF 15 DC IA 30 ASF 15 DC M1 IA 30 DSN 22 DC IA 30 ASN 22 DC M1 1) 2) For flush mounting in metal For non-flush mounting in metal Specifications Rated operational volt. (Ue) (UB) Ripple Rated operational current (Ie) Continuous No-load supply current (I) Voltage drop (Ud) Protection 12 to 36 VDC 10 to 40 VDC (ripple included) ≤ 10% ≤ 5-100 mA ≤ 0.8 mA ≤ 3 VDC at max. load Reverse polarity, short-circuit, transients Specifications are subject to change without notice (06.06.05) Transient voltage EMC Power ON delay Frequency of operating cycles (f) ≤ 1 kV/0.5 J Approved according to EN 50 080, EN 50 081 < 50 ms IA12xSF 1000 Hz IA12xSN 800 Hz IA18xSF 500 Hz IA18xSN 400 Hz IA30xSF 400 Hz IA30xSN 200 Hz 1 IA, DC, M12, M18 and M30, 2-wire Specifications (cont.) Indication Repeat accuracy (R) Hysteresis (H) (Differential travel) Assured operating dist. (Sa) Effective operating dist. (Sr) Usable operating dist. (S) Ambient temperature Operating Storage Degree of protection Housing material Body Front Back Connection Cable LED, yellow ≤ 10% 1 to 20% of sensing distance 0 ≤ Sa ≤ 0.77 Sn 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.85 x Sr ≤ Su ≤ 1.15 x Sr 2 m, 2 x 0.5 mm2, grey PVC, oil proof M12 x 1 CONH1A serie IA 12xxx 20 g IA 18xxF 26 g IA 18xxN 30 g IA 30xxF 50 g IA 30xxN 80 g IA 12 (x) 7 Nm 15 Nm IA 18 27.5 Nm IA 30 50 Nm CSA, UL Yes Plug Cables for plug (-1) Weight (cable excluded) -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4, 6, 13) Tightening torque In nickel-plated brass Grey thermoplastic polyester Black polyester (cable) In nickel-plated brass (plug) Approvals CE-marking Dimensions Type A B C Ø mm mm D mm E mm IA 12 DSF 04 D. IA 12 ASF 04 D. M1 IA 12 DSN 08 D. IA 12 ASN 08 D. M1 M 12 x 1 x 38 M 12 x 1 x 38 M 12 x 1 x 38 M 12 x 1 x 38 10.7 10.7 10.7 10.7 38 38 42 42 11 25.2 11 25.2 5.0 IA 18 DSF 08 D. IA 18 ASF 08 D. M1 IA 18 DSN 14 D. IA 18 ASN 14 D. M1 M 18 x 1 x 30 M 18 x 1 x 30 M 18 x 1 x 30 M 18 x 1 x 30 16.7 16.7 16.7 16.7 30 30 38 38 11.6 25.0 11.6 25.0 15.4 IA 30 DSF 15 D. IA 30 ASF 15 D. M1 IA 30 DSN 22 D. IA 30 ASN 22 D. M1 M 30 x 1.5 x 30 M 30 x 1.5 x 30 M 30 x 1.5 x 30 M 30 x 1.5 x 30 28 28 28 28 30 30 42 42 13.6 25.0 13.6 25.0 15.4 C 5.0 15.4 15.4 F SW mm mm 4 4 4 4 17 17 17 17 4 4 4 4 24 24 24 24 5 5 5 5 36 36 36 36 C E D B B D F F Cable type SW LED A Plug type M12 x 1 x 9.5 LEDs SW A Wiring Diagrams “NPN” “PNP” 1 LOAD 4 BU- 1 DC 2-wire break switching (NC) 2 LOAD BU- BU- 1 BN+ DC 2-wire break switching (NC) BN+ LOAD DC 2-wire make switching (NO) 4 2 1 BN+ DC 2-wire make switching (NO) BN+ LOAD 2 BU- Specifications are subject to change without notice (06.06.05) IA, DC, M12, M18 and M30, 2-wire Power Supplies Power supplies VDC: > SS 130/140. Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Specifications are subject to change without notice (06.06.05) 3
IA12DSF04DO 价格&库存
很抱歉,暂时无法提供与“IA12DSF04DO”相匹配的价格&库存,您可以联系我们找货
