ICB12SF02NOM1
ICB12SF02NOM1
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 2MM CYLIND
ICB12SF02NOM1 数据手册
Proximity Inductive Sensors Standard range, Nickel-Plated Brass Housing Types ICB, M12 • • • • • • • • • • • • Sensing distance: 2 mm Flush type Short and long body versions Rated operational voltage (Ub): 10 - 36 VDC Output: DC 200 mA, NPN or PNP Normally open, Normally closed LED indication for output ON Protection: reverse polarity, short circuit, transients Cable and M12 plug versions According to IEC 60947-5-2 Higher resistance to magnetic field CSA certified for Hazardous Locations Product Description Ordering Key A family of inductive proximity switches in industrial standard nickel-plated brass housings. They are able to handle applications where Type Housing style Housing material Housing size Housing length Detection principle Sensing distance Output type Output configuration Connection high sensing range is requested. Output is open collector NPN or PNP transistors. ICB12SF02NOM1 Type Selection Connection Body style Rated operating distance Sn Ordering no. NPN Normally open Ordering no. PNP Normally open Ordering no. NPN Normally closed Ordering no. PNP Normally closed Cable Plug Cable Plug Short Short Long Long 2 mm 2 mm 2 mm 2 mm ICB 12 SF 02 NO ICB 12 SF 02 NOM1 ICB 12 LF 02 NO ICB 12 LF 02 NOM1 ICB 12 SF 02 PO ICB 12 SF 02 POM1 ICB 12 LF 02 PO ICB 12 LF 02 POM1 ICB 12 SF 02 NC ICB 12 SF 02 NCM1 ICB 12 LF 02 NC ICB 12 LF 02 NCM1 ICB 12 SF 02 PC ICB 12 SF 02 PCM1 ICB 12 LF 02 PC ICB 12 LF 02 PCM1 Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% ≤ 200 mA @ 50°C Output current (Ie) (≤ 150 mA @ 50-70°C) OFF-state current (Ir) ≤ 50 µA No load supply current (IO) ≤ 15 mA Voltage drop (Ud) Max. 2.5 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) 300 ms Operating frequency (f) ≤ 2000 Hz Indication for output ON Activated LED, yellow NO version Target present NC version Target not present Specifications are subject to change without notice (18.01.2017) Indication for short circuit/ overload Assured operating sensing distance (Sa) Effective operating distance (Sr) Usable operating distance (Su) Repeat accuracy (R) Differential travel (H) (Hysteresis) Ambient temperature Operating Storage Shock and vibration Housing material Body Front LED blinking 0 ≤ Sa ≤ 0.81 x Sn 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr ≤ 10% 1 to 20% of sensing dist. -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IEC 60947-5-2/7.4 Nickel-plated brass Grey thermoplastic polyester 1 ICB, M12 Specifications (cont.) Approvals (cont.) Connection Cable Plug Degree of protection Weight (cable/nuts included) Cable Plug Dimensions Tightening torque Distance from sensing face from 2 mm to 5 mm > 5 mm Approvals UL (CULUS), CSA 2 m, 3 x 0.25 mm2, grey PVC, oil proof M12 x 1 IP 67 CCSAUS Note: The terminal connector (version ...M1) was not evaluated. The suitability of the terminal connector should be determined in the end-use application. Max. 120 g Max. 30 g See diagrams below 4 Nm 10 Nm As Industrial Control Equipment - Proximity Switches. Types 1, 4, 4X or 12. Max ambient temperature 40°C. CE-marking EMC protection IEC 61000-4-2 (ESD) IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-6 IEC 61000-4-8 As Process Control Equipment for Hazardous Locations. - Class I, Division 2, Groups A, B, C and D. - T5, Enclosure Type 4. Ambient temperature Ta: -25° to +60°C. CCC is not required for products with a maximum operating voltage of ≤ 36 V Yes According to IEC 60947-5-2 8 KV air discharge, 4 KV contact discharge 3 V/m 2 kV 3V 30 A/m Dimensions 65 50 1 7.5 7.5 32 1 47 LED LED Short body, flush version, cable Long body, flush version, cable 51 1 66 30 11 4 3 1 2 1 45 LED Short body, flush version, plug 2 LED 4 3 1 2 11 Long body, flush version, plug Specifications are subject to change without notice (18.01.2017) ICB, M12 Installation Flush sensor, when installed in damping material, must be according to Picture 1A. Picture 1A Flush sensors, when installed together in damping material, must be according to Picture 2A. Picture 2A d d d Free zone or nondamping material ≥ 3 x Sn Sn : nominal sensing distance d : sensor diameter d : sensor diameter For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 6 x Sn Sn : nominal sensing distance Wiring Diagrams 1 BN + 1 BN + 1 BN + 1 BN + 4 BK 2 BK 2 BK 4 BK 3 BU - NPN - Normally open 3 BU NPN - Normally closed Specifications are subject to change without notice (18.01.2017) 3 BU 3 BU PNP - Normally open PNP - Normally closed 3 ICB, M12 Reduction factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 Accessories for Plug Versions The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance Delivery Contents • • • 4 Inductive proximity switch ICB. 2 nuts NPB Packaging: plastic bag PVC 3-wire angled connector, 2 m cable CONB13NF-A2 3-wire angled connector, 5 m cable CONB13NF-A5 3-wire angled connector, 10 m cable CONB13NF-A10 3-wire angled connector, 15 m cable CONB13NF-A15 3-wire straight connector, 2m cable CONB13NF-S2 3-wire straight connector, 5m cable CONB13NF-S5 3-wire straight connector, 10m cable CONB13NF-S10 3-wire straight connector, 15m cable CONB13NF-S15 PUR CONB13NF-A2P CONB13NF-A5P CONB13NF-A10P CONB13NF-A15P CONB13NF-S2P CONB13NF-S5P CONB13NF-S10P CONB13NF-S15P For any additional information or different options, please refer to the “General Accessories Connector Cables -Type CONB1...” datasheets. Specifications are subject to change without notice (18.01.2017)
ICB12SF02NOM1 价格&库存
很抱歉,暂时无法提供与“ICB12SF02NOM1”相匹配的价格&库存,您可以联系我们找货
