NJ1.5-PD-E02-1.250-V95
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN CYLINDER POSITION
NJ1.5-PD-E02-1.250-V95 数据手册
Inductive sensor NJ1.5-PD-E02-1.250-V95 < < < < 4-wire DC Weld Immune Sensing range 1.5 mm 3000 psi rating Proximity switch Dimensions LEDs Ø48 35 2 x Ø6.5 Ø31.75 7/8"-16 Ø25 37.5 26.5 34.5 15.06 Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904455_eng.pdf "X" Ø12.7 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP/NPN sn Installation flush Output polarity Assured operating distance 1.5 mm DC sa 0 ... 1.21 mm Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ1.5-PD-E02-1.250-V95 Technical Data Reduction factor rAl 0.4 Reduction factor r304 0.85 Nominal ratings Operating voltage UB 10 ... 30 V DC Switching frequency f 30 Hz Hysteresis H 10 ... 20 typ. 15 % Reverse polarity protection yes Short-circuit protection yes Voltage drop Ud Operating current IL Off-state current Ir No-load supply current I0 ≤ 2 V DC ≤ 200 mA ≤ 100 µA ≤ 35 mA Mag. Field strength, AC fields 250 mT Mag. Field strength, DC fields 100 mT Limit data Operating pressure dynamically 3000 psi Indicators/operating means LED green Power on LED yellow Output status Standard conformity Standards EN 60947-5-2 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector 7/8"-16 UN , 5-pin Degree of protection IP67 Material Housing: zinc Probe: aluminum Note X = 1.250 in (31.8 mm) Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904455_eng.pdf Connection 1 L+ 2 4 5 L- Connection Assignment 1 5 2 4 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NJ1.5-PD-E02-1.250-V95 Wire colors 1 2 4 5 WH RD OR BK Additional Information NPT Type Mounting Holes: 1000 and 3000 psi NPT Types: Mounting hole screw thread shall be 1/4" - 20. Minimum thread engagement depth is 0.250" (6.35 mm) Hole spacing is 35 mm center to center. Sensor through-hole Mounting hole (x2) Mounting hole spacing Cylinder End-Cap Overhead View Mounting Screws: Standard 1000 and 3000 psi models use two, self-locking 1/4"- 20 socket head cap screws (provided). Recommended tightening torque: 150 in lb (16.95 N-m). Release date: 2020-03-24 Date of issue: 2020-03-30 Filename: 904455_eng.pdf Important: When using spacers, make certain to maintain the 0.250" (6.35 mm) minimum mounting screw thread engagement. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NJ1.5-PD-E02-1.250-V95 价格&库存
很抱歉,暂时无法提供与“NJ1.5-PD-E02-1.250-V95”相匹配的价格&库存,您可以联系我们找货
