CCN15-30GS60-E2-V1
CCN15-30GS60-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M30
    CAPACITIVE SEN 15MM PNP
CCN15-30GS60-E2-V1 数据手册
Capacitive sensor CCN15-30GS60-E2-V1 < < < < < 15 mm non-flush Operating distance adjustable via potentiometer High EMC resistance Stainless steel version Operating voltage range 10 V ... 60 V DC Dimensions M30 x 1.5 72.5 5 60 18 ø 27.7 36 LED M12 x 1 Technical Data Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 189963_eng.pdf General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation non-flush Output polarity Assured operating distance 15 mm DC sa Output type 0 ... 12.1 mm 3-wire Nominal ratings Installation conditions A 18 mm B 10 mm C 30 mm F 60 mm Operating voltage UB 10 ... 60 V DC Switching frequency f 0 ... 10 Hz Reverse polarity protection reverse polarity protected Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Capacitive sensor CCN15-30GS60-E2-V1 Technical Data Short-circuit protection pulsing Voltage drop Ud ≤ 2.8 V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA typ. 0.1 µA at 25 °C Off-state current TU =40 °C, switching element off ≤ 100 µA No-load supply current I0 ≤ 20 mA Time delay before availability tv ≤ 50 ms Switching state indicator LED, yellow Functional safety related parameters MTTFd 759 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Potentiometer sensitivity adjustment Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -40 ... 85 °C (-40 ... 185 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face PBT Degree of protection IP67 Connection 1 L+ Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 189963_eng.pdf 4 3 L- Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Capacitive sensor CCN15-30GS60-E2-V1 Wire colors in accordance with EN 60947-5-2 1 3 4 BN BU BK (brown) (blue) (black) Installation B F A sensing face C metal-free zone support Accessories Mounting flange, 30 mm V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 189963_eng.pdf BF 30 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
CCN15-30GS60-E2-V1 价格&库存
很抱歉,暂时无法提供与“CCN15-30GS60-E2-V1”相匹配的价格&库存,您可以联系我们找货
