EI5515NPAP
EI5515NPAP
    CARLOGAVAZZI
    Module
    SENSOR PROX INDUCTIVE 15MM MOD
EI5515NPAP 数据手册
Proximity Sensors Inductive Flat pack Polycarbonate Housing Types EI 5510/EI 5515, DC-Types • Sensing distance 10 or 15 mm • Flush and non-flush types • Rated operational voltage: 10 to 40 VDC • Output: DC 200 mA, NPN or PNP • Normally open and normally closed function • LED indication for output ON • Inductive, Capacitive and Photoelectric flat pack series in PC housing, IP 67 • Cable and plug versions Product Description Inductive proximity switch with sensing distance 10 mm flush mounted in metal or 15 mm non-flush mounted. 4-wire with both make (NO) and break (NC) switching. Flat pack housing size Ordering Key (W x H x D) 35 x 55 x 15 mm made in polycarbonate. Easy mounting with only two M 3.5 screws. Ideal for use in conveying and material handling applications. EI 55 10 NPA P-1 Type Housing Range Output type Housing material Connection type Type Selection Housing diameter WxHxD Rated operating dist. (Sn) Ordering no. NPN/cable NO & NC Ordering no. NPN/plug NO & NC Ordering no. PNP/cable NO & NC Ordering no. PNP/plug NO & NC 35 x 55 x 15 mm 35 x 55 x 15 mm 10 mm 1) 15 mm 2) EI 5510 NPAP EI 5515 NPAP EI 5510 NPAP-1 EI 5515 NPAP-1 EI 5510 PPAP EI 5515 PPAP EI 5510 PPAP-1 EI 5515 PPAP-1 1) 2) For flush mounting in metal For non-flush mounting in metal Specifications Rated operational volt. (Ue) (UB) Ripple Rated operational current (Ie) Continuous No-load supply current (Io) Voltage drop (Ud) Protection Power ON delay Frequency of operating cycles (f) EI 5510 EI 5515 Indication for output ON Assured operating dist. (Sa) Repeat accuracy (R) Hysteresis (H) (Differential travel) Effective operating dist. (Sr) Usable operating dist. (Su) 12 to 36 VDC 10 to 40 VDC (ripple included) ≤ 10% ≤ 200 mA ≤ 7 mA ≤ 2 VDC at max. load Reverse polarity, short-circuit ≤ 50 ms 500 Hz 250 Hz LED, yellow 0 ≤ Sa ≤ 0.81 Sn ≤ 5% 1 to 15% of sensing distance 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr Specifications are subject to change without notice (17.01.14) Ambient temperature Operating Storage Degree of protection Housing Dimensions Material Cable -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4 ,6, 13) 35 x 55 x 15 mm Polycarbonate, grey 2 m, 4 x 0.3 mm2 grey PVC, oil proof Weight Cable version 125 g Plug version 40 g EMC ratings Acc. to EN 50 082-2 ENV 50 140 RF Electromagnetic field AM, 80-1000 MHz, Level 3 10 V/m ENV 50 204 RF Electromagnetic field PM, 80-900 MHz, Level 3 10 V/m EN 61000-4-4 Fast transient Rep. freq. 5 kHz, Level 3 1 kV Approvals UL, CSA CE-marking Yes 1 EI 5510/EI 5515 Dimensions LED EI 551. .PAP EI 551. .PAP-1 LED Wiring Diagrams 1 BN 1 BN 4 BK 2 WH 2 WH 4 BK 3 BU NPN PNP 3 BU Installation Hints Relief of cable strain To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Accessories Delivery Contents • Plugs CONH1A.. series, please refer to "Accessories". • Inductive switch: EI 551. .... • Packaging: plastic bag 2 Specifications are subject to change without notice (17.01.14)
EI5515NPAP 价格&库存
很抱歉,暂时无法提供与“EI5515NPAP”相匹配的价格&库存,您可以联系我们找货
EI5515NPAP
  • 10+1438.9663810+179.81282
