NEB8-12GM50-E2-V1
NEB8-12GM50-E2-V1
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 8.8MM PNP
NEB8-12GM50-E2-V1 数据手册
Inductive sensor NEB8-12GM50-E2-V1 < Increased operating distance < 8 mm quasi flush Dimensions 60 41 17 49 4 M12 x 1 ø 10.5 8 LED (4x) Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 212697_eng.pdf M12 x 1 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance PNP sn Installation quasi flush Output polarity Assured operating distance 8 mm DC sa 0 ... 6.48 mm Reduction factor rAl 0.3 Reduction factor rCu 0.25 Reduction factor r304 0.7 Reduction factor rSt37 1 Nominal ratings Installation conditions Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NEB8-12GM50-E2-V1 Technical Data A 2 mm B 14 mm C 24 mm F 46 mm Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 400 Hz Hysteresis H ≤ 10 % Reverse polarity protection reverse polarity protected Short-circuit protection yes Voltage drop Ud ≤2V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.1 mA typ. 0.1 µA at 25 °C No-load supply current I0 ≤ 10 mA Switching state indicator LED, yellow Functional safety related parameters MTTFd 602 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector M12 x 1 , 4-pin Housing material chromium plated brass Sensing face PBT Degree of protection IP67 Protection class II Mass 34 g Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 212697_eng.pdf Connection 1 L+ 4 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NEB8-12GM50-E2-V1 Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Installation B F A sensing face C metal-free zone support Accessories Mounting flange, 12 mm V1-G-2M-PUR Female cordset, M12, 4-pin, PUR cable V1-W-2M-PUR Female cordset, M12, 4-pin, PUR cable Release date: 2020-03-23 Date of issue: 2020-03-30 Filename: 212697_eng.pdf BF 12 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NEB8-12GM50-E2-V1 价格&库存
很抱歉,暂时无法提供与“NEB8-12GM50-E2-V1”相匹配的价格&库存,您可以联系我们找货
