ICS12LN04NOM1-FB
ICS12LN04NOM1-FB
    CARLOGAVAZZI
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 4MM CYLIND
ICS12LN04NOM1-FB 数据手册
ICS, IP69K, M12 Proximity Inductive Sensors - Ecolab certified Standard and Extended Range, Stainless Steel Housing Types ICS, IP69K, M12 • Sensing distance: 2 to 8 mm • Flush or non-flush mountable • Long body version • Rated operational voltage (Ub): 10 - 36 VDC • Output: DC 200 mA, NPN or PNP • Normally open or normally closed • 4 x 90° LED indication for output ON, short-circuit and overload • Protection: reverse polarity, short circuit, transients • M12 plug version • According to IEC 60947-5-2 • High-pressure washdown resistant • Ecolab certified, FDA-certified plastic • Laser engraved on the housing, permanently legible • Extended temperature range: -40°C...+80°C • CSA certified for Hazardous Locations Product Description A family of inductive proximity switches in stainless steel (AISI 316L) ideal for food and beverage applications where sensors are exposed to high pressure and high temperature cleaning processes. Ordering Key They are fully sealed and resistant to all common acid and alkaline cleaning agents and disinfectants (Ecolab certified). IP68 and IP69K-rated products. Output is open collector NPN or PNP transistors. Type Housing style Housing material Housing size Housing length Detection principle Sensing distance Output type Output configuration Connection Washdown series ICS12LF04NOM1-FB Type Selection Connec- Body tion style Rated operating distance Sn Ordering no. NPN, Normally open Standard range Plug Long Plug Long 2 mm 1) 4 mm 2) ICS12LF02NOM1-FB ICS12LF02POM1-FB ICS12LF02NCM1-FB ICS12LF02PCM1-FB ICS12LN04NOM1-FB ICS12LN04POM1-FB ICS12LN04NCM1-FB ICS12LN04PCM1-FB Extended range Plug Long Plug Long 4 mm 1) 8 mm 2) ICS12LF04NOM1-FB ICS12LF04POM1-FB ICS12LF04NCM1-FB ICS12LF04PCM1-FB ICS12LN08NOM1-FB ICS12LN08POM1-FB ICS12LN08NCM1-FB ICS12LN08PCM1-FB 1) For flush mounting in metal 2) Ordering no. PNP, Normally open Ordering no. NPN, Normally closed Ordering no. PNP, Normally closed For non-flush mounting in metal Specifications Rated operational voltage (Ub) 10 to 36 VDC (ripple incl.) Ripple ≤ 10% Output current (Ie) ≤ 200 mA @ 50°C (≤ 150 mA @ 50-80°C) OFF-state current (Ir) ≤ 10 μA No load supply current (Io) ≤ 15 mA Voltage drop (Ud) Max. 2 VDC @ 200 mA Protection Reverse polarity, short-circuit, transients Voltage transient 1 kV/0.5 J Power ON delay (tv) ≤ 20 ms Operating frequency (f) ≤ 2000 Hz Specifications are subject to change without notice (10.01.17) Indication for output ON Activated LED, yellow (4x90°) NO version Target present NC version Target not present Indication for short circuit/ overload LED blinking (f = 2 Hz) Assured operating sensing distance (Sa) 0 ≤ Sa ≤ 0.81 x Sn Effective operating distance (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn Usable operating distance (Su) 0.9 x Sr ≤ Su ≤ 1.1 x Sr Repeat accuracy (R) ≤ 5% Differential travel (H) (Hysteresis) 1 to 20% of sensing dist. 1 ICS, IP69K, M12 Specifications (cont.) Ambient temperature Operating -40° to +80°C (-40° to +176°F) short exposure (15’) to 100°C during cleaning process Storage -40° to +80°C (-40° to +176°F) Shock and vibration IEC 60947-5-2/7.4 Housing material Body Stainless steel (AISI 316L) Front Grey PPS - FDA-certified Connection Plug M12 x 1 Degree of protection IP67, IP68 (1 m, 7 days), IP69K Weight (cable/nuts included) Max. 35 g Dimensions See diagrams below Tightening torque 25 Nm Approvals cULus (UL508) cCSAus Note: The terminal connector (version ...M1) was not evaluated. The suitability of the terminal connector should be determined in the end-use application. EMC protection IEC 61000-4-2 (ESD) IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-6 IEC 61000-4-8 MTTFd As Process Control Equipment for Hazardous Locations. - Class I, Division 2, Groups A, B, C and D. - T5, Enclosure Type 4. Ambient temperature Ta: -25° to +60°C CCC is not required for products with a maximum operating voltage of ≤ 36 V According to IEC 60947-5-2 8 KV air discharge, 4 KV contact discharge 3 V/m 2 kV 3V 30 A/m 770 years @ 50°C (122°F) Dimensions (mm) 64.8 64.8 38.7 6.2 9.6 6.2 10.3 32.5 6.2 9.6 10.3 4 3 4 3 1 2 1 2 LED (4 x 90°) LED (4 x 90°) Flush version Non-flush version Installation Flush mountable proximity switches, when installed in damping material, must be according to Picture 1A. Picture 1A Picture 1B d Free zone or non-damping material ≥3xd d ≥ 3 x Sn Free zone or non-damping material ** ≥ 3 x Sn Non-flush mountable proximity switches, when installed in damping material, must be according to Picture 1B. Sn : nominal sensing distance d : sensor diameter (12 mm) 2 Sn : nominal sensing distance d : sensor diameter (12 mm) ** ≥ 6 mm, Sn = 4 mm (1x) ≥ 12 mm, Sn = 8 mm (2x) Specifications are subject to change without notice (10.01.17) ICS, IP69K, M12 Installation (cont.) Flush mountable proximity switches, when installed together in damping material, must be according to Picture 2A. Picture 2A Non-flush mountable proximity switches, when installed together in damping material, must be according to Picture 2B. Picture 2B d d d d d : sensor diameter (12 mm) d 2xd d d d : sensor diameter (12 mm) For sensors installed opposite each other, a minimum space of 6 x Sn (the nominal sensing distance) must be observed (See Picture 3). Picture 3 ≥ 6 x Sn Sn : nominal sensing distance Wiring Diagram 1 + 1 + 1 + 1 + 4 2 2 4 3 NPN - Normally open - 3 - NPN - Normally closed Specifications are subject to change without notice (10.01.17) 3 PNP - Normally open - 3 - PNP - Normally closed 3 ICS, IP69K, M12 Reduction Factors The rated operating distance is reduced by the use of metals and alloys other than Fe360. Picture 4 IP69K Connector Cables The most important reduction factors for inductive proximity sensors are shown in Picture 4. Fe360 : Steel CrNi : Chrome-nickel CuZn : Brass Al : Aluminium Cu : Copper Sr : Effective operating distance 4-wire angled connector, 2 m cable 4-wire angled connector, 5 m cable 4-wire straight connector, 2 m cable 4-wire straight connector, 5 m cable CONB14NF-A2W CONB14NF-A5W CONB14NF-S2W CONB14NF-S5W For any additional information or different options, please refer to the “General Accessories” datasheets. Delivery Contents • Inductive proximity switch ICS. • 2 nuts stainless steel • Packaging: plastic bag 4 Specifications are subject to change without notice (10.01.17)
ICS12LN04NOM1-FB 价格&库存
很抱歉,暂时无法提供与“ICS12LN04NOM1-FB”相匹配的价格&库存,您可以联系我们找货
