NJ4-12GM50-WS-V12
NJ4-12GM50-WS-V12
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 4MM NO
NJ4-12GM50-WS-V12 数据手册
Inductive sensor NJ4-12GM50-WS-V12 < 2-wire AC Dimensions 60 38 4 5 M12x1 17 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 026583_eng.pdf LED Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn Installation non-flush Output polarity Assured operating distance 4 mm AC sa 0 ... 3.24 mm Reduction factor rAl 0.4 Reduction factor rCu 0.4 Reduction factor r304 0.7 Output type 2-wire Nominal ratings Operating voltage UB 20 ... 253 V Switching frequency f 0 ... 20 Hz Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NJ4-12GM50-WS-V12 Technical Data Voltage drop Ud Momentary current (20 ms, 0.1 Hz) typ. 4 V at 15 ... 200 mA typ. 6.5 V at 5 mA 0 ... 1200 mA Operating current IL 5 ... 200 mA Off-state current Ir typ. 0.7 mA Time delay before availability tv ≤ 30 ms Switching state indicator LED, yellow Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug 1/2"-20 UN , 3-pin Housing material Stainless steel 1.4305 / AISI 303 Sensing face PBT Degree of protection IP67 Note 1) In the temperature range below 0 °C, permissible operating voltage Ub 80...253 V Safety fuse ≤ 0.8 A (quick-blow) according to IEC 60127-2 Sheet 1 Recommendation: after a short circuit, check that the device is functioning correctly. General information Scope of delivery 2 self locking nuts in scope of delivery Connection 2 L 3 N Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 026583_eng.pdf 1 Connection Assignment 1 2 3 Wire colors 1 2 3 GN (green) RD/BK (red/black) RD/WH (red/white) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NJ4-12GM50-WS-V12 Accessories Mounting flange, 12 mm Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 026583_eng.pdf BF 12 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NJ4-12GM50-WS-V12 价格&库存
很抱歉,暂时无法提供与“NJ4-12GM50-WS-V12”相匹配的价格&库存,您可以联系我们找货
