NBB4-12GM65-US-V12
NBB4-12GM65-US-V12
    PEPPERL+FUCHS(倍加福)
    Cylinder,Threaded-M12
    INDUCTIVE SEN 4MM NO
NBB4-12GM65-US-V12 数据手册
Inductive sensor NBB4-12GM65-US-V12 < 4 mm flush < 2-wire AC/DC Dimensions 65 LEDs 74 82 53.5 17 58.5 4 M12 x 1 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 197867_eng.pdf 1/2-20 UNF 2A Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance Two-wire sn 4 mm Installation flush Output polarity AC/DC Reduction factor rAl 0.5 Reduction factor rCu 0.45 Reduction factor r304 0.75 Output type 2-wire Nominal ratings Operating voltage UB 20 ... 250 V AC/20 ... 300 V DC Switching frequency f 30 Hz Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBB4-12GM65-US-V12 Technical Data Hysteresis H Reverse polarity protection 3 ... 15 typ. 5 % reverse polarity tolerant Short-circuit protection yes Voltage drop Ud ≤8V Operating current IL 8 ... 200 mA AC/DC Off-state current Ir ≤ 0.8 mA Operating voltage indicator LED, green Switching state indicator LED, yellow Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 IEC 60947-5-2:2007 Approvals and certificates UL approval cULus Listed, General Purpose CSA approval cCSAus Listed, General Purpose CCC approval Certified by China Compulsory Certification (CCC) Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug 1/2"-20 UN , 3-pin Housing material brass, nickel-plated Sensing face PBT Degree of protection IP67 General information Scope of delivery 2 self locking nuts in scope of delivery Connection 2 AC/DC 3 1 Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 197867_eng.pdf Connection Assignment 1 2 3 Wire colors 1 2 3 GN (green) RD/BK (red/black) RD/WH (red/white) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBB4-12GM65-US-V12 Accessories Quick mounting bracket with dead stop V12-G-YE2M-PVC Connecting cable, 1/2" - 20 UNF, 3-pin, PVC cable Release date: 2020-12-10 Date of issue: 2020-12-10 Filename: 197867_eng.pdf EXG-12 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBB4-12GM65-US-V12 价格&库存
很抱歉,暂时无法提供与“NBB4-12GM65-US-V12”相匹配的价格&库存,您可以联系我们找货
