Proximity Sensors Capacitive
LD™
E
I
Thermoplastic Polyester Housing
SH
PLE
I
R
T
Type CA, M18, AC
• Featuring TRIPLESHIELD™ sensor protection
• Rated operational voltage: 20-250 VAC
• Adjustable sensing distance 3-8 mm or 3-12 mm
• Output: SCR
• Make or break switching function
• LED indication
• High noise immunity
• Flush and non-flush types
• Plug and cable versions
• DC versions in the same housing
Product Description
Ordering Key
Capacitive proximity switches
with either sensing distance
8 mm flush mounted in metal
or sensing distance 12 mm
non-flush mounted. 2-wire AC
output with make (NO) or bre-
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection type
ak (NC) switch
ing. Grey M18
polyester housing with 2 m
PVC cable or M12 plug. Ideal
for use in level and plas
tic
machinery applications.
CA18CLN12TOM6
Type Selection
Housing Rated
Mounting
diameter operating
dist. (Sn) 1)
M18
M18
8 mm
12 mm
Ordering no.
SCR/cable
Make
switching
Flush (built-in) CA18CLF08TO
Non-flush
CA18CLN12TO
Ordering no.
SCR/plug
Make
switching
Ordering no.
SCR/cable
Break
switching
Ordering no.
SCR/plug
Break
switching
CA18CLF08TOM6 CA18CLF08TC
CA18CLN12TOM6 CA18CLN12TC
CA18CLF08TCM6
CA18CLN12TCM6
1)
Object: Grounded steel plate
Specifications
Rated operating dist. (Sn)
CA18CLF08
3 to 8 mm
factory set at 8 mm
CA18CLN12
3 to 12 mm
factory set at 12 mm
Sensitivity
Adj. 270° turn pot. meter
Effective operation dist. (Sr) 0.9 x Sn ≤ Sr ≤ 1.1 x Sn
Usable operation dist. (Su)
0.8 x Sr ≤ Su ≤ 1.2 x Sr
Repeat accuracy (R)
≤ 5%
Hysteresis (H)
4 to 20% of sensing distance
Rated operational volt. (UB) 20 to 250 VAC (ripple incl.)
Ripple
≤ 10%
Rated operational current (Ie)
Continuous
≤ 500 mA
Short-time
< 2.5 A (max. 20 ms)
Min. load current
10 mA
Voltage drop (Ud)
≤ 10 VAC (at loads ≥ 20 mA)
Protection
Transients
Power ON delay
≤ 100 ms
Freq. of operating cycles (f) 10 Hz
Specifications are subject to change without notice (17.08.2018)
Indication for output ON
Environment
Degree of protection
Temperature
Operating temperature
Storage temperature
Housing material
Body
Front
Cable end
Nuts
Connection
Cable
LED, yellow
IP 67 (Nema 1, 3, 4, 6, 13)
-25° to +80°C ( -13° to +176°F)
-40° to +85°C (-40° to +185°F)
Grey, thermoplastic polyester
Grey, polyester
Polyester
Black, reinforced nylon
Grey, 2 m, 2 x 0.5 mm2
Oil proof PVC
M12 x 1, double keyed
CON.6A-series
Plug (M6)
Cable for plug (M6)
Weight
Cable version
Plug version
Approvals
CE-marking
110 g
30 g
UL, CSA
Yes
1
EC, M18, AC
Dimensions
Wiring Diagrams
1)
1)
BU (2)
BU (2)
BN (3)
BN (3)
1
2
3
M12 x 1
CA18CLxxxTC
1) Note: Only CA18CLN
CA18CLxxxTO
Adjustment Guide
The environments in which
capacitive sensors are install
ed can often be unstable re
garding temperature, humidity,
object distance and industrial
(noise) interference. Because
of this, Carlo Ga
vazzi offers
as standard features in all
TRIPLESHIELD™ capacitive
sensors a user-friendly sensitivity adjustment instead of
having a fixed sensing range,
extend
ed sen
sing range to
accommodate mechanically
demanding areas, temperature stability to ensure minimum
need for adjusting sensitivity
if temperature varies and high
immunity to electromagnetic
interference (EMI).
CA18CL...
Max.
Min.
Note:
Sensors are factory set (default) to maximum rated sensing range.
Sensitivity
Installation Hints
Capacitive sensors have the
unique ability to detect al
most all materials, either in li
quid or solid form. Capacitive
sensors can detect metallic
as well as non-metallic ob
jects, how
ever, their traditional use is for non-metallic
materials such as:
• Plastic Industry
Resins, regrinds or moulded products.
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
• Chemical Industry
Cleansers, fertilisers, liquid
soaps, corrosives and petrochemicals.
• Wood Industry
Saw dust, paper products,
door and window frames.
• Ceramic & Glass
Industry
Raw material, clay or finish
ed products, bottles.
Relief of cable strain
• Packaging Industry Package inspection for level or
contents, dry goods, fruits
and vegetables, dairy products.
Materials are detected due
to their dielectric constant.
The bigger the size of an
object, the higher the density of material, the better
or easier it is to detect the
object. Nominal sensing di
stan
ce for a capacitive sensor is referenced to a grounded me
tal plate (ST37).
For addi
tional information
regarding dielectric ratings
of materials please re
fer to
Technical Information.
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
2
EC, M18, AC
Delivery Contents
Accessories
• Capacitive switch: CA18CL...
• Screw driver
• 2 nuts
• Packaging: Cardboard box
• Installation & Adjustment Guide
• Plugs CON.6A-..series.
3
很抱歉,暂时无法提供与“CA18CLN12TO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2463.015541+307.93095
- 5+2339.867855+292.53479
- 10+2265.9856210+283.29789
- 25+2192.0972125+274.06022
