NBN30-U4-A2
NBN30-U4-A2
    PEPPERL+FUCHS(倍加福)
    Module
    INDUCTIVE SEN 30MM PNP
NBN30-U4-A2 数据手册
Inductive sensor NBN30-U4-A2 < Sensor head bidirectional and rotatable < 30 mm non-flush < 4 LEDs indicator for 360° visibility Dimensions ½ NPT” 40 LED ye LED gn 118 46 60 40 5.3 Release date: 2020-07-28 Date of issue: 2020-07-28 Filename: 203080_eng.pdf 30 LED gn LED ye Technical Data General specifications Switching function complementary Output type PNP Rated operating distance sn 30 mm Installation non-flush Output polarity DC Assured operating distance sa 0 ... 24.3 mm Reduction factor rAl 0.33 Reduction factor rCu 0.31 Reduction factor r304 0.74 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Inductive sensor NBN30-U4-A2 Technical Data Reduction factor rBrass 0.38 Output type 4-wire Nominal ratings Operating voltage UB 10 ... 30 V Switching frequency f 0 ... 230 Hz Hysteresis H typ. 5 % Reverse polarity protection reverse polarity protected Short-circuit protection pulsing Voltage drop Ud ≤2V Operating current IL 0 ... 200 mA Off-state current Ir 0 ... 0.5 mA No-load supply current I0 ≤ 20 mA Time delay before availability tv 80 ms Operating voltage indicator LED, green Switching state indicator LED, yellow Functional safety related parameters MTTFd 1230 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates UL approval cULus Listed, General Purpose CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 85 °C (-13 ... 185 °F) Release date: 2020-07-28 Date of issue: 2020-07-28 Filename: 203080_eng.pdf Mechanical specifications Connection type screw terminals Core cross-section max. 2.5 mm2 Housing material PA/metal with epoxy powder coating Sensing face PA Housing base metal Degree of protection IP68 / IP69K Mass 225 g Note Tightening torque: 1.8 Nm (housing) Connection 1 L+ 4 2 3 L- Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Inductive sensor NBN30-U4-A2 Accessories Modular mounting bracket Release date: 2020-07-28 Date of issue: 2020-07-28 Filename: 203080_eng.pdf MHW 01 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
NBN30-U4-A2 价格&库存
很抱歉,暂时无法提供与“NBN30-U4-A2”相匹配的价格&库存,您可以联系我们找货
