CA30CLN12MV10M
CA30CLN12MV10M
    CARLOGAVAZZI
    Cylinder,Threaded-M30
    SENSOR PROX CAPACITIVE 12MM CYL
CA30CLN12MV10M 数据手册
Proximity Sensors Capacitive Thermoplastic Polyester Types CA30CLN12Mxxxx • Level sensor for solid, fluid or granulated substances • Adjustable sensing distance: 4-12 mm • Multi voltage supply: 20.4 to 255 VAC/DC • SPDT relay output • Time delay on operate or release • Time delay options up to 10 minutes • CA30..MU/CA30..MV: With adjustable time delay • CA30CLN12MT: Without time delay • Cable versions Product Description Ordering Key Capacitive sensor in M30 thermoplastic polyester housing for mounting with 2 nuts. Available with adjustable sensing distance and with/­ without built-in time Type Time delay options Voltage Time delay delay (ON or OFF delay). The relay output ensures that the load can be driven directly. Ex­cellent for use in the agricultural sector (detection of grains, fluids etc.). CA30CLN12MU10M Type Selection Supply voltage Ordering no. Ordering no. Ordering no. With ON delay With OFF delay Without time delay 24- 230 V AC/DC CA30CLN12MU10M CA30CLN12MV10M CA30CLN12MT Specifications Rated operating distance (Sn) Up to 12 mm, referece target 30 x 30 mm ST37.1 mm thick, grounded Sensing distance 4-12 mm, adjustable Factory set at 7 mm Sensing distance adjustment Multiturn, 15 turns adjustment steps Temperature drift 0.8 x Sr ≤ Su ≤ 1.2 x Sr Hysteresis (H) 3 to 20% Rated operational volt. (UB) 20.4 to 255 VAC/DC (ripple included) Rated supply frequency 47 to 63 Hz Rated operational power 0.5 to 2.5 VA Output 2 A Relay SPDT@240 VAC AC12 2 A AC140 2 A DC12 2 A DC13 2 A Mechanical life typically 15x106 operations Electrical lifetime 1x105 operations @ 2A/240VAC Minimum operational current (lm) 10 mA@12 VDC (i.e. Minimum relay current) Protection Reverse polarity and transients Operating frequency (f) ≤ 1 Hz Specifications are subject to change without notice (15.10.2013) Response time OFF-ON (tON) ≤ 500 ms ON-OFF (tOFF ) ≤ 500 ms Power ON delay (tv) ≤ 200 ms Output function SPDT relay Output switching function N.O. and N.C. Indication Output ON Yellow LED Time Delay LED flashing depend on time delay Output Time delay Factory settings 0 sec. Delay on operate, adjustment CA30CLN12MU10M 1 sec. - 10 min. Delay on release, adjustment CA30CLN12MV10M 1 sec. - 10 min. No time delay CA30CLN12MT no delay Time delay adjustment Multiturn, 15 turns Environment Installation category III (IEC 60664/60664A; 60947-1) Pollution degree 3 (IEC 60664/60664A; 60947-1) Degree of protection IP 67, (IEC 60529; 60947-1) NEMA 1, 2, 4, 4X, 5, 6, 6P, 12 1 CA30CLN12Mxxxx Specifications (cont.) Ambient temperature Operating temperature -20º to +70ºC (-4º to +158ºF) Storage temperature -40º to +85ºC (-40º to +185ºF) Vibration 10 to 150 Hz, 1.0 mm/15 G (IEC 60068-2-6) Shock 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage ≥ 250 VAC (rms) Housing material Body PBTP Backpart Arnite Trimmer LCP Vectra Connection Cable PVC, grey, 2 m 5 x 0.75 mm2, Ø = 7.5 mm Weight ≤ 320 g Approvals UL (overvoltage category ll) cULus (UL508+CSA) CE-marking Yes Dimensions 97,6 17,5 2000 ø7.5 Distance 30 mm Time delay LED CA30CLN12MU10M/CA30CLN12MV10M 97,6 17,5 2000 30 mm ø7.5 Distance LED CA30CLN12MT Trimmer VS Delaytime Trimmer VS Distance Distance [Inches] 0,08 18 14 12 10 8 6 4 2 0 2 Turns on Potentiometer Turns on Potentiometer 16 0,6 6,0 60,0 Time delay [Seconds] 600,0 0,79 16 14 12 10 8 6 4 2 0 2 20 Distance [mm] Specifications are subject to change without notice (15.10.2013) CA30CLN12Mxxxx Detection Diagram Wiring Diagram Distance [Inches] 0,08 0,16 0,24 0,31 0,39 0,47 0,55 0,8 15,0 0,6 10,0 0,4 5,0 0,2 0,0 0,0 -5,0 -0,2 -10,0 -0,4 -15,0 -0,6 -20,0 0 2 4 6 8 10 Distance [mm] 12 14 BN BU [Inches] [mm] 0,00 20,0 μ 2A 240 VAC SUPPLY 24-230V AC/DC WH BK GR -0,8 Mode of Operation CA30CLN12MU10M (See operation diagram). Power supply is applied to the sensor (BN and BU wires). When the target is not present, the relay operates (connection be­ tween GR and BK wires) and LED lights. When the target is detect- ed the time measurement starts and LED flashes. After expiration of the set time (0-10 min.), the relay releases (connection between GR and WH wires) and LED turns off. The relay remains released as long as the target is detected. CA30CLN12MV10M (See operation diagram). Power supply is applied to the sensor BN and BU wires) and time measurement starts. When the set time has expired (0-10 min.) the relay operates (connection between GR and BK wires) and remains connected until the target is detected. After activation of the sensor the relay releases (connection between GR and WH wires). As soon as the target is not present again the time measurements of the set time starts. CA30CLN12MT (See operation diagram). Power supply is applied to the sensor (BN and BU wires). The relay operates (connection be­ tween GR and BK wires) and remains ON until the target is detected. After activation of the sensor the relay releases (connection between GR and WH wires.) Specifications are subject to change without notice (15.10.2013) Adjustment DISTANCE 4-12 mm LED CA30CLN12MT ON-DELAY 1s - 10min DISTANCE 4-12 mm LED CA30CLN12MU10M OFF-DELAY 1s - 10min DISTANCE 4-12 mm LED CA30CLN12MV10M 3 CA30CLN12Mxxxx Operation Diagrams Power supply (BN - BU wires) Target detected Relay ON (GR - BK wires) LED indication CA30CLN12MT Power supply (BN - BU wires) Target detected T T Relay ON (GR - BK wires) T LED indication CA30CLN12MU10M Power supply (BN - BU wires) Target detected Relay ON (GR - BK wires) T T T LED indication CA30CLN12MV10M Installation Hint Delivery Contents • Capacitive switch: CA30CLN12Mxxxx • Installation instruction • 2 x M30 Nuts • Screwdriver • Packaging: Plastic bag For mounting CA30CLN12Mxxxx through wall of tank 4 Specifications are subject to change without notice (15.10.2013)
CA30CLN12MV10M 价格&库存
很抱歉,暂时无法提供与“CA30CLN12MV10M”相匹配的价格&库存,您可以联系我们找货
